Results 1 to 10 of 18
Thread: 2009 Volkswagen CC 3.6L VR6 4Motion - Fueling/Misfire Issues
    Jun 2019
    Hey guys, first post. Been having some issues I've been trying to track down in between my busy schedule. Little background, purchased my VW with 67k miles and it now has 183k miles. I drive a lot, mostly highways and commutes. Car has been flawless, up until a couple weeks ago.
    My car has been having a hard time starting and staying on. It progressively got worse until I was able to leave it at my mechanics shop. Received some fueling codes relating to the fuel pressure regulator valve (N276). Here is the auto-scan of the engine module prior to some repairs:
    Friday,24,May,2019,08:28:47:48131
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWGU73C79E540902   License Plate:
    Mileage: 295260km-183466mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F
              52 53 55 56 62 65 6C 72 77
    VIN: WVWGU73C79E540902   Mileage: 295260km-183466miles
    Address 01: Engine (BLV)       Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 906 032 DN    HW: 03H 906 032 AB
       Component: P3.6-FSI-ULEV2  G   3056
       Revision: 5GH04---    Serial number: VWZCZ000000000
       Coding: 0000175
       Shop #: WSC 05311 000 00000
       VCID: 71E92CF5681519C222-8024
    11 Faults Found:
    001072 - Catalyst System; Bank 2
                   P0430 - 002 - Efficiency Below Threshold - Intermittent
                        Fault Frequency: 112
                        Mileage: 270944 km
                        Date: 2013.03.11
                        Time: 21:51:14
                        RPM: 1622 /min
                        Load: 32.5 %
                        Speed: 64.0 km/h
                        Temperature: 63.0C
                        Temperature: 6.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.351 V
    001110 - EVAP System
                   P0456 - 001 - Very Small Leak Detected - MIL ON
                        Fault Status: 11100001
                        Fault Frequency: 20
                        Mileage: 286686 km
                        Date: 2013.08.01
                        Time: 17:17:06
                        RPM: 1671 /min
                        Load: 38.0 %
                        Speed: 49.0 km/h
                        Temperature: 51.0C
                        Temperature: 6.0C
                        Voltage: 14.351 V
    012408 - Throttle Control
                   P3078 - 002 - Airflow at Idle too Low - Intermittent
                        Mileage: 289719 km
                        Date: 2013.08.26
                        Time: 16:56:25
                        RPM: 739 /min
                        Load: 22.3 %
                        Speed: 10.0 km/h
                        Temperature: 86.0C
                        Temperature: 28.0C
                        Voltage: 13.589 V
    006480 - Radiator Fan (V7)
                   P1950 - 002 - Movement Restricted / Jammed - Intermittent
                        Fault Frequency: 15
                        Mileage: 290813 km
                        Date: 2013.09.06
                        Time: 17:10:19
                        RPM: 703 /min
                        Load: 24.7 %
                        Speed: 10.0 km/h
                        Temperature: 88.0C
                        Temperature: 30.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.335 V
    006481 - Radiator Fan 2 (V177)
                   P1951 - 002 - Movement Restricted / Jammed - Intermittent
                        Fault Frequency: 7
                        Mileage: 292605 km
                        Date: 2013.09.22
                        Time: 08:26:06
                        RPM: 632 /min
                        Load: 29.8 %
                        Temperature: 87.0C
                        Temperature: 35.0C
                        Voltage: 13.589 V
                   P0087 - 002 - Too Low
                        Fault Status: 01100010
                        Mileage: 295222 km
                        Date: 2013.10.14
                        Time: 07:42:31
                        RPM: 773 /min
                        Load: 29.4 %
                        Temperature: 24.0C
                        Temperature: 21.0C
                        Voltage: 14.097 V
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 004 - Open Circuit
                        Fault Frequency: 196
                        Mileage: 295222 km
                        Date: 2013.10.14
                        Time: 07:42:51
                        RPM: 743 /min
                        Load: 34.5 %
                        Temperature: 25.0C
                        Temperature: 21.0C
                        Voltage: 13.843 V
                   P0300 - 008 -
                        Mileage: 295222 km
                        Date: 2013.10.14
                        Time: 07:42:60
                        RPM: 789 /min
                        Load: 32.1 %
