Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: HEX-CAN USB Interface not found
  1. #21
    Jun 2019
    I think I have the same cable and been using it with my 2014 A7 for some years. Yesterday I went to use it with an SQ5 probably about a 2016 model. It had prompted for an update to 19.6 so I had done that however the software didn't recognize the cable. I ended up uninstalling it and going back to 18.2.1 which worked fine.
  2. #22
    Quote Originally Posted by HaveBlue View Post
    Scratching my head. I've personally done scans on a several cars with 19.6 and a HEX+CAN cable even older than yours.
    If it works with 18.2, it's doesn't have munged up USB data like the OP in this thread does. I'm confident his (in the condition he reported) wouldn't work with any version.
    You can have different versions of VCDS installed at the same time. Just install them in different folders. My suggestion: Re-install 19.6 in a different folder than your working version and give us more details.
  3. #23
    May 2017
    Brazil
    Hi Uwe,
    Could you help me in one question?
    Hex can usb genuine last version work very well until the newer cars (ex: 2019 or 2020) or just older cars (ex: 2018, 2017,2016....). Thanks for your support.
    Best regards.
    Breno
  4. #24
    Quote Originally Posted by Papa Leguas View Post
    Hi Uwe,
    I'm not sure I understand exactly what you are asking. The HEX+CAN works fine on older cars. There are some compatibility problems with long adaptation channels in some modules starting around 2015, and there are some modules it can't talk to at all starting around 2016/2017. It doesn't work at all starting with 2019 models.
  5. #25
    May 2017
    Brazil
    Tks a lot!
