Mk5 retrofitted with 10channel Dynaudio and Discover Media - missing subwoofer slider
Christiank
C?ID=253485
Hey guys..
I've retrofitted 10channel Dynaudio system (2 speakers to each door and subwoofer ) I've seen some pictures on google with a Dynaudio menu?
Also I have no adjustment slider for my subwoofer - I only have "bass-middle-tweeter" sliders to adjust the sound but I've also seen some pictures with a slider for the subwoofer
siLc
Tallinn, Estonia
C?ID=330192
Well, after recently swapping out my DM for a newer unit, the new unit wasn't initally coded to have an external sound system present and the subwoofer slider was there. After coding/adapting to have a sound system present and functioning, the slider no longer wasn't there.
Christiank
C?ID=253485
I've coded my DM unit to fit the Dynaudio system on adaptations and long coding
Makes no logic sense that your DM did get subwoofer slider when not coded to external sound system and it disapered when you coded it to fit your system... Do you remember which value you had it byte 4 and 11 I think are the bytes for sound systems
Christiank
C?ID=253485
Thursday,13,June,2019,19:27:12:31035
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ1KZ5W036030   License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 3D 42 44 46 47 52 55 5F 61
          62 65 72 7D
VIN: WVWZZZ1KZ5W036030   Mileage: 377580km-234617miles
3D-Special Function -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 KC    HW: 028 101 190 3
   Component: R4 2,0L EDC G000SG  8457
   Revision: 12345678    Serial number: VWZ7Z0D0121566
   Coding: 0000072
   Shop #: WSC 00774 204 87198
   VCID: 6ED39C4A79EE3E3A3F-803A
19558 - Motor for Intake Manifold Flap (V157)
            P3102 - 000 - No Signal
                    RPM: 798 /min
                    Torque: 40.0 Nm
                    Voltage: 13.98 V
                    Bin. Bits: 00101100
                    Torque: 168.0 Nm
                    Torque: 0.0 Nm
19557 - Motor for Intake Manifold Flap (V157)
            P3101 - 000 - Open or Short to Ground
                    RPM: 798 /min
                    Torque: 38.0 Nm
                    Voltage: 13.91 V
                    Bin. Bits: 00101100
                    Torque: 166.0 Nm
                    Torque: 0.0 Nm
17075 - Fan 1 Control Circuit
            P0691 - 000 - Short to GND
                    RPM: 798 /min
                    Torque: 38.0 Nm
                    Voltage: 13.98 V
                    Bin. Bits: 00101100
                    Temperature: 56.7°C
                    Duty Cycle: 9.6 %
Readiness: 0 0 1 1 1
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: 113B600D09250000880B06E790190042A108F080
   Shop #: WSC 19427 133 00001
   VCID: 75E1B326DCB80DE2FE-8020
   Part No SW: 1K8 907 044 CE    HW: 1K8 907 044 CE
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 001000C002
   Shop #: WSC 00020 999 12345
   VCID: 74E78E22DFC214EAC9-8020
   Part No SW: 1K0 937 087 BA    HW: 1K0 937 087 AL
   Component: BCM PQ35  H+  112 0903
   Revision: AF112771
   Coding: 47180BB8C421E5E00008008C2000890707F10080637D8540E44C60000041
   Shop #: WSC 33361 790 00056
   VCID: 71E98736A8D021C222-8024
   Subsystem 1 - Part No SW: 1K1 955 119 B    HW: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  12  0401
   Coding: 00FFD5
   Component: RLS 140712 05  54  0403
   Coding: 0750AD
01134 - Alarm Horn (H12)
                    Reset counter: 9
                    Mileage: 377581 km
                    Date: 2019.06.13
                    Time: 19:22:54
                    Voltage: 13.95 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331618400023
   Coding: 0031151001
   Shop #: WSC 00066 790 00321
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 377D792E8E34BFF22C-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW35)
   Part No SW: 1K0 909 605 D    HW: 1K0 909 605 D
   Component: 01 AIRBAG VW8   022 0600
   Revision: 05022000    Serial number: 0033JD0F8V28
   Coding: 0012337
   Shop #: WSC 01371 785 00200
   VCID: 2D515B46B468052246-8078
   Subsystem 1 - Serial number: 6332MSME4C4A5203
   Subsystem 2 - Serial number: 6342MSME74384E02
   Subsystem 3 - Serial number: 6351HSME32087E02
   Subsystem 4 - Serial number: 6361HSME4D0B5C02
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20180828100080
   Coding: 3180000000
   Shop #: WSC 01286 386 08256
   VCID: 020BD8FA95762A5ACB-8056
   Part No SW: 1K8 920 885 G    HW: 1K8 920 885 G
   Component: KOMBI         H03 1008
   Coding: 170F090000
   Shop #: WSC 01234 567 56789
   VCID: 3B75651EB21C9B92C8-806E
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 200917F1001107
   Coding: 350032
   VCID: 7BF5A51EFA9C5B9288-802E
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 02018B6B74745D545420363E00
   VCID: 2D515B467468052246-8078
   Component: IMMO          H03 1008
   Shop #: WSC 00020 999 00000
   VCID: 6ADB905A8D06D21A63-803E
Address 3D: Special Function        Labels: None
   Part No SW: 1F9 909 919 A    HW: 1F9 909 919 A
   Component: MultifunctionDevice 0067
   Revision: 00H03000    Serial number: 00000000000435
   Coding: 390037
   Shop #: WSC 01342 020 12345
   VCID: 3663742A413E46FA37-8062
   Subsystem 1 - Part No: 6C0 959 442 C
   Component: E221__MFL-DC1
   Part No SW: 5K0 959 701 J    HW: 5K0 959 701 J
   Component: Tuer-SG         009 2105
   Coding: 0004351
   VCID: 39797F167020A982DA-806C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 74     3501
   Revision: 00H22000
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0078943
   VCID: 285FAA52538A200AB5-807C
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0004350
   VCID: 33654D3E524C53D210-8066
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000003
   Shop #: WSC 01392 785 00200
   VCID: 74E78E2217C214EAC9-8020
01537 - Vehicle Level Sensor; Supply Voltage
            007 - Short to Ground
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0472
   Serial number: VWZAZ2U0922832
   Coding: 02130601AA0000000111110300880A009F0106D4002001004F
   Shop #: WSC 00012 790 50316
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 2541A36624983D628E-8070
   Subsystem 1 - Part No SW: V03 825 254 C    HW: -----------
   Component: ECE DL3 19/20  --- 1115
6714 - Databus
                    Reset counter: 9
                    Mileage: 377581 km
                    Date: 2019.06.13
                    Time: 19:22:59
                    Voltage terminal 30: 13.9 V
   Component: Batt.regelung H56 1682
   Coding: F20008FE
   Component: J367-BDM  H07 0180
   Serial number: 32007215191491309407
Address 62: Door, Rear Left        Labels: None
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000208
   Shop #: WSC 01357 011 1012551
   VCID: 356173265C384DE23E-8060
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 30000000060897
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
Address 72: Door, Rear Right        Labels: None
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000208
   VCID: 34674E22574254EA09-8060
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Revision: 00700000    Serial number:
   VCID: 2C5756428F720C2A51-8078
End-------------------------(Elapsed Time: 03:17)--------------------------
Here's my autoscan
siLc
Tallinn, Estonia
C?ID=330192
Here's my DM coding to compare.
   Component: MU-S-ND-ER    H41 0475
   Serial number: VWZAZ2U0923338
   Coding: 02740401AA00000011111203000908231F0100C400200100CC
   Shop #: WSC 12345 123 98765
   ROD: EV_MUStd4CTSAT_VW46.rod
   VCID: 25170C24C56A487F997-8070
downtime
C?ID=280813
Are you sure the digital amplifier is compatible with the MIB unit?
Christiank
C?ID=253485
tried to put all variations of the 2 bytes for sound setup and nothing did the job to get 4 sliders - sadly..
It should be since it comes from new facelift Beetle
karldietmann
C?ID=339222
@siLc And @Christiank I did the same retrofit and the audio sounds „lean“. Worse than without amp. After swapping to another DM unit, the sound improved a LOT. Exact same coding and adaptions. Thats why I think it may be a dataset issue. Since you guys have the exact same DM as I; could you do me a huge favor and go to VCDS -> Information Electronics -> Advanced ID -> „Dataset Number“ and tell me what value it reads there?
Cuzoe
C?ID=279487
It is all in the datasets... some info here...
Admins... please delete if these links are not allowed, and I will consider myself warned.