                        Temperature: 26.0C
                        Temperature: 21.0C
                        Voltage: 14.224 V
    000774 - Cylinder 6
                   P0306 - 008 - Misfire Detected
                        Mileage: 295222 km
                        Date: 2013.10.14
                        Time: 07:43:42
                        RPM: 771 /min
                        Load: 28.6 %
                        Temperature: 33.0C
                        Temperature: 20.0C
                        Voltage: 14.224 V
    000770 - Cylinder 2
                   P0302 - 008 - Misfire Detected
                        Mileage: 295222 km
                        Date: 2013.10.14
                        Time: 07:43:42
                        RPM: 771 /min
                        Load: 28.6 %
                        Temperature: 33.0C
                        Temperature: 20.0C
                        Voltage: 14.224 V
                   P0087 - 008 - Too Low
                        Mileage: 295231 km
                        Date: 2013.10.14
                        Time: 07:53:40
                        RPM: 2786 /min
                        Load: 78.8 %
                        Speed: 80.0 km/h
                        Temperature: 87.0C
                        Temperature: 27.0C
                        Voltage: 13.970 V
    The radiator fans are a different story. I'll have to get to those another day.
    Anyway, had the mechanic next to my shop replace the thrust sensor, since the dealership service writer (a friend of my brothers and I) suggested that sometimes it's this sensor that goes bad and not the fuel pump. After this didn't cure the issue, I ordered a new high pressure fuel pump. After this was replaced, we got a little better.
    When receiving my old fuel pump, I was informed that they replaced the spark plugs. I didn't know what type they were so I went home and replaced all the spark plugs and coil packs with new ones I purchased previously. My old spark plugs were very very black probably due to the car running rich.
    Prior to getting the car home, it would start up very rough like, but I was able to give it some gas and get it going. After driving it for one minute, it would even out and the car would run just fine. Even coming to a stop, it would idle as it normally would. When getting it home, I went ahead and pulled all the plugs and coils, replacing them with new NGK laser iridium plugs and Denso coils from FCPEuro. When starting the car up to move from garage to driveway, it fired up perfectly. I think this was due to it being warm.
    This morning comes around and I start the car to get to work. It starts up rough like again and I slowly get it out of my driveway and it solves itself out again and drives normally. I get myself to work just fine where I scan the car again. Here is the engine module scanned again:
    Thursday,13,June,2019,08:19:19:48131
    VCDS Version: 19.6.0.2 (x64)
    Mileage: 295450km-183584mi   Repair Order:
    VIN: WVWGU73C79E540902   Mileage: 295450km-183584miles
       Coding: 0000175
       VCID: 71E92CF5681519C76E-8024
                   P0087 - 002 - Too Low - MIL ON
                        Fault Status: 11100010
                        Mileage: 295409 km
                        Date: 2013.11.03
                        Time: 00:23:14
                        RPM: 994 /min
                        Load: 24.7 %
                        Temperature: 74.0C
                        Temperature: 32.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 13.335 V
                   P0300 - 008 -
                        Mileage: 295409 km
                        Date: 2013.11.03
                        Time: 07:36:01
                        RPM: 950 /min
                        Load: 31.0 %
                        Temperature: 25.0C
                        Temperature: 21.0C
                        Absolute Pres.: 960.0 mbar
                        Voltage: 13.970 V
    000770 - Cylinder 2
                        Mileage: 295409 km
                        Date: 2013.11.03
                        Time: 07:36:60
                        RPM: 1387 /min
                        Load: 43.5 %
                        Speed: 17.0 km/h
                        Temperature: 32.0C
                        Temperature: 20.0C
                        Voltage: 13.970 V
                        Mileage: 295411 km
                        Date: 2013.11.03
                        Time: 07:39:37
                        RPM: 1607 /min
                        Load: 51.4 %
                        Speed: 64.0 km/h
                        Temperature: 61.0C
                        Temperature: 16.0C
                        Voltage: 13.716 V
    Readiness: 0110 0101
    I did some scanning during lunch to monitor a few blocks. Not exactly sure what to look for but I noticed that I was able to get misfires on 2, 4 and 6 while in park and upwards of 4-5k RPM's.
