Results 1 to 10 of 11
Thread: VW Polo AW Blind Spot Detection Help
    Oct 2014
    Guys I have Retro fitted Blind Spot Detection to my polo but even though I don't have any faults its not working 100% correctly.
    Sometimes when driving the wing mirror glass detects vehicles and then it also detects nothing but lights up,its like its over sensitive and needs calibration.
    I spoke to the local vw dealers and the master tech said that there is no requirement to calibrate after checking the w/shop manual.
    I bought the Radars from ebay used from a vw polo and I have also asked Kufatec and they said that once you buy there kit the radars need calibration so who is right?
    In the 3C lane Change there is the options for...
    IDE00498-Resetting of all adaption values
    IDE01475-Resetting of all adaptions
    IDE02325-Reset to factory setting
    Just not sure what would happen using any of these...
    Can anyone help?
    cheers
    Scan
    Monday,10,June,2019,17:15:57:03210
    VCDS Version: 19.6.0.2  HEX-V2 CB: 0.4505.4
    Dealer/Shop Name: VCDS
    Workshop Code: 444 03743 000001
    VIN: WVWZZZAWZKU007157   License Plate: SL68XKS
    Mileage: 8982km-5581mi   Repair Order:
    Chassis Type: AW-VW27 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 17 19 3C 44 5F CA
    VIN: WVWZZZAWZKU007157   Mileage: 8982km-5581miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 025 M    HW: 04C 907 309 BB
       Component: R3 1.0l TFS   H20 6196
       Revision: D7H20000
       Coding: 0125003223041D080000
       Shop #: WSC 31414 790 00200
       ASAM Dataset: EV_ECM10TFS01104C906025M 002003
       ROD: EV_ECM10TFS01104C906025B_002_VW27.rod
       VCID: 2A0D01F4AC7FE1F7B45-807E
    Readiness: 1110 0001
       Part No SW: 0CW 300 042 D    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1606
       Revision: 00005008    Serial number: CU501806176987
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW27.rod
       VCID: 372B28806FCD4C1F3BB-8062
       Part No SW: 2Q0 614 517 AD    HW: 2Q0 614 517 N
       Component: ESC_base_vFGS H23 0223
       Serial number: 08514728180704
       Coding: 0A034C64354150B432FDAC1B24E142A649124D26226A242444541254452442659248B26444562424222A482AA251D64A3D8A6B52BC
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
       ROD: EV_Brake1BOSCHESPMQBA0.rod
       VCID: 70B9D39C4A23DB273A1-8024
    Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
       Part No SW: 2G0 907 044 L    HW: 2G0 907 044 L
       Component: Climatronic   H03 0501
       Coding: 0121000008000100011008010244010D0000000000000000000000000000
       Shop #: WSC 03743 444 00001
       ASAM Dataset: EV_ACClimaBHBMQBA0 004017
       ROD: EV_ACClimaBHBMQBA0_VW27.rod
       VCID: 2D070AE89D91F6CF517-8078
       Part No SW: 2Q0 937 090 A    HW: 2Q0 937 090
       Component: BCM A0 Std+   H98 0926
       Serial number: 00001817500231
       ASAM Dataset: EV_BCMA0 204001
       ROD: EV_BCMA0_204.rod
       VCID: 3039139C8AA39B277A1-8064
       Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
       Component: RLHS  052 0107
       Serial number: SAY18M07D11H03M24S29
       Coding: 0038DD
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 2Q2 959 881 D    HW: 2Q2 959 881 D
       Component: FHSG_DRV  001 0002
       Serial number: 00000000000021749146
       Coding: 1F0037
       Subsystem 3 - Part No SW: 2Q2 959 882 D    HW: 2Q2 959 882 D
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000021753752
       Coding: 058037
       Serial number: 000000000ZY181501S2X
       Serial number: 00000000000099190056
       Subsystem 6 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000022454493
       Coding: 1F0000
       Subsystem 7 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000022520572
       Coding: 070000
       Serial number: 000308418018181
       Coding: 0471155011
       ROD: EV_EPHVA18AU3700000_009_VW27.rod
       VCID: 4CC1676C064BDFC7669-8018
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3200600248FF8748949C8145004087
       VCID: 3E253DA440F77D57F8D-806A
       Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
       Component: VW22Airbag    010 0248
       Revision: --------
       Coding: 88CCC0C0000000005C5400CF008800000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 025D8954748FD9B7DC5-8056
       Subsystem 1 - Part No SW: -----------    HW: 442 061 207 18
       Serial number: 3577Y20B127578D2E47A
       Subsystem 2 - Part No SW: -----------    HW: 442 061 207 18
       Serial number: 3587Y20B127578D3D235
       Subsystem 3 - Part No SW: -----------    HW: 442 0B0 707 18
       Serial number: 351778299293EDC5510T
       Subsystem 4 - Part No SW: -----------    HW: 442 0B0 707 18
       Serial number: 35277829B293EDC3E465
       Subsystem 5 - Part No SW: -----------    HW: 442 132 705 18
       Component: FrontSensor_D  290 118A
       Serial number: 355AG11B5298CB11C69%
       Part No SW: 2G0 920 790 A    HW: 2G0 920 790 A
       Component: KOMBI         506 1701
       Coding: 20AD010821802600018872095001000000000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001026
       ROD: EV_DashBoardVDDMQBA0_VW27.rod
       VCID: 2517F2C8C561CE8F997-8070
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5344
       Serial number: 14061811602488
       Coding: 030100046F085600FA0002481C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 3D273AA84DF1664FE17-8068
       Component: 1-00-02-00-04
       Subsystem 2 - Part No SW: 2G0 959 442 K    HW: 2G0 959 442 K
       Component: E221__MFL-DC1  H02 0052
       Serial number: 39170002831130077484
       Coding: 25FFFF
       Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
       Component: J367-BDMBOSCH  H02 2011
       Serial number: 10088840
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
       Component: HRE3_Kl15_Mst H03 0051
       Serial number: 00000435986817
       Coding: 90014500
       ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
       ROD: EV_HREntryHellaGen3Kl15_001_VW48.rod
       VCID: 38292BBC62D34367321-806C
    Address 44: Steering Assist (J792)       Labels:* None
       Part No SW: 2Q2 909 144 J    HW: 2Q2 909 144 F
       Component: TRW_G4L_MQBA0 620 6030
       Serial number: 0646183CB4J1942
       Coding: 00000000000000000101020101000101000001
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
       ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
       VCID: 3A2D31B45CDF5177C45-806E
       Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
       Component: MU-S-ND-ER    853 0890
       Coding: 02720001BE00000041110101008808001F0500F601200000CF
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 323D199484AFA9370C5-8066
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZHV1564256
       Subsystem 2 - Part No SW: 5NA 919 866 R    HW: -----------
       Component: ECE AS 19/20  --- 1115
       Part No SW: 4M0 907 594 H    HW: 4M0 907 594
       Coding: 508000727001
       VCID: 3B2334B053E5687FDF3-806E
    End----(Elapsed Time: 01:19, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
    Adapmap
    ;SW:2Q0-907-686-A HW:2Q0-907-686-A --- Lane Change
    ;Component:HRE3_Kl15_Mst H03 0051, Coding:90014500
    ;EV_HREntryHellaGen3Kl15,001009,EV_HREntryHellaGen 3Kl15_001_VW48.rod
    ;Monday,10,June,2019,19:01:48:03210
    ;VCDS Version: Release 19.6.0 Data version: 20190529 DS308.0
    ;VCID: 38292BBC62D34367321-806C
    IDE00001-Production mode,OFF ,3
    IDE02332-Deactivate production mode,Deactivating ,3
    IDE80001-Analysis 1,not activated ,1
    IDE80011-Analysis 11,not activated ,1
    IDE80015-Analysis 15,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,42
    Elapsed Time: 00:01
    Tartu, Estonia
    I don't have experience with these radars, but I believe they aren't higher tech as golf 7 MidRangeRadars.
    Those don't need calibration, but they do need correct parameter dataset to function correctly. Calibration is done automatically while driving.
    The world is my oyster...
  3. Likes Uwe liked this post
    Oct 2014
    I took a scan of all these and wondered is there any way to switch on Dynamic Calibration?????
