Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: Cannot Auto Scan with HEX-NET, USB, and VCDS 19.6.0
    Mar 2019
    Just auto updated the VCDS software on my laptop. I am using a HEX-NET enthusiast version. On VCDS, I tested the USB port via the laptop and the HEX-NET is found. However, when I try to auto scan, I get an error message:
    Scan: Auto-Detect
    Function not supported by the gateway
    VIN: xxx
    End------(Elapsed Time: 00:07, VBatt start/end: 12.9V/12.9V)-----
    Used to be able to auto scan, etc., with my setup before (2 months ago) with no problem.
    Can someone help?
    Mar 2019
    BTW, this is for a 2019 Audi SQ5.
    Mar 2019
    Just tried connecting with WiFi and using my smartphone/app. With auto-scan on the app, I get a different message: Can't check ASAM data in AP mode. Unable to reach server.
    Any thoughts?
    Car front hood is open ?
    Mar 2019
    No, it wasn't. Tried with ignition on as well as engine on too.
    What are the exact results when you do [Options] -> [Test] in VCDS with the HEX-NET connected to your PC via USB and plugged into the car?
  7. #7
    Quote Originally Posted by edwyun View Post
    Try again with the hood open - some newer models require the hood to be open for the diagnostics to connect...
  8. #8
    Should not affect the ability to do an Auto-Scan. The "Diagnostic Firewall" does not prevent reading data from modules, only writing to them.
  9. Likes Eric, PetrolDave, _Val, edwyun liked this post
  10. #9
    This is expected, you don't have access to the outside internet in AP mode, and it needs to download data from the server. You can either use a wifi tether, or you can take it back inside and now download the data with VCIConfig -> "Check for Updates"
  11. Likes Uwe, edwyun liked this post
  12. #10
    Mar 2019
    Will try again and let you know tonight.
