Results 1 to 2 of 2
Thread: C5 RS6 won't run readiness tests, did PO code them out?
    Jul 2017
    I have failed emissions, and want to solve this with the help of this group if possible.
    I bought this car without ever seeing it, and spent 5 months with it on the lift, it went together well, no leaks, no major issues. Power steering whined and I replaced the pump. After a few test drives I tried emissions, I will continue every 60 days until I get it to pass legally. I had no MIL so I thought I give it a shot.
    I found a blown fuse to SAI, replaced it, and pulled blower out and it works fine. Put a new relay in to be sure. I have 01101101 for readiness, no MIL on. I do not get SAI codes, currently have 0441 evap flow low. I am unable to run any readiness tests, (no script available)?
    I have my VAGCOM on a toughbook with bad LAN and wireless, so software is old. I have new version on it now, but says the cable is not up to date....
    I will get a new enthusiast version soon.
    How can I see if the SAI test is trying to run? Why when I run xxx77 I start test, but it doesn't show test on- or run blower. Is there some requirement I haven't met? car running, ebrake on.
    I am in CT, and plan to get somebody(Jack) to supply / code a new airbag controller. Maybe during the winter?
    Nothing else seems too concerning?
    What do you see?
    [Thursday,18,July,2019,20:57:56:63906
    VCDS Version: 15.7.1.0
    Data version: 20150904
    VIN: WUAPV54B63N904793   License Plate:
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
              75 76 77
    Address 01: Engine        Labels: 077-907-558-BCY.lbl
       Part No: 4D1 907 558 D
       Component: 4.2l V8/5VT     G   0003
       Coding: 0006752
       Shop #: WSC 13364 153 403078
       VCID: 2F6D1966BDE4EE46F4-5140
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 01L-927-156.lbl
       Part No: 4B0 927 156 FL
       Component: AG5 01L 4.2l5VT USA 0305
       VCID: 76E3EC02023E9F8E77-5140
    18265 - Load Signal
                P1857 - 003 - Error Message from ECU - Intermittent
       Part No: 4B0 614 517 AD
       Component: ESP 5.7 RS 6        2310
       Coding: 06697
       VCID: 63C5A556F1AC1A2620-5124
    01119 - Gear Recognition Signal
                35-10 -  -  - Intermittent
    Address 06: Seat Mem. Pass        Labels: None
       Part No: 4B0 959 760 C
       Component: Sitzmemory R1 BF    0205
       Coding: 00003
       VCID: 2D51036EE7E89C56C6-4B1A
                06-10 - Signal too High - Intermittent
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AR
       Component: A6-Klimavollautomat 0208
       Coding: 00010
       VCID: 6ADBC87216864B6EE3-2580
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 Q
       Component: Airbag 8.4EP        3001
       Coding: 0000707
       Shop #: WSC 00000 785 00200
       VCID: 3E7334226A8E17CE6F-5140
       Part No: 4B0 920 983 D
       Component: KOMBI+WEGFAHRS. VDO D13
       Coding: 03284
       Shop #: WSC 05314
       VCID: 2959F77ED30080762A-5140
       WUAPV54B63N904793     AUZ7Z0C2418783
    Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15945
       Shop #: WSC 08316
       VCID: 3365151601CCCAA690-4EEA
    13 Faults Found:
                35-00 -  -
                35-00 -  -
                35-00 -  -
    01369 - Alarm triggered by Hood Switch
                35-00 -  -
    01368 - Alarm triggered by Luggage Compartment Switch
                35-00 -  -
    01561 - Rear left door
                59-00 - Can't Unlock
    01574 - Alarm triggered by Door Contact Switch; Rear Right
                35-00 -  -
    01573 - Alarm triggered by Door Contact Switch; Rear Left
                35-00 -  -
    01366 - Opened Due to Crash Signal
                30-00 - Open or Short to Plus
    00951 - Tailgate Central Locking Motor Relay (J398)
                29-10 - Short to Ground - Intermittent
    01586 - Locking Cylinder Contact Switch; Passenger Side (F242); Close
    01585 - Locking Cylinder Contact Switch; Passenger Side (F242); Open
    01141 - Luggage Compartment Unlocking Switch (E165)
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0204
       Coding: 00001
       VCID: 2C570E6ADCF2955ED1-4B1A
       Part No: 4Z7 907 357
       Coding: 00050
       VCID: 040786CA14E2BD1E79-4B4C
    Address 56: Radio        Labels: 8E0-035-1xx-56.lbl
       Part No: 4B0 035 195 N
       Component: symphony II NP2    0400
       Coding: 00201
       Shop #: WSC 00003
       VCID: 2B550D76D9FC9266D8-5092
                49-00 - No Communications
    00856 - Radio Antenna
                36-00 - Open Circuit
    Address 75: Telematics        Labels: 8E0-035-616.lbl
       Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
       Component: Telematik USA1
       Coding: 0002003
       Shop #: WSC 08353 444 66568
       VCID: 2345E556E12C5A2660-5124
    01531 - Emergency Battery
                002 - Lower Limit Exceeded - MIL ON
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283
       Component: Parkingsyst. A6 RDW D08
       Coding: 01116
       VCID: 020B80D20EF6B32E4B-5140
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
    01548 - Sensor for Parking Aid; Rear Right (G206)
                37-00 - Faulty
    End-------------------------(Elapsed Time: 04:]
    I don't adapt used ABS or SRS units due to liability reasons & only new from dealer & encourage you to check with OEM and NHTSA for recalls since free.
    Vehicle Identification No. WUAPV54B63N904793
    Model Audi RS6 qu.
    RS6
    Date of production 02.07.2003
    Model year 2004
    Sales type 4B45EZ
    Engine Code BCY
    Transmission Code GAG
    Emission standard 0GL Emission standard TLEV
    Coding: 0006752
    Correct part......only way to know if FOD is to check code or try and see if you can run readiness code tests.
    Let's start with a scan that shows the actual DTC's okay?
    Please also post the OBD2 data 0x33-MODES 01-01, 03, 07, 09 if supported.
    Time to JPPSG to qualify FOD, however, if you had a blown fuse for SAI PUMP and no aforementioned SAI fault, that would imply tampering now wouldn't it?
    https://forums.ross-tech.com/showthr...ut-0x01-08-000
    Prepare to qualify!
  3. Likes DrPeter liked this post