AINils
Germany (AIB)
C?ID=56975
          62 65 72 7D
   Coding: 0000072
                    RPM: 798 /min
                    Torque: 40.0 Nm
                    Voltage: 13.98 V
                    Bin. Bits: 00101100
                    Torque: 168.0 Nm
                    Torque: 0.0 Nm
                    RPM: 798 /min
                    Torque: 38.0 Nm
                    Voltage: 13.91 V
                    Bin. Bits: 00101100
                    Torque: 166.0 Nm
                    Torque: 0.0 Nm
                    RPM: 798 /min
                    Torque: 38.0 Nm
                    Voltage: 13.98 V
                    Bin. Bits: 00101100
                    Temperature: 56.7°C
                    Duty Cycle: 9.6 %
   Revision: 00H46001
   Revision: 00001K05
   Coding: 001000C002
   Revision: AF112771
   Coding: 00FFD5
   Coding: 0750AD
                    Reset counter: 9
                    Mileage: 377581 km
                    Date: 2019.06.13
                    Time: 19:22:54
                    Voltage: 13.95 V
                        Term 50 Off
   Coding: 0031151001
   ROD: N/A
   Coding: 0012337
   Coding: 3180000000
   Coding: 170F090000
   Coding: 350032
   Revision: AA001002
   Coding: 390037
   Coding: 0004351
   Revision: 00H22000
   Coding: 0004350
   Coding: 0000003
6714 - Databus
                    Reset counter: 9
                    Mileage: 377581 km
                    Date: 2019.06.13
                    Time: 19:22:59
   Coding: F20008FE
   Coding: 0000208
   Coding: 0000208
Here's my autoscan
Try in 5F Bte 11 to value "06", this value isn't documented, but worked fine in my Golf 5 with Dynaudio and DM PQ Retrofit ;-)
@Cuzoe Sound Dataset in DM PQ are different to ZR (MQB) Units. There are no differences as these values are in Firmware of the device in a "Sound table"
Cuzoe
C?ID=279487
@AINils Ugghhh, old cars... I never even think of them, haha.
karldietmann
C?ID=339222
@Cuzoe thanks anyway!
@Christiank thanks for the AutoScan, however it doesn't contain that information. You'd have to use VCDS and go to Advanced ID...
I tried the suggested coding value "06", it didn't make a difference :-(
karldietmann
C?ID=339222
Sure.
Samstag,04,M‰rz,2023,09:18:30:13079
VCDS -- Windows-basierter VAG/VAS-Emulator l‰uft auf Windows 10 x64
VCDS Version: PCI 22.3.1.7  HEX-V2 CB: 0.4623.4
Datenstand: 20220530 DS338.0
www.vcdspro.de
Fahrzeug-Ident.-Nr.: WVWZZZ1KZAM697495   KFZ-Kennzeichen: M-MM8533
Kilometerstand: 293500km   Reparaturauftrag:
Fahrzeugtyp: 1K-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 1C 25 2B 2E 36 3C
          3D 42 44 46 47 4F 52 53 55 5F 61 62 65 69 6C 72 7D A5 A6 B9
Fahrzeug-Ident.-Nr.: WVWZZZ1KZAM697495   Kilometerstand: 293500km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
14-Radd‰mpfung -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: Fehler 0010
18-Standheizung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: Fehler 0010
1C-Fahrzeuglageerk. -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
2B-Lenks‰ulenverrieg. -- Status: i.O. 0000
2E-Media Player 3 -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
3D-Sonderfunktionen -- Status: nicht erreichbar 1100
42-T¸relektr. Fahrer -- Status: Fehler 0010
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
4F-Zentralelektrik II -- Status: i.O. 0000
52-T¸relektr. Beifahr. -- Status: Fehler 0010
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: Fehler 0010
5F-Informationselek. I -- Status: i.O. 0000
61-Batterieregelung -- Status: i.O. 0000
62-T¸relektr. hi. li. -- Status: i.O. 0000
65-Reifendruck -- Status: i.O. 0000
69-Anh‰nger -- Status: i.O. 0000
6C-R¸ckfahrkamera -- Status: i.O. 0000
72-T¸relektr. hi. re. -- Status: i.O. 0000
7D-Zuheizer -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
A6-Mikrofon -- Status: nicht erreichbar 1100
B9-Zusatzanzeige-/Bedieneinheit -- Status: i.O. 0000
Adresse 01: Motorelektronik (CAX)       Labeldatei: DRV\03C-906-016-CAX.clb
   Teilenummer SW: 03C 906 016 AJ    HW: 03C 907 309 A
   Bauteil: MED17.5.5       A   6711
   Revision: LCH09---    Seriennummer:
   Codierung: 0000077
   Betriebsnr.: WSC 00028 028 00001
