Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 67
Thread: Cannot Auto Scan with HEX-NET, USB, and VCDS 19.6.0
  1. #31
    Apr 2015
    Brazil
    +1 with a Q5 MY2019. I'm getting different results each time: "not supported by gateway" and missing many modules in the list are the most common that I can remember of.
  2. #32
    Quote Originally Posted by fzanicotti View Post
    You try 19.6.0.7 too, please. The link is in post #29 of this thread.
  3. Likes Boki Ar, Eric, fzanicotti liked this post
  4. #33
    Jul 2016
    Downloadea latest software and tested today.
    Again did 10 scans , result 6 ok 4 fail with same message.
    All ok scans seemed to be complete, but on two occasions
    when you went to module list the "installed modules " lists wern't there?
    computer details:-
    Dell Inspiration laptop
    64 bit 4g ram 2.5 Ghz
    Windows 7 Pro.
    Been using same laptop for a couple of years without any problems.
    Saturday,15,June,2019,11:04:23:52854
    VCDS Version: 19.6.0.7 (x64) HEX-V2 CB: 0.4505.4
    VIN: WAUZZZ4M5GD022610 License Plate:
    Chassis Type: 4M (4M - Audi Q7 (2016 >))
    Scan: Auto-detect
    Function not supported by the gateway.
    End----------(Elapsed Time: 00:10, VBatt start/end: 12.2V/12.2V)-----------
  5. Likes Uwe liked this post
  6. #34
    Mar 2019
    Quote Originally Posted by Andy View Post
    jagpurr,
    Please try a fresh download from our website:
    https://www.ross-tech.com/vcds/download/current.php
    I will also try this this weekend. Thanks.
  7. Likes Uwe liked this post
  8. #35
    Mar 2016
    Hi Uwe and team
    I can confirm that 19.6.0.7 seems to be working much better than 19.6.0.4 and 19.6.0.6. I have not got a "Function not supported by the Gateway" error and when I do full autoscans they now complete with ALL modules in my car without issue.
    My only observation is when the full scan is running on 19.6.0.7 it seems to always start with Module 17 now, whereas in 18.9.x it always started with Engine (Module 01)
    Not sure what you changed, but everything seems to be better
    I'm going to keep 18.9 installed for the time being "just in case"
    Appreciate your support
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
  9. Likes Andy, jyoung8607, PetrolDave, Uwe liked this post
  10. #36
    Mar 2019
    So I updated to VCDS version 19.6.0.7 and ran an autoscan via USB using HEX-NET. While the scan appeared to finish, i did get the same error message pop up as before (see post #17). I've attached the scan results below:
    Sunday,16,June,2019,11:25:28:12197
    VCDS Version: 19.6.0.7 (x64)  HEX-NET CB: 0.4505.4
    VIN: WA1C4AFY4Kxxxxxxx   License Plate:
    Mileage: 7666km-4763mi   Repair Order:
    Chassis Type: FY-AU49 (80A)
    Scan: 01 02 03 08 09 13 15 16 17 19 1B 29 32 36 39 3C 42 44 46 47
              52 5F 6C 6D 74 75 81 82 8B A5 A9 BB BC CA CF D6 D7
    VIN: WA1C4AFY4Kxxxxxxx   Mileage: 7666km-4763miles
    74-Chassis Control -- Status: Malfunction 0010
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CWGD)       Labels: None
       Part No SW: 80A 907 559 D    HW: 06M 907 309 L
       Component: V6 3.0l TFSI  H10 0002
       Revision: BAH10000
       Coding: 2A2A0032256E090E34380000000000000000000000000000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TFS01180A907559D 001002
       ROD: EV_ECM30TFS01180A907559D.rod
       VCID: 302C18AB6B0CF6CF24-8064
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 80A 927 158 A    HW: 0D5 927 156 H
       Component: 0D5  30TSIUSA H05 1005
       Revision: --H05---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 2A180AC34DD08C1FEA-807E
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
       Part No SW: 80A 907 379 K    HW: 80A 907 379 A
       Component: ESP9 Premium  H13 0775
       Coding: 1CAA14BE30A20A98919E5895588458A2E5359A38280C50891A1A1A45A7AC59
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 373E23B78E6221F765-8062
    419584 - TPMS Warning; Rear Left Tire
