Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Fault code 17950
Hybrid View
    Dec 2018
    Sweden
    Fault code 17950
    Golf IV Variant 2003
    Engine BCB
    EPC light lits first - after a while Engine light comes on.
    After restart - no MIL.
    Fault code: 17950 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
    Below I have erased the fault vode - the rest looks like this - after couple of test drives - the MIL on again:
    Monday,10,June,2019,17:16:55:18201
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    Dealer/Shop Name: Firma Johannes Bruun
    Workshop Code: 000 02013 000000
    VIN: WVWZZZ1JZ3W270756   License Plate: SDD744ROSSTECH
    Mileage: 224990km-139802mi   Repair Order:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: WVWZZZ1JZ3W270756   Mileage: 224990km-139802miles
    Address 01: Engine        Labels: 036-906-034-AZD.clb
       Part No: 036 906 034 DR
       Component:  MARELLI 4MV G      5957
       Coding: 00031
       Shop #: WSC 40150
       VCID: 6597B3CE2C75B7BF0DB-4B5C
       WVWZZZ1JZ3W270756     VWZ6Z0B0301606
    Readiness: 1010 0001
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 L
       Component: ABS FRONT MK60      0101
       Coding: 0001025
       Shop #: WSC 01266 785 00200
       VCID: 33331D96D721190F53F-51A8
       Part No: 1C0 909 605 A
       Component: 27 AIRBAG VW51 01   0006
       Coding: 12855
       Shop #: WSC 01266
       VCID: 221DE8D27DDB8087A89-5184
    00532 - Supply Voltage B+
       Part No: 1J0 920 806 B
       Component: KOMBI+WEGFAHRS. RB8 V24
       Coding: 05113
       VCID: 2615F4C211F37CA7C41-5184
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 01266
       VCID: 70B9D29AE3B762176ED-5184
       Part No: 1C0 959 799
       Component: 1F Komfortgerát HLO 0001
       Coding: 00259
       Shop #: WSC 01266
       VCID: 74B1DE8A97AF5E378A5-4B3C
       Component: 1F Tőrsteuer.FS KLO 0004
       Component: 1F Tőrsteuer.BF KLO 0004
       Component: 1F Tőrsteuer.HL KLO 0004
       Component: 1F Tőrsteuer.HR KLO 0004
                27-00 - Implausible Signal
    End----(Elapsed Time: 05:00, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    The Throttle body is changed sometime before - VDO.
    And Measuring block 062 looks like this with resting accelerator pedal - engine off:
    17:18:08 Group 062: Electronic Throttle (Sensor Values)
      4.9 %  Throttle Valve Sensor 1 (G187)
      94.4 %  Throttle Valve Sensor 2 (G188)
      14.0 %  Accel. Pedal Pos. Sensor 1 (G79)
      14.0 %  Accel. Pedal Pos. Sensor 2 (G185)
    17:18:08 Group 060: Electronic Throttle (Throttle Body Alignment)
      94.0 %  Throttle Valve Sensor 2 (G188)
      12.0  Throttle Valve Steps Counter
      ADP. O.K.  Throttle Body Alignment Status
    17:18:08 Group 061: Electronic Throttle
      0 /min  Engine Speed (G28)
         Battery Voltage (Terminal 30)
      27.1 %  Throttle Valve Angle
         00000  Operating Condition
    And with pedal on floor
    17:20:28 Group 062: Electronic Throttle (Sensor Values)
      79.0 %  Accel. Pedal Pos. Sensor 1 (G79)
      78.0 %  Accel. Pedal Pos. Sensor 2 (G185)
    % on both pedal position sensor 1 and 2 are the same! (Throttle position sensors % were moving as they should - this above was measured with engine off)
    Is the pedal sensor known to go bad or is there somewhere alse I should take a look before changing the pedal/sensor?
    Can the sensor be fixed?
    Thanks
    The fault code is for the sensor on the throttle body, not the pedal.
    If you have already replaced the throttle body, my bet is in a dodgy connection of some kind to the throttle body.
    In addition to Uwe's suggestion......
    A faulty OXS sensor heater circuit or consumer on power BUS can take out the throttle drivers in ECU sporadically or wipe them out entirely making people change the TV and pedal sensor unneeded and indeed could be the ECU being faulty now or even a wire harness from ECU to TV.
    I would unplug OXS sensors or fuse them real low to see if a heater shorting pops the circuit to protect ECU and open ECU and inspect for damage, you might be in time before it burns down.
    This problem while seems more reported in Bosch type controllers in this time period of production & indeed took place also with Simos and Marelli too!
    Dec 2018
    Sweden
    This is how the autoscan looks like - again =/:
    Wednesday,12,June,2019,14:34:56:18201
    VIN: WVWZZZ1JZ3W270756   License Plate: SAD799
    Mileage: 225040km-139833mi   Repair Order:
              76
    VIN: WVWZZZ1JZ3W270756   Mileage: 225040km-139833miles
       Coding: 00031
       Shop #: WSC 40150
                P1542 - 35-10 - Implausible Signal - Intermittent
    Readiness: 1000 0000
       Coding: 0001025
       Coding: 12855
       Shop #: WSC 01266
       Coding: 05113
       Coding: 00006
       Shop #: WSC 01266
       Coding: 00259
       Shop #: WSC 01266
    End----------(Elapsed Time: 05:02, VBatt start/end: 14.1V/14.1V)-----------
    Reason why I suspected accelerator pedal s ensors is this:
    Accelerator sensors give same %. Both say 14% when pedal not depressed - and both say ca 79% when its pressed on floor.
    I guess is time to take out the lambda sensors.
    Last edited by Orchid70; 06-12-2019 at 12:50 PM. Reason: Wrote down numbers in the picture
    Dec 2018
    Sweden
    I found the old fault codes I had from last summer when the car went into limp home and I do not like what I see, now when I know better:
    17591 - O2 sensor short to plus - intermittent
    17953 - Throttle valve controller - intermittent
    17962 - Throttle actuator - conditions for masic settings not met - intermittent
    Taking out the lambdas now!
    I have a friend who use to work for VAG and has his own garage now - he had NO idea of this, about the lambda sonds and how they get shorted, frying the ECM!
    Shiiit.
    Dec 2018
    Sweden
    Connector to the Throttle body is new. The locking pin was broken.
    Battery is not that very healthy. But I dont like those other fault codes in supply voltage and engine control module.....
  9. #8
    Dec 2018
    Sweden
    Yes?
    Sometimes I have hard time understanding you =) (Swedish or actually Finnish, you see - english is not my native language).
    Im trying to figure out how to manage to fuse the heated circuits, any bright ideas? Only way I can figure it - Id need to cut the wire somewhere.
    Sensors look good, wiring on them as well look good.
  10. #9
    Dec 2018
    Sweden
    Cannot erase the Address 03: ABS
    01304 Engine Controle Module - DTC precent
    Taking out the ECM to the local electric repair guy and see if we can see whats happened to it.
    And ordering both O2 sensors - is this the right thing to do in this point?
    Would it be a good idea to take it to the VAG dealer first to retrieve the code from ECM?
  11. #10
    Dec 2018
    Sweden
    Found the fault?!!
    Finelly ECU out - someone have been there before - the wire holder wasnt snapped round the loom.
    Pin number 101 is bent together to pin 100 on the ECU...
    Check the colour on some of the pins....
    ECU:
    Magnetti Marelli
    036906034DR
    61600.666.08
    Pictures of the pins:
