Results 1 to 3 of 3
Thread: O2 Sensor Replaced - MIL on and showing same O2 faults
    Nov 2018
    I just replaced both upstream O2 sensors myself on my 2006 Audi A6 Avant, and I cleared the existing O2 codes after I was done, but they are still there. Does this seem to be something other than the sensors themselves or will these go away after a period of driving again?
    Thank you !!
    Sunday,09,June,2019,11:57:59:55997
    VCDS Version: 19.6.0.4 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WAUKG74F76N063701   License Plate:
    Mileage: 279240km-173511mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 65 67 72 76 77
    VIN: WAUKG74F76N063701   Mileage: 279240km-173511miles
    Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
       Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0030
       Revision: --H15---    Serial number:
       Coding: 0000000000000000
       Shop #: WSC 22162 444 53437
       VCID: 2B0305BDFF089B8F4F5-807E
    000304 - Oxygen (Lambda) Sensor B1 S1
                   P0130 - 006 - Malfunction in Circuit - Intermittent - MIL ON
                        Fault Status: 10100001
                        Fault Frequency: 32
                        Reset counter: 40
                        Mileage: 279066 km
                        Date: 2019.05.31
                        Time: 15:14:03
                        RPM: 832 /min
                        Mass Air / Rev.: 169.0 mg/str
                        Temperature: 36.0°C
                            Idle
                        Voltage: 13.57 V
                        Bin. Bits: 00000010
    008785 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
                   P2251 - 007 - Open Circuit - MIL ON
                        Fault Status: 10100010
                        Fault Frequency: 31
                        Reset counter: 40
                        Mileage: 279066 km
                        Date: 2019.05.31
                        Time: 15:14:09
                        RPM: 832 /min
                        Mass Air / Rev.: 174.4 mg/str
                        Temperature: 37.5°C
                            Idle
                        Time: 76.8 s
                        Bin. Bits: 00000100
    004502 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1
                   P1196 - 006 - Electrical Malfunction - Intermittent
                        Reset counter: 23
                        Mileage: 279077 km
                        Date: 2019.06.01
                        Time: 10:09:11
                        RPM: 672 /min
                        Mass Air / Rev.: 136.3 mg/str
                        Temperature: 69.0°C
                            Idle
                        Time: 51.2 s
                        Bin. Bits: 00000010
       Part No SW: 4F1 910 156 P    HW: 09L 927 156 A
       Component: AG6 09L 3,2 FSI USA 0030
       Revision: --H01---    Serial number:        4068051
       Shop #: WSC 02327 785 00200
       VCID: 313F17D5DD24F15F759-8064
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H04 0090
       Coding: 0020895
       VCID: 2D070BA5C11C95BF511-8078
       Component: FBSAUDIC6 ELV   H31 0240
       Revision: 07020801    Serial number: 10600600229680
       Coding: 0000143
       Shop #: WSC 22162 444 84622
       VCID: 6393AD9DD75813CFB75-8036
       Component: FBSAUDIC6 KSG   H26 0080
       Subsystem 3 - Part No: 4F0 910 220 G
       Component: FBSAUDIC6 IDG   H44 0060
       Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 303HJ057505560
       Coding: 0001003
       Shop #: WSC 02335 785 00200
       Component: Bedienteil MMIC6H07 0050
       Subsystem 2 - Serial number: 00000000208947
       Subsystem 3 - Serial number: 0129.07.050000000100010125ÿ
       Subsystem 4 - Serial number: 010125ÿ
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 234
                        Mileage: 279241 km
                        Date: 2019.06.09
                        Time: 11:52:51
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0160
       Revision: 00000027    Serial number: 00000000171457
       Coding: 0524582
       VCID: 5BE3957DEF282B0FFF5-800E
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H15 0190
       Coding: 0014123
       VCID: 2A0D00B9F0F28287B43-807E
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE7216688
       VCID: 1C61D661AAA66C3736F-8048
    Address 0F: Digital Radio        Labels: 4E0-910-593-XM.lbl
       Part No SW: 4E0 910 593 G    HW: 4E0 035 593 C
       Component: SDAR XM         H04 0670
