Results 1 to 10 of 10
Thread: VW Passat abs coding
    Jun 2019
    Hi all, I need a ABS code for passat 2008 2.0tdi auto hold. Some other guys changed parking brake control module and lost original code and now I get this car to sort it out, part numbers mach on both units, I find one code which is 0001291 with this code there is no more faults but parking brake fault light still flashes, there is autoscan from before
    Thursday,06,June,2019,10:47:39:57164
    VCDS Version: 19.6.0.2 (x64)
    VIN: WVWZZZ3CZ8E229849   License Plate: YF08KDJ
    Mileage: 243710km-151434mi   Repair Order: 321
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
    VIN: WVWZZZ3CZ8E229849   Mileage: 243710km-151434miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 BL    HW: 03L 907 309
       Component: R4 2,0L EDC G001SG  6221
       Revision: --H01---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 00377 210 84959
       VCID: 70E86E68637C5FCF61-8024
                   U1017 - 000 -
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 16:53:34
                        Voltage: 11.55 V
                        Bin. Bits: 11001010
                        Bin. Bits: 00000000
                        (no units): 0.0
                   U1017 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 16:53:39
                        Voltage: 11.55 V
                        Torque: 219.0 Nm
                        Hex Value: 0xFF00
                        Bin. Bits: 11001010
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 K    HW: 3C0 614 109 K
       Component: J104    C4 440 V2   0005
       Revision: --020---    Serial number: 00000785497737
       Coding: 0004408
       Shop #: WSC 05311 000 00000
       VCID: 264448309138417FCB-8072
    8 Faults Found:
                        Fault Priority: 9
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 17:07:35
                        Hex Value: 0x0000
                        Voltage: 14.00 V
                        Bin. Bits: 00000000
                        Count: 228
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 17:01:00
                        Hex Value: 0x0000
                        Voltage: 14.00 V
                        Bin. Bits: 00011110
                        Count: 199
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 17:01:00
                        Hex Value: 0x0000
                        Voltage: 14.00 V
                        Bin. Bits: 00011110
                        Count: 149
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 17:01:00
    01542 - Yaw Rate Sensor (G202)
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 17:01:00
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 17:01:00
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 17:01:00
    00810 - Sensor 1/2 for Brake Pressure
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 17:01:00
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 77FA5574061208F7A0-8022
       Revision: 00H54000    Serial number: 01000008249487
       Coding: A8808F0700041A1E470F00000F0000000008594300000100000000000000
       Shop #: WSC 05124 000 00000
       VCID: 71EE6B6C687656C76E-8024
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 280308 022  0601
       Coding: 00046997
       Shop #: WSC 05124
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__006 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DP70N8VX
       Coding: 0012342
       VCID: 3B7289447ABAEC9784-806E
       Subsystem 1 - Serial number: 6333FTS650180798
       Subsystem 2 - Serial number: 6343FTS610270708
       Subsystem 3 - Serial number: 6353ETS6R2T1TVNP
       Subsystem 4 - Serial number: 6363ETS6LMC0TVNP
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
                        Fault Status: 11101001
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 16:54:23
       Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C5953507AT
       Coding: 0000111
       VCID: 6FEA6D147E42403778-803A
       Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0004405
       Shop #: WSC 00400 067 57207
       VCID: 275A453496325877F0-8072
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 E    HW: 3C0 907 951
       Component: J533__Gateway   H10 0080
       Revision:   H10       Serial number: 1200P0841203C1
       Coding: F9807F0E0002021003
       VCID: 23425124E20AB457AC-8076
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       VCID: 397E934C7086DE8796-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
       Component: J386  TUER-SG FT    1132
       Revision: 32008001    Serial number: 00000501488327
       Coding: 0000693
                        Fault Status: 01100101
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 16:54:23
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.134 H08 1901
       VCID: 36649870419831FF7B-8062
       Component:    KSG PQ46 ELV 042 0472
       Coding: 01910A0001860E7630049E1F70085FCE107C01
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1132
       Revision: 32008001    Serial number: 00000562088319
       Coding: 0000692
       VCID: 3C708A587FB4EBAF8D-8068
       Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
       Component: J540 EPB3  VW-09393 0009
       Revision:   008       Serial number: 00000000372665
       Coding: 0000057
       Shop #: WSC 00028 028 00001
       VCID: 295E430C80266E07E6-807C
                        Fault Status: 11101101
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 16:54:21
                        Voltage: 11.30 V
                        Count: 71
                        Hex Value: 0x1240
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 00000000    Serial number: VWZ1Z2I6880722
       Coding: 0500040002
       Shop #: WSC 31414 790 31414
       VCID: 6BD279048A5ABC1754-803E
    00856 - Radio Antenna
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 16:54:40
    03138 - Input AUX IN
                        Reset counter: 14
                        Mileage: 243713 km
                        Date: 2019.06.03
                        Time: 16:54:27
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0308
       Revision: 41004101    Serial number: 00000000329349
       Coding: 0000144
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0308
       Revision: 41004101    Serial number: 00000000324622
       Coding: 0000144
    Address 76: Park Assist        Labels: 3C0-919-283.lbl
       Part No SW: 3C0 919 283 C    HW: 3C0 919 283 C
       Component: Parkhilfe 8-Kan 004 0013
       Revision: 00004000    Serial number: 90640810000579
