Cannot Auto Scan with HEX-NET, USB, and VCDS 19.6.0
   #22
jagpurr
C?ID=275617
Andy
OK will do,
I assume you mean the software.
The problem seemed to arrive with the firmware update but I may be wrong
as I think I did both on the same day.
Will let you know how I get on tomorrow.
Cheers
   #24
jagpurr
C?ID=275617
HI,
Downloaded latest sftware version and installed,
Carried out "port test " all ok
Carried out 10 x autoscans 5 fail with attached message 5 seemed to work ok ? Randomly.
Friday,14,June,2019,11:33:34:52854
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUZZZ4M5GD022610   License Plate:
Chassis Type: 4M-AU73 (4M - Audi Q7 (2016 >))
Scan: Auto-detect
Please Wait... 75%
VIN: WAUZZZ4M5GD022610   Mileage: 42988km-26711miles
Function not supported by the gateway.
End-----(Elapsed Time: 00:08, VBatt start/end: 12.3V/0.0V. VIgn 0.0V)------
Any suggestions?
   #25
Andy
Sector 7G
HC424490
Can you try testing with the engine running?
   #26
andyhud
C?ID=32695
Uwe \ Andy
This really seems to be a vcds software issue.
I have 18.9 and 19.6.0.6 running side by side in different installation directories on the same pc.
Using the same Hex-Net dongle.
Ive had 2 x 2017 A4s in the garage today. Doing autoscans on 19.6.0.6 fail. Close it and open 18.9 and do the autoscan and it works fine. Repeatable everytime.
Same pc (Windows 7 x86 with 4Gb ram, 250gb ssd).
The issue is easily recreatable. Just launch 19.6.0.6 and the issues occur. Close it and open 18.9 and everything is fine.
Andy
Interestingly enough, we have a 2017 A4 and haven't been able to re-create it on that, or any other car we've got, but we're in receipt of some debug files now that have useful clues.
andyhud
C?ID=32695
Thanks Uwe.
I'll try over the weekend.
Odd that you haven't been able to recreate yet I know Jagpurr and he has Hexv2 with same issue and the original OP too of this thread.
Surely cant be coincidence which all happened after 19.6 update.
Will test 19.6.0.7 and report back.
Thanks.
Andy
fzanicotti
Brazil
C?ID=201619
+1 with a Q5 MY2019. I'm getting different results each time: "not supported by gateway" and missing many modules in the list are the most common that I can remember of.
   #32
You try 19.6.0.7 too, please. The link is in post #29 of this thread.
jagpurr
C?ID=275617
Downloadea latest software and tested today.
Again did 10 scans , result 6 ok 4 fail with same message.
All ok scans seemed to be complete, but on two occasions
when you went to module list the "installed modules " lists wern't there?
computer details:-
Dell Inspiration laptop
64 bit 4g ram 2.5 Ghz
Windows 7 Pro.
Been using same laptop for a couple of years without any problems.
Saturday,15,June,2019,11:04:23:52854
VCDS Version: 19.6.0.7 (x64) HEX-V2 CB: 0.4505.4
Chassis Type: 4M (4M - Audi Q7 (2016 >))
Scan: Auto-detect
End----------(Elapsed Time: 00:10, VBatt start/end: 12.2V/12.2V)-----------
andyhud
C?ID=32695
Hi Uwe and team
I can confirm that 19.6.0.7 seems to be working much better than 19.6.0.4 and 19.6.0.6. I have not got a "Function not supported by the Gateway" error and when I do full autoscans they now complete with ALL modules in my car without issue.