   VCID: 678A4DBFB36EE5436E6-8032
   VINID: 9E69EAAAA05BA9174624710914B1983704
Adresse 02: Getriebe        Labeldatei: DRV\0AM-927-769.clb
   Teilenummer SW: 0AM 300 050 D    HW: 0AM 927 769 D
   Bauteil: GSG DSG AG7     431 9062
   Revision: 00043014    Seriennummer: CU501110076325
   Codierung: 0000024
   Betriebsnr.: WSC 00788 648 00255
   VCID: 2A0CF48B60FC182BB18-807E
Adresse 03: Bremsenelektronik (J104)       Labeldatei:. DRV\1K0-907-379-60EC1F.clb
   Teilenummer SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Bauteil: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Codierung: 113B400D892B0001880F02ED911E004183FB507A
   Betriebsnr.: WSC 12345 678 98765
   VCID: 75B617F7F5C207D3ECA-8020
Adresse 05: Zugangs-/Startber. (J518)       Labeldatei:| DRV\5K0-959-434.clb
   Teilenummer SW: 5K0 959 434 K    HW: 5K0 959 434
   Bauteil: VWKESSYPQ35GP 093 1405
   Revision: 00093000    Seriennummer: 0403861509
   Codierung: 030C1C
   Betriebsnr.: WSC 12345 123 12345
   ASAM Datensatz: EV_KESSYPQ35G A02721
   ROD: EV_KESSYPQ35G_A02_VW32.rod
   VCID: 3D26CFD78DF29F93E4A-8068
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei:| DRV\5K0-907-044.clb
   Teilenummer SW: 5K0 907 044 GM    HW: 5K0 907 044 GM
   Bauteil: Climatronic   H19 1313
   Revision: 00001004
   Codierung: 0000100018
   Betriebsnr.: WSC 01357 011 00200
   ASAM Datensatz: EV_Climatronic A01010
   VCID: 7CA002D3D668569B934-8028
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\1K0-937-08x-09.clb
   Teilenummer SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Bauteil: BCM PQ35 M    122 0182
   Revision: BC122001
   Codierung: 20180E3FF829C3C060080088780089EC03F54E88F37D8DB3B2C46804E048
   Betriebsnr.: WSC 00020 790 12345
   VCID: 45D6A737E5A2D753BCA-8010
   Subsystem 1 - Teilenummer: 1K1 955 119 F  Labeldatei: DRV\1KX-955-119.CLB
   Bauteil: Wischer 01061  23  0512
   Codierung: 009F95
   Subsystem 2 - Teilenummer: 1K0 955 559 AH  Labeldatei: DRV\1K0-955-559-AG.CLB
   Bauteil: RLS 190410 05  54  0403
   Codierung: 0730AD
   Subsystem 3 - Teilenummer: 7N0 951 172
   Bauteil: Sensor, DWA 0  005 0402
   Codierung: 000000
2 Fehlercodes gefunden:
00380 - Steuerger‰t f¸r Sonderfahrzeuge (J608)
            004 - kein Signal/Kommunikation
             Umgebungsbedingungen:
                    Fehlerstatus: 01100100
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 214
                    Kilometerstand: 290642 km
                    Zeitangabe: 0
                    Datum: 2023.01.21
                    Zeit: 17:20:59
                        Kl.15 EIN
                    Spannung: 11.45 V
                        ein
                        ein
                        aus
                        aus
                        aus
01049 - Bordspannung Klemme 50
            011 - Unterbrechung
                    Fehlerstatus: 01101011
                    Fehlerpriorit‰t: 1
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 215
                    Kilometerstand: 290754 km
                    Zeitangabe: 0
                    Datum: 2023.01.23
                    Zeit: 07:59:32
                        Kl.15 EIN
                    Spannung: 11.65 V
                        ein
                        ein
                        aus
                        aus
                        ein
Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:| DRV\1Q0-919-475.clb
   Teilenummer SW: 7N0 919 475 F    HW: 5Q0 919 298 C
   Bauteil: PLA 3.0 12KH08 0007
   Seriennummer: ˇˇˇ305183615051
   Codierung: 1071167001
   Betriebsnr.: WSC 05311 115 00088
   ASAM Datensatz: EV_EPHVA3CVW428GP00 001005
   ROD: EV_EPHVA2CVW428GP00.rod
   VCID: 3E24C8DB80F4848BFD0-806A
1 Fehler gefunden:
13688835 - Datenbus empfangener Fehlerwert
          U1123 00 [008] - -
          [Steuerger‰t f¸r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
          Sporadisch - best‰tigt - gepr¸ft seit letzter Lˆschung
                    Fehlerstatus: 00000001
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 52
                    Kilometerstand: 293503 km
                    Datum: 2023.03.04
                    Zeit: 09:15:13
Adresse 13: Distanzregelung        Labeldatei: DRV\3AA-907-567.clb