       Coding: 0000014
    End-------------------------(Elapsed Time: 01:50)--------------------------
    Address 03: DTCs cleared
    Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0000301,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0002412,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0013569,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0004408,to,0000309,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000309,to,0000267,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000266,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000265,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000267,to,0000264,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000263,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000262,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000264,to,0000261,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000261,to,0000258,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000274,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000268,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000269,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000258,to,0000270,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000271,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000272,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000270,to,0000273,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000273,to,0000275,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000273,to,0000276,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000277,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000278,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000276,to,0000279,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000280,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000281,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000279,to,0000282,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000282,to,0002322,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000282,to,0002333,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000307,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0002415,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0033272,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0029998,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000293,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0002333,to,0000333,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0034125,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0004275,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0000333,to,0001282,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0001282,to,0001288,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0001298,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0000415,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0000307,(05311/000/00000),
    Address 03,3C0 614 109 K,recoded (Short coding),from,0001288,to,0001291,(05311/000/00000),
    Address 01: DTCs cleared
    Address 44: DTCs cleared
  2. Likes Dana liked this post
  3. #2
    Jun 2019
    new autoscan is this
    Friday,07,June,2019,10:21:37:57164
    Mileage: 243730km-151446mi   Repair Order: 321
    VIN: WVWZZZ3CZ8E229849   Mileage: 243730km-151446miles
       Coding: 0000072
       Coding: 0001291
       Coding: 00046997
       Shop #: WSC 05124
       Coding: 0012342
       Coding: 0000111
       Coding: 0004405
       Coding: 0000693
       Coding: 0000692
       Coding: 0000057
       Coding: 0500040002
                        Reset counter: 18
                        Mileage: 243736 km
                        Date: 2019.06.03
                        Time: 22:12:46
                        Reset counter: 18
                        Mileage: 243736 km
                        Date: 2019.06.03
                        Time: 22:12:42
       Coding: 0000144
       Coding: 0000144
       Coding: 0000014
    End-------------------------(Elapsed Time: 01:53)--------------------------
    Mar 2019
    Poland
    Hello ; 3C0 614 109 K J104 C4 440 V2 0005 cod 0000285
    Jun 2019
    be trying this no work at all
    United States
    Hello Andis,
    Now that you are registered and a Verified VCDS user I can move this to the Car Repair Support sub-forum. In the meanwhile I'll check into the coding of WVWZZZ3CZ8E229849 and report back in forum (rather than to the e-mail) with any coding suggestions we may have so the answer becomes searchable.
    United States
    Vehicle Identification No. WVWZZZ3CZ8E229849
    Model passat sedan
    PA
    Date of production 22.04.2008
    Model year 2008
    Sales type 3C2192
    Engine Code CBAB
    Transmission Code KNS
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0HG Vehicle class differentiation -3C0-
    Emission standard 7MB Emission standard EU 4 plus
    Trailer hitch 1D0 without trailer towing
    airbag 4UE driver and front passanger airbags
    Aktivkohlebehälter / Ottopartikelfilter 1E0 Without activated charcoal canister
    Tray areas package QE2 Storage compartment
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 5RV Right exterior mirror, aspherical
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment levels A8C Comfort equipment
    Brake type in rear 1KU Disc brakes in rear
    batteries J0N Battery 330 A (61 Ah)
    Brake type, front 1LH Silver caliper
    Beverage holders 4M6 Beverage holders
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0N Component parts set, complying with vehicle type for Great Britain, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VF Information kit in English
    Operating voltage 9Z0 Operating voltage 12 V
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H0 Without "drive select"
    General operating permit, alterations C15 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FA roof without cut out
    Suspension system in rear 1JA Rear shock absorption, basic design 1
    Suspension system in front G07 Shock absorption in front
    Load-through hatch/ski bag 3X2 Load-through hatch
    Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
    Installation differentiation for components 0EN Installation differentiation for transmission MQ 350 -- vehicle components --
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 7TM Decorative inserts
    Scuff plates 7M0 Plastic scuff plates in door apertures
    Park distance control 7X2 Park distance control in front and rear
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL1 Extended pedestrian protection measures
