Results 1 to 7 of 7
Thread: 2002 beetle tdi cruise
    Jun 2019
    Missouri, USA
    I have a 2002 beetle tdi I did a 5speed swap on. The cruise worked with the ECU still set for auto transmission. I just got VAG Com from Ross-Tech and followed the directions to change the code to manual to get rid of the CEL. After doing this my cruise no longer worked. I then followed the directions to turn cruise on and still have no cruise. I ran auto scan but can’t share at this time as I am on my phone and traveling. Auto scan showed codes for right front ABS and left rear ABS wheel speed sensor fault. No communication to transmission control module. Open circuit for radio antenna and speaker open circuit. Any idea?
    Nov 2015
    Gonna need that autoscan I'm afraid when you get off your phone.
  3. Likes PetrolDave, Uwe, Eric liked this post
    Jun 2019
    Missouri, USA
    Quote Originally Posted by Viking View Post
    Tuesday,11,June,2019,11:11:46:53135
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: 3VWCP21C72M401376   License Plate:
    Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
    Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
    VIN: 3VWCP21C72M401376   Mileage: 358860km-222985miles
    Address 01: Engine        Labels: 038-906-012-AGR.clb
       Part No: 038 906 012 FF
       Component: 1,9l R4 EDC G400SG  4104
       Coding: 00002
       Shop #: WSC 03078
       VCID: 59EF8C8C30058A3FEDF-4B1E
       3VWCP21C72M401376     VWZ5Z0Z5031104
    Readiness: 0 0 1 0 0
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 J
       Component: ABS FRONT MK60      0103
       Coding: 0004097
       Shop #: WSC 04042 551 00000
       VCID: 313F142C0D35A27F75F-5160
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
       Part No: 6Q0 909 605 A
       Component: 25 AIRBAG VW5  0E   0006
       Coding: 12853
       Shop #: WSC 00066
       VCID: 3537203CFC5D8E5F297-4B3C
    Address 17: Instruments        Labels: 1C0-920-x4x.lbl
       Part No: 1C0 920 921 B
       Component: KOMBI+WEGFAHRS. M73 V07
       Coding: 03232
       Shop #: WSC 07431
       VCID: 1D67D89C64AD361FC17-4B1E
                49-00 - No Communications
       Part No: 6N0 909 901
       Component: Gateway K<->CAN    V072
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70B9D128C3BFEB773A1-4B1E
       Part No: 1C0 959 799 G
       Component: 2K Komfortgerát HLO 0004
       Coding: 00064
       Shop #: WSC 00066
       VCID: 3B233604DA79582FDF3-4B00
       Subsystem 1 - Part No: 1C2959802A
       Component: 2K Tőrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 1C2959801A
       Component: 2K Tőrsteuer.BF KLO 0002
       Part No: 1C0 035 157 D
       Component:  Radio DE2         0006
       Coding: 06031
       VCID: 1D67D89C64AD361FC17-51CE
    00856 - Radio Antenna
                36-00 - Open Circuit
                35-00 - -
    End----------(Elapsed Time: 03:35, VBatt start/end: 12.2V/12.1V)-----------
    Nov 2015
    At a guess (I'm by no means an expert) it looks as though the Gateway controller 19 is looking for the auto transmission. Did you remove the auto transmission from the installation list in controller 19?
    This car is too old to have an accessible/modifiable Installation List.
    What should be done here: The Gateway needs to be re-coded with the same value that's already there (00006) and preferably with a different WSC. This will cause it to re-learn what's actually installed in the car.
  7. Likes PetrolDave liked this post
    Jun 2019
    Missouri, USA
    New to this coding stuff. What is a WSC?
    See how WSC is bold, dark green, and has a broken underline? Hover your cursor over it.