   Teilenummer SW: 3AA 907 567 A    HW: 3AA 907 567
   Bauteil: AC201  RDW A    036 0170
   Revision: 00036000    Seriennummer: 00000000517519
   Codierung: 0010000
   VCID: 3828DEC3AE50BABB37C-806C
1 Fehler gefunden:
01316 - Bremsensteuerger‰t
            013 - bitte Fehlerspeicher auslesen - Sporadisch
                    Fehlerstatus: 00101101
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 52
                    Zeitangabe: 0
                    Datum: 2023.03.04
                    Zeit: 09:15:13
                    Anzahl: 15
Adresse 14: Radd‰mpfung (J250)       Labeldatei:. DRV\3C0-907-376.clb
   Teilenummer SW: 3C0 907 376 A    HW: 3C0 907 376
   Bauteil: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Seriennummer: 04060909130001
   Codierung: 030180
   Betriebsnr.: WSC 01324 020 00200
   VCID: 270A0DBF7FEE2543AE6-8072
3 Fehlercodes gefunden:
03263 - Funktionseinschr‰nkung
            000 - - - Warnleuchte EIN
                    Fehlerstatus: 11100000
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Zeitangabe: 0
                    Datum: 2023.03.04
                    Zeit: 09:14:34
                    Fehlercode: 7
                    Bin‰rwert: 00000000
00776 - Geber f¸r Fahrzeugniveau vorn links (G78)
            010 - Unterbrechung/Kurzschluss nach Plus
                    Fehlerstatus: 01101010
                    Fehlerpriorit‰t: 2
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Zeitangabe: 0
                    Datum: 2023.03.04
                    Zeit: 09:14:34
01769 - Geber f¸r Fahrzeugniveau vorn rechts (G289)
                    Fehlerpriorit‰t: 2
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Zeitangabe: 0
                    Datum: 2023.03.04
                    Zeit: 09:14:34
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5K0-959-655.clb
   Teilenummer SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Bauteil: AirbagVW10    037 0606
   Seriennummer: 003FKRA67B9M
   Codierung: 00003137
   Betriebsnr.: WSC 00066 000 00000
   ASAM Datensatz: EV_AirbaVW10SMEVW360 A01011
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B22C1CF93E691A3DAE-806E
   Crashsensor f¸r Seitenairbag Fahrerseite:
   Subsystem 1 - Teilenummer SW: 1KM 955 557     HW: 1KM 955 557
   Bauteil: S.Sens.Fahr.V  H01 ----
   Seriennummer: 3572MSME29572452ZZZT
   Crashsensor f¸r Seitenairbag Beifahrerseite:
   Subsystem 2 - Teilenummer SW: 1KM 955 557     HW: 1KM 955 557
   Bauteil: S.Sens.Beif.V  H01 ----
   Seriennummer: 3582MSME38166452ZZZT
   Crashsensor f¸r Seitenairbag hinten Fahrerseite:
   Bauteil: S.Sens.Fahr.H  --- ----
   Seriennummer: 3511HSME26024D21ZZZB
   Crashsensor f¸r Seitenairbag hinten Beifahrerseite:
   Bauteil: S.Sens.Beif.H  --- ----
   Seriennummer: 3521HSME661D4D21ZZZS
Adresse 16: Lenkradelektronik (J527)       Labeldatei:| DRV\5K0-953-569.clb
   Teilenummer SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Bauteil: LENKS.MODUL   016 0180
   Revision: --X01---    Seriennummer: 20200327200105
   Codierung: 301AA40000
   Betriebsnr.: WSC 65437 003 104857
   ASAM Datensatz: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 025C7C2BB48C206BD98-8056
   Steuerger‰t f¸r Multifunktionslenkrad:
   Subsystem 1 - Teilenummer SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labeldatei: DRV\3C8-959-537.CLB
   Bauteil: E221__MFL-TAT  H06 0023
   Seriennummer: 3241500482800065AE1B
   Codierung: 2D0000
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
   Teilenummer SW: 5K7 920 882 D    HW: 5K7 920 882 D
   Bauteil: KOMBI         H02 1103
   Seriennummer: 00000000000000
   Codierung: 111F3A0800
   ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 3828DEC3A2D0BABB37C-806C
1 Fehler gefunden:
13635328 - Funktionseinschr‰nkung wegen fehlender Botschaft
          U1111 00 [009] - -
          [Steuerger‰t f¸r Sonderfahrzeuge: keine Kommunikation]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Datum: 2023.03.04
                    Zeit: 09:14:35
Adresse 18: Standheizung        Labeldatei: DRV\1K0-815-007.clb
   Teilenummer: 5K0 963 272 B
   Bauteil: Standheizer     022 3907
   Revision: 00022000    Seriennummer: 09020188000000
