So I was dinking around with VCDS on my MK5 the other day and notice the soft coding in my ECU is set to 0000003, according to the pop up info it is set to 4-speed automatic and I have a 6-speed also, the options for the cruise control and stuff aren't coded in.
Is this a big deal? or is some wrong info about the coding popping up?
Auto-scan ---
Auto-scan ---
Sunday,09,June,2019,13:07:09:46044
VCDS Version: 19.6.0.2 (x64)
VIN: 3VWSF31K06M605292 License Plate:
Mileage: 169500km-105322mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWSF31K06M605292 Mileage: 169500km-105322miles
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 06A 906 032 QE HW: Hardware No
Component: 2.5l R5/4V G 9424
Revision: 00000000 Serial number: VWZ7Z0E1472109
Coding: 0000003
Shop #: WSC 46338 002 1048576
VCID: 71E9272A681AC6C76E-8024
Readiness: 0110 1101
Part No: 09G 927 750 AS
Component: AQ 250 6F 1205
Coding: 0000008
VCID: 020B78E65DBCCD5F87-8056
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 3A7BC00675EC459F9F-806E
014 - Defective
Part No: 1K0 820 047 EG
Component: Climatic PQ35 084 0404
VCID: 6DD13B5A742222274A-8038
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000028222
Coding: 14058E02400418000014000000140000000073035C
VCID: 3979DF0A70EA4E8796-806C
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1T AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD00XEAE
Coding: 0012628
VCID: 2E53FC56B9A4993F33-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME080F4662C
Subsystem 3 - Serial number: 6342MSME08256140+
Subsystem 4 - Serial number: 6351HSME057C0578B
Subsystem 5 - Serial number: 6361HSME060D45130
Subsystem 6 - Serial number: 63727SME062C026F3
Subsystem 7 - Serial number: 63827SME061A0413T
Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
Component: J0527 010 0045
Coding: 0010021
VCID: 72EB28266D1CFDDF97-8026
Part No: 1K0 920 851 L
Component: KOMBIINSTRUMENT 3HL 0720
Coding: 0023303
Shop #: WSC 20200 993 00998
VCID: 3169E72AA89A86C72E-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104C0807AB
Coding: 3F3F0340071002
VCID: 29590F4A804AFE07E6-807C
Component: IMMO 3HL 0720
Shop #: WSC 37478 002 1048576
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1K0 959 701 L
Component: Tuer-SG 024 2475
Coding: 0000175
Shop #: WSC 98765 666 30737
VCID: 377DD93246FE58F760-8062
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 306FE22EA3908FCF21-8064
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AM
Component: KSG 0401
Coding: 137803487F6D050F880F049051A0
VCID: 7BF505023A56BC97C4-802E
Component: LIN BACKUP HORN H02 1301
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Component: Tuer-SG 024 2339
Coding: 0001269
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 HW: 1K0 035 161
Component: Radio DE2 009 0012
Revision: 00009000 Serial number: VWZ4Z7E6003887
Coding: 0040400
VCID: 5CB7669E9F985BAFAD-8008
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2416
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 326BE826AD9CBDDF57-8066
End-------------------------(Elapsed Time: 01:43)--------------------------
