Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 2006 A4 Avant Quattro, APR stage 2+ 160K miles
    Jan 2018
    Good afternoon all, tried to follow instructions as close as possible for new posts. I'm seeking help as a means to learn the VCDS better and diagnose properly. Too busy fixing chevy trucks here in AR to work on my own stuff and learn by myself...need some training.
    Car ran fine until recently. Noticed a loss of power and CEL came on for P310B. I know its a common problem but I'm not throwing parts at this. Vehicle came with AutoZone DElphi LPFP which has worked fine for 2 yrs. After code came on, they gave me a new fuel pump. Installed it and now the car only runs for about 10 min then shuts off. Then it becomes hard to start. If it does start, it will only run for a few minutes and shut down. If it sits until cool, it will restart & the process starts all over again.
    I'm not replacing parts just bc they aren't OEM. I agreed to some degree aftermarket aren't the best, but that's not an excuse to replace parts...I want to learn this system and actually diagnose this problem. I need to prove a bad part as best as possible.
    Tuesday,11,June,2019,13:13:43:19959
    VCDS Version: 19.6.0.5 (x64)  HEX-NET CB: 0.4505.4
    VIN: WAUKF78E96xxxxx   License Plate:
              67 69 75 76 77
    VIN: WAUKF78E96A159082   Mileage: 258470km-160605miles
       Part No SW: 8E0 910 115 M    HW: 8E0 907 115 D
       Component: 2.0l R4/4V TFSI     0070
       Revision: --H10---    Serial number:
       Coding: 010C010A190F0120
       Shop #: WSC 25324 444 54344
       VCID: AB1668C70A48471793-80FE
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - Intermittent
                        Mileage: 258478 km
                        Temperature: 24.0°C
                        Temperature: 28.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.192 V
    012555 - Low Pressure Fuel regulation
                   P310B - 008 - Fuel Pressure Outside Specification - MIL ON
                        Fault Status: 11101000
                        Mileage: 258478 km
                        RPM: 949 /min
                        Load: 29.4 %
                        Temperature: 25.0°C
                        Temperature: 27.0°C
                        Voltage: 13.716 V
    Readiness: 0000 0101
       Part No SW: 8E1 910 156 C    HW: 09L 927 156 B
       Component: AG6 09L 2.0TFSI USA 0030
       Revision: --H01---    Serial number:        4115320
       Shop #: WSC 06325 000 00000
       VCID: A71E94F716A0637777-80F2
    009783 - Torque Management Feedback Signal A
                   P2637 - 000 -  - Intermittent
                        Reset counter: 39
                        Mileage: 253756 km
                        RPM: 96 /min
                        (no units): 30.0
                        (no units): 25.0
                        Temperature: 48.0°C
                        T.B. Angle: 0.0°
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
       Component: ESP8 quattro    H05 0120
       Coding: 0004528
       VCID: A91A92CF00B4550761-80FC
    18265 - Load Signal
                P1857 - 000 - Error Message from ECU - Intermittent
                        Fault Frequency: 21
                        Reset counter: 40
                        Hex Value: 0x3500
                        Hex Value: 0x4006
                        Hex Value: 0x0028
                        Hex Value: 0x01A8
                        Hex Value: 0x0001
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2832
       Coding: 00000
       VCID: ED92A6DFA5DC8927CD-50D0
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  USA 0504
       Coding: 11023
       Shop #: WSC 65536
       VCID: BB365887AB28D79703-4AA4
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H11 3540
       Revision: 91H1135    Serial number: 0036N0016SH+
       Coding: 0032607
       VCID: BC345B9BFF26D0AF0A-80E8
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 002 0070
       Subsystem 2 - Serial number: 363UT
       Subsystem 3 - Serial number: 0001.01.000000200000000000˙†63
       Subsystem 4 - Serial number: 000000˙†6332DRB40275900FL˙†63
       Subsystem 5 - Serial number: 5900FL˙†6342DRB40275C98B ˙†63
       Subsystem 6 - Serial number: 5C98B ˙†6352ARB400B501436˙†63
       Subsystem 7 - Serial number: 501436˙†6362ARB400B39287N˙†63
       Subsystem 8 - Serial number: 39287N˙†63729RB400C57256K˙†63
       Subsystem 9 - Serial number: 57256K˙†63829RB400C57219K˙
       Subsystem 10 - Serial number: 57219K˙
       Part No: 8E0 953 549 Q
       Component: Lenksįulenmodul     0601
       Coding: 04042
       Shop #: WSC 06325
       VCID: C1CA2A6FC9C4BD4759-4AA4
    01304 - Radio
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 982 F    HW: 8E0 920 982 F
