Results 1 to 3 of 3
Thread: 2014 8k A4 possible coding changes for convienience features??
    Jan 2017
    Ireland
    Hello everyone.. I bought this 2014 (142) red a4 black edition 2litre TDI, I am looking to possibly activate the following if anyone has seen any coding changes? I looked in long coding helper but saw nothing obvious.. Ill attach a log of the car at the end..
    1) is it possible to activate so that when reverse is engaged that the left hand wing mirror motor moves the glass down? iv seen this in some a4s, not sure is it just the spec with the different driver profile and electric seats with the 1/2/off switch on the door panel but I have electric mirrors and obviously reverse light switch so wondering is it possible??
    2) I have LED rear lights, when I put on the indicators the LED bar lights up completely but I am wondering is it possible to make it start on the inside and travel outward? I am unsure of the correct term for this..
    Thanks everyone,
    Shane..
    VIN: WAUZZZ8K5FA001846   License Plate:
    Mileage: 165620km-102911mi   Repair Order:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72 77
    VIN: WAUZZZ8K5FA001846   Mileage: 165620km-102911miles
    Address 01: Engine (J623-CJCD)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 SJ    HW: 03L 906 018 JL
       Component: R4 2.0l TDI   H25 9978
       Revision: 45H25---
       Coding: 0A194012242401080000
       Shop #: WSC 62186 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018SJ 003004
       ROD: EV_ECM20TDI01103L906018SG.rod
       VCID: 045286A44E923D97BA5-8050
              U1113 00 [032] - -
              U1113 00 [032] - -
    17403 - Implausible Data Received from Parking Brake Control Module
              U0417 00 [032] - -
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
       Component: ESP8 front    H09 0020
       Coding: 161DCC01
       Shop #: WSC 06325 000 00000
       VCID: 074891A87F24168FDF7-8052
                        Fault Status: 00101101
                        Reset counter: 10
                        Mileage: 163336 km
                        Hex Value: 0x0000
                        Hex Value: 0x0280
                        Hex Value: 0x001A
                        Hex Value: 0x09A0
                        Hex Value: 0x0000
    02214 - Tire Pressure Warning
                000 -  -  - Intermittent
                        Reset counter: 20
                        Mileage: 163808 km
                        Date: 2018.12.10
                        Time: 12:54:18
                        Hex Value: 0x8900
                        Hex Value: 0x4006
                        Hex Value: 0x1F21
                        Hex Value: 0x1FB9
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 JE    HW: 8K0 907 064 JE
       Component: BCM2 2.0      H14 0650
       Coding: 03B14040000000000000
       VCID: 7CA2FE4436E24557C25-8028
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0514000070932008
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 0214000089158008
       Part No SW: 8K2 820 043 BA    HW: 8K2 820 043 BA
       Revision: D0000000    Serial number: 01150520141234
       Coding: 342402E000
       VCID: 698CB7104970C0FF293-803C
    03269 - Functionality Linited due to Energy Management
                        Reset counter: 22
                        Mileage: 164034 km
                        Date: 2018.12.12
                        Time: 16:31:45
       Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
       Revision: 07016001    Serial number: 00000818480701
       Coding: 260000108034AFC00081400000001D0D001D030827090201000008004400020100000024000000
       VCID: 77A8E1680FC4660FAF7-8022
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 120514  H06 0080
       Serial number: SWF14055125229
       Coding: 00FD11
       Serial number: 22639825
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000605141072
       Serial number: 6AE84A27000000000001
    02069 - Front Parking Aid Sensors
                        Fault Status: 00101011
                        Reset counter: 29
                        Mileage: 165008 km
                        Date: 2019.01.21
                        Time: 15:51:14
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003KFDC1KDP-
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 58875 001 1048576
       VCID: 48CA5294323AD9F716D-801C
       Serial number: 6334MSME451A734AH
       Serial number: 6344MSME451872034
       Serial number: 6352QSME3C444B54O
       Serial number: 6362QSME273F3D48X
       Serial number: 63732SME483F28422
       Serial number: 63832SME443F04782
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NEH0004F
       Coding: 000016
       VCID: 48CA529432BAD9F716D-801C
       Part No SW: 8K0 920 983 G    HW: 8K0 920 983 G
       Component: KOMBIINSTR.   H35 0564
       Revision: 00100000    Serial number: ZAC403E5F
       Coding: 3384080003012600010000
       VCID: 392C27507950B07F993-806C