    Possible ideas that my buddies and I have thought of could be:
    Carbon cleaning needed
    Injectors need to be cleaned
    Kinked fuel pressure line that flows fine when warm/pressurized
    With the information above, what do you guys believe I should be doing? If you guys have any need for certain engine measurement blocks to be monitored/posted, please let me know what to do. Thank you all for getting through my first post!
  2. Likes Boki Ar liked this post
  3. #2
    Nov 2014
    New Zealand
    FYI on the fans - they can sometimes be opened, clean up the brushes (they stick in their holders) and reassembled to work a while longer. Sometimes the brushes are just worn out though! I've done it on my wifes Touran.
    Have you checked the low pressure fuel side? If the HPFP doesn't get enough flow to it, it will struggle to get to the required pressure. I'm not familiar with your actual engine, but the 4 cylinder NA FSI engines run full pressure on the low side when starting cold (6.6bar, regulator built into filter) and then vary the low pressure pump speed to match the "requirements" of the engine.
    Someone a lot more clever than I will surely be along soon, but there should be a measuring block for the low pressure pump duty cycle, somewhere.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
    Jun 2019
    That's what I've been reading regarding the fans as well. I'll have to get to them sometime soon.
    I have not checked the low pressure side. I left work today and though it idled okay during lunch when I was doing my scanning, I got a way worse drive. I'll have to drive it home tonight but I'm leaning towards taking it to a mechanic nearby who specializes in VW vehicles. Here is a full auto scan when I finished driving just recently.
    Thursday,13,June,2019,18:19:16:48131
    Mileage: 295530km-183633mi   Repair Order:
    VIN: WVWGU73C79E540902   Mileage: 295530km-183633miles
       Coding: 0000175
    8 Faults Found:
                        Mileage: 295409 km
                        Date: 2013.11.03
                        Time: 00:23:14
                        RPM: 994 /min
                        Load: 24.7 %
                        Temperature: 74.0C
                        Temperature: 32.0C
                        Voltage: 13.335 V
                   P0300 - 008 -  - Intermittent
                        Mileage: 295409 km
                        Date: 2013.11.03
                        Time: 07:36:01
                        RPM: 828 /min
                        Load: 33.7 %
                        Speed: 10.0 km/h
                        Temperature: 36.0C
                        Temperature: 23.0C
                        Voltage: 13.843 V
    000770 - Cylinder 2
                   P0302 - 008 - Misfire Detected - Intermittent
                        Mileage: 295409 km
                        Date: 2013.11.03
                        Time: 07:36:60
                        RPM: 1387 /min
                        Load: 43.5 %
                        Speed: 17.0 km/h
                        Temperature: 32.0C
                        Temperature: 20.0C
                        Voltage: 13.970 V
                   P0087 - 008 - Too Low - Intermittent - MIL ON
                        Fault Status: 10101000
                        Fault Frequency: 15
                        Mileage: 295411 km
                        Date: 2013.11.03
                        Time: 07:39:37
                        RPM: 1607 /min
                        Load: 51.4 %
                        Speed: 64.0 km/h
                        Temperature: 61.0C
                        Temperature: 16.0C
                        Voltage: 13.716 V
    000774 - Cylinder 6
                   P0306 - 008 - Misfire Detected - Intermittent
                        Mileage: 295452 km
                        Date: 2013.11.03
                        Time: 16:43:43
                        RPM: 1650 /min
                        Load: 45.5 %
                        Speed: 20.0 km/h
                        Temperature: 39.0C
                        Temperature: 22.0C
                        Voltage: 14.097 V
    000772 - Cylinder 4
                   P0304 - 008 - Misfire Detected - Intermittent
                        Mileage: 295452 km
                        Date: 2013.11.03
                        Time: 16:43:43
                        RPM: 1650 /min
                        Load: 45.5 %
                        Speed: 20.0 km/h
                        Temperature: 39.0C
                        Temperature: 22.0C
                        Voltage: 14.097 V
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 004 - Implausible Signal - MIL ON
