Hi all, I need a ABS code for passat 2008 2.0tdi auto hold. Some other guys changed parking brake control module and lost original code and now I get this car to sort it out, part numbers mach on both units, I find one code which is 0001291 with this code there is no more faults but parking brake fault light still flashes, there is autoscan from before
Thursday,06,June,2019,10:47:39:57164
VCDS Version: 19.6.0.2 (x64)
VIN: WVWZZZ3CZ8E229849 License Plate: YF08KDJ
Mileage: 243710km-151434mi Repair Order: 321
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ8E229849 Mileage: 243710km-151434miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BL HW: 03L 907 309
Component: R4 2,0L EDC G001SG 6221
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 00377 210 84959
VCID: 70E86E68637C5FCF61-8024
U1017 - 000 -
Mileage: 243713 km
Date: 2019.06.03
Time: 16:53:34
Voltage: 11.55 V
Bin. Bits: 11001010
Bin. Bits: 00000000
(no units): 0.0
U1017 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 243713 km
Date: 2019.06.03
Time: 16:53:39
Voltage: 11.55 V
Torque: 219.0 Nm
Hex Value: 0xFF00
Bin. Bits: 11001010
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 K HW: 3C0 614 109 K
Component: J104 C4 440 V2 0005
Revision: --020--- Serial number: 00000785497737
Coding: 0004408
Shop #: WSC 05311 000 00000
VCID: 264448309138417FCB-8072
8 Faults Found:
Fault Priority: 9
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 17:07:35
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00000000
Count: 228
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 17:01:00
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011110
Count: 199
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 17:01:00
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00011110
Count: 149
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 17:01:00
01542 - Yaw Rate Sensor (G202)
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 17:01:00
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 17:01:00
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 17:01:00
00810 - Sensor 1/2 for Brake Pressure
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 17:01:00
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 77FA5574061208F7A0-8022
Revision: 00H54000 Serial number: 01000008249487
Coding: A8808F0700041A1E470F00000F0000000008594300000100000000000000
Shop #: WSC 05124 000 00000
VCID: 71EE6B6C687656C76E-8024
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 280308 022 0601
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__006 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP70N8VX
Coding: 0012342
VCID: 3B7289447ABAEC9784-806E
Subsystem 1 - Serial number: 6333FTS650180798
Subsystem 2 - Serial number: 6343FTS610270708
Subsystem 3 - Serial number: 6353ETS6R2T1TVNP
Subsystem 4 - Serial number: 6363ETS6LMC0TVNP
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Fault Status: 11101001
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 16:54:23
Part No SW: 3C0 953 549 AE HW: 3C0 953 549 AE
Component: J0527 0020
Revision: 00026000 Serial number: 3C5953507AT
Coding: 0000111
VCID: 6FEA6D147E42403778-803A
Component: E0221 002 0010
Part No SW: 3C0 920 971 E HW: 3C0 920 971 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0004405
Shop #: WSC 00400 067 57207
VCID: 275A453496325877F0-8072
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P0841203C1
Coding: F9807F0E0002021003
VCID: 23425124E20AB457AC-8076
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 397E934C7086DE8796-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1132
Revision: 32008001 Serial number: 00000501488327
Coding: 0000693
Fault Status: 01100101
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 16:54:23
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.134 H08 1901
VCID: 36649870419831FF7B-8062
Component: KSG PQ46 ELV 042 0472
Coding: 01910A0001860E7630049E1F70085FCE107C01
Component: Neigungssensor 004 0611
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1132
Revision: 32008001 Serial number: 00000562088319
Coding: 0000692
VCID: 3C708A587FB4EBAF8D-8068
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000372665
Coding: 0000057
Shop #: WSC 00028 028 00001
VCID: 295E430C80266E07E6-807C
Fault Status: 11101101
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 16:54:21
Voltage: 11.30 V
Count: 71
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 00000000 Serial number: VWZ1Z2I6880722
Coding: 0500040002
Shop #: WSC 31414 790 31414
VCID: 6BD279048A5ABC1754-803E
00856 - Radio Antenna
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 16:54:40
03138 - Input AUX IN
Reset counter: 14
Mileage: 243713 km
Date: 2019.06.03
Time: 16:54:27
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0308
Revision: 41004101 Serial number: 00000000329349
Coding: 0000144
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0308
Revision: 41004101 Serial number: 00000000324622
Coding: 0000144
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90640810000579
Coding: 0000014
End-------------------------(Elapsed Time: 01:50)--------------------------
Address 03: DTCs cleared
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0000301,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0002412,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0013569,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0000309,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000309,to,0000267,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000266,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000265,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000264,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000263,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000262,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000261,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000261,to,0000258,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000274,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000268,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000269,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000270,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000271,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000272,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000273,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000273,to,0000275,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000273,to,0000276,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000277,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000278,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000279,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000280,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000281,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000282,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000282,to,0002322,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000282,to,0002333,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000307,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0002415,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0033272,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0029998,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000293,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000333,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0034125,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0004275,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0001282,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001282,to,0001288,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0001298,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0000415,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0000307,(05311/000/00000),
Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0001291,(05311/000/00000),
Address 01: DTCs cleared
Address 44: DTCs cleared