   Codierung: 0031012
   Betriebsnr.: WSC 26056 001 104857
   VCID: 2F3AE59F5B1E7D03666-807A
Adresse 19: Diagnoseinterface (J533)       Labeldatei:. DRV\7N0-907-530-V2.clb
   Teilenummer SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Bauteil: J533  Gateway H56 1682
   Revision:   H56       Seriennummer: 200917F1001100
   Codierung: 352032
   VCID: 7BA201CFD3E651A39AE-802E
                    Fehlerpriorit‰t: 2
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Zeitangabe: 0
                    Datum: 2023.03.04
                    Zeit: 09:14:35
03753 - Steuerger‰t f¸r Mikrofon
                    Fehlerpriorit‰t: 2
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Zeitangabe: 0
                    Datum: 2023.03.04
                    Zeit: 09:14:39
Adresse 1C: Fahrzeuglageerk.        Labeldatei: DRV\1Kx-919-xxx-1C.lbl
   Teilenummer SW: 5N0 919 879     HW: 5N0 919 879
   Bauteil: Kompass         001 0001
   Revision: 00001000    Seriennummer: 1225223T719M04
   Codierung: 0000002
   VCID: 7EA408DBCCF4448BBD0-802A
Adresse 25: Wegfahrsperre (J334)       Labeldatei:| DRV\5K0-920-xxx-25.clb
   Teilenummer SW: 5K0 953 234     HW: 5K0 953 234
   Bauteil: IMMO          H02 1103
   Seriennummer:
   Codierung: 000007
   ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
   VCID: 6A8C348BACFCD82B718-803E
Adresse 2B: Lenks‰ulenverrieg. (J764)       Labeldatei:* DRV\5K0-905-861.clb
   Teilenummer SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Bauteil: ELV-PQ35      H21 0240
   Revision: 00000000    Seriennummer: 12000008013003
   Codierung: 4900000000000000
   Betriebsnr.: WSC 09003 957 00200
   ASAM Datensatz: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3038E6E34AA062FB7FC-8064
Adresse 2E: Media Player 3 (J650)       Labeldatei:. DRV\5N0-035-342.lbl
   Teilenummer SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Bauteil: SG EXT.PLAYER H19 0770
   Revision: A1001003    Seriennummer: 7666474107
   Codierung: 020100
   Betriebsnr.: WSC 33361 790 00076
   VCID: 2B02F18F630601234AE-807E
Adresse 36: Sitzverst. Fahr. (J810)       Labeldatei: 3C0-959-760.lbl
   Teilenummer SW: 3C8 959 760 F    HW: 3C8 959 760 F
   Bauteil: Sitzmemory    H02 1301
   Revision: 00H02000
   Codierung: 000039
   Betriebsnr.: WSC 12336 024 394758
   VCID: 3828DEC3A250BABB37C-806C
Adresse 3C: Spurwechsel (J1086)       Labeldatei:* Keine
   Teilenummer SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Bauteil: HRE3_Kl15_Mst H06 0150
   Seriennummer: 14520006521952
   Codierung: 5294C4A0
   ASAM Datensatz: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_VW36.rod
   VCID: 392EDBC799DAA3B3C82-806C
   Steuerger‰t 2 f¸r Spurwechselassistent:
   Subsystem 1 - Teilenummer SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Bauteil: HRE3_Kl15_Slv  H06 0150
   Seriennummer: 14520002162627
1 Fehler gefunden:
2240558 - Datenbus empfangener Fehlerwert
          U1123 00 [008] - -
          [databus error value received - ESP_33 - ESC_Verz_Reg_nicht_verfuegbar]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 40
                    Datum: 2023.03.04
                    Zeit: 09:15:12
Adresse 3D: Sonderfunktionen
nicht erreichbar
Adresse 42: T¸relektr. Fahrer (J386)       Labeldatei:| DRV\3C0-959-70X-GEN4.clb
   Teilenummer SW: 3C0 959 701 C    HW: 3C0 959 793 A
   Bauteil: TUER-SG FT    002 0307
   Revision: 12101005    Seriennummer: 0000900204
   Codierung: 0011FF
   Betriebsnr.: WSC 01383 790 50316
   ASAM Datensatz: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 28080E8372702A3BA7C-807C
   Slave Driver:
   Subsystem 1 - Teilenummer SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Labeldatei: DRV\1K0-959-70X-GEN4.CLB
   Bauteil: J388__TSG-HL  006 1401
   Seriennummer: 00000004943587
   Codierung: 000090
1 Fehler gefunden:
68105 - Funktionseinschr‰nkung wegen fehlender Botschaft
          U1111 00 [009] - -
          [Front CAN MFG]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Datum: 2023.03.04
                    Zeit: 09:14:36
Adresse 44: Lenkhilfe        Labeldatei: DRV\1K0-909-14x-GEN3.clb
   Teilenummer: 1K0 909 144 R
   Bauteil: EPS_ZFLS Kl. 205    3501