My only observation is when the full scan is running on 19.6.0.7 it seems to always start with Module 17 now, whereas in 18.9.x it always started with Engine (Module 01)
Not sure what you changed, but everything seems to be better
I'm going to keep 18.9 installed for the time being "just in case"
Appreciate your support
Andy
   #36
edwyun
C?ID=159254
So I updated to VCDS version 19.6.0.7 and ran an autoscan via USB using HEX-NET. While the scan appeared to finish, i did get the same error message pop up as before (see post #17). I've attached the scan results below:
Sunday,16,June,2019,11:25:28:12197
VCDS Version: 19.6.0.7 (x64)  HEX-NET CB: 0.4505.4
VIN: WA1C4AFY4Kxxxxxxx   License Plate:
Mileage: 7666km-4763mi   Repair Order:
Chassis Type: FY-AU49 (80A)
Scan: 01 02 03 08 09 13 15 16 17 19 1B 29 32 36 39 3C 42 44 46 47
          52 5F 6C 6D 74 75 81 82 8B A5 A9 BB BC CA CF D6 D7
VIN: WA1C4AFY4Kxxxxxxx   Mileage: 7666km-4763miles
74-Chassis Control -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD)       Labels: None
   Part No SW: 80A 907 559 D    HW: 06M 907 309 L
   Component: V6 3.0l TFSI  H10 0002
   Revision: BAH10000
   Coding: 2A2A0032256E090E34380000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS01180A907559D 001002
   ROD: EV_ECM30TFS01180A907559D.rod
   VCID: 302C18AB6B0CF6CF24-8064
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 158 A    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H05 1005
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 2A180AC34DD08C1FEA-807E
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 80A 907 379 K    HW: 80A 907 379 A
   Component: ESP9 Premium  H13 0775
   Coding: 1CAA14BE30A20A98919E5895588458A2E5359A38280C50891A1A1A45A7AC59
   ASAM Dataset: EV_ESP9BOSCHCMP 002013
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 373E23B78E6221F765-8062
419584 - TPMS Warning; Rear Left Tire
          C1059 00 [040] - Flat
                    Mileage: 6016 km
                    Date: 2019.05.24
                    Time: 17:31:09
                    81 00 80 10 89 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 06
   Part No SW: 80A 820 043 N    HW: 80A 820 043 N
   Component: Klima Zone 3  H60 0251
   Coding: 6608090D5548010D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 281CF0CB53DCBE0FFC-807C
   Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002641759
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: A7201C3900PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158 A    HW: 80A 919 158 A
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0313
   Coding: 07500363E0691CCD050D51199CAE9CB9130B3D090000000000000000600016010A6301ABA2B70A
   ASAM Dataset: EV_BCM1BOSCHAU736 019008
   ROD: EV_BCM1BOSCHAU736_019.rod
   VCID: 034687678A3ABD5789-8056
   Subsystem 1 - Part No SW: 80B 955 119 A    HW: 80B 955 119
   Component: 426 LL 180814  040 0581
   Serial number: 00000001808102106321
   Coding: FFC7F7
   Serial number: 21623284X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
   Component: E1 - LDS  H06 0008
   Serial number: 29 08 2018  82410261
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z00F202
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20180904231553 01079
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE117081823310646
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 80A 947 135 AN    HW: 80A 947 135
   Component: Dachmodul Q5  H32 0330
   Serial number: Q00044904
   Coding: 0D0101
   Electrically Adjustable Steering Column:
   Subsystem 8 - Part No SW: 80A 907 705     HW: 80A 907 705
   Component: J866-EVLS-SG  H03 0100
   Serial number: WA132105000048332616
   Coding: 0A0700
   Subsystem 9 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2818000172217002
   Part No SW: 80A 907 561 B    HW: 8W0 907 561
   Component: LRR4          H10 0340
   Coding: B4779FF358FFEC05757A61A1
   ASAM Dataset: EV_ACCBOSCHAU49X 003022
   ROD: EV_ACCBOSCHAU49X.rod
   VCID: 271EF3F75EC2B177F5-8072
1542 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_BLIND]
                    Reset counter: 213
                    Mileage: 5757 km
                    Date: 2019.05.20
                    Time: 17:55:06
                    Control Module temperature: 59 °C
                    Voltage terminal 15: 12.7 V
                    Velocity_vehicle_reference: 8.47 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.59 m/s²
Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
   Part No SW: 80A 959 655 M    HW: 80A 959 655 M
   Component: AirbagVW30    054 0605
   Serial number: 003W2M00BRV%
   Coding: AECCFCC000800000A000003FF20C400000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: 3D32319FAC5E0BA7BF-8068
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 80A857705K0192S01609
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 80A857706K0180S01447
   Coding: 80000D
