Results 1 to 8 of 8
Thread: 2006 Bentley GT 34 Level Control
    Jun 2019
    Indiana, USA
    Hello, I'm new and wanted to introduce myself. I'm from Northwest Indiana and hope to learn a lot from the forum. Most just call me CJ.
    I had some front end work done and now the front end is sitting low and the rear is sitting high. The first time I tried to do anything to correct this I would get an error code code when putting the last value in for the last wheel height. When I tried again on Friday I couldn't get passed the second wheel.
    Parts that were changed:
    Struts
    Upper control arms
    Lower control arms
    Outer tie rod ends
    CV axles
    ARB links
    The front don't rub the fender when I drive but its really close. When trying to do the adaptation, it lowers and rises as it should,but back to there it originally started. Its suppose to go to the shop on Monday but if I can get this figured out before then that would be great!
    Side note: some of the communications faults comes from me changing out the radio and taking out the phone, navi and cd changer.
    Friday,07,June,2019,15:14:35:13450
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: SCBCR63W86C031559   License Plate: SCJ
    Mileage: 104070km-64666mi   Repair Order:
    Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
              37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
    VIN: SCBCR63W86C031559   Mileage: 104070km-64666miles
    Address 01: Engine        Labels: None
       Part No SW: 07C 906 018 CQ    HW:
       Component: BY-6.0L-TT      G  ª6720
       Revision: 83ÿTT       Serial number:  000-00025.06.
       Coding: 0000173
       VCID: 76B51A8594D47517E0D-513C
    049412 - No Communication with Cruise Control Module
                   U0104 - 008 -  - Intermittent
    001384 - Cruise Control Switch (E45)
                   P0568 - 004 - Implausible Signal - Intermittent
    049508 - No Communications with HVAC Control Module (J301)
                   U0164 - 008 -  - Intermittent
    001349 - Sensor 1 for Exhaust Temp Bank 1 (G235)
                   P0545 - 002 - Short to Ground
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
       Part No SW: 09E 927 760 G    HW: GS1 904 1
       Component: AG6 09E 6.0L W12TT  1905
       Coding: 0000101
       Shop #: WSC 00083 000 00000
       VCID: 3431E08DC22827071E9-5160
    Address 03: ABS Brakes        Labels: 3W0-614-517-V1.lbl
       Part No: 3W0 614 517 D
       Component: ESP 5.7 4WD     H01 0021
       Coding: 0007878
       Shop #: WSC 03124 000 00000
       VCID: 3635DA85D454351720D-51F2
       Part No SW: 3D0 909 137 A    HW: 5WK 470 26
       Component: 1Y Kessy            6700
       Revision: 67005514    Serial number: VWZ3Z0E7362053
       Coding: 0405741
       VCID: 25170DC979F24E8F997-5160
       Subsystem 1 - Part No: 4E0 905 852 D
       Component: ELV                 1834
    00184 - Control Circuit for Engine Start/Stop Switch
       Part No: 3W0 959 759 A
       Component:    CM Seat Pass.    0009
       Shop #: WSC 03239 103 59246
       VCID: 47CBA741A3BEBC9F4BB-5160
    01971 - Adjuster for Seat Heating & Ventilation (E399)
    Address 08: Auto HVAC        Labels: 3W7-907-040.clb
       Part No: 3W0 907 040 E
       Component: Climatronic BY614   2010
       Coding: 0000102
       VCID: 3333E391C726203F073-5160
    00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
    Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
       Part No: 3D0 937 049 H
       Component: STG.Bordnetz        5101
       Coding: 0000107
       VCID: 2F3BEFE12B0E04DF63B-5160
       Part No: 3D0 909 601 E
       Component: 0P Airbag 8.4E+ H10 0936
       Coding: 0012368
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 D
       Component: Lenksäulenmodul     3401
       Coding: 0000012
       VCID: 2E05F2E52C040DD768D-5160
    Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
       Part No: 3W8 920 840 C
       Component: KOMBIINSTRUMENT RB8 0610
       Coding: 0023203
       VCID: 3C21C8ADEA78EF47D69-5160
    00459 - Control Module for Display and Input; Front (J523)
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70B92C9DF6B05B273A1-5160
    Address 34: Level Control        Labels: 3Wx-907-553-34.clb
       Part No: 3W0 907 553 A
       Component: LUFTFDR.-CDC- 3C3V0 7203
       Coding: 0005561
