Good Morning,
I'm having some difficulties retrofitting cruise control. I managed to complete the coding change in the ECM but won't accept coding in the Steering Wheel control module.
The cruise control option fitted is via the turn signal stalk, but would only accept the option for cruise control on the MFSW.
Would this just require a change of steering wheel module (Currently fitted is 5K0 953 549 A)
I've posted a copy of the log below
Saturday,08,June,2019,20:03:05:20472
VCDS Version: 19.6.0.2 (x64)
Dealer/Shop Name: S81 Diagnostics
VIN: WVWZZZ1KZBW****** License Plate: ******
Mileage: 127890km-79467mi Repair Order: CC Retrofit
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 42 44 46 52 55 56
VIN: WVWZZZ1KZBW****** Mileage: 127890km-79467miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Part No SW: 1K8 907 115 F HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: 5BH19--- Serial number:
Coding: 0403000C1C0F0060
VCID: 3163198EA866A2C72E-8064
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - MIL ON
Fault Status: 11100010
Mileage: 118506 km
Date: 2013.05.08
Time: 02:31:29
RPM: 1392 /min
Load: 31.0 %
Speed: 32.0 km/h
Temperature: 80.0°C
Temperature: 30.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Part No SW: 02E 300 013 HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2204
Revision: 05151112 Serial number: 00001007241859
VCID: 4E996272D998DD3F53-801A
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 163B800D092800FE680F01E4901E00813D0000
VCID: 040D805A8754E76FB5-8050
02214 - Tire Pressure Warning
Reset counter: 107
Mileage: 127706 km
Date: 2013.10.27
Time: 00:01:55
Count: 32768
Count: 4608
Count: 397
Count: 50690
Count: 65280
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
VCID: 7DFBF5BEECBE96A7FA-8028
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 48180A3A8037F10040080080340008E44375008E736D8960E48000240040
VCID: 387524AA8B1C738F69-806C
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 06081 26 0512
Coding: 009795
Component: RLS 100810 05 54 0403
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
00061 - Footwell Lights
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 73
Mileage: 118466 km
Date: 2013.05.07
Time: 05:09:59
Voltage: 11.70 V
Term 50 Off
03266 - Control Circuit for Signal Horn
Fault Status: 00101001
Reset counter: 77
Mileage: 127043 km
Date: 2013.10.09
Time: 17:05:04
Term 15 Off
Voltage: 12.00 V
Term 50 Off
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRAB3FY9
Coding: 00003135
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B7F3BA6B22A589784-806E
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME396C5455ZZZ%
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME75767555ZZZ+
Serial number: 3512QSME080F6C3CZZZ4
Serial number: 3522QSME164B6215ZZZS
Part No SW: 5K0 953 507 AF HW: 5K0 953 549 A
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JFU001C0
Coding: 1892040000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 74EDD09ADFF4D7EF85-8020
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0014026
Coding: 830000
Part No SW: 5K6 920 971 B HW: 5K6 920 971 B
Component: KOMBI H03 0406
Coding: 770D01
VCID: 346D109A9F7497EF45-8060
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 300710F1001395
Coding: ED831F0600021200000001
VCID: 6DDBC5FE74DE06274A-8038
00469 - Infotainment Databus in Single Wire Operation
Fault Status: 00101011
Reset counter: 90
Mileage: 127043 km
Date: 2013.10.10
Time: 08:28:07
03272 - Control Module for Audio Interface
Reset counter: 250
Mileage: 118466 km
Date: 2013.05.07
Time: 05:10:02
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 448D405A07D4276FF5-8010
Component: IMMO H03 0406
VCID: 6AD1CEE28D30111F2F-803E
Address 2E: Media Player 3
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2150
Coding: 0000564
VCID: 336F1386527A90D75C-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2118
Coding: 0000564
VCID: 32611682AD6099DF57-8066
00110 - Right Mirror Turn Signal Lamp (L132)
Component: AFS-Steuergeraet 0142
Coding: 1475932
Shop #: WSC 52589 001 1048576
VCID: 346D109A577497EF45-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio
End-------------------------(Elapsed Time: 02:20)--------------------------
Gateway Installation List: 7N0 907 530
Address 01,1K8 907 115 F,recoded (Long Coding),from,0403000C1C0F0060,to,0403000C1C0F0160,(01357/011/00200),
Address 16,5K0 953 507 AF,recoded (Long Coding),from,1892040000,to,1892140000,(01357/011/00200),
Control Module Part Number: 5K0 953 507 AF
Component and/or Version: Lenks.Modul 007 0080
Software Coding: 1892040000
Work Shop Code: WSC 01357
Advanced Identification/FAZIT
Identification: KO3-KLO
Revision: --------
Date: 30.06.10
Manufacturer number: 0003
Test stand number: 01C0
Flash Status
Programming Attempts(application): 0/0
Successful Attempts(application): 0/0
Programming Attempts(data): 0
Successful Attempts(data): 0
Programming Status: 00000000
Flash Date: 00.00.00
Flash Tool Code(data): 00000 000 00000
Software
UDS: 00.00.01
UDS: 14.03.00
LIN 2.0: 01.02.05
CAN: 00.1E.02
CAN: 00.07.00
Theft prot.: 01.02.15
OSEK-OS: 00.1E.03
Theft prot.: 00.0A.00
Generic Net Mgt: 03.70.03
OSEK-Com: 00.1E.03
Theft prot.: 00.0D.00
Generic Net Mgt: 02.50.00
LIN 2.0: 00.1E.02
Misc.
Hardware number: 5K0 953 549 A
Workshop System Name: J527
Equipment/PR Code: 0000000000000000
Dataset Number: 5K0953507AF
Dataset Version: D005
End of Line Equipment Level: ------------------
ASAM Dataset Revision: A05001
VCDS Info:
Labels: 5K0-953-569.clb
Address 16,5K0 953 507 AF,recoded (Long Coding),from,1892040000,to,1892240000,(01357/011/00200),
Address 16,5K0 953 507 AF,recoded (Long Coding),from,1892040000,to,1892440000,(01357/011/00200),
Address 16,5K0 953 507 AF,recoded (Long Coding),from,1892440000,to,1892040000,(01357/011/00200),
Address 16: DTCs cleared
