Cannot Auto Scan with HEX-NET, USB, and VCDS 19.6.0
   #41
Andy
Sector 7G
HC424490
I just tested with my really slow Winbook using 19.6.0.7 on my 2018 A3 e-tron and repeated AutoScans worked fine, selecting either Auto-Detect or the chassis code (FF). Multiple Gateway Installation List clicks also worked fine.
   #42
OK, who is still having problems with not being able to do Auto-Scans with 19.6.0.7?
Chime in here. I think we have a potential fix we'd like you to try.
fzanicotti
Brazil
C?ID=201619
I do and I'm available to test it.
   #44
OK, I just put your HEX-NET on the Alpha channel temporarily. Please check for updates; it should update to CB 0.4506. Once it does, please test on the problem car (2019 Q5, IIRC) and let us know the results.
edwyun
C?ID=159254
Are you giving the interface enough time to retrieve the VIN after you plug it in and/or turn on the ignition, before starting the autoscan? If so, please send support the .DLM files resulting from your autoscan with debug level set to 1024 in Options .
Sorry for the delay - yes, I am giving it enough time. I wlll try to get the .DLM file after I autoscan with the debug level at 1024.
   #46
fzanicotti
Brazil
C?ID=201619
Uwe, sorry for the late response (on a flight to Miami as I type). Straight to the point: USB tested fine, WiFi not so much (failed once, in three attempts). One thing to mention is that I did update the interface as instructed, but was under the impression something went wrong with the procedure (every time I checked for updates right after, there were "new" ROD updates available, which seemed repetitions). Unfortunately, I'll be away for a few days, but sure I can keep testing as soon as I'm back at home.
   #48
Sounds like a major improvement though?
ROD updates aren't needed or used by VCDS, they only affect VCDS-Mobile.
Let us know when you're back.
fzanicotti
Brazil
C?ID=201619
It sounds because to me it is. ;-)
I'll let you know when I'm back and available (after July 1st).
Thanks Uwe, glad to know.
   #50
BavarianCare
Ireland
C?ID=11022
Where is it possible to download v18.9? I just wish to have both versions installed.
I deleted by accident.
Is there software archive on main site?
   #54
jagpurr
C?ID=275617
Hi Uwe,
Still having same problems with my HEX-V2
Will that new version help me?
Thanks
   #55
Hi Uwe,
Thanks
I just put your HEX-V2 on the Alpha channel. Check it for updates; that should bump you onto CB 0.4506. Please try that first and let us know if it makes any difference.
VASTech
Zalau, SJ, RO
C?ID=345137
Hi!
I have some issues aswell when try to connect to an AXR 2005 ECU.
Error attached. (Inv.Msg.Type:FFFFFFE)
If I restart program again, everything returns to normal.
Any help? Maybe a link to 18.9.1?
Thank you!
   #57
Hi!
Thank you!
This is clearly not a "Can't Auto-Scan" problem. More info please.
- Is this with your HEX-NET, or with the older HEX+CAN that you also have?
- Is this ECU in a car? If so, please tell us exactly what car it is in.
- Please make a Debug file and send it to Support.
[Options] -> Set Debug Level to 1024 -> [Apply]
Then do whatever is necessary to reproduce the problem. Once it occurs,
exit VCDS and send the file DEBUG-01.DLM to our Support e-mail please.
Dana
Western PA, USA
VASTech A.D.,
Thanks for the files. I replied to that e-mail from support a moment ago and sent you a PS shortly after.
Dana
Western PA, USA
VASTech A.D.,
I sent of yet another e-mail. If you happen to run any scans or testing this weekend feel free to bump this thread back up as a reminder for one of us to check Support mail.
Best,
Dana
   #60
NHN
C?ID=63355
Yeap still problematic, used with latest vcds & fw on Hexnet via had today on an 8P 2010 & 8T 2013, both had numerous autoscan failures which also seems to lock vcds out from using Hexnet until a few restarts of vcds & unplugging usb & disconnecting Hexnet from the laptop & car.
Seems if you forgoe autoscan & use direct module access, this works, bit if you try & fail autoscan, then try a direct module access, it either fails to load the module or takes ages to login to said module.
This has been happening for months even on 18.9, if I can provide any data to help, let me know.
Glad it's not an isolated incident, thought I was going mad.
