Results 1 to 9 of 9
Thread: Golf mk7.5 halogen to golf mk7.5 led headlights
    New User
    Jun 2019
    England
    hi everyone i have golf 7.5 2017 with halogen headlights and have purchased genuine golf 7.5 full led headlights
    my car does not come with the headlight control module 4b (j745) i would like to retrofit this can anyone shed some light
    thankyou very much any info on the wiring 10pin plug to the 14 pin would be a great help
    Apr 2018
    ITALY
    what version of LED headlight did you buy? Golf 7.5 has more than one.
    please post a full autoscan of your car.
    WD for you VIN you can get on erwin by buying just one hour access.
  3. Likes Uwe liked this post
    New User
    Jun 2019
    England
    hi mate thanks this is full autoscan of the vehicle i can access wiring diagrams
    the part number for the headlights i have purchased is 5G2 941 060
    VIN: WVWZZZAUZHW321287   License Plate:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZHW321287   Mileage: 9481km-5891miles
    Address 01: Engine (2D2D2-DDYA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 056 HE    HW: 04L 907 445 E
       Component: R4 1.6l TDI   H01 3758
       Revision: 22005001
       Coding: 0125401243651D092000
       ASAM Dataset: EV_ECM16TDI03004L906056HE 004005
       ROD: EV_ECM16TDI03004L906056HE_004_VW37.rod
       VCID: 77FDF14FCE3CD9F2EC-8022
    25802 - Steering Column Control Module
              U0212 00 [039] - No Communications
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:18:18
                        Engine speed: 765.75 /min
                        Normed load value: 25.9 %
                        Coolant temperature: 43 °C
                        Intake air temperature: 20 °C
                        Voltage terminal 30: 14.859 V
                        Accelerator pedal travel: raw value: 0.00 %
                        CAN status - engine control module: 0
                        Cruise Control System (CCS): status: ERROR
                        selected gear: Shifting process active
    Readiness: N/A
       Part No SW: 0CW 300 041 D    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1004
       Revision: 00005026    Serial number: CU501701188366
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 36633C4B89B6E0FA37-8062
       Revision: 00000000    Serial number: 60487000000379
       Coding: 01FA8AA12422096D4779060840CA2580512490E26002A4733842F078C202430000000012121212B835351919323200
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [008] - -
                        Reset counter: 27
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
       Part No SW: 5G0 907 426 AQ    HW: 5G0 907 426 AQ
       Component: AC Manuell    H03 1801
       Revision: 00001K06
       Coding: 00120104202110001000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004134
       ROD: EV_ACManueBHBVW37X_004_VW37.rod
       VCID: 7AFBE87BFD2EC49A93-802E
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 242
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:00
                        Outside air temperature: 18.0 °C
                        Engine speed: 700 /min
                        Temperature after evaporator: 22.3 °C
                        System run time-Engine running time: 255 s
                        System run time-Terminal 15 on: 255 s
       Part No SW: 5Q0 937 084 CE    HW: 5Q0 937 084 CE
       Component: BCM MQBAB M   H34 0236
       Serial number: 02001702700020
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7DF1E367EC00F3A2B6-8028
       Component: WWS    170120  042 0551
       Serial number:         170206154322
       Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  042 0105
       Serial number: S3Y17M02D14H08M10S47
       Coding: 00A8DD
       Serial number: 000000000ZY1701639X9
       Serial number: 00000000000068351803
    558100 - Databus
                        Reset counter: 242
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:05
       Part No SW: 5QA 919 294 A    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0038
       Serial number: 000308418617049
       Coding: 0471051011
       ASAM Dataset: EV_EPHVA18AU3700000 009031
       VCID: 4A9B78BBED4E941A43-801E
       Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0620
       Coding: 3300678111FFC728949C810580400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002005
       VCID: 3C772E63B79A3AAAC1-8068
    1076 - Databus
                        Reset counter: 242
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
                        Control Module temperature: 34 °C
                        Voltage terminal 15: 14.8 V
                        Status_ACC_System: ACC_irreversible error
    2119 - Databus
                        Reset counter: 27
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
    1116 - Databus
              U1122 00 [009] - Implausible Message
                        Reset counter: 242
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:18:48
                        Control Module temperature: 35 °C
                        Voltage terminal 15: 14.7 V
    2068 - Databus
