Results 1 to 10 of 19
Thread: Help ! Audi A3 what unit are coded to immobiliser
    Jan 2015
    Hi guys a long story . But after I got my lads car back from been stolen and attempted fire , the car will not start or crank or fuel pump fire up , even when opening door, no noise as before , and when turn key . Theres no pressure what so ever
    On fuel ,Ive scaned car and loads of fault, I think leading from burnt wires shorting modules out, any way I think my ecu is fried and bcm, on my gateway Im getting no communication to all units , is this saying the gateway is fried to ? , what Im thinking is Ive found somebody that is selling a clock set , to inc clocks bcm ignition and keys and locks , so basically hopefully everything that is coded for immobiliser, is this right with what Ive said is included or are there any other things that are coded together ie gateway coded to the key , Im on my phone now pulling my hair out while sat in car waiting for the wife . I cant put a scan up yet, please anyone that can tell what is all linked to the key to start the car please help me, the car is a 2017 Audi A3, we didnt want to claim on insurance because my lads insurance policy with a claim on it would go up by 5000 a year more, crazy , but he loves his first car, thanks in advance
    Please ignore my spellings and gramma, I didnt learn this when I was young, hard life ,
    Start with the gateway. Verify it's getting power and ground. The Gateway should only need five things to talk:
    • Switched power
    • Unswitched power
    • Ground
    • CAN-H -- goes to Pin 6 of the Diagnostic socket
    • CAN-L -- goes to Pin 14 of the Diagnostic socket
    Jan 2015
    Thanks uwe Ill try that, which units are all connected for the immobiliser,? I no clocks/clusters and bcm and Something to do with key , is there anything else I would need, and would I have any problems transferring all these units from a dona car, into my lads car, asking as all modules are same part number , just to get it to running again if all else fails , thanks for your help again
    Quote Originally Posted by John ler View Post
    Thanks uwe I’ll try that, which units are all connected for the immobiliser,?
    Depends on how the car is equipped. Keyless entry/start? Automatic transmission?
    You wouldn't happen to have a scan of this car from when it was still in running condition, would you?
    Jan 2015
    Ill get a scan tomorrow uew, yes its key and its auto , it had wires burnt, Ive repaired all them, but first Im getting when putting foot on break firstly no noise when opening door or when putting key in first position , but no crank , full battery , but if putting power to starter solenoid using a power probe , it turns over fine off battery in car, but no fuel pump , Ive got fault saying accelerator pedal Wichita Ive tried another one, as I do have a golf at my address same everything apart from manual , tried fuel pump module or what ever its called and the pedal, but while getting fault saying accelerator fault, Ive got both o2 sensors, I understand having faults showing on them, you can get fault on pedal ?? Im just thinking ecu fealty, fire was so light , and really warm away from engine. Just down right side front around headlight underside , so wires damaged where around that area, but was heat to damage o2 sensor wires at plugs, but Id say really not enough heat to damage the ecu, this is why Im thinking a short causing damage to ecu, trouble is, while wires poss touching, power will have been turned on, by recovery and police/garage , Ill get an up to date scan on tomorrow , I do have on the central electrics, 0000000 all the way along the coding, dont no how Ill get the coding back, in insight we should have let insurance have it, but my lad loved the car and I didnt have the hart to say it was going and insurance was going to cost to much, so hell need to drive an old crapper , he had a hard enough time when he saw his car had gone, along with his mum anniversary present TTS , thanks for your help
    Sorry about grammar mate I do my best
    Jan 2015
    sorry forgotten how to put a scan up, on the bcm, i have tried to enter a code from a golf i have with the same engine etc, and 9 bcm will accept a code, why would it loses its coding, Im thinking both ecu and bcm have had it,, many thanks for looking, how would I get the coding back for the bcm now its lost,
    Thursday,06,June,2019,14:02:52:33601
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUZZZ8V1HA093146   License Plate: A3
    Mileage: 48778km-30309mi   Repair Order:
                    Address 01: Engine       Labels: 04E-907-309-V1.clb
    Control Module Part Number: 04E 906 027 HF    HW: 04E 907 309 BJ
      Component and/or Version: R4 1.4l TFS   H23 3545
               Software Coding: 02250012232401082000
                Work Shop Code: WSC 06314 790 00021
                  ASAM Dataset: EV_ECM14TFS01104E906027HF 001006 (AU37)
                           ROD: EV_ECM14TFS01104E906027HF.rod
                          VCID: 6FEC560BB61E4D3234-803A
    7 Faults Found:
    2813 - Accelerator Position Sensor (G79)
              P2122 00 [167] - Signal too Low
                        Mileage: 48778 km
                        Date: 2019.06.06
                        Time: 14:01:22
                        Coolant temperature: 70 C
                        Intake air temperature: 20 C