    ;SW:2Q0-907-686-A   HW:2Q0-907-686-A ---  Lane Change --- SA: 20103
    ;Component:HRE3_Kl15_Mst H03 0051, Coding:90014900
    ;EV_HREntryHellaGen3Kl15,001009,EV_HREntryHellaGen3Kl15_001_VW48.rod
    ;Thursday,13,June,2019,18:53:11:03210
    Group,Description,Actual
    IDE00018,Voltage terminal 15,14.08, V
    IDE00030,Status of actuator test,not active,
    IDE00075,Vehicle speed,0.00, km/h
    IDE00102,Control Module temperature,39.0, °C
    IDE00322,Status of basic setting,was not yet started,
    IDE00323,Security Access: Number of invalid keys,0,
    IDE00925,Yaw rate,0.01, °/s
    IDE01441,Back-up light,OFF,
    IDE01766-MAS01853,Distance impulses-Left front,0,
    IDE01766-MAS01854,Distance impulses-Right front,0,
    IDE01766-MAS01855,Distance impulses-Left rear,0,
    IDE01766-MAS01856,Distance impulses-Right rear,0,
    IDE02049,Trailer detected,not recognized,
    IDE02057-MAS10062,Dynamic calibration: status-Auto. calibration: distance travelled,419.00, km
    IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,100, %
    IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
    IDE02057,Dynamic calibration: status,OFF,
    IDE02219-MAS02471,Steering wheel angle: sign-Sign,Negative,
    IDE02219,Steering wheel angle: sign,0.00,
    IDE03619,System status,On,
    IDE05064,lane change assist. 2: supply voltage,14.08, V
    IDE05065,lane change assist. 2: temperature,36.0, °C
    IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,passive,
    IDE05067-MAS10332,Functional status of lane change assist.-Parking assistant,passive,
    IDE05070,Curve radius,17792, m
    IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,2,
    IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,362,
    IDE05077,Rain/light recognition sensor via data bus,installed,
    IDE05087,Dynamic angle offset lane change assist. 1,0.30, °
    IDE05088,Dynamic angle offset lane change assist. 2,0.40, °
    IDE06199-MAS01167,Indicator light for lane change assist. in instrument cluster-Actuation time,no control,
    IDE06199-ENG39349,Indicator light for lane change assist. in instrument cluster-IoReached Status,Output diagnostic test not active,
    IDE10102,Right warning light flashing cycle,OFF,
    IDE10103,Left warning light flashing cycle,OFF,
    IDE10104,Left warning light status,OFF,
    IDE10106,Right warning light status,OFF,
    IDE10107,Dimming value of left warning light: warning algorithm,0, %
    IDE10108,Status of left warning light: warning algorithm,--no display--,
    IDE10109,Dimming value of right warning light: warning algorithm,0, %
    IDE10110,Status of right warning light: warning algorithm,--no display--,
    IDE10229-IDE10101,Warning light for blind spot assistant in left exterior mirror-Dimming value of left warning light,0, %
    IDE10229-MAS01167,Warning light for blind spot assistant in left exterior mirror-Actuation time,no control,
    IDE10229-ENG39349,Warning light for blind spot assistant in left exterior mirror-IoReached Status,Output diagnostic test not active,
    IDE10230-IDE10105,Warning light for blind spot assistant in right exterior mirror-Dimming value of right warning light,0, %
    IDE10230-MAS01167,Warning light for blind spot assistant in right exterior mirror-Actuation time,no control,
    IDE10230-ENG39349,Warning light for blind spot assistant in right exterior mirror-IoReached Status,Output diagnostic test not active,
    IDE10235-IDE10233,Status night design-Night design,not activated,
    IDE10235-IDE10234,Status night design-Day design,activated,
    IDE10235,Status night design,OFF,
    IDE11133-MAS01167,Output of parking assistant warning-Actuation time,no control,
    IDE11133-ENG39349,Output of parking assistant warning-IoReached Status,Output diagnostic test not active,
    MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation is available,
    MAS05108-MAS10059,ESP-Blind spot warning: message,inconsistent,
    MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
    MAS08785-IDE02679,Parking aid-Tone sensor,Not available,
    MAS08785-IDE03619,Parking aid-System status,System off,
    MAS12659-IDE00007,VW/Audi part numbers of sub-bus users-VW/Audi part number,2Q0907685A ,
