Results 1 to 3 of 3
Thread: 2012 Golf VI problem with LED DRL coding (byte 18?)
    Verified VCDS User obdserwis-pl's Avatar
    May 2019
    Poland
    I have problem with Golf VI. LED DRLs not working after wrong coding by customer I think
    LED DRLs were oryginally fitted in factory (not retrofitted)
    Tried different combination in 18 byte (00, 02, 04, 40) with no success
    Actually LED light not working, and have bulb indicator about Parking light left and right (also Fog light, but this is truthly damaged bulb)
    Here is coding:
    Monday,10,June,2019,09:18:22:02777
    VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
    Dealer/Shop Name: OBDserwis.pl
    VIN: WVWZZZ1KZCM663529   License Plate:
    Mileage: 230050km-142946mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 55 56 62
              72 77
    VIN: WVWZZZ1KZCM663529   Mileage: 230050km-142946miles
    Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 AN    HW: 03L 907 309 R
       Component: R4 2,0L EDC   H25 6779
       Revision: 42H25---    Serial number: 00000000000000
       Coding: 00190012042400080000
       Shop #: WSC 00066 000 00219
       ASAM Dataset: EV_ECM20TDI01103L906018AN 003007
       ROD: EV_ECM20TDI01103L906018AM_003_VW36.rod
       VCID: 76A0EAAEC9CDE4FFBB-8022
       Revision: 00H31001
       Coding: 143B600D092800FD281006E690220042350000
       VCID: 7DB2F582E4FBB7A7FA-8028
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Revision: 00001004
       Coding: 0000004002
       Shop #: WSC 00066 000 00118
       VCID: 004C8C769B09DA4F91-8054
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0064
       Revision: BC021001
       Coding: 00180E3F882DE3C0400800C0740089A44B750008737D0520648400200040
       Shop #: WSC 03585 002 104857
       VCID: 3E30328EA97D6CBFA3-806A
       Component: Wischer 08011  26  0512
       Coding: 009795
       Component: RLS 051211 05  54  0403
       Coding: 0330AD
       Component: Innenraumuebe  004 0611
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 100
                        Mileage: 230053 km
                        Date: 2013.10.31
                        Time: 09:17:24
                        Voltage: 13.65 V
                        Reset counter: 100
                        Mileage: 230053 km
                        Date: 2013.10.31
                        Time: 09:17:24
                        Voltage: 13.65 V
       Part No SW: 1K9 919 475 A    HW: 5K0 919 475 E
       Component: PARKHILFE 8K  H01 0004
       Revision: --------    Serial number: 12501128000240
       Coding: 108003
       VCID: 393A2192B0534B8796-806C
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Serial number: 003G6RA6BAVY
       Coding: 00003536
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 322816BE6525B8DF57-8066
       Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME272B5265ZZZX
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME1A175265ZZZV
       Serial number: 3511HSME591F5129ZZZS
       Serial number: 3521HSME170A5129ZZZH
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Revision: --------    Serial number:  90440KK80008R
       Coding: 108A140000
       Shop #: WSC 00066 000 00186
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 72A8D6BEA5A5F8DF97-8026
       Serial number: 0887172
       Coding: 820000
       Part No SW: 5K0 920 872 A    HW: 5K0 920 872 A
       Component: KOMBI         H33 0317
       Revision: X0033006    Serial number:
       Coding: 111D1B
       Shop #: WSC 00123 123 12345
       ASAM Dataset: EV_KombiUDSMM9RM10 A04305
       ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
       VCID: 2D1205C27C1BE7270A-8078
       Part No SW: 7N0 907 530 P    HW: 1K0 907 951
       Component: J533  Gateway H40 1623
       Revision:   H40       Serial number: 21011201291032
       Coding: 352002
       Shop #: WSC 00000 048 12644
       VCID: 3D323582A47B77A7BA-8068
       Part No SW: 5K0 953 234     HW: 5K0 920 872 A
       Component: IMMO          H33 0317
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6A98CEDE8D75301F2F-803E
       Revision: A1001003    Serial number: 7661290493
       Coding: 020000
       VCID: 291AF1D240F3FB07E6-807C
    Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
       Part No SW: 3C0 035 270 B    HW: 3C0 035 270
       Component: RNS310        H20 0357
       Revision: 11000000    Serial number: VWZ1Z2L7296285
       Coding: 04080401040000000104000E
       ASAM Dataset: VW_RNS310 A02007
       ROD: EV_VWRNS310UDS.rod
       VCID: 197AC11218936B8776-804C
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0501
       Revision: 12110009    Serial number: 0004013391
       Coding: 0000B4
       Shop #: WSC 01383 790 50316
       VCID: 1C74D80617A11EAF6D-8048
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  007 1509
       Serial number: 00000006256591
       Coding: 000090
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 71     3201
       Revision: 00H20000
       VCID: 342410A65731B6EF45-8060
       Component: EZE_2         H40 1623
       Coding: 050B0501
       VCID: 6FAEDFCABE97D53778-803A
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0501
       Revision: 14110009    Serial number: 0004010131
       Coding: 0001B4
       VCID: 1D72D5020CBB17A79A-8048
       Slave Passenger:
       Component: J389__TSG-HR  007 1509
       Serial number: 00000006272206
       Coding: 000090
       Coding: 1442908
       Coding: 00000022
       Coding: 00000022
       Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B
       Component: Telefon       011 0723
       Revision: --------    Serial number: 35909603267310
       Coding: 020000010100000000000000
       ASAM Dataset: EV_UHVPremi A02003
       ROD: EV_UHVPremi_A02.rod
       VCID: 2208E6FE35C5285FA7-8076
    End----------(Elapsed Time: 01:35, VBatt start/end: 13.9V/13.9V)-----------
    May 2019
    Poland
    Problem solved. 18 byte coding for proper vehicle and lights type and 09 module coding backed DRLs to life. Also BCM changes to original from this car
  3. Likes Uwe liked this post
    16.4905 S, 151.7375 W
    The two coding values I see in the Long Coding helper that you have tried are:
    [02] = Lighting: VW Golf (5K1/VW360) Rest of World (RoW)
    [04] = Lighting: VW Golf GTI (5K1/VW360) Rest of World (RoW)
    Have you tried this one?
    [0E] = Lighting: VW Golf Plus (521/VW369) Rest of World (RoW)
    Also [40] does not seem to be documented, be careful when entering in and testing undocumented values, it could be possible that an incorrect value would 'brick' the controller, or so I have heard, not verified.
    It the above does not work, this vehicle can be coded with an online connection to the manufacture and the ODIS software (dealer).
    If you have that procedure done at the dealer, be advised that the new value of byte [18] will be [00], this is NOT an actual value, since the real value is hidden from view when checked by the Coding function, even the dealer techs do not know what the real value is.
    Hope this helps,
    drpeter
  5. Likes Uwe liked this post
