Results 1 to 3 of 3
Thread: VW Arteon 2018 fuse panel removal
    New User
    Jan 2018
    Romania
    Anybody knows anything about how to remove the fuse box under the steering wheel?
    I need to remove the fuse box because I need to plug in 4 wires for the Trailer module.
    Here is an image from the module, the wires colors are brown, but they are +12V.
    https://i.ibb.co/QdLzSvT/20190613-151109.jpg
    Thanks in advance!
    16.4905 S, 151.7375 W
    Quote Originally Posted by alectrans1 View Post
    Here is an image from the module, the wires colors are brown, but they are +12V. https://i.ibb.co/QdLzSvT/20190613-151109.jpg
    Thanks in advance!
    You will need to use the erWin web site for Volkswagen. For (7,00 €), you get 1 hour incl. printing rights.
    Look for....
    [3H7] - Arteon
    Electrical Equipment pdf file.
    There is a section called: "Relay and Fuse Panel Behind Instrument Panel, Removing and Installing"
    This is copyrighted material and can not be reproduced or posted here.
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
    New User
    Jan 2018
    Romania
    Thank you, I solved by removing the airbag and plugging in the wires
