Results 1 to 6 of 6
Thread: CLB label files
    Verified VCDS User VASTech A.D.'s Avatar
    Oct 2018
    SJ, RO
    Question CLB label files
    Hi
    Is there some trick seeing the CLB label files descriptions?
    I`m missing something here?
    Please let me know how can I see that bytes description, because it is not the first time when I see that popup but the label file is CLB not LBL.
    Thank`s!
    Saturday,08,June,2019,10:21:50:52276
    VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
    Dealer/Shop Name: VASTech Auto Diagnostics
    Workshop Code: 444 03743 000001
    VIN: WVGZZZ1TZ5W008514   License Plate:
    Mileage: 234400km-145649mi   Repair Order:
    Chassis Type: 1T (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
    VIN: WVGZZZ1TZ5W008514   Mileage: 234400km-145649miles
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 EH    HW: 028 101 145 0
       Component: R4 2,0L EDC G000SG  5687
       Revision: 12345678    Serial number: VWZ7Z0D9972339
       Coding: 0000072
       Shop #: WSC 10133 133 12345
       VCID: ED92B1EFF45D4A27CA-80B8
    18104 - Powertrain Data Bus
                P1696 - 000 - Implausible Message from Steering Column Controller
                        RPM: 798 /min
                        Torque: 36.0 Nm
                        Voltage: 14.21 V
                        Bin. Bits: 11001100
                        Bin. Bits: 00000000
                        (no units): 1.0
    Readiness: 0 0 1 1 1
       Part No: 1K0 907 379 D
       Coding: 0056006
       Shop #: WSC 10133 133 45725
       VCID: B3266797D2F9DCD7DC-80E6
       Part No: 1T0 907 044 S
       Component: ClimatronicPQ35 040 0202
       VCID: C0CC385B934F774F51-8094
       Part No SW: 1K0 937 049 G    HW: 1K0 937 049 G*
       Component: PQ35 BordnetzSG 1.0 0302
       Revision: 12345678    Serial number: 00000000027418
       Coding: 01898F000004100000120C000000000000
       Subsystem 1 - Part No: 1T0 955 119 A  Labels: 1TX-955-119.CLB
       Component: Wischer WWS A-MPV   0101
       Coding: 16711700
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No SW: 1T0 909 605     HW: 1T0 909 605
       Component: 04 AIRBAG VW62 0102 2112
       Coding: 0012340
       Shop #: WSC 01324 785 00200
       VCID: F2A8A293ED6395DF17-80A6
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 007 0030
       Coding: 0000042
       Shop #: WSC 03743 444 00001
       VCID: B02C689B23EFE7CFA1-80E4
    00895 - Cruise Control Switch (E45)
                014 - Defective
       Part No: 1T0 920 860 A
       Component: KOMBIINSTRUMENT VDD 1312
       Coding: 0007101
       Shop #: WSC 11111 111 11111
       VCID: AF2E6BE73ED1F837B8-80FA
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 A
       Component: Zuheizer            0506
       Revision:        B    Serial number: 09006207
       Coding: 0000011
       VCID: A30697D762194C572C-80F6
       Part No SW: 1K0 907 530 A    HW: 1K0 907 951
       Component: Gateway         H06 0020
       Revision: 06          Serial number: 00000133042D29
       Coding: 3D3F1340078002
       VCID: A50289CF6C2DB26742-80F0
       Component: IMMO                1312
       Shop #: WSC 06402 785 00200
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 B
       Component: Tuersteuergeraet 08 1915
       Coding: 0000116
       VCID: AD1271EF34DD8A278A-80F8
    Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
       Part No: 1K1 909 143 K
       Component: EPS_ZFLS Kl.0       0308
       VCID: B22862932DE3D5DFD7-80E6
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 C
       Component:    KSG              0545
       Coding: 00E802087F2D8404084F0100
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 B
       Coding: 0000116
       VCID: AE1076E339DBF13FB3-80FA
       Part No: 1K0 035 186 D
       Component: Radio BNO           0218
       Coding: 0020400
       VCID: A71E83C71621A07770-80F2
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 B
       Component: Tuersteuergeraet 04 0014
       Coding: 0000048
                014 - Defective
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 B
       Component: Tuersteuergeraet 05 0107
       Coding: 0000048
       Shop #: WSC 67814 141 02114
    End----------(Elapsed Time: 01:08, VBatt start/end: 14.1V/14.0V)-----------
  2. Likes Boki Ar, _Val liked this post
  3. #2
    Hmm.. The "See Label file" thing is kinda silly in a .CLB.
    If you could see it, this is what you would see:
    006,2,Pedal Monitoring,,See Label File
    ; xxxxxxx1 = Brake Light Switch operated
    ; xxxxxx1x = Brake Pedal Switch operated
    ; xxxxx1xx = Clutch Pedal Switch operated
    ; xxxx1xxx = CCS enabled
    ; xxx1xxxx = ACC enabled
    ; xx1xxxxx = Main Switch
    ; 00xxxxxx = ACC/CCS Mode not active
    ; 10xxxxxx = Status override
    ; 01xxxxxx = ACC/GRA active
    ; 11xxxxxx = ACC blocked
    006,4,Switch Monitoring,,See Label File
    ; xxxxxxx? = Stuck ON
    ; xxxxxx?x = Pressed OFF
    ; xxxxx?xx = Decelerate (-)
    ; xxxx?xxx = Accelerate (+)
    ; xxx?xxxx = Set (SET)
    ; xx?xxxxx = Resume (RESET)
    ; ?xxxxxxx = Stuck ON (Hardware)
    Nov 2017
    Latvia
    Was checking Level control on A8 D3 measuring blocks and 4E0-910-553.clb shows on screen to see label file. 015, 024-028
    024.1 - actually it was LEBEL file with an error.
    As I understand, I need to open this file from older vcds version as it got cbl'ed in summer of 2018 and it lost comment lines afterwards.
    Jul 2019
    So what is the point? Why are there some clb and no corresponding lbl files containing info?
    Quote Originally Posted by tultalk View Post
    I'm not sure I understand what you are asking.
    See Uwe's reply in this thread https://forums.ross-tech.com/showthr...d&p=188006#top
    .CLB files are encrypted label files. They are encrypted so that our wannabe competitors (mostly in the far east) can't just take the data we've put together and incorporate it in their tools.
  8. Likes NitrousOxide liked this post