       Component: KOMBI+WFS 4     H12 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0023241
       Shop #: WSC 25324 444 84418
       VCID: B12A7AAF29642DC7A9-50F4
    01304 - Radio
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023241
       VCID: B12A7AAF29642DC7A9-5118
    01304 - Radio
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: F1AABAAFBAE46DC7E9-4B3C
       Part No: 8E0 959 433 BT
       Component: Komfortgerįt T7B    3332
       Coding: 12156
       Shop #: WSC 06325
       VCID: 8444E37B9656686F32-4AA4
       Component: Tõrsteuer.FS BRM 0506
       Component: Tõrsteuer.BF BRM 0205
       Component: Tõrsteuer.HL BRM 0606
       Component: Tõrsteuer.HR BRM 0606
                35-00 - -
       Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
       Component: AFS 1           H01 0010
       Coding: 0000019
       VCID: A81C97CB1BBE6C0F7E-80FC
       Subsystem 1 - Part No: 8E0 941 329
       Component: AFS-Modul links H03 0020
       Subsystem 2 - Part No: 8E0 941 329
       Component: AFS-Modul rechtsH03 0020
       Part No SW: 8P0 862 335 G    HW: 8P0 862 335 G
       Component: FSE_255x BT     H21 0190
       Revision: 00000001    Serial number: 00000000348880
       Coding: 0001677
       VCID: BA385D83F412EE9F18-50D0
    01304 - Radio
                        Reset counter: 158
                        Time Indication: 15
    End----------(Elapsed Time: 05:13, VBatt start/end: 12.8V/12.8V)-----------
    Sep 2014
    Are you seeing sensible live values for Fuel Pressure in Measuring Blocks?
    If you click the Advanced Measuring Values button, it should show a list of live data offered and hopefully you can find fuel pressure listed.
    Your MAF fault may also be responsible for the engine cutting out.
  3. Likes Uwe, Jack@European_Parts liked this post
    Jan 2018
    I agree with the MAF issue causing same problem. I slaved in a known good one and came up with same result.
    blk 106
    field 1 = 50 bar at idle
    field 2 = 83.1 at idle. I know that is high. thinking bc its a delphi pump.
    after shut down and a heat soak I drop to 3 bar in field 1.
    blk 140 hpfp
    field 3 = 50 bar
    blk 230 field 3 = deviation .01-1
    high side seems to be fine
    I had the VCDS hooked up when it died this last time but don't know to how retrieve that data...
    maybe I need to look at the MAF after it cools down again instead of fuel pressure...i'm not eliminating that as the culprit...It acted the same way the last time it went bad.
    btw, I'm trying to get the erWin data but cant seem to figure out how to download the manual I need or get a price for the subscription...
    Sep 2014
    From your post, it sounds like you may have already seen the Ross-Tech Wiki page on this but here is the link for reference:
    http://wiki.ross-tech.com/wiki/index...cial_Functions
    If you have already tried a different MAF, you can probably rule that out for the moment. Did the MAF fault code go away when you fitted the borrowed sensor?
    Before the Fuel Pump was changed, the car ran ok but just threw up pressure faults, is that correct? Or did it have the same cutting-out symptoms as now?
    Component: 2.0l R4/4V TFSI 0070 <<<<<<<<<<<<<<<<<<<<<<<<<<<< FIRMWARE UPDATE NEEDED!
    blk 106
    blk 140 hpfp
    field 3 = 50 bar
    Vehicle Identification No. WAUKF78E96A159082
    Model audi a4 av. qu. 2,0
    A4
    Date of production 06.12.2005
    Model year 2006
    Sales type 8ED5EL
    Engine Code BPG
    Transmission Code JJE
    Emission standard 7GB Emission standard ULEV 2
    OP: Can you clear fault codes and re-post the new auto-scan & with additionally the OBD2 data MODES 1-01, 3, 7 & 9 please?
    OP: Have you checked to be sure the integrated FPR in fuel filter is working as specified with new lift pump & for volume using mechanical tests such as gauges and V-metric confirmed delivery?
    OP: Did you check the fuel module control unit for proper function ground and ability carry AMP load capacity to lift pump & did you measure the duty cycle with DVOM or observe in VCDS?
    OP: Is the mechanical HPP in proper order & stroke of lifter or cam ramp correct?
    JPPSG lately?
    Tuning by definition is induced FOD!
    Check for ECU water ingress!
    Jan 2018
    I did follow that guide and took notes of pressure settings waiting for the engine to die and hopefully capture the cause. The MAF code came on bc I started the engine with the MAF connector disconnected after swapping it and didn't erase it.
    So the engine ran ok but at lower power than normal. Stage 2 on this engine is like a bull out of the gates, it began to accelerate slower and took longer to get up to speed. It never cut out though.
    Jan 2018
    Ok...first off, Im having no luck getting a service manual for this car. Andy (Rosstech) confirmed to me this morning that Bentley has been superseded by erWin (and doesn't provide good data on the FSI engine) and I cant figure out the website to get the troubleshooting data I need. I'm continuing efforts to get that data...
    I will try to start engine, clear codes and repost data requested. Not sure about the OBD2 data modes requested. I'll search for those.
    I haven't taken FPFP off yet bc I'm pulling data first. Its on my visual check list though.
    I have not checked the FPR in the filter yet. I have not checked volumetric efficiency bc I don't have tech data to tell me what to expect.
    VCDS showed 83.1 duty cycle at idle if that's what you're asking.
    Jack, I did read your post about FOD in the ecu...I will do an inspection of the part. I've done plenty of FOD walks on the flight line keeping our B52s flying.
    Tuesday,11,June,2019,16:49:27:19959
    VIN: WAUKF78E96A159082   License Plate:
    Mileage: 258470km-160605mi   Repair Order:
              67 69 75 76 77
                        Mileage: 258479 km
                        RPM: 944 /min
                        Load: 24.7 %
                        Temperature: 36.0°C
                        Temperature: 31.0°C
                        Voltage: 13.843 V
                        Reset counter: 39
                        Mileage: 253756 km
                        RPM: 96 /min
                        (no units): 30.0
                        (no units): 25.0
                        Temperature: 48.0°C
                        T.B. Angle: 0.0°
       Coding: 0004528
    18265 - Load Signal
                        Fault Frequency: 21
                        Reset counter: 40
                        Hex Value: 0x3500
                        Hex Value: 0x4006
                        Hex Value: 0x0028
                        Hex Value: 0x01A8
                        Hex Value: 0x0001
       Coding: 00000
       Coding: 11023
       Shop #: WSC 65536
       Coding: 0032607
       Coding: 04042
       Shop #: WSC 06325
    01304 - Radio
       Coding: 0023241
    01304 - Radio
       Coding: 0023241
    01304 - Radio
       Coding: 00002
       Coding: 12156
       Shop #: WSC 06325
                35-00 - -
       Coding: 0000019
       Coding: 0001677
    01304 - Radio
                        Reset counter: 158
                        Time Indication: 15
    End----------(Elapsed Time: 05:12, VBatt start/end: 14.0V/14.0V)-----------
    Tuesday,11,June,2019,16:56:19:19959
    VCDS Release 19.6.0 (x64):  Generic OBD2
    Mode 01 - PID 01 : Readiness  --  Address 7E8
    Number of DTCs stored: 0  --  MIL Status: MIL OFF
    Misfire monitoring:  Passed
    Fuel System:  Passed
    Comprehensive Components:  Passed
    Catalyst monitoring:  Failed or Incomplete
    Heated catalyst monitoring: Not installed.
    Evaporative system monitoring:  Failed or Incomplete
    Secondary air system monitoring: Not installed.
    A/C system refrigerant monitoring: Not installed.
    Oxygen sensor monitoring: Not installed.
    Oxygen sensor heater monitoring: Not installed.
    Exhaust Gas Recirculation: Not installed.
    Tuesday,11,June,2019,16:56:57:19959
    Mode 03: Emission related fault codes
    Address 7E8: No fault code found.
    Address 7E9: No fault code found.
    Tuesday,11,June,2019,16:57:34:19959
    Mode 07: Pending emission related fault codes
    Address 7E8: 1 Fault Found:
    P0089 - Valve for Fuel Metering (N290): Implausible Signal
    Tuesday,11,June,2019,16:57:55:19959
    Mode 9 : Calibration Identification
    Type 02 - VIN : WAUKF78E96A159082 (Address E8)
    Type 04 - Calibration ID : 8E0910115M  0071 (Address E8)
    Type 04 - Calibration ID : 8E1910156C  0030 (Address E9)
    Type 06 - Calibration Verification Number : 483FB60A (Address E8)
    Type 06 - Calibration Verification Number : D63D83FA (Address E9)
    I cleared out codes, started engine and auto scanned. P310B came back immediately.
    Also posted OBD2 data for Jack.
  9. #8
    Nein! Measure using the RTFB & proper tools + specs .....not just a visual!
    RTFB can be had here and yes indeed the website works!
    https://erwin.audiusa.com/erwin/showHome.do
    Awesome...... thank you very much!
  10. #9
    Jan 2018
    I'm sure the erWin site works...I just cant figure out how to create a log in to get the data. No data means nein on the technical inspection of the HPFP and associated parts.
  11. #10
  12. Likes Uwe, Fredrick Awuor, grant@gendan liked this post
