Introduction
   #21
Does this offer apply to those of us who received our Hex-Nets via the upgrade program?
It should, but your HEX-NET's serial number is in a new "range" that likely hasn't been accommodated yet by one of the servers involved.
StorableComa
C?ID=219649
Thank you for the update. Any idea on when I should try again?
   #23
I can't really say. VIS is provided by one of our distributors, not Ross-Tech directly.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
@ StorableComa, use mail (in which you will list Your registration details): info@pc-autodiagnostika.cz and convey greetings from Boyan / Serbia.
   #25
autocomsoft
Czech Republic
C?ID=56999
@Jan autocomsoft
I just tried to register, but the registration page says that my email address is not associated with my Hex-Net. I can confirm I am trying to register with the same email address on vis4vag that I registered my HEX-NET too which is also the same as my forum registration.
Can you please advise how this can be fixed?
Martyn
I'm having an issue with registration. I get an error "4-Wrong interface number". I've double checked and my SN is correct as listed under "About" in VCDS.
Thanks,
Sean
Dear Martyn and Sean,
send me Your registration data in a text format on info@pc-autodiagnostika.cz and I will make Your registration manually.
Thank You
Jan
   #26
pero
Croatia
C?ID=281123
I have two interfaces HEX+CAN and HEX-V2. Both are registered from the same mail address, but cannot register on vis4vag .
Constantly throws out error 12 - email address and serial number are not associated when I try the serial number of the HEX-V2 .
   #27
I see no obvious reason for it here. You might want to try contacting @autocomsoft
HMC
C?ID=28246
Do you not have to own a HEX-NET?
Regards HMC
   #33
Derek
UK (ilexa)
C?ID=56983
Hello @autocomsoft
Is there a time limit between someone buying their VCDS and registering for the free years access?
Could someone who bought their interface 2, 3 or even more years ago register and get the free year?
I'd like to mention Vis4Vag in my customer newsletter but want to check before anyone asks me
Best regards
Derek
   #35
Derek
UK (ilexa)
C?ID=56983
Thank you Jan
Best regards
Derek