                        Voltage terminal 30: 0.000 V
                        Outside air temperature: 19 C
                        Absolute intake pressure: 100 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 6.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 15.9998
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Overrun cut-off-Bits 0-7: 0
    2815 - Accelerator Position Sensor 2 (G185)
              P2127 00 [167] - Signal too Low
                        Mileage: 48778 km
                        Date: 2019.06.06
                        Time: 14:01:22
                        Fuel level: 6.00 l
    4239 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
              P2184 00 [039] - Signal too Low
                        Mileage: 48778 km
                        Date: 2019.06.06
                        Time: 14:01:23
                        Fuel level: 6.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.2061
    2698 - Fuel Pressure Sensor (G247)
              P0192 00 [167] - Short to GND
                        Mileage: 48778 km
                        Date: 2019.06.06
                        Time: 14:01:23
                        Fuel level: 6.00 l
    17129 - Oxygen (Lambda) Sensor B1 S1
              P0131 00 [039] - Signal too Low
                        Mileage: 48778 km
                        Date: 2019.06.06
                        Time: 14:01:30
                        Fuel level: 6.00 l
    17143 - Oxygen (Lambda) Sensor B1 S2
              P0137 00 [039] - Signal too Low
                        Mileage: 48778 km
                        Date: 2019.06.06
                        Time: 14:01:30
                        Exh mss flw bef main cat conv bank 1 filtered: 0.0 kg/h
                        Exhaust gas temperature before catalytic converter: 19.49 C
                        Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120: 0.000 Ohm
                        Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister: 1
                        Test of oxygen sensors bank 1: Delta-Lambda: 0.00000
                        Oxygen sensor 2 bank 1 internal resistance limit value: 131070 Ohm
    4263 - System Voltage
              P0560 00 [039] - Malfunction
                        Mileage: 48778 km
                        Date: 2019.06.06
                        Time: 14:01:27
                        Coolant temperature: 71 C
                        Absolute intake pressure: 101 kPa abs
                        Fuel level: 6.00 l
    Readiness: 1110 0001
    Sunday,09,June,2019,18:08:11:52681
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 08 09 15 16 17 19 29 39 42 44 52 55 5F D6 D7
    VIN: WAUZZZ8V1HA093146   Mileage: 48778km-30309miles
    01-Engine -- Status: Cannot be reached 0100
    15-Airbags -- Status: Cannot be reached 0100
    29-Left Light -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    44-Steering Assist -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
       Component: R4 1.4l TFS   H23 3545
       Revision: R6H23---
       Shop #: WSC 06314 790 00021
       VCID: 6FB8DBB43711D0EF23B-803A
       CAN Converter 01:
    7 Faults Found:
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:13
                        Coolant temperature: 34 C
                        Intake air temperature: 19 C
                        Outside air temperature: 17 C
                        Fuel level: 6.00 l
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:13
                        Fuel level: 6.00 l
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:13
                        Coolant temperature: 35 C
                        Fuel level: 6.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.1775
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:13
                        Fuel level: 6.00 l
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:22
                        Coolant temperature: 36 C
                        Fuel level: 6.00 l
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:22
                        Exhaust gas temperature before catalytic converter: 17.24 C
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:18
                        Fuel level: 6.00 l
       Part No SW: 0CW 300 041 B    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1010
       Revision: 00005026    Serial number: CU501612106459
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 343214D81EB7B3371E9-8060
    10679 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [047] - -
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:13
                        Engine speed: 18.75 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 57 km/h
                        Control Module temperature: 20 C
                        CURRENT pressure: -9.5 bar
                        Clutch: primary stat: Driving
                        selected gear: GANG_UNDEFINIERT
                        Accelerator position: 0.0 %
                        DTC memory status: 12032
    21223 - No Communications with Power Steering Control Module
              U0131 00 [047] - -
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:13
                        DTC memory status: 25344
    21191 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [047] - -
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:13
                        Accelerator position: 0.4 %
