Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Help ! Audi A3 what unit are coded to immobiliser
    Jan 2015
    Many that’s uew, which sensors etc do you see not communicating , thanks
  2. #12
    Jan 2015
    Hi uew , I’ve put a ecu from my lads golf same engine basically same car , but vw golf , same engine code and sane ecu part number , so I tried to change the coding over , because that car is Manual and not dsg, it wouldn’t let me change this over, the fuel pump did turn on, this hasn’t happen since car was stolen, but did t start, short or something on starter realy . this is what is said when not aloud to put the faulty car coding fir ecu
    Coding rejected Error 22
    I’m now thinking the ecu is part of the fault , but only part of the fault, I’m going to buy a complete set
    Clocks
    Ecu
    Bcm
    Key transponder
    Steering column
    Is there anything else linked to the immobiliser that needs the key code us it SKC thanks again fir your time
  3. #13
    Quote Originally Posted by John ler View Post
    Clocks
    Ecu
    Bcm
    Key transponder
    Steering column
    You can't just swap in a different ECU and expect the car to start. That's been true since the advent of the first immobilizers 20+ years ago.
    On an 8V A3, if it has an Auto box, I believe the transmission controller is also tied in, but I'm not 100% certain; it might be "only" Component Protection.
    You can't do any immo work on this car with just a PIN/SKC. The Immo uses a challenge/response mechanism. The challenge changes with every key cycle and the only place the response is calculated from the challenge is the server on the corporate mothership.
  4. #14
    Jan 2015
    Can a auto lock smith do this, like they make a new key on the immobiliser side of things. And the component protection that might be on,it, can that be access buy again by the key guy? . I didn’t put the diffrent ecu on expection the car to start, I hoped I’d get the fuel pump prime, which It did and see what other codes it would show, to see if I had same codes as on the original ecu, most the faults didn’t show on the scan, pulse the priming of the fuel pump on opening door and turning the key, and an short to earth on the fuel system was no longer showing, my big thing is, can I change the coding over from an old ecu to the coding from my cars ecu, is this possible, thanks
  5. #15
    I do not know what exactly what an automotive locksmith can and can't do on this car.
    As for coding the replacement ECU, that depends whether it's truly compatible with the configuration of this car. Some ECUs can be switched between Auto and Manual, while others cannot. I do not know whether this one can or can't. You say it's the same part number, but you haven't posted a scan from it, so I'm not sure what you mean by that. If the full part number "04E-906-027-HF" is the same, then I would think it should be possible. But if by "part number" you only mean "04E-906-027", then all bets are off.
  6. #16
    Jan 2015
    hi got a little further on with the car now, but got fault on engine control unit, 1
    fault 17149 check coding of ecu , powertrain data bus and left with mil light on and epc,, cant select any of drive select options, or cruse control, any help would be great im totaly stuck now, ,many thanks
    Wednesday,07,August,2019,16:21:50:52681
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WAUZZZ8V1HA093146   License Plate: HARRYS CAR
    Mileage: 48779km-30309mi   Repair Order:
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 08 09 15 16 17 19 29 39 42 44 52 55 5F D6 D7
    VIN: WAUZZZ8V1HA093146   Mileage: 48779km-30309miles
    Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
       Component: R4 1.4l TFS   H23 2489
       Revision: R6H23---
       Coding: 02250012232401082000
       Shop #: WSC 55975 003 1048576
       ASAM Dataset: EV_ECM14TFS01104E906027HF 001005
       ROD: EV_ECM14TFS01104E906027HF.rod
       VCID: 6FB8DBB43711D0EF23B-803A
       CAN Converter 01:
    17149 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
              [Checking coding/versions ofcontrol modules in drivetrain]
                        Mileage: 48779 km
                        Date: 2019.08.07
                        Time: 16:16:20
                        Coolant temperature: 27 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 12.038 V
                        Acceleration: 0.000 m/s²
                        Cruise Control System (CCS): status-Bits 0-7: 7
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 2
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
    Readiness: 1110 0001
       Part No SW: 0CW 300 041 B    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1010
       Revision: 00005026    Serial number: CU501612106459
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 343214D81EB7B3371E9-8060
       Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
       Component: ESC           H62 0643
       Revision: 00000000    Serial number: 63516000001985
       Coding: 10F18AA22429226F89780E0440C928085124449170021472022150748208420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
       VCID: 78AAE0E8425F9757F21-802C
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [009] - -
                        Fault Frequency: 12
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.08.05
                        Time: 18:48:08
       Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
       Component: AC Automat    H03 0130
       Revision: 20002000    Serial number: 00000001115338
       Coding: 00100004000000011000000000001100
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
       VCID: 3C223CF836E77B77D69-8068
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: 12B8826800PAG0MUFU03
       Serial number: 02001634803465
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA6F6F0607BA967B8D-802A
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 160821  043 0580
       Serial number:         160830183041
       Coding: 0A47F7
       Serial number: 62499239
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 08 10 2016  00000157
       Serial number: 000000000ZY1631436M4
       Serial number: 00000000000037111248
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0317
       Serial number: 003TDR2F1D4L
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 107AB8484AEFAF175A1-8044
       Subsystem 1 - Part No SW: -----------    HW: 480 001 612 16
       Serial number: 35700000000D4A2D1D1T
       Subsystem 2 - Part No SW: -----------    HW: 480 001 612 16
       Serial number: 35800000000B7A2D1D1V
       Subsystem 3 - Part No SW: -----------    HW: 480 401 412 16
       Serial number: 3510001AB22CA56634C7