    Headlight activation 8K0 Without special driving light switching
    Parking brake UH2 Parking brake
    Alternators 8GV Alternator 180 A
    Transmission types/gearshift mechanisms 0G4 Cable gearshift
    Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
    Weight category front axle L02 Suspension range 02 installation control only, no requirement forecast
    Base engine TG3 4-cylinder diesel engine 2.0 l unit 03L.A
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Transmission specifications G0K 6-speed manual transmission
    Cruise control system and speed limiter 6Y9 without cruise control system
    Brackets 3P0 Without bracket for first aid kit and warning triangle
    Rear seats 3NU Rear bench seat, not split, split backrest, folding centre armrest
    Heating and air-conditioning system 9AP Climatic air-conditioning system (semi-automatic)
    Headlamps 8BK Twin headlamps for driving on the left, with integrated high beam
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5B Instrument insert, mph speedometer Great Britain
    Breakaway interior rearview mirror 4L2 Breakaway interior rearview mirror, dimming
    headphone connection, rear 8MA no headphone connection in rear
    Body style K8B Notchback
    Luggage compartment floor covering 6SE Flat needle-punched trunk floor covering
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y1 Standard climatic zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 0F5 Fuel system for diesel engine
    Body measures 5C0 Without special body measures
    Radiator grille 6KA Radiator grille
    Rear license plate bracket 6P1 Rear license plate carrier (ECE)
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Country codes FE0 Without country code (no DVD player in vehicle)
    Steering system arrangement L0R Right-hand drive
    Reading lamp 8S7 2 reading lights in front
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P8 Electrically adjustable lumbar support for right front seat
    steering wheels 2ZB Leather-wrapped multi-function steering wheel
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E3 Center armrest in front
    Multi-function display/trip computer 9Q5 Multi-function display with control
    center console 3I5 center console
    Engine cooling 8Z5 not hot country
    Engine specifications D91 4-cyl. turbo diesel engine 2.0 L/103 KW (4 V) TDI common rail TG3/TJ3/TU3/TL4/TP4/TM3/TW3/TR4/TS1/TN5
    Left vanity mirror 4SV Vanity mirror, left, illuminated
    Right vanity mirror 4TU Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TD Rear fog light for driving on the left
    Front fog lamp/additional headlamp 8WA Without fog lights
    Hubcaps 1NL Trims for alloy wheels
    Wheels CP4 Alloy wheels 7.5J x 17
    Radios 8AG Radio with CD/MP3
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K0 Without tyre pressure monitor
    umbrella NS0 Without umbrella(s)
    tire HK0 Tires 235/45 R17 97W x1
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G3 Alloy spare wheel with original equipment tires
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    RCL "RCD 300" with MP3 replay function, 4 x 20 W, 8 speakers
    WD7 Anti-theft alarm system "Plus" -Single door opening and comfort locking-EU right-hand drive vehicle
    WHL Highline package UK
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SK Taillight assemblies with diodes (LED)
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TF Front left comfort seat
    Front seat, right 3SF Comfort seat, front right
    Seat belt check 9P1 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    seat covers N0X Seat trim covers in part-leather "Sports Grain"
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A3 seat heating for front seats separat controlable
    Side lights 7R3 Side turn signal lights (white)
    Audio-response system/voice control QH0 without voice control
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Protective side molding 4B4 Protective side molding
    Sunroof roller blind for rear/side windows 3Y0 without roller blind
    power outlet 7B3 12-volt outlet(s)
    Bumper 2JC Comfort bumpers
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
    Special approval measures 3M0 Without special measures
    Nameplate set 1DG Nameplate set "TDI"
    Special alarm systems 9A0 Without taxi alarm system
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B09 Type approval country GB/Northern Ireland
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Transit coating NT0 Transit coating (type 1)
    Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Assembly parts for engine (drive bearing) 1VG Assembly part for 4-cyl. engine
    Identification plates 1EX Special identification plate for EU
    Delivery equipment 2A0 Without delivery equipment
    First aid kit / warning triangle 1T0 Without first-aid material, without warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E6 electric air additional heater
    Windshield Glass 4GF Windshield in heat-insulating glass
    Second battery/battery installation 8FA without 2nd battery
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
    As far as I can tell, 0001291 is the correct 03-ABS coding. Furthermore, 03, 17, 19 and 53 all appear to be coded properly for drive-side, country and UH2 Auto-Hold. Did you try test driving the car, using the EPB a few times and locking the doors for a CAN nap yet .. or perhaps a good-old fashioned battery disconnect to clear confusion?
  8. Likes Uwe, Jack@European_Parts liked this post
    Jun 2019
    Yes be trying disconnect battery for 30 min, car be driving now for 2 days in normal use all works fine only this handbrake fault light flashes
  10. #8
    Is brake fluid low by any chance or have you jumped out tank sensor to verify function?
    Is the parking brake switch the correct part and or any parts in system possibly FOD?
    Checking each of the part numbers is advised.
  11. Likes Fredrick Awuor liked this post
  12. #9
    Jun 2019
    Ok guys, problem solved. So quick explaining after coding abs unit yellow parking brake light still flashes and there no be fault codes as you can see from autoscans, what I did disconnect battery for 3h and after running a parking brake test and light go off for good.
    Thanks all
  13. Likes Jack@European_Parts, Uwe, Dana, Boki Ar liked this post
  14. #10
    United States
    Excellent, I added a new Special Notes section to the Gen 3/EPB3 VW page here: http://wiki.ross-tech.com/wiki/index...#Special_Notes
  15. Likes Uwe, Boki Ar liked this post