                        DTC memory status: 7680
       Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
       Component: ESC           H62 0643
       Revision: 00000000    Serial number: 63516000001985
       Coding: 10F18AA22429226F89780E0440C928085124449170021472022150748208420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
       VCID: 78AAE0E8425F9757F21-802C
    15 Faults Found:
    0056 - Front Right Wheel Speed Sensor
              C101B 01 [137] - Electrical Failure
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    0166 - Steering angle sensor
              B1168 31 [137] - No Signal
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    8200 - Databus
              [FCAN: Airbag_01 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    8204 - Databus
              [FCAN: Airbag_02 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:17
    8206 - Databus
              [FCAN: Airbag_03 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:20
    8238 - Databus
              U1121 00 [137] - Missing Message
              [FCAN: LH_EPS_01 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    8242 - Databus
              [FCAN: LH_EPS_03 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    8246 - Databus
              [FCAN: Motor_Code_01 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:20
    8250 - Databus
              [FCAN: Motor_07 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:20
    8252 - Databus
              [FCAN: Motor_11 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    8254 - Databus
              [FCAN: Motor_12 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    8256 - Databus
              [FCAN: Motor_14 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    8258 - Databus
              [FCAN: Motor_20 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    8264 - Databus
              [FCAN: Tsk_06 message is not received]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    32993 - Control Module for Electric Parking Brake
              C10E2 F0 [009] - RPM Sensor Implausble Signal
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
       Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
       Component: AC Automat    H03 0130
       Revision: 20002000    Serial number: 00000001115338
       Coding: 00100004000000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
       VCID: 3C223CF836E77B77D69-8068
    262658 - High Pressure Sensor
              B10AE 31 [009] - No Signal
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
                        Outside air temperature: 17.5 C
                        Engine speed: Measured value not available
                        Temperature after evaporator: 20.6 C
                        System run time-Terminal 15 on: 166 s
    459009 - Databus
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
    459023 - Databus
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
    263682 - Exterior Air Quality/Humidity Sensor
              B137A 31 [009] - No Signal
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:15
                        Voltage terminal 30: 12.4 V
                        System run time-Terminal 15 on: 169 s
       Serial number: 02001634803465
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA6F6F0607BA967B8D-802A
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 160821  043 0580
       Serial number:         160830183041
       Coding: 0A47F7
       Serial number: 62499239
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 08 10 2016  00000157
       Serial number: 000000000ZY1631436M4
       Serial number: 00000000000037111248
    9 Faults Found:
    528405 - Databus
              [Airbag_01 Datenbus fehlende Botschaft]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:14
    541973 - Databus
              [Motor_04 Datenbus fehlende Botschaft]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:17
    542229 - Databus
              [Motor_14 Datenbus fehlende Botschaft]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:17
    542485 - Databus
              [Motor_18 Datenbus fehlende Botschaft]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:18
    555285 - Databus
              [LWI_01_alt aktiv]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:17
    555541 - Databus
              [Motor_12_alt aktiv]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:17
    556053 - Databus
              [LH_EPS_02_alt aktiv]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:17
    558101 - Databus
              [Airbag_02 Datenbus fehlende Botschaft]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:17
    559125 - Databus
              [Motor_07 Datenbus fehlende Botschaft]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:04:18
    Address 15: Airbags
       Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 09121604400207
       Coding: A418
       VCID: 015C8D0C1185D69FC5F-8054
       Part No SW: 8V0 920 972 J    HW: 8V0 920 972 J
       Component: KOMBI         H04 8316
       Coding: 27A401082B8026000100E8001000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009054
       VCID: 45D4591C452D3ABFB97-8010
    16776962 - Databus
              [Airbag_01 keine Kommunikation]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
    16776971 - Databus
              [Motor_04 keine Kommunikation]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