   Revision: 00H17000
   VCID: 392EDBC7955AA3B3C82-806C
Adresse 47: Soundsystem (R12)       Labeldatei: 5K0-035-456.clb
   Teilenummer SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Bauteil: KonzernAmp10K H09 6831
   Revision: --------    Seriennummer: EAA098C0078921
   ASAM Datensatz: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
Adresse 4F: Zentralelektrik II (J520)       Labeldatei:. DRV\1K0-907-532.clb
   Teilenummer SW: 7N0 907 532     HW: 7N0 907 530 AN
   Bauteil: EZE_2         H56 1682
   Codierung: 05090101
   VCID: 6FBA259F979E3D03266-803A
   Subsystem 1 - Teilenummer SW: 8R0 959 591 A    HW: 8R0 959 591
   Bauteil: J245EE20SKB13  H01 0220
   Seriennummer: 0123456789ABCDEFGHIJ
   Subsystem 2 - Teilenummer SW: 8R0 959 591 A    HW: 8R0 959 591
   Bauteil: J394EE20SKB13  H01 0220
Adresse 52: T¸relektr. Beifahr. (J387)       Labeldatei:| DRV\3C0-959-70X-GEN4.clb
   Teilenummer SW: 3C0 959 702 C    HW: 3C0 959 792 A
   Bauteil: TUER-SG BT    002 0307
   Revision: 14101005    Seriennummer: 0000888041
   Codierung: 0011FE
   ASAM Datensatz: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 290E0B87697A1333B82-807C
   Slave Passenger:
   Subsystem 1 - Teilenummer SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labeldatei: DRV\1K0-959-70X-GEN4.CLB
   Bauteil: J389__TSG-HR  006 1401
   Seriennummer: 00000004934929
   Codierung: 000090
1 Fehler gefunden:
          U1111 00 [009] - -
          [Front CAN MFG]
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Datum: 2023.03.04
                    Zeit: 09:14:36
Adresse 53: Feststellbremse (J540)       Labeldatei:| 56D-907-801.clb
   Teilenummer SW: 56D 907 801 B    HW: 56D 907 801 A
   Bauteil: EPB-4         H03 0005
   Revision: --------    Seriennummer: 00000000311268
   Codierung: 0F3C55
   ASAM Datensatz: EV_ParkiBrakeTRWVW411 002007
   ROD: EV_ParkiBrakeTRWVW411.rod
   VCID: 2A0CF48B6C7C182BB18-807E
Adresse 55: Leuchtweitenreg. (J745)       Labeldatei:. DRV\5M0-907-357-V3.clb
   Teilenummer SW: 5M0 907 357 F    HW: 7L6 907 357 C
   Bauteil: AFS-ECU       H05 0111
   Revision: --------    Seriennummer: --------------
   Codierung: 043200104F000000
   ASAM Datensatz: EV_HeadlRegulVWAFSPt 002016
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 372ADDFFAFCEB5C33E6-8062
   Subsystem 1 - Teilenummer: 4H0 941 329   Labeldatei: 3D0-941-329.CLB
   Subsystem 2 - Teilenummer: 4H0 941 329   Labeldatei: 3D0-941-329.CLB
1 Fehler gefunden:
13705990 - Datenbus empfangener Fehlerwert
          U1123 00 [137] - -
          [Fehlerwert im Signal NI2_Hoehe_VL_Roh]
          Warnleuchte EIN - best‰tigt - gepr¸ft seit letzter Lˆschung
                    Fehlerpriorit‰t: 6
                    Fehlerh‰ufigkeit: 1
                    Verlernz‰hler: 12
                    Datum: 2023.03.04
                    Zeit: 09:14:36
Adresse 5F: Informationselek. I (J794)       Labeldatei:| 5G0-035-MIB-STD2.clb
   Teilenummer SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Bauteil: MU-S-ND-ER    H41 0478
   Seriennummer: VWZAZ2U1579020
   Codierung: 02731001AA00000011111103808808001F0107C400200100CF
   Betriebsnr.: WSC 00020 999 12345
   ASAM Datensatz: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 251607B7056237539CA-8070
   Datentr‰ger:
   Subsystem 1 - Teilenummer SW: 5NA 919 866 AR    HW: -----------
   Bauteil: ECE AS 20/21  --- 1430
   Seriennummer: --------------------
Adresse 61: Batterieregelung (J840)       Labeldatei:. DRV\1K0-907-534.clb
   Teilenummer SW: 7N0 907 534     HW: 7N0 907 530 AN
   Bauteil: Batt.regelung H56 1682
   Codierung: F2040800
   VCID: 71BE23E781AA2BF3302-8024
   Subsystem 1 - Teilenummer SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Bauteil: J367-BDM  H07 0180
   Seriennummer: 00000000001490638271
Adresse 65: Reifendruck (J502)       Labeldatei: 3AA-907-273.clb
   Teilenummer SW: 3AA 907 273 H    HW: 5Q0 907 273
   Bauteil: RDKBERU30     H04 0012
   Seriennummer: 40000000368053
   ASAM Datensatz: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW36.rod
Adresse 69: Anh‰nger (J345)       Labeldatei:. DRV\1K0-907-383-V2.clb
   Teilenummer SW: 1K0 907 383 F    HW: 1K0 907 383 F
