Results 1 to 3 of 3
Thread: CLB label files
    Verified VCDS User VASTech A.D.'s Avatar
    Oct 2018
    SJ, RO
    Question CLB label files
    Hi
    Is there some trick seeing the CLB label files descriptions?
    I`m missing something here?
    Please let me know how can I see that bytes description, because it is not the first time when I see that popup but the label file is CLB not LBL.
    Thank`s!
    Saturday,08,June,2019,10:21:50:52276
    VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
    Dealer/Shop Name: VASTech Auto Diagnostics
    Workshop Code: 444 03743 000001
    VIN: WVGZZZ1TZ5W008514   License Plate:
    Mileage: 234400km-145649mi   Repair Order:
    Chassis Type: 1T (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
    VIN: WVGZZZ1TZ5W008514   Mileage: 234400km-145649miles
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 EH    HW: 028 101 145 0
       Component: R4 2,0L EDC G000SG  5687
       Revision: 12345678    Serial number: VWZ7Z0D9972339
       Coding: 0000072
       Shop #: WSC 10133 133 12345
       VCID: ED92B1EFF45D4A27CA-80B8
    18104 - Powertrain Data Bus
                P1696 - 000 - Implausible Message from Steering Column Controller
                        RPM: 798 /min
                        Torque: 36.0 Nm
                        Load: 0.0 %
                        Voltage: 14.21 V
                        Bin. Bits: 11001100
                        Bin. Bits: 00000000
                        (no units): 1.0
    Readiness: 0 0 1 1 1
       Part No: 1K0 907 379 D
       Coding: 0056006
       Shop #: WSC 10133 133 45725
       VCID: B3266797D2F9DCD7DC-80E6
       Part No: 1T0 907 044 S
       Component: ClimatronicPQ35 040 0202
       VCID: C0CC385B934F774F51-8094
       Part No SW: 1K0 937 049 G    HW: 1K0 937 049 G*
       Component: PQ35 BordnetzSG 1.0 0302
       Revision: 12345678    Serial number: 00000000027418
       Coding: 01898F000004100000120C000000000000
       Subsystem 1 - Part No: 1T0 955 119 A  Labels: 1TX-955-119.CLB
       Component: Wischer WWS A-MPV   0101
       Coding: 16711700
       Part No SW: 1T0 909 605     HW: 1T0 909 605
       Component: 04 AIRBAG VW62 0102 2112
       Coding: 0012340
       Shop #: WSC 01324 785 00200
       VCID: F2A8A293ED6395DF17-80A6
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 007 0030
       Coding: 0000042
       Shop #: WSC 03743 444 00001
       VCID: B02C689B23EFE7CFA1-80E4
    00895 - Cruise Control Switch (E45)
                014 - Defective
       Part No: 1T0 920 860 A
       Component: KOMBIINSTRUMENT VDD 1312
       Coding: 0007101
       Shop #: WSC 11111 111 11111
       VCID: AF2E6BE73ED1F837B8-80FA
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 A
       Component: Zuheizer            0506
       Revision:        B    Serial number: 09006207
       Coding: 0000011
       VCID: A30697D762194C572C-80F6
       Part No SW: 1K0 907 530 A    HW: 1K0 907 951
       Component: Gateway         H06 0020
       Revision: 06          Serial number: 00000133042D29
       Coding: 3D3F1340078002
       VCID: A50289CF6C2DB26742-80F0
       Component: IMMO                1312
       Shop #: WSC 06402 785 00200
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 B
       Component: Tuersteuergeraet 08 1915
       Coding: 0000116
       VCID: AD1271EF34DD8A278A-80F8
    Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
       Part No: 1K1 909 143 K
       Component: EPS_ZFLS Kl.0       0308
       VCID: B22862932DE3D5DFD7-80E6
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 C
       Component:    KSG              0545
       Coding: 00E802087F2D8404084F0100
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 B
       Coding: 0000116
       VCID: AE1076E339DBF13FB3-80FA
       Part No: 1K0 035 186 D
       Component: Radio BNO           0218
       Coding: 0020400
       VCID: A71E83C71621A07770-80F2
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 B
       Component: Tuersteuergeraet 04 0014
       Coding: 0000048
                014 - Defective
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 B
       Component: Tuersteuergeraet 05 0107
       Coding: 0000048
       Shop #: WSC 67814 141 02114
    End----------(Elapsed Time: 01:08, VBatt start/end: 14.1V/14.0V)-----------
  2. Likes Boki Ar, _Val liked this post
  3. #2
    Hmm.. The "See Label file" thing is kinda silly in a .CLB.
    If you could see it, this is what you would see:
    006,2,Pedal Monitoring,,See Label File
    ; xxxxxxx1 = Brake Light Switch operated
    ; xxxxxx1x = Brake Pedal Switch operated
    ; xxxxx1xx = Clutch Pedal Switch operated
    ; xxxx1xxx = CCS enabled
    ; xxx1xxxx = ACC enabled
    ; xx1xxxxx = Main Switch
    ; 00xxxxxx = ACC/CCS Mode not active
    ; 10xxxxxx = Status override
    ; 01xxxxxx = ACC/GRA active
    ; 11xxxxxx = ACC blocked
    006,4,Switch Monitoring,,See Label File
    ; xxxxxxx? = Stuck ON
    ; xxxxxx?x = Pressed OFF
    ; xxxxx?xx = Decelerate (-)
    ; xxxx?xxx = Accelerate (+)
    ; xxx?xxxx = Set (SET)
    ; xx?xxxxx = Resume (RESET)
    ; ?xxxxxxx = Stuck ON (Hardware)
    Nov 2017
    Latvia
    Was checking Level control on A8 D3 measuring blocks and 4E0-910-553.clb shows on screen to see label file. 015, 024-028
    024.1 - actually it was LEBEL file with an error.
    As I understand, I need to open this file from older vcds version as it got cbl'ed in summer of 2018 and it lost comment lines afterwards.
