Results 1 to 10 of 19
Thread: MK7 Halo headlight range to cluster illum dimmer
    Apr 2018
    ITALY
    I am finalizing the retrofit of LED headlights to my Golf 7, I had halogens as stock. Halogens had a manual height adjustment next to the light switch, please see picture:
    https://www.dropbox.com/s/iqsonxrlow820w0/HaloRange.jpg
    since that dial is not necessary anymore, I replaced it with the cluster illumination dimmer, please see picture:
    https://www.dropbox.com/s/3wjcutqvq0...sterDimmer.jpg
    this is the wiring diagram, where I understand they are wired the very same, so I believe they are exchangeable:
    https://www.dropbox.com/s/lgarsspw40...llumWiring.JPG
    actually the illumination dimmer does not work, so I wonder if any coding/adaptation need to be adjusted. I looked into modules 09 and 17 but could not find anything obvious.
    does anybody have a solution? thanks
  2. Likes jyoung8607 liked this post
  3. #2
    With 398 posts here you should know that when asking a question about coding or adaptation you need to include a full unedited VCDS Auto-Scan
  4. Likes Uwe liked this post
  5. #3
    Apr 2018
    ITALY
    you have a point. the autoscan is here and all the adaptation maps are here:
    https://www.dropbox.com/s/pofkgokte2..._JUN132019.zip
    for the record, I tried DISABLING BIT 2 from BYTE 12 in module 17 without any luck.
    Thursday,13,June,2019,16:08:18:06888
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    Dealer/Shop Name: dB
    Workshop Code: 031 33097 006209
    VIN: WVWZZZAUZHW0xxxxx   License Plate: FULL-LED-FINAL
    Mileage: 29697km-18452mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 18 19 3C 42 44 52 55 5F 65
    VIN: WVWZZZAUZHW0xxxxx   Mileage: 29697km-18452miles
    Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
       Component: R4 1.4l TFS   H25 2833
       Revision: R7H25---
       Coding: 0119003A23441D082000
       Shop #: WSC 33097 031 06209
       ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
       ROD: EV_ECM14TFS01104E906027HB.rod
       VCID: 6B833BBF03045EDF0F3-803E
       CAN Converter 01:
    Readiness: 1110 0001
       Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
       Component: ESC           H62 0637
       Revision: 00000000    Serial number: 91596000011507
       Coding: 01FA6AA1242219704779060841C62980562498E26082947314205008408903
       VCID: 74B120C35E3A8127DE9-8020
       Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
       Revision: 00001K08
       Coding: 00020004104111011005004000101022
       VCID: 73B323DF5B34861FC73-8026
       Serial number: 01061633700891
       Coding: 00000846C20102FB0B244080B11407281400000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 045170030E9AB1A7EE9-8050
       Component: WWS    160522  043 0551
       Serial number:         160601172917
       Coding: 0E4DFD
       Component: RLFS  024 0042
       Serial number: Y13M05D10H00M20S03S4
       Coding: 06A8DD
       Serial number: 000000000ZY15028208R
       Serial number: 00000000000030139763
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617145
       Coding: 0271165041
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 50F98C538A629D071A1-8004
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
       Component: ACC3          H08 0390
       Serial number: 19021303030627
       Coding: 00000300FE030B
       ASAM Dataset: EV_ACCBoschMQB 001021
       ROD: EV_ACCBoschMQB_VW37.rod
       VCID: 3FDBBFEF27FC127FF3B-806A
       Serial number: 003F6R1V1W4Y
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 41DFB9175108648F85F-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 35767000000432B44C1Q
       Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 358670000008B4C4DB17
       Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
       Serial number: 3516502BB205729313D3
       Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
       Serial number: 3526502AF2076340F201
       Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 35565029B21160C1025X
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 13061608490829
       Coding: 0400
       VCID: 0D4755275DD0F0EFB17-8058
       Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
       Component: KOMBI         303 8311
       Coding: 03A501802E88000D02882B0D1401000000000000
       VCID: 26150A8BD866A3B790D-8072
       Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
       Component: STH-MQB       006 0069
       Coding: 1309
       VCID: 3537DDC715C0D82F297-8060
       Component: R64 D208L  004 0401
       Serial number: 00000000000000180382
       Revision: --------    Serial number: 0004271482
       Coding: 030100043F085700FB000258080F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA108E3766AC967969-8028
       Component: E221__MFL-DC1  H10 0038
       Serial number: 29140002632800044485
       Coding: 2C0000
