Thursday,13,June,2019,17:55:09:50816
VCDS Version: 19.6.0.2 (x64)
VIN: WV1ZZZ2KZDX062214 License Plate:
Mileage: 149930km-93162mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61 76
VIN: WV1ZZZ2KZDX062214 Mileage: 149930km-93162miles
76-Park Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PD HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 8014
Revision: --H43--- Serial number: 00000000000000
Coding: 00114034032501080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PD 003010
ROD: EV_ECM16TDI02103L906023PB.rod
VCID: 77FBDD0ECE0BC4F7A0-8022
Readiness: 1110 1000
Revision: 00H31001
Coding: 433C400D092803FCC20D02E5901DC091310000
Shop #: WSC 35110 377 08192
VCID: 7DF7CF26E437EEA7FA-8028
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000004003
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 0009B6D29BC5834F91-8054
Part No SW: 5K0 937 086 P HW: 5K0 937 086 P
Component: BCM PQ35 M+ 021 0068
Revision: BD021001
Coding: 4F1A583A8025F16A088800829000016403810088424F8520648087000041
VCID: 418F73D6D84F4A47DE-8014
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 05101 26 0512
Coding: 009795
Subsystem 2 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 2K0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0004
Revision: -------- Serial number: 32961228601607
Coding: 108001
ASAM Dataset: EV_EPHVA14VN3370000 001006
ROD: EV_EPHVA14VN3370000.rod
VCID: 70E9E612AB6593CF61-8024
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02B H07 0013
Revision: -------- Serial number: 003HL00EBP49
Coding: 000000000000000000000000000000003242
VCID: 356717069487F6E772-8060
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422LFT001CS
Coding: 108A100000
Shop #: WSC 00028 028 00311
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72EDEC1AA569A1DF97-8026
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0033053
Coding: 820000
267264 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 14
Mileage: 149935 km
Date: 2019.06.13
Time: 17:52:33
Part No SW: 2K0 920 975 L HW: 2K0 920 975 L
Component: KOMBI H05 0705
Coding: 781801
VCID: 397F1B36B89F128796-806C
Part No SW: 7N0 907 530 BJ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1682
Revision: H58 Serial number: 091016F1000263
Coding: 357421
VCID: 79FFDB36F01FD287D6-802C
01327 - Control Module for Parking Aid (J446)
Reset counter: 14
Mileage: 149935 km
Date: 2013.11.03
Time: 17:52:39
Component: IMMO H05 0705
VCID: 6ADDF47A8DB9691F2F-803E
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2130
Coding: 0135792
Shop #: WSC 00020 790 00000
VCID: 397F1B36709F128796-806C
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
Shop #: WSC 33377 001 1048576
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Component: Tuer-SG 009 2128
Coding: 0135792
VCID: 3A7D043A7599199F9F-806E
00830 - Convertible Top Control Module (J256)
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 7N5 035 680 C HW: 7N5 035 680 C
Component: MU-S-ND-ER H31 0359
Serial number: SEZAZ2S5018754
Coding: 063307013C00000011111101008808001F0109D6002001004F
Shop #: WSC 11867 022 05673
ROD: EV_MUStd4CTSAT_SK26.rod
VCID: 3363291E9AF3E8D75C-8066
Subsystem 1 - Part No SW: 6P0 919 866 H HW: -----------
Component: ECE1 2016/17 --- 0635
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 14
Mileage: 149935 km
Date: 2019.06.13
Time: 17:52:32
Voltage terminal 30: 11.8 V
Byte_Coding_Condition-byte_0_condition: ERROR
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
U1101 00 [009] - Active
Reset counter: 14
Mileage: 149935 km
Date: 2019.06.13
Time: 17:52:32
Voltage terminal 30: 11.7 V
7179 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 14
Mileage: 149935 km
Date: 2019.06.13
Time: 17:52:35
BAP-BAP_Function_ID: 02
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1682
Coding: 030F1873
VCID: 71EFE316A86F9AC76E-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900314039
Address 76: Park Assist (J446) Labels:* None
Coding: 108001
End-------------------------(Elapsed Time: 02:47)--------------------------
