Results 21 to 30 of 31
Thread: Fault code 17950
  1. #21
    Dec 2018
    Sweden
  2. Likes Jack@European_Parts, Uwe liked this post
  3. #22
    Dec 2018
    Sweden
    So:
    None of the components/sensors that should get their ground from this "220 Earth connection (sender earth), in engine wiring harness" has any continuity to ground.
    All have continuity between each other:
    G62 - Coolant tep. sensor
    G40 - Hall sensor
    G42 - MAP sensor
    N18 - EGR valve
    G28 - engine speed sensor is the only one I have not checked separatly
    I havent found any diagram for every ground point in the car - so I have cleaned the ones I found:
    Under the battery tray
    On the engine
    In the plenum chamber (front of the ECU)
    What does this even mean:
    "Earth connection (sender earth), in engine wiring harness"
  4. #23
    Dec 2018
    Sweden
    If this is correct - then I have a broken/damaged wire - or Im not getting whats wrong - how can any of it work if theres no ground??:
    http://web.mit.edu/dennis/www/vw/grounds.html
    I put my hubby to clean the plenum ground point when I had to run... and he tells me know that ground have been cleaned before!!
    Whaaat a....??!!
  5. Likes Uwe liked this post
  6. #24
    If it were mine, I'd probably run a new ground wire (even if only temporary) to the affected components, just to verify that this fixes the problem(s).
  7. Likes Jack@European_Parts, Orchid70 liked this post
  8. #25
    Dec 2018
    Sweden
    Shall do - hubby said the same =)
  9. Likes Uwe liked this post
  10. #26
    Dec 2018
    Sweden
    It did not help with ground wire. Same fault code on one of the sensors on the Throttle.
    Drove to a friend and got a good known VW Throttle to test with.
    I remembered to take a picture from the collections of the groundwires to the sensors... shall put it here later. Forgot to take picture of the ready made ground wire - but I used something called Heat Shrink Solder connectors and a 5 square mm wire, around 15 cm long piece to the ground connection by the ECU.
    Want to get home some VW heat shrink connectors, where can I find them in Europe?
    Going out to test the throttle.....
  11. #27
    Dec 2018
    Sweden
    Wrong size on the throttle - so have to find an other one to test with.
    Connection of the brown/blue wires from the sensors to the ECU connector (on the left in the picture):
    This is where I attached the ground wire.
  12. #28
    Dec 2018
    Sweden
    Fixed
    So - the car is fixed.
    It WAS the throttle - so called "VDO" looks like a pirate copy to me.
    Look at these two pictures. I took a part the VW original Throttle body in plan to change the electric inside of it. NOT easy so gave up that idea =)
    But - doing that - I could get a look at what a original throttle body electric connections looked like:
    First picture of the original:
    This is how the throttle body mounted in the car looked like:
    Lesson learned:
    Trust the fault code.
    Dont know why - but there is no nead for continuity to ground on wire number 108 on ECU.
    The numbers on Measuring block 062 - for accelerator pedal - are still looking same: 14 % on both sensors at rest - and climbing up when pressin the pedal - equally!
    At least for Golf IV - 1,6 engine code BCB.
  13. Likes Uwe, Jack@European_Parts, PetrolDave liked this post
  14. #29
    So did you fix the OXS heater fault yet?
  15. #30
    Dec 2018
    Sweden
    Jack - I forgot all about it.
    A fuse then, on the brown wire coming right from the ECU?
    What size would be correct? 10A?
    The other blue/yellow wire to the heater, is fused 10A.
    Also - I need to get home those special connectors for VAG, before doing this proper. Or would it be ok to use the same kind of heat shrink connectors I used for the ground point?
    Like these:
    https://www.ebay.com/itm/100Pcs-Heat...-/132699448065
    Thank you Jack =)