    16776978 - Databus
              [LH_EPS_01 keine Kommunikation]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
    16776988 - Databus
              [TSK_07 keine Kommunikation]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
       Component: GW MQB High   515 5286
       Serial number: 03121610520548
       Coding: 030100043F0857005B0002481C0B00000001010000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 2F381BB4F79190EF63B-807A
       Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
       Component: J453 MFL  H04 0003
       Serial number: 20161128222640 22575
       Serial number: 75410803001612136964
    131602 - Power Steering Control Module
              U101D 00 [009] - No Communication
              [Timeout Knoten 0x12 / 44 - Steuergert fr Lenkhilfe]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
                        Supply voltage: Terminal 30: 12.4 V
                        Terminal 15: On
    131605 - No Communications with Airbag Control Module
              U0151 00 [009] - -
              [Timeout Knoten 0x15 / 15 - Steuergert fr Airbag]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
                        Terminal 15: On
    131702 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [009] - -
              [Timeout Knoten 0x76 / 01 - Motorsteuergert]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
                        Terminal 15: On
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H06 0016
       ASAM Dataset: EV_LCMLeftCONTIAU426 001008
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42DE420054030D879C5-8016
    0279 - Databus
              [databus - message missing]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001008
    0279 - Databus
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 261116EKP09088
       Coding: 001C0A204001040100001002
       VCID: 41DC4D0C5105169F85F-8014
    458752 - Databus
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
    458803 - Databus
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
    Address 44: Steering Assist
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 261116EKQ09304
       Coding: 001C02204001040100001002
       VCID: 40DA48085A0F1F978A1-8014
    458752 - Databus
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
    458803 - Databus
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:10
       Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0230
       Coding: 0EDE00102B230200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
       VCID: 3E2636F020FB6967F8D-806A
    13705485 - Databus
              [Timeout CAN-Message Airbag_02]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    13705474 - Databus
              [LWI_01 Datenbus fehlende Botschaft]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
    13705475 - Databus
              [Motor_20 Datenbus fehlende Botschaft]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
    13705986 - Databus
              U1123 00 [137] - Received Error Message
              [Empfangener Fehlerwert im Signal ESP_VR_Radgeschw_02: Message ESP_19]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:12
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 81A 035 192 B    HW: 81A 035 192
       Component: MU-HS-LND-EU  045 0170
       Coding: 01730001FF00000011111101000A00102F002AC601F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 201AE888BA4F3F97EA1-8074
       Subsystem 1 - Part No SW: 8W0 919 866 M    HW: -----------
       Component: ECE 2017  --- 0024
       Component: DU High  H49 0014
       Serial number: AUZ8Z9GY2095FF
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL125111600010803
    6697 - Databus
              [Airbag: no communication]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
    6708 - Databus
              [Engine: no communication]
                        Reset counter: 152
                        Mileage: 48778 km
                        Date: 2019.06.09
                        Time: 18:02:11
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 1768C3546F01782F1BB-8042
       Component: LED1R         H09 0008
    End----(Elapsed Time: 01:13, VBatt start/end: 12.4V/12.3V. VIgn 0.0V)------
  7. #7
    Looks like you got it communicating, but gosh, that car's a mess. I'm not sure where to even start.
  8. #8
    Jan 2015
    Dose that look like engine ecu is ok ? Its been like that from start, didnt notice , bcm had no coding, would that make any difference, why would it have no coding uwe, some of the things I understand, , there area that had damage to wiring was only down right hand side of the car under the bonnet/hood , is there any way I could get any coding for that module , that might work , any ideas , thanks appreciate any help , Ive got live at gateway , and earth , live before ignition switched on and another with its on , dose that make any sense, thanks again
  9. #9
    Jan 2015
    Is there anywhere I can find which pins on the ecu plug should be live and earth , have you ever seen a ccm showing no code in it, without it been a new module , thanks
  10. #10
    Since it communicates, it's powered up. However, it looks like some of the actuators and sensors connected to it might not be.
    I believe an all-zero coding is normal for that BCM. All the things that used to be adjustable via Coding were moved to Adaptation channels.