                        Fault Status: 11100100
                        Mileage: 295458 km
                        Date: 2013.11.03
                        Time: 16:53:30
                        RPM: 1697 /min
                        Load: 39.2 %
                        Speed: 67.0 km/h
                        Temperature: 88.0C
                        Temperature: 17.0C
                        Voltage: 14.224 V
    004506 - Fuel Pressure Sensor (G247)
                   P119A - 002 - Malfunction - MIL ON
                        Mileage: 295459 km
                        Date: 2013.11.03
                        Time: 16:54:23
                        RPM: 701 /min
                        Load: 33.3 %
                        Speed: 24.0 km/h
                        Temperature: 88.0C
                        Temperature: 18.0C
                        Voltage: 13.970 V
    Readiness: 0010 0001
       Part No SW: 09G 927 750 HH    HW: 09G 927 750 HH
       Component: AQ 250 6F           1392
       Revision: 00H76000    Serial number:
       Coding: 0000840
       VCID: 7EF307C9294B76BFE3-802A
                013 - Check DTC Memory
                        Fault Status: 00101101
                        Reset counter: 201
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
       Component: J104    C4 440 V2   0011
       Revision: --025---    Serial number: 00000786346176
       Coding: 0000409
       VCID: 2B55FE9D8AB9331714-807E
                        Fault Status: 01101101
                        Reset counter: 73
                        Mileage: 295458 km
                        Date: 2013.11.03
                        Time: 16:53:31
                        Speed: 68.0 km/h
                        Hex Value: 0x011D
                        Voltage: 14.00 V
                        Bin. Bits: 00011111
                        Count: 217
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 AR    HW: 5K0 907 044 AR
       Component: Climatronic   130 0303
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 7BF50EDDF2596397C4-802E
    9474417 - Motor for Front Air Distribution Flap
              B1091 71 [008] - Actuator stuck
                        Fault Frequency: 220
                        Reset counter: 113
                        Mileage: 295370 km
                        Date: 2019.06.12
                        Time: 12:00:08
    9474418 - Motor for Front Air Distribution Flap
              B1091 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 68
                        Mileage: 295370 km
                        Date: 2019.06.12
                        Time: 11:59:49
       Revision: 00H54000    Serial number: 00000009067296
       Coding: F3E69F8950021A0047970F0017000000000BFF4564500965170000000000
       Shop #: WSC 05124 123 12345
       VCID: 3365E6FD52896BD75C-8066
       Subsystem 1 - Part No: 3C8 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 211008 022  0602
       Coding: 00046997
       Shop #: WSC 05124
       Component: RLS     131108 054  0402
       Coding: 00479437
       Shop #: WSC 05124
    02390 - Control / Regulation for Ambience Lighting (E400)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 73
                        Mileage: 295370 km
                        Voltage: 11.15 V
       Part No SW: 3C8 919 475     HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0007
       Revision: --------    Serial number: 97530830812388
       Coding: 300101
       Shop #: WSC 05314 000 00000
       VCID: 71E92CF5A81519C76E-8024
       Part No SW: 5N0 959 655     HW: 5N0 959 655
       Component: J234__314 VW10 HI   1815
       Revision: 19013000    Serial number: 0039BPMPBF0Z
       Coding: 0012596
       VCID: 7AFB0BD935635A9FDF-802E
       Subsystem 1 - Part No: 3C8 959 339
       Component: BF-Gewichtsens. 001 0003
       Subsystem 2 - Serial number: 0000000000211U
       Subsystem 3 - Serial number: 0021.10.080000100000640024†63
       Subsystem 4 - Serial number: 640024†6333FTS669562728 †63
       Subsystem 5 - Serial number: 62728 †6343FTS637462748 †63
       Subsystem 6 - Serial number: 62748 †6353ETS66NDKVVNJ †63
       Subsystem 7 - Serial number: KVVNJ †6363ETS6PUNJVVNR †63
       Subsystem 8 - Serial number: JVVNR †6374CTS6HRKOVVNR †63
       Subsystem 9 - Serial number: OVVNR †6384CTS6EAKPU5KR
       Subsystem 10 - Serial number: PU5KR
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CN
       Coding: 0001611
       VCID: 74E725E117072CEF85-8020
       Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP   H4 0021
       Coding: 00000227
       Part No SW: 3C8 920 970 F    HW: 3C8 920 970 F
       Component: KOMBI         H05 0107
       Coding: 240E00