              C1059 00 [040] - Flat
                        Mileage: 6016 km
                        Date: 2019.05.24
                        Time: 17:31:09
                        81 00 80 10 89 24 00 00 00 00
                        Unlearning counter according OBD-OBD unlearning counter: 06
       Part No SW: 80A 820 043 N    HW: 80A 820 043 N
       Component: Klima Zone 3  H60 0251
       Coding: 6608090D5548010D10000100080000000000000000000000000000000000
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 281CF0CB53DCBE0FFC-807C
       Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
       Component: J126 FLuftV  H09 0003
       Serial number: 00000000000002641759
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: A7201C3900PAG0MUFU02
       Subsystem 3 - Part No SW: 80A 919 158 A    HW: 80A 919 158 A
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0313
       Coding: 07500363E0691CCD050D51199CAE9CB9130B3D090000000000000000600016010A6301ABA2B70A
       ASAM Dataset: EV_BCM1BOSCHAU736 019008
       ROD: EV_BCM1BOSCHAU736_019.rod
       VCID: 034687678A3ABD5789-8056
       Subsystem 1 - Part No SW: 80B 955 119 A    HW: 80B 955 119
       Component: 426 LL 180814  040 0581
       Serial number: 00000001808102106321
       Coding: FFC7F7
       Serial number: 21623284X81A955555A0
       Coding: 02006E
       Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
       Component: E1 - LDS  H06 0008
       Serial number: 29 08 2018  82410261
       Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H10 0100
       Serial number: 0000009600350Z00F202
       Coding: 350000
       Garage Door Opener Operating Unit:
       Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20180904231553 01079
       Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
       Component: Y7_Innenspieg  H01 0002
       Serial number: GX1CE117081823310646
       Coding: 030000
       Interior Light Module:
       Subsystem 7 - Part No SW: 80A 947 135 AN    HW: 80A 947 135
       Component: Dachmodul Q5  H32 0330
       Serial number: Q00044904
       Coding: 0D0101
       Electrically Adjustable Steering Column:
       Subsystem 8 - Part No SW: 80A 907 705     HW: 80A 907 705
       Component: J866-EVLS-SG  H03 0100
       Serial number: WA132105000048332616
       Coding: 0A0700
       Subsystem 9 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2818000172217002
       Part No SW: 80A 907 561 B    HW: 8W0 907 561
       Component: LRR4          H10 0340
       Coding: B4779FF358FFEC05757A61A1
       ASAM Dataset: EV_ACCBOSCHAU49X 003022
       ROD: EV_ACCBOSCHAU49X.rod
       VCID: 271EF3F75EC2B177F5-8072
    1542 - Sensor for Automatic Distance Control
              [FAULT_SYSTEM_BLIND]
                        Reset counter: 213
                        Mileage: 5757 km
                        Date: 2019.05.20
                        Time: 17:55:06
                        Control Module temperature: 59 °C
                        Voltage terminal 15: 12.7 V
                        Velocity_vehicle_reference: 8.47 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.59 m/s²
    Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
       Part No SW: 80A 959 655 M    HW: 80A 959 655 M
       Component: AirbagVW30    054 0605
       Serial number: 003W2M00BRV%
       Coding: AECCFCC000800000A000003FF20C400000C5
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
       ROD: EV_AirbaVW31SMEAU65x_AU49.rod
       VCID: 3D32319FAC5E0BA7BF-8068
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
       Component: BeltPretRevFL  306 2033
       Serial number: 80A857705K0192S01609
       Coding: 80000D
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
       Component: BeltPretRevFR  306 2033
       Serial number: 80A857706K0180S01447
       Coding: 80000D
       Occupant Detection:
       Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
       Component: BF-Gewichtss.  H11 0022
       Serial number: IBH0000J18000A375B0O
       Coding: 303039