       Revision: 00000000    Serial number: AUZ4Z7E2029525
       Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
       Component: 66 AIRBAG AUDI8RH29 0300
       Revision: 12H29000    Serial number: 00359D0A1KM/
       Coding: 0013878
       Subsystem 1 - Part No: 4F0 910 339 A
       Component: BF-Gewichtsens. H02 0050
       Subsystem 2 - Serial number: 6332CSME0B1468191
       Subsystem 3 - Serial number: 6342CSME0A775A6CJ
       Subsystem 4 - Serial number: 6352QSME036211796
       Subsystem 5 - Serial number: 6362QSME04522F15C
       Subsystem 6 - Serial number: 63734SME03440C4D+
       Subsystem 7 - Serial number: 63834SME044F41771
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026052070161
       Coding: 0002042
       Shop #: WSC 02323 785 00200
       VCID: 6695B489246A66E750B-8032
       Component: Lenkradmodul    H07 0080
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 N
       Component: KOMBIINSTR. M73 H16 0630
       Revision: 00000000    Serial number: 4PY175X75
       Coding: 2129263
       VCID: 211FE7958DC441DFE59-8074
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 13008058118151
       Coding: ECFE73CD1B7904
       VCID: 270BF98DE3E0BFEFABD-8072
       Coding: 0082954
       VCID: 619FA795CD4401DFA59-8034
       Part No SW: 4E0 910 887 N    HW: 4E0 919 887 C
       Component: MNS US          H45 0740
       Revision: 00000000    Serial number: 355GS057552228
       VCID: 38292AF13E5E2017327-806C
       Component: TSG FA          H12 0080
       Revision: 00-00000
       Coding: 0052971
       Shop #: WSC 98765 666 36911
       VCID: 2C0106A1FA069CB746F-8078
       Component: Komfortgeraet   H19 0140
       Revision: 01400019    Serial number: 01006252890000
       Coding: 4618813
       VCID: 2E050CA9CC1AEEA768B-807A
       Part No SW: 4F0 910 223 A    HW: 4F0 035 223 A
       Component: DSP-High C6     H09 0140
       Revision: PROD_01     Serial number: 00000000702172
       Coding: 0000126
       Shop #: WSC 22162 444 13633
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000005735
       Coding: 0002114
       VCID: 5EE59C69FC3A3E2798B-800A
       Component: TSG BF          H12 0080
       Revision: 00-00000
       Coding: 0052971
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0005022
       Shop #: WSC 02334 785 00200
       VCID: 5DE79B65F13C253F811-8008
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000016
       VCID: 2615F489E4EAA6E790B-8072
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
    02626 - Dynamic Cornering Light Motor; Right (V319)
                        Fault Status: 11101010
                        Reset counter: 234
                        Mileage: 279240 km
                        Date: 2019.06.09
                        Time: 11:52:53
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
       Revision: 00000000    Serial number: 394HO057601711
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000088324
       Shop #: WSC 26107 444 01170
       VCID: 2313ED9D97D853CFF75-8076
       Subsystem 1 - Part No: 4F0 915 105 E
       Component: von VA0  00915105CE
       Coding: 344630393135313035452056413030303931353130354345
       Coding: 0052778
       Part No SW: 4F0 910 273     HW: 4F0 907 273
       Component: Reifendruck 3   H04 0080
       Revision: 00040080    Serial number: 00000900008357
       Coding: 0062221
       VCID: 6099A291C64E08D7AA7-8034
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000508050033
       Shop #: WSC 12336 024 394758
       VCID: 34311EC12236C4771EF-8060
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Coding: 0052778
       Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
       Component: Parkhilfe 4-Kan H09 0020
       Revision: 00H09000    Serial number: 11720521406897
       Coding: 0001216
    Address 77: Telephone
    End----------(Elapsed Time: 01:56, VBatt start/end: 13.4V/13.5V)-----------
    Component: 3.2l V6 FSI 0030 <<<<<<<<<<<<<<<<<<<<<<<<< UPDATE PROGRAMMING NEEDED!
    Thank you !!
    Because the car is running emission deletes FOD tuning.........and the sensors could be wrong part numbers, short in wiring harness or the ECU is FUBAR!
    JPPSG
  3. Likes jyoung8607 liked this post
    May 2016
    CD, would appear even more definitive, coding indicates negative lead on that sensor.
    As Jack stated either At ECU or between, need wire diag and some time or move to a shop.
    Bin. Bits: 00000010
    Fault Frequency: 31
    Reset counter: 40
    Mileage: 279066 km
    Date: 2019.05.31
    Time: 15:14:09