       Serial number: 8442320304
       Component: HRE_Master    H11 0071
       Serial number: 0392234969
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3C21C8E336EA0967D69-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H11 0071
       Serial number: 0381249049
       Coding: 020111
       Serial number: 300516EEU02971
       Coding: 003F0220D000040100001000
       VCID: 43D3B31F4B14769F973-8016
       Coding: 8307
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2DCEFB3CDE3757C45-806E
       Serial number: 280516EER24731
       Coding: 003F0020DE00040100801000
       VCID: 42DDB61B540E7F979C5-8016
       Coding: 029A000001000000
       Shop #: WSC 00028 028 00068
       VCID: 75B71DC75540982FE97-8020
       Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
       Component: MU-S--ER      710 0744
       Coding: 02730000AA0000005111000100080A001F0206D40120010003
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2C01F8A3C68A99E7469-8078
       Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
       Component: ABT_Std-2  H50 8120
       Serial number: VWZ6ZHT1541317
       Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0009
       Serial number: 40000000018766
       ROD: EV_RDKBERU30_006_VW37.rod
       VCID: 3431E0C31EBAC1271E9-8060
    End----(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
  6. #4
    Aug 2018
    I don't have an answer, but I'm looking for similar information. I want to be able to dim the dashboard/instrument panel lights to 'off' or at least much darker than the factory setting. If you find an answer, please share. See the clues left by others in my earlier thread by searching for my user name 'jgordon'. It's the only thread I've posted.
    Apr 2018
    ITALY
    does anybody have a MQB car with the dimmer fitted as stock? I am stumbled upon this and I could scans/admaps as an example.
    ^^^^^ Darkchina- Hi.
    I've developed a database (read, MS excel spreadsheet) of the "standard" function for BCM code switches for MQB platform vehicles over a number of years.
    The data in my spreadsheet has come from many places (i.e. the net, options on various diagnostic cables and rare discussions with dealer master-technicians). At first in good citizen fashion, I started the spreadsheet by also recording the source of the information, but in my characteristic slack style that part of my record keeping disappeared - so attribution of the data is not possible (alas).
    Anyhow - this is an extract from my spreadsheet that might be of interest:
    • Byte 7, Bit 0-1 (Lighting adjustment-Input media),
    • Options: not installed=hex0, Potentiometer=hex1, Button=hex2, HMI=hex3
    The code string on your auto-scan reports Bit 7, Bit 0-1 as hex3 (i.e. control via the MENU). Try changing Bit 1 to 0
    EDIT: Arrrhh........... I found it- always rely on the "yellow" helper screens!!!
  9. Likes Uwe, jyoung8607 liked this post
  10. #7
    Apr 2018
    ITALY
    thank you Don, I made some progress. I changed bits 0-1 to hex 01 (potentiometer) and here's the error I get:
    https://www.dropbox.com/s/yah7gm02rl...immerFault.jpg
    this makes me believe that the BCM does not sense the pot.
    so I opened both pots, the old headlight level range and the new illum dimmer. they basically are the same, they have a 7pin connector but only 5 pins are populated.
    pins 2 and 6 are for the illumination.
    pins 3, 4 and 5 are the actual pot (the resistor is across 3 and 4 and 5 is the wiper).
    when the car was stock, pin 5 was directly connected to the two motors that regulated height inside the halogen headlights. that wire is now disconnected on the headlights' side, because the new LED headlights height is regulated by control module 55.
    so that pin 5 should now go to BCM, but I am not sure where. the wiring diagram says it COULD go to B33 "according to equipment / from May 2017", so I am perplexed.
  11. #8
    ^^^ hmm... small baby steps!!! I can't find much about the potentiometer for the illumination on my WD s. But I did manage to find this on the BCM pin out:
    T73c /19 - Designation= Switch and instrument illumination regulator -E20-
    Not sure if it helps, or hinders - hope the former, but I apologize if the latter applies
  12. #9
    Apr 2018
    ITALY
    what revision of WD do you have? mine is JUNE 2017, from erWin, and on the BCM pinout B33 and C19 are both shown as unused (blank).
    E20 is indeed the pot I am trying to install
  13. #10
    ^^ My WD s are earlier (MY13 & MY14) - but the entire matter is academic if your BCM physically doesn't have either of the 2 x pin options in question. Perhaps start by confirming this (i.e. eye-ball the pins on the B & C sockets)? If the pins are not present, then you might need to forget this part of the exercise - it seems like the tail-wagging-the-dog if you are considering changing the BCM (IMO)