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0060
       Revision: 1V090029    Serial number: 2941V145040262
       Coding: 80CF07FF00
       Serial number: 6957993303
       Serial number: 14134001217021200410
                        Reset counter: 26
                        Mileage: 162547 km
                        Date: 2018.11.23
                        Time: 13:24:24
                        Bin. Bits:    10000
                        Voltage: 12.40 V
                        Count: 17
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020202
       Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
       Component: TSG FA        H09 0305
       Coding: 011002204001410001
       VCID: 57E881E8EF04460F8F7-8002
       Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0006561152
       Coding: 100000000001
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 35342B6055C8541F7DB-8060
    16400 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Unterspannung an Versorgungsspannung bei Lenkunterstützung]
                        Reset counter: 26
                        Mileage: 164932 km
                        Date: 2019.01.06
                        Time: 08:57:16
                        Write only channel
    2305 - Function Restriction due to Start Voltage Interruption
              U1410 00 [008] - -
              [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei niedriger Geschwindigkeit]
                        Reset counter: 32
                        Mileage: 161526 km
                        Date: 2018.11.10
                        Time: 13:40:52
                        Write only channel
    2306 - Function Restriction due to Start Voltage Interruption
              U1410 00 [008] - -
              [Funktionseinschränkung der Lenkung durch Spannungseinbruch bei hoher Geschwindigkeit]
                        Reset counter: 26
                        Mileage: 164932 km
                        Date: 2019.01.06
                        Time: 08:57:16
                        Write only channel
       Revision: 00002001    Serial number: 0335831488
       Coding: 011B062280B900408320013680000047
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T1 035 223     HW: 8T1 035 223
       Component: DSP Prem      H05 0040
       Revision: 00005001    Serial number: 94803029351403
       Coding: 0203010302
       VCID: 6C82CE044682D5D7525-8038
       Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
       Component: TSG BF        H08 0305
       VCID: 56F68CECE80E7F07941-8002
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 30000000210268
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A2E385C7CD6BB67909-806E
    131584 - Switch for Electric Parking Brake
              C100C 07 [008] - Mechanical Failure
                        Reset counter: 11
                        Mileage: 163336 km
                        Date: 2018.12.03
                        Time: 18:37:28
                        Voltage terminal 30: 12.4 V
                        Internal Fault ID: 11
                        Function light in parking brake button: On
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Internal Parking Brake state: No enabling
                        Status of parking brake button: Close
                        Status ParkingBrake left: is closed
                        Status ParkingBrake right: is closed
       Part No SW: 8R2 035 186 P    HW: 8R2 035 186 P
       Component: Concert3 DAB  H06 0470
       Revision: 00000003    Serial number: AUZ5Z6N2039138
       Coding: 0403008201018D00435B071800
       VCID: 43D045B80B9CFAAFC3F-8016
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0305
       Coding: 010002204001210001
       VCID: 59EC87D09910507FB93-800C
       Component: TSG HR        H07 0305
       Shop #: WSC 06335 000 00000
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005766563
       Coding: 0010320
       VCID: 3D24334061788C5FB5B-8068
    End----(Elapsed Time: 01:42, VBatt start/end: 12.4V/12.0V. VIgn 11.9V)-----
    Sep 2015
    I would guess the answer is no and no.
    Although, you CAN enable the mirror reverse function, but it will probably not work as it should since you do not have the electric seats with memory. I believe it can be enabled on module 52 long coding, byte 04, bit 2 and 3, if you want to try for yourself. Turn your mirror control switch to passenger side position and put car on reverse, mirror should go down. Then it comes back up as you start driving forwards. Usually activating this to cars that didn't have it from factory, produces funny side effects such as mirror sometimes staying down when driving forward or mirror coming all the way up and showing you only passing airplanes.
    Indicators can not be coded to behave the way you described (and the way they are in newer models).
  3. Likes PetrolDave liked this post
    Jan 2017
    Ireland
    Quote Originally Posted by Mika_M View Post
    That's perfect thanks for the reply, I'll try it and add how it goes