       Subsystem 4 - Part No SW: -----------    HW: 480 401 412 16
       Serial number: 3520001AB22CA563052-
       Subsystem 5 - Part No SW: -----------    HW: 480 401 411 16
       Serial number: 3550002C922E8E118178
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: -----------
       Component: PedP_Sensor_D  --- ----
       Serial number: -------------------$
       Subsystem 7 - Part No SW: -----------    HW: -----------
       Component: PedP_Sensor_P  --- ----
       Subsystem 8 - Part No SW: -----------    HW: 480 000 512 16
       Serial number: I0M00000000449C0EE1C
       Subsystem 9 - Part No SW: -----------    HW: 480 000 512 16
       Serial number: I0N00000000B59C0EE1L
    9450005 - Pedestrian Protection Crash Sensor (driver's side)
              B1032 15 [137] - Open or Short to Plus
                        Mileage: 48778 km
                        Date: 2019.08.05
                        Time: 18:48:28
    9450261 - Pedestrian Protection Crash Sensor (passenger's side)
              B1033 15 [137] - Open or Short to Plus
                        Mileage: 48778 km
                        Date: 2019.08.05
                        Time: 18:48:28
              U1101 00 [137] - Active
              [ATP Wrong IKA]
                        Fault Frequency: 10
                        Mileage: 48778 km
                        Date: 2019.08.05
                        Time: 18:48:24
       Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 09121604400207
       Coding: A418
       VCID: 015C8D0C1185D69FC5F-8054
       Part No SW: 8V0 920 972 J    HW: 8V0 920 972 J
       Component: KOMBI         H04 8316
       Coding: 27A401082B8026000100E8001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009054
       VCID: 45D4591C452D3ABFB97-8010
       Component: GW MQB High   515 5286
       Serial number: 03121610520548
       Coding: 030100043F0857005B0002481C0B00000001010000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 2F381BB4F79190EF63B-807A
       Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
       Component: J453 MFL  H04 0003
       Serial number: 20161128222640 22575
       Serial number: 75410803001612136964
              U1101 00 [009] - Active
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.08.05
                        Time: 18:57:08
                        Supply voltage: Terminal 30: 12.5 V
                        Terminal 15: On
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H06 0016
       ASAM Dataset: EV_LCMLeftCONTIAU426 001008
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42DE420054030D879C5-8016
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001008
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 261116EKP09088
       Coding: 001C0A204001040100001002
       VCID: 41DC4D0C5105169F85F-8014
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 261116EKQ09304
       Coding: 001C02204001040100001002
       VCID: 40DA48085A0F1F978A1-8014
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0EDE00102B230200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E2636F020FB6967F8D-806A
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 81A 035 192 B    HW: 81A 035 192
       Component: MU-HS-LND-EU  045 0170
       Coding: 01730001FF00000011111101000A00102F002AC601F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 201AE888BA4F3F97EA1-8074
       Subsystem 1 - Part No SW: 8W0 919 866 M    HW: -----------
       Component: ECE 2017  --- 0024
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY2095FF
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL125111600010803
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
                        Reset counter: 152
                        Mileage: 48779 km
                        Date: 2019.08.07
                        Time: 16:19:16
                        Voltage terminal 30: 14.6 V
                        Software module: status-SW_Status_Consistency: 01 00 00
                        Software module: status-SW_Status_Device:
    7191 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 152
                        Mileage: 48779 km
                        Date: 2019.08.07
                        Time: 16:19:18
                        Voltage terminal 30: 14.5 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 1768C3546F01782F1BB-8042
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 01:14, VBatt start/end: 14.7V/14.7V)-----------
  7. #17
    Jan 2015
    new scan, clearing the airbag faults i knew about, am I putting scan in wrong place, ie quotes ?
    Thursday,08,August,2019,12:32:17:52681
       Revision: R6H23---
       CAN Converter 01:
              P1647 00 [167] - -
                        Mileage: 48779 km
                        Date: 2019.08.08
                        Time: 12:25:04
                        Coolant temperature: 23 °C
                        Voltage terminal 30: 11.921 V
              P1612 00 [009] - -
                        Fault Frequency: 23
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.08.05
                        Time: 18:48:08
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 111 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001BB231F2C3B356
       Subsystem 7 - Part No SW: -----------    HW: 480 402 111 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001BB231F2C54352
              [ATP Wrong IKA]
                        Mileage: 48779 km
                        Date: 2019.08.08
                        Time: 12:24:16
       Coding: A418
       ROD: EV_GatewNF.rod
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.08.05
                        Time: 18:57:08
                        Terminal 15: On
       Coding: 8107
              U1111 00 [009] - -
                        Reset counter: 152
                        Mileage: 48779 km
                        Date: 2019.08.08
                        Time: 12:27:41
                        Voltage terminal 30: 11.8 V
    End----(Elapsed Time: 01:14, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
  8. #18
    Jul 2014
    Tallinn, Estonia
    Instead of QUOTE tags, use CODE tags.
    You are not seeing any drive modes because something has triggered Component Protection on the CAN gateway. You need to go to the dealer (or someone with a factory diagnostic connection) to get it removed.
  9. Likes Uwe, PetrolDave liked this post
  10. #19
    Jan 2015
    Many thanks, it’s the CP causing this is it, will that give me this epic light on dash to, I no reason and about the cp on gateway, because I had to fit a used engine ECU, is it the CP that’s giving me the message (check coding off engine powetrain, ) because the coding is as when it left factory, many thanks for reply, big help,