       Shop #: WSC 05311 115 12345
       VCID: 2F6DEA8D76A14F3738-807A
       Part No SW: 3C0 907 530 J    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 2900R08A268023
       Coding: FDA3FF07504613009002
       Shop #: WSC 03112 444 57305
       VCID: 285F01919B4F180FF9-807C
       Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
       Component: Haldex 4Motion      4013
       Coding: 0000005
       VCID: 4487B5210727DC6FF5-8010
       Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 03170 444 84404
       VCID: 78FF11D10B6F488FA9-802C
    02861 - Electronic Steering Column Lock Check Sum Error
                        Reset counter: 110
                        Mileage: 295409 km
                        Date: 2013.11.03
                        Time: 07:35:19
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0084
       Revision: A1001003    Serial number: 7667307552
       VCID: 26430FA9515B0E7FCB-8072
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760     HW: 3C8 959 760
       Component: J810                0801
       Revision: 00002000    Serial number: 00000000000000
       VCID: 72EB23F96D1322DF97-8026
       Part No SW: 3C0 035 684 A    HW: 3C0 035 684 A
       Component: RNS-MID       H01 0380
       Revision: AB001001    Serial number: VWZ6Z7H7308012
       Coding: 04050000010000A000
       Shop #: WSC 05314 123 12345
       VCID: 21491CB53875E947BE-8074
                        Fault Frequency: 15
                        Reset counter: 72
                        Mileage: 295368 km
                        Date: 2019.06.12
                        Time: 12:00:02
       Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1533
       Revision: 71009005    Serial number: 00000878288915
       Coding: 0001463
       VCID: 408FB931133FC04FD1-8014
       Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.077 0502
       Revision: 1AH02240    Serial number: 00082590167802
       Coding: 0000258
       VCID: 3979D4D570E5918796-806C
       Component:    KSG PQ46 RDK 052 0412
       Coding: 13910F8001864E3676021415F08A8F0E085841
       Shop #: WSC 05311 123 12345
       Part No SW: 3C8 035 456 C    HW: 3C8 035 456 C
       Component: DSP 10 Kanal        0070
       Revision: 00H05001    Serial number: 75805000694104
    Address 4F: Centr. Electr. II (J533_)       Labels:. 1K0-907-532.clb
       Part No SW: 1K0 907 532     HW: 3C0 907 951
       Revision: --------    Serial number: 2900R08A268023
       Coding: 01030100
       VCID: 66C34FA991DBCE7F0B-8032
       Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
       Component: J245/J878  H04 0054
       Serial number: 841600030442
       Coding: 000006
       Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1533
       Revision: 71009005    Serial number: 00000644888929
       Coding: 0001462
       VCID: 4189BC351835C947DE-8014
       Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
       Component: J540 EPB4  VW-53083 0006
       Revision:   H18       Serial number: 00000000062804
       Coding: 0021057
       VCID: 326BE3F9AD9362DF57-8066
       Component: AFS-Steuergeraet    0136
       Coding: 3536008
       VCID: 3467E5E157876CEF45-8060
       Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0003
       Coding: 00000053
       Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0003
       Coding: 00000053
                        Fault Frequency: 15
                        Reset counter: 72
                        Mileage: 295368 km
                        Date: 2019.06.12
                        Time: 12:00:02
       Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
       Component: J388   TUER-SG HL   0309
       Revision: 43004101    Serial number: 00000000688598
       Coding: 0001168
       VCID: 3169ECF5A89559C72E-8064
       Component:    RDK              0453
       Coding: 0100101
       Part No SW: 3C8 907 441     HW: 3C8 907 441
       Component: J772__Rearview      0022
       Revision: 00H06000    Serial number: 525PA8-J830084
       Coding: 0120008
       VCID: 67DD42AD56D1D77730-8032
       Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
       Component: J388   TUER-SG HR   0309
       Revision: 43004101    Serial number: 00000000684002
       Coding: 0001168
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 051 730 A    HW: 1K8 051 730 A
       Component: Telefon       H01 5200
       Revision: 00001000    Serial number: 20389520012340
       Coding: 412120
       VCID: 254108A52C5D0567C2-8070
    End-------------------------(Elapsed Time: 03:24)--------------------------
    May 2016
    Newark, still see fuel pressure low. New HPP, but is system corrupted or is it starving.
