Results 1 to 10 of 11
Thread: Rolling windows up/down via door handle dimple
    Apr 2019
    NO ASS no cert no worries
    I understand this is a possibility. Anyone ever tinker with this? Iíve tried looking online and found mixed messaging, so now Iím asking the experts. 😊 I donít want to use my fob so as not to drain the battery too quickly.
    Again, thanks in advance,
    Chris
    My Auto-Scan is here
    Quote Originally Posted by kawzx7 View Post
    I don’t want to use my fob so as not to drain the battery too quickly.
    Huh? Key batteries cost under 50 cents each:
    https://www.amazon.com/dp/B008XBK7PG/
    Apr 2019
    Iíve never owned one of these keyless start vehicles. I dread the day the battery goes dead on the remote.
    US 2014 GTI Drivers Edition/DSG
    typically, the car will tell you when the FOB battery is low.
    I keep a spare battery in my glove box for my volt, which is similar to kessy.
    Quote Originally Posted by D-Dub View Post
    Yep, it will fuss at you as the battery is getting low, and even with the battery dead as a door-nail, or removed entirely, there should still be a way to get into the car and start it. I don't know exactly what the 2019 Jetta's key fob looks like, but there's likely a small cut key hidden in there somewhere that will allow you to mechanically unlock the car, and then there's a magic spot somewhere inside the car that you can hold the un-powered fob that will allow the car to talk to the transponder in the key in order to start the car.
  7. Likes PetrolDave, jyoung8607 liked this post
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    It should be something you can turn on. I'll be home in a couple hours and give you the relevant adaptations then if someone hasn't already.
    Silence gives consent.
    Apr 2019
    Please do, Iím exhausted.
  10. #8
    Dec 2016
    DE
    You mean something like this?
    From your AdpMap in this thread I would suggest the following changes in the BCM adaptions:
    Allow comfort opening in general [mandatory]:
    ENG141681-IDE02022-ZV Komfort-Comfort opening > active
    Opening by KESSY (closing is already enabled):
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen > active
    Opening/Closing by Key Fob:
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen > active
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen > active
    Opening/Closing by Keyhole:
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen > active
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen > active
    Also, please check in the HMI, if comfort operation is enabled.
  11. Likes Uwe liked this post
  12. #9
    Apr 2019
    BINGO! Thank you. Now Iím all set. Youíve done me a great favor. As I ask the others, if you have a favorite charity, Iíll donate $25 in your name (or screenname). :-)
  13. Likes Uwe, jyoung8607 liked this post
  14. #10
    Dec 2016
    DE
    Thanks for your offer, which I will kindly deny, as I donĎt think my post is worth 25$.
  15. Likes Uwe liked this post