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J18000A375B0O
   Coding: 303039
   Subsystem 4 - Part No SW: -----------    HW: 480 000 108 18
   Serial number: 357000000001756C733G
   Subsystem 5 - Part No SW: -----------    HW: 480 000 108 18
   Serial number: 3580000000029C91133D
   Subsystem 6 - Part No SW: -----------    HW: 480 033 006 18
   Serial number: 351001C101C430711E9W
   Subsystem 7 - Part No SW: -----------    HW: 480 033 006 18
   Serial number: 352001C101C3FC30FD3F
   Subsystem 8 - Part No SW: -----------    HW: 480 031 107 18
   Component: FrontSensor_D  002 0149
   Serial number: 355001C143DCC5E02A6M
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 031 107 18
   Component: FrontSensor_P  002 0149
   Serial number: 356001C143D508D05C27
   Central Sensor XY:
   Subsystem 10 - Part No SW: -----------    HW: 480 022 307 18
   Component: CentrSensorXY  000 0108
   Serial number: I0O0001C7297DB21F621
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 213
                    Mileage: 5758 km
                    Date: 2019.05.20
                    Time: 17:55:21
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 213
                    Mileage: 5758 km
                    Date: 2019.05.20
                    Time: 17:55:21
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 80A 907 129 CQ    HW: 80A 907 129 CQ
   Component: Lenks.Modul   H02 0005
   ROD: EV_SMLSKLOAU736_007_AU49.rod
   VCID: 79BAE58FF8F6F787D3-802C
   Part No SW: 8W5 920 890 E    HW: 8W5 920 890 E
   Component: FBenUSA       H20 0417
   Coding: 09CF96C53CB8CF0502B369601800400008000000
   ASAM Dataset: EV_DashBoardAU736 001032
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 45C2597FC48E4367E7-8010
   Part No SW: 80A 907 468 B    HW: 80A 907 468 B
   Component: Gateway       H05 0118
   Serial number: 15F01007412801
   Coding: 03010001000006405407000000590032FC9A00079A0000000175078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003160
   ROD: N/A
   VCID: 2D1201DF7C3E9B270F-8078
   Subsystem 1 - Part No SW: 80A 951 523 E    HW: 80A 951 523 E
   Component: J453 MFL  H06 0004
   Serial number: 20180828071135 00009
   Serial number: 4217346000
No ASAM data for: "EV_Gatew31xAU65x" ()
131687 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 201
                    Mileage: 4421 km
                    Date: 2019.04.29
                    Time: 13:35:37
131702 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Frequency: 19
                    Reset counter: 210
                    Mileage: 2912 km
                    Date: 2019.04.10
                    Time: 18:45:12
   Part No SW: 8W0 907 144 J    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0710
   Serial number: 30303030303030
   ASAM Dataset: EV_SCUZFLSAU49X 002019
   ROD: EV_SCUZFLSAU49X_002.rod
   VCID: 42C84263D5A0745FC2-8016
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 C    HW: 80A 907 397 C
   Component: LCM_MLBevo    H07 0022
   VCID: 2F2E1BD77632E9373D-807A
Address 32: Differential Locks (J187)       Labels: None
   Part No SW: 8W0 907 163     HW: 8W0 907 163
   Component: QSP QCU Gen2  H08 0060
   Revision: 5WK12700    Serial number: 605824603200507
   Coding: 0001
   ASAM Dataset: EV_TVDCQSP22 001008
   ROD: EV_TVDCQSP22.rod
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0042
   Serial number: 12A14825300992
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
Address 39: Right Light (J1023)       Labels: None
   Part No SW: 80A 907 566 A    HW: 80A 907 566
   Component: MRR1Rear      H20 0431
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 2B160FC7422A951711-807E
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS001 0188
   Serial number: CLSM1RIA017FL
   Coding: 005D8B015E00148000010032
   VCID: 40CC486BDBAC664FD4-8014
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000561746
   Coding: A1112101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 342414BB9F14CAEF40-8060
   Part No SW: 4N0 907 064 BP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H14 0145
   Coding: 013400004FB100C0650BA0006C01980203004000810026502F0000000F04803F001E0001000000
   Shop #: WSC 00008 444 00000
   ASAM Dataset: EV_BCM2CONTIAU651 008007
   ROD: EV_BCM2CONTIAU651_008.rod
   VCID: 7EB0F693E1D8D0BFE6-802A
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY181901QRM
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099352079
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11116528
   Rear Spoiler Adjustment:
   Part No SW: 80A 035 223 A    HW: 80A 035 223
   Component: MIB2_amp_P_Q5 H03 0420
   Revision: 00000001    Serial number: AUZ8ZAJTK034AWU
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 197AC50F18B6178773-804C
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS001 0188
   Serial number: CLSM1RI8011H0
   Coding: 005D8B015E00148000010030
   VCID: 3FCE4B97A65219B7AD-806A