    Did your HPP, have any trash in the screen ? Did it start to fail and pumped it through the system.
    At this time also MAF, CODED but still have low fuel. Don't know about this car but is there a filter prior to the HPP?
    LARIMORE
    Did you inspect coil packs and plugs for water vapor corrosion ingress and ground enhancements performed?
    Have you check lift pump output, and regulation/combined filter & HPP, cam lifter/follower and possible camshaft run out & resulting in low FP PSI or volume?
    Additionally can't tap tests for brushes on fans be done, replaced or shimmed or even soldered in universals easily for the poor, as can't a shim be added to lifter of HPP to get more time if run down & to remove resonance?
  7. Likes Uwe liked this post
    Jun 2019
    Hey guys,
    I had a mechanic replace the HPFP and thrust/fuel sensor. They didn't report anything looking funny, but then again, they don't specialize in VW's so possibly, they didn't look for such issues?
    Checked the coils and plugs when replacing them. The previous plugs had a lot of black on them since the car was running very rich. The coils, didn't look bad at all. I've replaced a bad coil or two previously on the car and those looked way worse than what I pulled out.
    It's currently at a European shop that specializes in VW's and I'm waiting for a diagnostics after reporting to the service writer what I've already completed. The more I think about it, the more I feel as if it's something to do with the lower fuel rail connecting to cylinders 2, 4 and 6 since those are constantly failing. Due to my own fault, I do run this car too close to empty so I wouldn't doubt that the system's sucked up some gunk by now.
    I'll report back with what the shops found out.
    No it is not relevant to your behavior and not your fault what you aforementioned.
  10. Likes D-Dub liked this post
  11. #8
    Jun 2019
    Got the call just a bit ago.
    Seems that the ups and downs while driving seem to correlate with inconsistent MAF readings being read.
    They're going to run tests on the low pressure and high pressure pumps to rule those out and have a suggestion as to what to fix after that.
  12. Likes NZDubNurd liked this post
  13. #9
    Wanna bet this aforementioned fault is more likely related to MAF speculation?
  14. Likes nawarkk liked this post
  15. #10
    Jun 2019
    Got another update today. They seem to be working/checking things out a little slower than I anticipated.
    Was told that both fuel pumps seem to be operating correctly, though the high pressure pump doesn't seem to be responding the ECU. Was told the ECU is giving off the signal but the HPFP is delayed in response. Something also about the vacuum not being at the level it should be either.
    He mentioned that they think that it might be a mechanical failure and that it's possible that it skipped timing though he's skeptical on that part as well as the car runs okay when it's getting the fuel that it needs. When I called in, his mechanic was still digging through some areas so I was informed I'd be getting a call by end of day, which already passed or tomorrow.
    He had asked if the Cam Follower/Roller was inspected prior to re-assembly of the new HPFP which it was not, though if the roller was bad, I'd imagine it wouldn't run correctly either.
    What do you guys think? This has been an expensive ordeal so far and I hope something as simple as the MAF is the TRUE issue.
