Results 1 to 10 of 11
Thread: 2011 Polo Lost ABS coding after engine swap
    Jun 2019
    Australia
    All the coding has turned to 000000000 after engine swap and prolonged battery disconnect.
    Any help would be greatly appreciated to recover the correct coding for the ABS module.
    Thanks Dave
    Thursday,13,June,2019,14:02:02:30858
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ6RZBU042763   License Plate:
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 02 03 04 08 09 15 17 19 25 2E 44 56 77
    VIN: WVWZZZ6RZBU042763   Mileage: 117840km-73222miles
    Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
       Part No SW: 03F 906 070 E    HW: 03F 906 070 D
       Component: SIMOS10.20H02 9699
       Revision: --------    Serial number:
       Coding: 002500D6202400080000
       Shop #: WSC 31414 790 50316
       ASAM Dataset: EV_ECM12TFS02103F906070E 003012
       ROD: EV_ECM12TFS_003_VW25.rod
       VCID: 24479D522FA3756A99-8070
       Part No SW: 0AM 300 060 G    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 4540
       Revision: 00043014    Serial number: CU501402286462
       Shop #: WSC 04940 001 00001
       VCID: 2E537F7ABA6FCF3A7F-5124
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0001
       Revision: --------
       Shop #: WSC 31414 790 31414
       VCID: 071DEADEB255BE729C-8052
    03306 - Coding Not Valid
                        Reset counter: 245
                        Mileage: 117848 km
                        Date: 2013.11.03
                        Time: 01:13:19
                        Hex Value: 0x0007
                        Hex Value: 0x0002
                        Hex Value: 0x3209
                        Hex Value: 0x1495
                        Hex Value: 0x007F
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
                        Reset counter: 245
                        Mileage: 117848 km
                        Date: 2013.11.03
                        Time: 01:13:19
                        Hex Value: 0x0007
                        Hex Value: 0x0002
                        Hex Value: 0x3211
                        Hex Value: 0x1495
                        Hex Value: 0x007F
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6R0 907 044 B    HW: 6R0 907 044 B
       Component: Climatronic   H08 0305
       Revision: V0000000
       VCID: 326B6B0A6D57EBDA1B-8066
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 215
                        Mileage: 116995 km
                        Date: 2013.10.26
                        Time: 02:33:47
                        Fault Status: 00101101
                        Reset counter: 24
                        Mileage: 117395 km
                        Date: 2013.10.29
                        Time: 07:04:47
       Part No SW: 6R0 937 087 F    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0221
       Revision: BF046001    Serial number: 0345 252102308
       Coding: 24B02BBF08A1000001380000342B0ED000C0410F60040000200000000000
       Shop #: WSC 10551 001 1048576
       VCID: 408F31C2D3FB494A9D-8014
       Component: RLS 200710 05  54  0403
       Coding: 208941
       Subsystem 2 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  006 0903
       Serial number: KU0-KU023.09.1016705
       Coding: 18BC30
       Subsystem 3 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  006 0902
       Serial number: KU0-KU024.09.1010225
       Coding: 08BC30
       Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
       Serial number: 0341897
       Coding: 020000
       Subsystem 5 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
       Component: J388__TSG_HL  006 0902
       Serial number: KU0-KU020.09.1017142
       Coding: 08BC32
       Subsystem 6 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
       Component: J389__TSG_HR  006 0902
       Serial number: KU0-KU019.09.1010471
       Coding: 08BC32
       Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
       Component: VW10Airbag00N H09 0020
       Revision: --------    Serial number: 003GY001MC13
       Coding: 00304E
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4B9516EEE2BD9A1278-801E
       Serial number: 3572SRB40000CB5121B1
       Serial number: 3582SRB40000CBE4895M
       Serial number: 3515RRB405H01NFSCP71
       Serial number: 3525RRB404V02CB84H01
       Part No SW: 6R0 920 860 F    HW: 6R0 920 860 F
       Component: KOMBI         H04 0304
       Coding: 140A00
       VCID: 377D5A1E8E350EF22C-8062
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 0221
       Coding: 002300
       VCID: 70EFA102A3DB99CA2D-8024
       Component: IMMO          H04 0304
       VCID: 6ADBB36A8D07631A63-803E
       Revision: A1001003    Serial number: 7668396309
       VCID: 275D8A5E56959E72BC-8072
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        C277
       Coding: 11230
       Shop #: WSC 31414
       VCID: 2F6D627EEA65C63274-807A
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 01000000    Serial number: VWZ1Z2K8585562
       Coding: 0500040002
       Shop #: WSC 00000 000 31414
       VCID: 6BD5B66E8AFD7A1218-803E
    03138 - Input AUX IN
                        Reset counter: 215
                        Mileage: 116995 km
                        Date: 2013.10.26
                        Time: 02:34:02
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 051 730 D    HW: 1K8 051 730 D
       Component: Telefon       H03 6900
       Revision: 00003000    Serial number: 00000A07838834
       Coding: 402120
       Shop #: WSC 30049 959 91392
       VCID: 285F89625B8B910AB5-807C
    End-------------------------(Elapsed Time: 03:26)--------------------------
    Aug 2016
    The Hague, NL
    Try this please: 230228E3217100B4C42C14E884D400800700
    Otherwise 230228E3217100B4C42C14E884D400801700
  3. Likes Uwe liked this post
    Jun 2019
    Australia
    Thanks iichel. I tried both those lines of coding but neither worked it came up with this window any ideas.
    Thanks Dave
    Jun 2019
    Australia
    Sorry tried posting image, wont work for some reason but it says "Coding rejected Error 00: Unknown".
    It is a right hand drive car if this makes any difference
    Aug 2016
    The Hague, NL
    Check if the advanced ID sections of the engine, instruments and immobiliser all contain the same VIN please
  7. Likes Jack@European_Parts, Uwe liked this post
    Jun 2019
    Australia
    Checked VIN numbers in all the modules specified and they are all the same vin number.
    I have been playing around with inputing some other numbers from a code generator I found online but still no good.
    I now get a message displaying "Coding rejected Error:22 condition not correct or request sequence error."
    Hope this helps
    Thanks Dave
    Maybe try: 230228E3417100B4C42C14E882D400801700
  10. Likes Uwe liked this post
  11. #8
    Mar 2019
    Poland
    See if you have an active time delay in abs.
  12. #9
    Jun 2019
    Australia
    Thanks NEtech that was the right coding. It accepted it and all is sorted now. Thanks to everyone who helped.
    Cheers Dave
  13. #10
    HQ
    So... we cool?
    Jef