                        Reset counter: 242
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0317
       Serial number: 003TDR2LNUM+
       Coding: 98CCC000000000005C0000CF008800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 102FAAD3CB92EECA4D-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E10021741078
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E10021750469
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 802 17
       Serial number: 3570000000002C7C612E
       Subsystem 4 - Part No SW: -----------    HW: 480 001 702 17
       Serial number: 35800000000EA11D212H
       Subsystem 5 - Part No SW: -----------    HW: 480 400 902 17
       Serial number: 3510001BF248E89507DK
       Subsystem 6 - Part No SW: -----------    HW: 480 400 902 17
       Serial number: 3520001A1244A731633M
       Subsystem 7 - Part No SW: -----------    HW: -----------
       Component: FrontSensor_D  --- ----
       Serial number: -------------------$
    7 Faults Found:
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
              B1007 1B [137] - Resistance Too High
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
    9438491 - Igniter for Driver head airbag
              B1005 1B [137] - Resistance Too High
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
    9438235 - Igniter for Front passenger's Head Curtain Airbag
              B1004 1B [137] - Resistance Too High
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
    9443861 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:04
    9447189 - Seat Occupied Sensor; Passenger's Side
              B1027 15 [137] - Open or Short to Plus
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:02
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 12021708490279
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 020B909B95FE8C5ACB-8056
       Part No SW: 5G1 920 941 B    HW: 5G1 920 941 B
       Component: KOMBI         202 9630
       Coding: 27A42A082780060001882B011400000000000000
       ASAM Dataset: EV_DashBoardJCIMQBAB 009007
       ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
       VCID: 285FE2335302860AB5-807C
       Component: GW MQB High   418 4286
       Revision: --------    Serial number: 0005940024
       Coding: 030100045F086800FB00005C1C0F00010001050000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       VCID: 2F6D092F76ECD13274-807A
       Subsystem 2 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
       Serial number: 3548513004
    197169 - Controls in Steering Wheel
                        Reset counter: 242
                        Mileage: 9481 km
                        Date: 2019.06.04
                        Time: 23:17:01
                        Supply voltage: Terminal 30: 14.5 V
                        Terminal 15: On
       Serial number: 250117EAP21114
       Coding: 00310220D001048000001000
       VCID: 4385559FCA64455280-8016
       Serial number: 00000000000013353753
       Coding: 0D0000
       Component: EPS_MQB_ZFLS  129 1072
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45814B87C4507B62AE-8010
       Serial number: 280117EAS0739A
       Coding: 00310020DE01048000801000
       VCID: 428B509BD57E4C5A8B-8016
       Serial number: 00000000000013387970
       Coding: 150000
       Part No SW: 3Q0 035 842 B    HW: 3Q0 035 842 B
       Component: MU-S-D-ER     710 0751
       Coding: 02731000FF00000051110101008808001F0500C60120010003
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 2C571E2347FAAA2A51-8078
       Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
       Component: ABT_Std-2  H41 8074
       Serial number: VWZ6ZET0503061
    End-------------------------(Elapsed Time: 03:48)--------------------------
  5. Likes Uwe liked this post
  6. #4
    Apr 2018
    ITALY
    please do not cut the header from the autoscan, also try clearing DTCs to clean it up a bit.
    5G2 941 059 and 5G2 941 060 are the two headlights.
    find a car which has those headlights stock and find what is the PR code for headlights. once you know that it's easy to find the correct sheet on the WD.
    you have a MID level BCM which might not be enough for the new headlights.
    +1
    Knowing which version of VCDS and which cable you have used is often important.
  8. Likes Uwe liked this post
  9. #6
    New User
    Jun 2019
    England
    hi i will be deleting all error codes sorry ive had all interior out and roof lining so once i have completed that will post a full autoscan along with the vcds version i have thanks for all feedback much appreciated
  10. #7
    New User
    May 2019
    Singapore
    Just wonder if without connection to BCM and AFS, can LED headlight lights up when power on?
  11. #8
    New User
    May 2019
    Singapore
    Hi darkchina811, how do we know which BCM will support what features? Check available pin connection physically? Or is there a table from VW? Or we just have to go for High module for safest bet?
  12. #9
    Apr 2018
    ITALY
    yeah, why bother, just install a HIGH, but only the one that ETKA declares as fit for your VIN.
    my Golf left the factory with 23 ECUs. now she has 36. and counting