       Subsystem 4 - Part No SW: -----------    HW: 480 000 108 18
       Serial number: 357000000001756C733G
       Subsystem 5 - Part No SW: -----------    HW: 480 000 108 18
       Serial number: 3580000000029C91133D
       Subsystem 6 - Part No SW: -----------    HW: 480 033 006 18
       Serial number: 351001C101C430711E9W
       Subsystem 7 - Part No SW: -----------    HW: 480 033 006 18
       Serial number: 352001C101C3FC30FD3F
       Subsystem 8 - Part No SW: -----------    HW: 480 031 107 18
       Component: FrontSensor_D  002 0149
       Serial number: 355001C143DCC5E02A6M
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 031 107 18
       Component: FrontSensor_P  002 0149
       Serial number: 356001C143D508D05C27
       Central Sensor XY:
       Subsystem 10 - Part No SW: -----------    HW: 480 022 307 18
       Component: CentrSensorXY  000 0108
       Serial number: I0O0001C7297DB21F621
    1060617 - Databus
              [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                        Reset counter: 213
                        Mileage: 5758 km
                        Date: 2019.05.20
                        Time: 17:55:21
    1060614 - Databus
              [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                        Reset counter: 213
                        Mileage: 5758 km
                        Date: 2019.05.20
                        Time: 17:55:21
    Address 16: Steering wheel (J527)       Labels: None
       Part No SW: 80A 907 129 CQ    HW: 80A 907 129 CQ
       Component: Lenks.Modul   H02 0005
       ROD: EV_SMLSKLOAU736_007_AU49.rod
       VCID: 79BAE58FF8F6F787D3-802C
       Part No SW: 8W5 920 890 E    HW: 8W5 920 890 E
       Component: FBenUSA       H20 0417
       Coding: 09CF96C53CB8CF0502B369601800400008000000
       ASAM Dataset: EV_DashBoardAU736 001032
       ROD: EV_DashBoardAU736_AU49.rod
       VCID: 45C2597FC48E4367E7-8010
       Part No SW: 80A 907 468 B    HW: 80A 907 468 B
       Component: Gateway       H05 0118
       Serial number: 15F01007412801
       Coding: 03010001000006405407000000590032FC9A00079A0000000175078E10000000
       ASAM Dataset: EV_Gatew31xAU65x 003160
       ROD: N/A
       VCID: 2D1201DF7C3E9B270F-8078
       Subsystem 1 - Part No SW: 80A 951 523 E    HW: 80A 951 523 E
       Component: J453 MFL  H06 0004
       Serial number: 20180828071135 00009
       Serial number: 4217346000
    No ASAM data for: "EV_Gatew31xAU65x" ()
    131687 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 201
                        Mileage: 4421 km
                        Date: 2019.04.29
                        Time: 13:35:37
    131702 - ROD - Unknown Error Code
              - 00 [008]
                        Fault Frequency: 19
                        Reset counter: 210
                        Mileage: 2912 km
                        Date: 2019.04.10
                        Time: 18:45:12
       Part No SW: 8W0 907 144 J    HW: 8W0 907 144 C
       Component: SCU_MLBevo    H03 0710
       Serial number: 30303030303030
       ASAM Dataset: EV_SCUZFLSAU49X 002019
       ROD: EV_SCUZFLSAU49X_002.rod
       VCID: 42C84263D5A0745FC2-8016
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 80A 907 397 C    HW: 80A 907 397 C
       Component: LCM_MLBevo    H07 0022
       VCID: 2F2E1BD77632E9373D-807A
    Address 32: Differential Locks (J187)       Labels: None
       Part No SW: 8W0 907 163     HW: 8W0 907 163
       Component: QSP QCU Gen2  H08 0060
       Revision: 5WK12700    Serial number: 605824603200507
       Coding: 0001
       ASAM Dataset: EV_TVDCQSP22 001008
       ROD: EV_TVDCQSP22.rod
       Part No SW: 4M4 959 760     HW: 4M4 959 760
       Component: MEM-FS        009 0042
       Serial number: 12A14825300992
       Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
       ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
    Address 39: Right Light (J1023)       Labels: None
       Part No SW: 80A 907 566 A    HW: 80A 907 566
       Component: MRR1Rear      H20 0431
