Results 1 to 3 of 3
Thread: 2006 Jetta 2.5l Auto ECU soft coding
    Jun 2019
    Canada
    So I was dinking around with VCDS on my MK5 the other day and notice the soft coding in my ECU is set to 0000003, according to the pop up info it is set to 4-speed automatic and I have a 6-speed also, the options for the cruise control and stuff aren't coded in.
    Is this a big deal? or is some wrong info about the coding popping up?
    Auto-scan ---
    Sunday,09,June,2019,13:07:09:46044
    VCDS Version: 19.6.0.2 (x64)
    VIN: 3VWSF31K06M605292   License Plate:
    Mileage: 169500km-105322mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: 3VWSF31K06M605292   Mileage: 169500km-105322miles
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 06A 906 032 QE    HW: Hardware No
       Component: 2.5l R5/4V      G   9424
       Revision: 00000000    Serial number: VWZ7Z0E1472109
       Coding: 0000003
       Shop #: WSC 46338 002 1048576
       VCID: 71E9272A681AC6C76E-8024
    Readiness: 0110 1101
       Part No: 09G 927 750 AS
       Component: AQ 250 6F           1205
       Coding: 0000008
       VCID: 020B78E65DBCCD5F87-8056
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0021122
       Shop #: WSC 00066 000 00000
       VCID: 3A7BC00675EC459F9F-806E
                014 - Defective
       Part No: 1K0 820 047 EG
       Component: Climatic PQ35   084 0404
       VCID: 6DD13B5A742222274A-8038
       Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
       Component: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 00000000028222
       Coding: 14058E02400418000014000000140000000073035C
       VCID: 3979DF0A70EA4E8796-806C
       Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
       Component: 1T AIRBAG VW8R  024 6300
       Revision: 03024000    Serial number: 0037KD00XEAE
       Coding: 0012628
       VCID: 2E53FC56B9A4993F33-807A
       Subsystem 1 - Part No: 1K0 959 339 B
       Component: BF-Gewichtsens. 006 0003
       Subsystem 2 - Serial number: 6332MSME080F4662C
       Subsystem 3 - Serial number: 6342MSME08256140+
       Subsystem 4 - Serial number: 6351HSME057C0578B
       Subsystem 5 - Serial number: 6361HSME060D45130
       Subsystem 6 - Serial number: 63727SME062C026F3
       Subsystem 7 - Serial number: 63827SME061A0413T
       Part No SW: 1K0 953 549 AB    HW: 1K0 953 549 AB
       Component: J0527           010 0045
       Coding: 0010021
       VCID: 72EB28266D1CFDDF97-8026
       Part No: 1K0 920 851 L
       Component: KOMBIINSTRUMENT 3HL 0720
       Coding: 0023303
       Shop #: WSC 20200 993 00998
       VCID: 3169E72AA89A86C72E-8064
       Part No SW: 1K0 907 530 E    HW: 1K0 907 951
       Component: Gateway         H09 0110
       Revision: 09          Serial number: 2700104C0807AB
       Coding: 3F3F0340071002
       VCID: 29590F4A804AFE07E6-807C
       Component: IMMO            3HL 0720
       Shop #: WSC 37478 002 1048576
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1K0 959 701 L
       Component: Tuer-SG         024 2475
       Coding: 0000175
       Shop #: WSC 98765 666 30737
       VCID: 377DD93246FE58F760-8062
    00131 - Outside Door Handle Illumination/mirror Light Driver Side
       Part No: 1K1 909 144 H
       Component: EPS_ZFLS Kl.3       1502
       VCID: 306FE22EA3908FCF21-8064
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AM
       Coding: 137803487F6D050F880F049051A0
       VCID: 7BF505023A56BC97C4-802E
       Component: LIN BACKUP HORN H02 1301
    01134 - Alarm Horn (H12)
       Part No: 1K0 959 702 K
       Component: Tuer-SG         024 2339
       Coding: 0001269
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161     HW: 1K0 035 161
       Component: Radio DE2       009 0012
       Revision: 00009000    Serial number: VWZ4Z7E6003887
       Coding: 0040400
       VCID: 5CB7669E9F985BAFAD-8008
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2416
       Coding: 0000144
       Part No: 1K0 959 704 D
       Coding: 0000144
       VCID: 326BE826AD9CBDDF57-8066
    End-------------------------(Elapsed Time: 01:43)--------------------------
    If it ain't broke, don't fix it!
    Googling that ECU part number, most if not all are coded 0000003.
    The label file is applicable to quite a few different part numbers, and I suppose the coding info isn't correct for yours.
    Yes, as far as I know should be:
    0000xx?: Transmission
          1 = Manual Transmission
          3 = 6-Speed Automatic Transmission
  5. Likes Uwe, Dana liked this post