    MAS12659-MAS01170,VW/Audi part numbers of sub-bus users-Subsystem designation,Unknown (1595),
    MAS12659-ENG39145,VW/Audi part numbers of sub-bus users-Number Of Expected SubSystem Identification,1,
    MAS12659-ENG39146,VW/Audi part numbers of sub-bus users-Number Of Retrieved SubSystem Identification,1,
    MAS12659-ENG39149,VW/Audi part numbers of sub-bus users-SubSystem Node Address,06 3B,
    MAS12660-IDE00016,Hardware version number of sub-bus users-Hardwareversion,H03,
    MAS12660-MAS01170,Hardware version number of sub-bus users-Subsystem designation,Unknown (1595),
    MAS12660-ENG39145,Hardware version number of sub-bus users-Number Of Expected SubSystem Identification,1,
    MAS12660-ENG39146,Hardware version number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
    MAS12660-ENG39149,Hardware version number of sub-bus users-SubSystem Node Address,06 3B,
    MAS12661-IDE00008,Software version number of sub-bus users-Softwareversion,0051,
    MAS12661-MAS01170,Software version number of sub-bus users-Subsystem designation,Unknown (1595),
    MAS12661-ENG39145,Software version number of sub-bus users-Number Of Expected SubSystem Identification,1,
    MAS12661-ENG39146,Software version number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
    MAS12661-ENG39149,Software version number of sub-bus users-SubSystem Node Address,06 3B,
    MAS12662-IDE00012,Hardware part number of sub-bus users-Hardware part number,2Q0907685A ,
    MAS12662-MAS01170,Hardware part number of sub-bus users-Subsystem designation,Unknown (1595),
    MAS12662-ENG39145,Hardware part number of sub-bus users-Number Of Expected SubSystem Identification,1,
    MAS12662-ENG39146,Hardware part number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
    MAS12662-ENG39149,Hardware part number of sub-bus users-SubSystem Node Address,06 3B,
    MAS12663-IDE00010,Series number of sub-bus users-Serial number,00000435987516      ,
    MAS12663-MAS01170,Series number of sub-bus users-Subsystem designation,Unknown (1595),
    MAS12663-ENG39145,Series number of sub-bus users-Number Of Expected SubSystem Identification,1,
    MAS12663-ENG39146,Series number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
    MAS12663-ENG39149,Series number of sub-bus users-SubSystem Node Address,06 3B,
    MAS12665-MAS00966,FAZIT identifications of sub-bus users-Manufacture location index,HLH-45F,
    MAS12665-MAS00968,FAZIT identifications of sub-bus users-Day of manufacture,01.06.17,
    MAS12665-MAS00969,FAZIT identifications of sub-bus users-Manufacturer- test stand number,6CA2,
    MAS12665-MAS00970,FAZIT identifications of sub-bus users-Running manufacturer number,3058,
    MAS12665-MAS01170,FAZIT identifications of sub-bus users-Subsystem designation,Unknown (1595),
    MAS12665-ENG39145,FAZIT identifications of sub-bus users-Number Of Expected SubSystem Identification,1,
    MAS12665-ENG39146,FAZIT identifications of sub-bus users-Number Of Retrieved SubSystem Identification,1,
    MAS12665-ENG39149,FAZIT identifications of sub-bus users-SubSystem Node Address,06 3B,
    MAS12666-MAS01170,SubSystemNodeAddress of sub bus participant-Subsystem designation,Unknown (1595),
    MAS12666-ENG39149,SubSystemNodeAddress of sub bus participant-SubSystem Node Address,06 3B,
    MAS12667-ENG39148,Specified installation of sub-bus users-SubSystem coded Bit 0,Yes,
    MAS12667-ENG45626,Specified installation of sub-bus users-SubSystem coded Bit 1,No,
    MAS12667-ENG45625,Specified installation of sub-bus users-SubSystem coded Bit 2,No,
    MAS12667-ENG45624,Specified installation of sub-bus users-SubSystem coded Bit 3,No,
    MAS12667-ENG45623,Specified installation of sub-bus users-SubSystem coded Bit 4,No,
    MAS12667-ENG45622,Specified installation of sub-bus users-SubSystem coded Bit 5,No,
    MAS12667-ENG45621,Specified installation of sub-bus users-SubSystem coded Bit 6,No,
    MAS12667-ENG45620,Specified installation of sub-bus users-SubSystem coded Bit 7,No,
    MAS12668-ENG39150,Actual installation of sub-bus users-SubSystem present Bit 0,can be reached,
    MAS12668-ENG45633,Actual installation of sub-bus users-SubSystem present Bit 1,cannot be reached,