       Revision: --------
       Coding: 0EC002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001022
       VCID: 2B160FC7422A951711-807E
       Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
       Component: TSG FS001 0188
       Serial number: CLSM1RIA017FL
       Coding: 005D8B015E00148000010032
       VCID: 40CC486BDBAC664FD4-8014
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H22 0005
       Serial number: 0000561746
       Coding: A1112101000101
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
       VCID: 342414BB9F14CAEF40-8060
       Part No SW: 4N0 907 064 BP    HW: 4N0 907 064 P
       Component: BCM2 MLBevo H14 0145
       Coding: 013400004FB100C0650BA0006C01980203004000810026502F0000000F04803F001E0001000000
       Shop #: WSC 00008 444 00000
       ASAM Dataset: EV_BCM2CONTIAU651 008007
       ROD: EV_BCM2CONTIAU651_008.rod
       VCID: 7EB0F693E1D8D0BFE6-802A
       Ignition key:
       Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY181901QRM
       Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000099352079
       Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11116528
       Rear Spoiler Adjustment:
       Part No SW: 80A 035 223 A    HW: 80A 035 223
       Component: MIB2_amp_P_Q5 H03 0420
       Revision: 00000001    Serial number: AUZ8ZAJTK034AWU
       Coding: 0194010800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: EV_AMPMst16C2Gen2ALPI.rod
       VCID: 197AC50F18B6178773-804C
       Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
       Component: TSG BFS001 0188
       Serial number: CLSM1RI8011H0
       Coding: 005D8B015E00148000010030
       VCID: 3FCE4B97A65219B7AD-806A
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W5 035 880 C    HW: 8W5 035 880
       Component: MU-P-LNS-US   035 1316
       Serial number: A798I0J9450527
       Coding: 012456020000000051220002041A00332F001AE401700904BE
       Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
       Component: NAR 2018/2019  --- 0066
       Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
       Component: AU426_DU_HIGH  H42 0008
       Serial number: AUZ8Z9JBL05TPD
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
       Component: ControlUnit_P  H15 0209
       Serial number: 18071800000000000776
       Component: Gracenote2  --- 3013
    3086 - Antenna for Telephone Mount
              B1564 01 [008] - Electrical Failure
                        Reset counter: 226
                        Mileage: 3170 km
                        Date: 2019.04.14
                        Time: 10:36:14
                        Voltage terminal 30: 12.0 V
                        Status of telephone-Antenna diagnostic: OK
                        Status of telephone-Telephone baseplate diagnostic: not connected
                        Status of telephone-Handset in handset holder (cradle): not selected
                        Status of telephone-Handset holder (cradle): not connected
    7219 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                        Fault Frequency: 18
                        Reset counter: 223
                        Mileage: 3117 km
                        Date: 2019.04.13
                        Time: 18:10:45
                        Voltage terminal 30: 14.3 V
                        BAP-BAP_Function_ID: 10
       Part No SW: 4M0 907 428 F    HW: 4M0 907 428
       Component: Areaview 2    H13 0318
       Serial number: C854607JN005384
       Coding: 02240602BE0FA10038004000
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
       ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
       VCID: 352229BF946ED3E777-8060
       Part No SW: 8W8 959 107 B    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: A2-C748-5750-5
       Coding: 0730
       VCID: 48DC504BF39C5E0F1C-801C
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 80A 907 777 M    HW: 80A 907 777 C
       Component: Fahrwerk-SG   H37 1214
       Serial number: 0708180406
       Coding: 5C603832F8