   Bauteil: Anhaenger     H09 0100
   Revision: 3A001001    Seriennummer: 00008200011550
   Codierung: 010D000100000000
   VCID: 3038E6E34A2062FB7FC-8064
Adresse 6C: R¸ckfahrkamera (J772)       Labeldatei:| 5Q0-907-441.clb
   Teilenummer SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Bauteil: VW428 RVC Mid H04 0040
   Codierung: 01640401A301000700
   Betriebsnr.: WSC 00020 999 39850
   ASAM Datensatz: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
Adresse 7D: Zuheizer        Labeldatei: DRV\1K0-963-235.lbl
   Teilenummer SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Bauteil: PTC-Element         0404
   Revision: 00800000    Seriennummer:
   Betriebsnr.: WSC 00000 000 00000
   VCID: 2D06FF9751120F1354A-8078
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
   Teilenummer SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Bauteil: MQB_B_MFK     H10 0610
   Seriennummer: 28011915K11249
   Codierung: 000307020000040500262347C0978900DB000E10004000
   ASAM Datensatz: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D8B623FA00F27B8FC-8014
Adresse A6: Mikrofon
nicht erreichbar
Adresse B9: Zusatzanzeige-/Bedieneinheit (J285)       Labeldatei:* DRV\5C5-919-527.clb
   Teilenummer SW: 5C5 919 527 E    HW: 5C5 919 527 E
   Bauteil: ZUSATZANZEIGE H02 0102
   Codierung: 05
   ASAM Datensatz: EV_Auxi_Disp_Unit_UDS_VDD 001010
   ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
   VCID: 3332E9EFBBB659E302E-8066
Ende--(Dauer: 02:35, Batt.-Spannung Start/Ende: 11.6V/11.6V. VIgn 0.0V)----
siLc
Tallinn, Estonia
C?ID=330192
Oh my, that's a heavily retrofitted Golf 6 :)
I have amp 5K0035456C from the factory and sound is good with the appropriate 680G DM PQ coding option (not built-in amp, not Dynaudio).
AINils
Germany (AIB)
C?ID=56975
Wow that car is heavily modified with new equipment. I think I know the issue in your case, you used wrong Amplifier for Golf ;-)
5C6 035 456 C is used for following models:
- Beetle
- Beetle Cabrio
- Jetta
- Passat (NMS)
- Scirocco
- Tiguan
So if there's Dataset for car with different chassis, sound can be worst. You should check if you use Jetta Dataset, which should be nearest body to your Golf. Or you use 5K0 Version, which I used in my Golf 5. With this Amp Sound was really good
karldietmann
C?ID=339222
Thanks for the input, guys. I suspect my DM to have issues (defective?) and will have a friend temporarily install it in his DynAudio-equipped car. I will report back.
@AINils the car is a Golf 6 Variant for which DynAudio wasn't an option. So I decided to install Scirocco DynAudio amp and speakers.
Maybe it will come in handy for other retrofitters - and I dont know a better place where to put it - so here some of my notes (no guarantee that this is correct - feel free to PM me if you wish to correct or add to it):
PQ platform Discover Media unit part numbers
Construction periodWithout DABWith DAB
2012 to Mid 20155C00356805C0035680A
Mid 2015 to Mid 20165C0035680B5C0035680C
Mid 2016 to Mid 20175C0035680D5C0035680E
Mid 2017 to date5C0035680F5C0035680G
  • List only considers VW brand
  • List only considers EU market
  • List only considers PQ platform
  • HW number always seems to equal SW number
PQ platform sound system speaker installations
When I decided to retrofit the "sound system" (= amp) option, it soon was clear to me that I should get the 10-Ch. system, because i wanted a subwoofer. But I didn't expect that there would be so many variations:
10-Ch. using 4 Ch. for Front and 4 Ch. for Rear and 2 Ch. for Subwoofer
10-Ch. using 6 Ch. for Front (4 speakers) and 2 Ch. for Rear and 2 Ch. for Subwoofer
10-Ch. using 6 Ch. for Front (6 speakers) and 2 Ch. for Rear and 2 Ch. for Subwoofer
10-Ch. using 6 Ch. for Front and 4 Ch. for Rear
11-Ch. using 6 Ch. for Front and 4 Ch. for Rear and 1 Ch. for Center
  • The fact that there are different speaker installations is the reason why the 10-Ch. amp needs to be flashed with the according data set. Chances are that buying a used 10 Ch. amp it may have the wrong data set. It will result in fault codes because the speaker impedances appear implausible.
  • The list lacks 8-Channel amplifiers