    MAS12668-ENG45632,Actual installation of sub-bus users-SubSystem present Bit 2,cannot be reached,
    MAS12668-ENG45631,Actual installation of sub-bus users-SubSystem present Bit 3,cannot be reached,
    MAS12668-ENG45630,Actual installation of sub-bus users-SubSystem present Bit 4,cannot be reached,
    MAS12668-ENG45629,Actual installation of sub-bus users-SubSystem present Bit 5,cannot be reached,
    MAS12668-ENG45628,Actual installation of sub-bus users-SubSystem present Bit 6,cannot be reached,
    MAS12668-ENG45627,Actual installation of sub-bus users-SubSystem present Bit 7,cannot be reached,
    MAS12669-ENG39147,Bus identification of sub-bus users-Bus ID,1,
    MAS13422-IDE00013,System description of sub bus participant-System description,HRE3_Kl15_Slv,
    MAS13422-MAS01170,System description of sub bus participant-Subsystem designation,Unknown (1595),
    MAS13422-ENG39145,System description of sub bus participant-Number Of Expected SubSystem Identification,1,
    MAS13422-ENG39146,System description of sub bus participant-Number Of Retrieved SubSystem Identification,1,
    MAS13422-ENG39149,System description of sub bus participant-SubSystem Node Address,06 3B,
    Elapsed Time: 00:05
    May 2017
    No need to turn it on as the calibration procedure is completed :
    Unfortunately that's just how thet BSD behaves. Same in our Leon, sometimes it just detects ghosts. Luckily they're very random.
    Oct 2014
    Does anyone know if there is a Parameter file available for the polo?
    Scott
    May 2017
    I haven't seen one.
    Jul 2019
    South Africa
    Can-H & Can-L
    Quote Originally Posted by golfman View Post
    Can anyone help?
    cheers
    Scan
       Revision: D7H20000
       Coding: 0038DD
       Coding: 1F0037
       Coding: 058037
       Coding: 1F0000
       Coding: 070000
       Coding: 0471155011
       Revision: --------
       ROD: EV_GatewNF.rod
       Coding: 25FFFF
       Coding: 90014500
    Adapmap
    Elapsed Time: 00:01
    Hi Golfman
    I installed the Blind Spot system in a new Polo AW1, RHD, and used this kit from Kufatec: https://www.kufatec.com/en/volkswage...polo-aw1-42675
    Unfortunately, they provided no instructions, and I need to know where to connect the Can-H and Can-L. Can you advise? Also, they provided a coding dongle, but it does not work. They say I need to turn ignition on (engine off), plug in the dongle and red and green LEDS will flash. Red will stop and green will continue to flash and when it goes off, coding is done. In my case, both LEDS flash for a few seconds, and then go off. On the radio under car settings I see the Blind Spot menu, with a tick in the box, but it does not allow me to untick. Maybe because my can-H and can-L is not connected yet. Do you have instructions/info on using my Hex cable?
  9. #8
    Nov 2014
    Your Pin location will depend on what you have installed
    There are two options for the Polo AW
    Built in Gateway in the BCM or stand alone Gateway
  10. Likes Uwe liked this post
  11. #9
    May 2017
    Quote Originally Posted by jeanl View Post
    Hi Golfman
    One good point to connect CAN lines is a connection junction under the left side door sill in the front (this in LHD car but I think it's the same in RHD). I presume in Polo, BSM system is connected to extended CAN. So the colors are orange/brown and orange/grey.
    You should not use the coding dongle until you have the BSM connected as well. It probably needs to code the BSM modules as well and that ain't possible until you have CAN lines connected.
  12. #10
    Jul 2019
    South Africa
    Hi. Thank you for your kind and informative feedback. I appreciate it. The car is currently at VW who is assisting me to re-code the car to standard, as it was before we tried the coding dongle. It makes sense to code the car after we connected the BSD to the correct can wires, so when I get it back later today, I will look for the can wires you specified on the passenger side (RHD car) and once connected, I will re-attempt to code.
    I will post an update with some more information, in order to assist anyone else with the same issue.
    Thank you once again.