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
       VCID: 3B363F87B24A059781-806E
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
       Component: V66LFKompOLV  H06 0013
       Serial number: 00000000004130351838
       Coding: 303030
    32776 - Sensor for Ride-Height
              C1048 07 [008] - Mechanical Failure
                        Reset counter: 192
                        Mileage: 6062 km
                        Date: 2019.05.25
                        Time: 08:01:31
       Part No SW: 4K1 035 283 A    HW: 4K1 035 283 A
       Component: ConBox        H08 0100
       Serial number: 005CCA12F040072
       Coding: 01C020FE4040800000
       ASAM Dataset: EV_ConBoxAU651 001004
       ROD: EV_ConBoxAU651_001_AU49.rod
       VCID: 2600FEF359C8A87FCE-8072
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 80B 713 041 M    HW: 80B 713 041 M
       Component: GSM-LL        H10 0077
       Revision: 0L0D5012    Serial number: 20180828000193
       ASAM Dataset: EV_GSMWaehlZFAU736 001017
       ROD: EV_GSMWaehlZFAU736.rod
    Address 82: Heads Up Display (J898)       Labels:* None
       Part No SW: 80A 919 617     HW: 80A 919 617
       Component: HeadUpDisplay H13 1640
       Coding: 4F01E0
       ASAM Dataset: EV_HudNSEIKAU736 001017
       ROD: EV_HudNSEIKAU736.rod
       VCID: 6A98CAC38D504C1F2A-803E
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 80A 907 541 B    HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 003022
       ROD: EV_ACC2BOSCHAU49X.rod
       VCID: 2502F9FF24CEA367C7-8070
    1538 - Sensor for Automatic Distance Control
              [FAULT_SENSOR_BLIND]
                        Reset counter: 213
                        Mileage: 4170 km
                        Date: 2019.04.25
                        Time: 08:49:53
                        Control Module temperature: 32 °C
                        Voltage terminal 15: 13.1 V
                        Velocity_vehicle_reference: 11.98 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.80 m/s²
                        Status_ACC_System: ACC_Off_MainSwitch_Off
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 80A 907 217 A    HW: 80A 907 217 A
       Component: BVS           H17 0050
       Coding: 0404020600000204012023A6CD0000FEB0F0C020C020
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
       VCID: 2404E4FB2FF45A6FD0-8070
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 80A 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 180416201156
       VCID: 689CB0CB935C7E0F3C-803C
       Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
       Component: TSG HFS003 0188
       Serial number: CLSM1RI8014QB
       Coding: 000D8B000000148040000020
       Component: TSG HBFS003 0188
       Serial number: CLSM1RI8014O0
       Coding: 228000042602
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 80A 907 590 A    HW: 80A 907 590
       Revision: --------
       Coding: 0EC002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001022
       ROD: EV_RearRadarS2BoschAU736.rod
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 177EC337EEA201F745-8042
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 02:38, VBatt start/end: 12.8V/12.8V)-----------
  11. #37
    Quote Originally Posted by edwyun View Post
    OK, not being able to find a ROD file for your Gateway is a separate/different problem than not being able to run a scan.
  12. #38
    Apr 2015
    Brazil
    Uwe, some autoscan completed, and some not (two ok, two not). Gateway list though, fails every time. For the record, same computer with zero problem on previous versions.
  13. Likes Uwe liked this post
  14. #39
    Mar 2019
    So, what should I do to correct the ROD file error?
  15. #40
    Are you giving the interface enough time to retrieve the VIN after you plug it in and/or turn on the ignition, before starting the autoscan? If so, please send support the .DLM files resulting from your autoscan with debug level set to 1024 in Options .
  16. Likes Uwe, Dana liked this post