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 880 C    HW: 8W5 035 880
   Component: MU-P-LNS-US   035 1316
   Serial number: A798I0J9450527
   Coding: 012456020000000051220002041A00332F001AE401700904BE
   Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9JBL05TPD
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 18071800000000000776
   Component: Gracenote2  --- 3013
3086 - Antenna for Telephone Mount
          B1564 01 [008] - Electrical Failure
                    Reset counter: 226
                    Mileage: 3170 km
                    Date: 2019.04.14
                    Time: 10:36:14
                    Voltage terminal 30: 12.0 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
7219 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                    Fault Frequency: 18
                    Reset counter: 223
                    Mileage: 3117 km
                    Date: 2019.04.13
                    Time: 18:10:45
                    Voltage terminal 30: 14.3 V
                    BAP-BAP_Function_ID: 10
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JN005384
   Coding: 02240602BE0FA10038004000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
   VCID: 352229BF946ED3E777-8060
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: A2-C748-5750-5
   Coding: 0730
   VCID: 48DC504BF39C5E0F1C-801C
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 80A 907 777 M    HW: 80A 907 777 C
   Component: Fahrwerk-SG   H37 1214
   Serial number: 0708180406
   Coding: 5C603832F8
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 3B363F87B24A059781-806E
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130351838
   Coding: 303030
32776 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
                    Reset counter: 192
                    Mileage: 6062 km
                    Date: 2019.05.25
                    Time: 08:01:31
   Part No SW: 4K1 035 283 A    HW: 4K1 035 283 A
   Component: ConBox        H08 0100
   Serial number: 005CCA12F040072
   Coding: 01C020FE4040800000
   ASAM Dataset: EV_ConBoxAU651 001004
   ROD: EV_ConBoxAU651_001_AU49.rod
   VCID: 2600FEF359C8A87FCE-8072
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 80B 713 041 M    HW: 80B 713 041 M
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 20180828000193
   ASAM Dataset: EV_GSMWaehlZFAU736 001017
   ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 80A 919 617     HW: 80A 919 617
   Component: HeadUpDisplay H13 1640
   Coding: 4F01E0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736.rod
   VCID: 6A98CAC38D504C1F2A-803E
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541 B    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 003022
   ROD: EV_ACC2BOSCHAU49X.rod
   VCID: 2502F9FF24CEA367C7-8070
1538 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_BLIND]
                    Reset counter: 213
                    Mileage: 4170 km
                    Date: 2019.04.25
                    Time: 08:49:53
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 13.1 V
                    Velocity_vehicle_reference: 11.98 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.80 m/s²
                    Status_ACC_System: ACC_Off_MainSwitch_Off
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H17 0050
   Coding: 0404020600000204012023A6CD0000FEB0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 2404E4FB2FF45A6FD0-8070
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 80A 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 180416201156
   VCID: 689CB0CB935C7E0F3C-803C
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS003 0188
   Serial number: CLSM1RI8014QB
   Coding: 000D8B000000148040000020
   Component: TSG HBFS003 0188
   Serial number: CLSM1RI8014O0
   Coding: 228000042602
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 80A 907 590 A    HW: 80A 907 590
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_RearRadarS2BoschAU736.rod
   Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
   Component: LED1L         H09 0008
   VCID: 177EC337EEA201F745-8042
   Component: LED1R         H09 0008
End----------(Elapsed Time: 02:38, VBatt start/end: 12.8V/12.8V)-----------
OK, not being able to find a ROD file for your Gateway is a separate/different problem than not being able to run a scan.
fzanicotti
Brazil
C?ID=201619
Uwe, some autoscan completed, and some not (two ok, two not). Gateway list though, fails every time. For the record, same computer with zero problem on previous versions.
edwyun
C?ID=159254
So, what should I do to correct the ROD file error?
   #40
Eric
HC800000
Are you giving the interface enough time to retrieve the VIN after you plug it in and/or turn on the ignition, before starting the autoscan? If so, please send support the .DLM files resulting from your autoscan with debug level set to 1024 in Options .