       Shop #: WSC 03242 103 72660
       VCID: 3829D4BDDE40C367321-5160
    01437 - Control Position not Learned
       Part No: 3W0 959 760 A
       Component:    CM Seat Driver   0008
       Shop #: WSC 03124 104 180667
       VCID: 3FDBBFA1FB6EF45FF3B-5160
    Address 38: Roof Electronics        Labels: None
       Part No: 3W0 907 135 C
       Component: Dachmodul           0703
       Coding: 0000157
       VCID: 3635DA85D454351720D-5160
    00211 - Control Circuit for Rear Illumination Lights
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component: 4S HSG              0101
       Coding: 0000034
       VCID: 3333E391C726203F073-4B00
       Subsystem 1 - Part No: 3W8 959 701 B
       Component: Tuersteuergeraet FS 1002
       Subsystem 2 - Part No: 3W8 959 702 B
       Component: Tuersteuergeraet BF 1002
       Subsystem 3 - Part No: 3W8 959 703 A
       Component: Tuersteuergeraet HL 1002
       Subsystem 4 - Part No: 3W8 959 704 A
       Component: Tuersteuergeraet HR 1002
       Subsystem 5 - Part No: 7L0 907 719
       Component:    Neigungssensor   0020
    6 Faults Found:
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    01503 - Bulb for 3rd Brake Light (M25)
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3W0 035 456 C
       Component: 12K-AUDIOVERST      4121
    00419 - Left Front DSP Midrange Speaker (R103)
    Address 53: Parking Brake        Labels: 3W0-907-801.clb
       Part No SW: 3W0 907 801 B    HW: 3W0 907 801 B
       Component: EPB  BC6HX23    HC6 X230
       Coding: 0022401
       VCID: 3537DD89C9523E0F297-5160
    Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
       Part No: 1C0 959 733 H
       Component: Heckspoiler         0002
       VCID: 3039EC9D33301B277A1-51F2
    01509 - Spoiler not Extended at Speed Exceeding Warning Threshold
                35-10 - - - Intermittent
    Address 65: Tire Pressure        Labels: Redir Fail!
       Part No: 3W7 907 273
       Component: Reifendruckueberw.  0003
       Coding: 0080352
       VCID: 7DA705A9B1E2264FA17-5160
    Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
       Part No: 3W1 955 023 C
       Component: Wische(
       Shop #: WSC 00000 725 65552
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 C
       Component: Batteriemanagement  2700
       VCID: 231313D177C6B0BFF73-5160
       Part No: 3W0 919 283 A
       Component: 02 Einparkhilfe     0303
       VCID: 3B23CBB1EF76E87FDF3-5160
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                006 - Short to Plus
    End----(Elapsed Time: 07:48, VBatt start/end: 12.3V/12.2V. VIgn 0.0V)------
    Thank you for any help that comes my way.
    Verify basic mechanical settings of control arms to ride height sensors are set proper.
    They can be manually repositioned to raise or lower the vehicle using the RTFB and a ruler.
    Communication with J523 must be corrected using WD and RTFB.
    Supply voltage and terminal 30 must be verified, corrected or addressed.
  3. Likes Uwe liked this post
    Jun 2019
    Indiana, USA
    Thank you for the reply, but I must tell you, I am GREEN when it comes to all this so I will need the laymans version to understand it all. I'm looking up what RTFB/WD means now.
    Quote Originally Posted by Teamjones View Post
    See how RTFB and WD are bold green underlined? On this forum that means if you hover your mouse over them an explanation will appear
  6. Likes Uwe liked this post
    Jun 2019
    Indiana, USA
    I noticed that yesterday. Mines just has a question mark when I hover over it.
    Edit...Got it
    Thank YOU for being informative
    Jun 2019
    Indiana, USA
    Received a call from Bentley today and was told that the tech was “locked out” of the control module and couldn’t make any adjustments. Has anyone ever heard of this?
    Yup....
    Adjust it manually as per RTFB at control arms & to extend range needed doing mechanical measurement.
    If the adaptation goes full sweep there is nothing left if your basic setting is incorrectly set and past threshold limits.
    This can be seen by checking sweep of potentiometers in VCDS blocks.
  10. #8
    Jun 2019
    Indiana, USA
    Thanks you the info. I’ll relay this back when they open. I’ll change RTFB to Workshop manual because I don’t think they may know what that means. Again thank you for the info.
