Results 1 to 3 of 3
Thread: Ibiza 6J - esp 9.0 problem
    Sketchy
    Mar 2015
    Poland
    Hello friends,
    I have a small problem
    Ibiza 2015 1.2 TSI
    ESP 9.0
    auto after the conversion from RHD to LHD, in esp returns one and the same error, after deleting not depending on anything once after 100m, once after 2km jumps error. The second error is from tyre pressure, it jumps at the same time with the first one. I did adaptations of everything, nothing helps. Maybe in coding I have to change from RHD to LHD? just what does it matter? and in which byte is this information? Everything in the car is original from RHD, including wires. No other module has errors. Rotary wheel sensors work properly, esp sensors etc. too. Any suggestions ? Thanks in advance for your help.
    Niedziela,02,Czerwiec,2019,12:22:31:27911
    VCDS -- Emulator VAG/VAS pracujący w środowisku Windows, uruchomiony na Windows 7 x64
    Wersja VCDS: AKP 18.9.1.0
    Wersja danych: 20190205 DS296.0
    www.vcds.pl
    VIN: VSSZZZ6JZFR155588   Numer rejestracyjny: IBIZA
                    Adres 03: ABS/hamulce       Plik etykiet: Brak
    Oznaczenie elementu: 6R0 907 379 BQ    HW: 6R0 907 379 AS
      Komponent i/lub wersja: ESP9.0i front H03 0002
               Kodowanie: 13DD287D412800C5C8191471825900880909
               Kod serwisu: WSC 00788 648 00255
                  Zbiór danych ASAM: EV_Brake1ESP90iBOSCH 003020 (SE25)
                           ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
                          VCID: 0E13A674D13A623A5F-805A
    2 - ilość znalezionych błędów. Oto one:
    0018 - suspension sensor
              C104B 29 [137] - inccorect signal
              MIL zapalona - Potwierdzony - Testowany od skasowania kodów błędów
                 Ramka zamrożona:
                        Stan błędu: 00000001
                        Priorytet błędu: 2
                        Częstość błędu: 1
                        Wew.licznik błędów: 80
                        Przebieg: 358 km
                        Data: 2014.14.06
                        Czas: 03:03:15
    0625 - Unknown error code
              C1146 02 [137] - Błąd sygnału
                 Ramka zamrożona:
                        Priorytet błędu: 2
                        Częstość błędu: 1
                        Przebieg: 358 km
                        Data: 2014.14.06
                        Czas: 03:03:25
    Please post a complete Auto-Scan using the English version of VCDS. You can download it from this page and it will happily co-exist with the Polish translation you are currently using.
    Sketchy
    Mar 2015
    Poland
    Scan oryginal coding RHD
    Saturday,08,June,2019,10:05:09:27911
    VCDS Version: 19.6.0.2 (x64)
    VIN: VSSZZZ6JZFR155588   License Plate: IBIZA
    Mileage: 400km-248mi   Repair Order:
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 02 03 04 08 09 10 15 17 19 25 44 4B 56
    VIN: VSSZZZ6JZFR155588   Mileage: 400km-248miles
    Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
       Part No SW: 03F 906 070 GS    HW: 03F 907 309 AE
       Component: SIMOS10.22AH10 5494
       Revision: --H10---    Serial number:
       Coding: 002500D6202400080000
       Shop #: WSC 00049 770 00189
       ASAM Dataset: EV_ECM12TFS02103F906070GS 004007
       ROD: EV_ECM12TFS02103F906070FP.rod
       VCID: 79F9E5A8F8B45587D6-802C
    Readiness: 0010 0101
       Part No SW: 0AM 300 062 P    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 6201
       Revision: 00043014    Serial number: CU501504196286
       Shop #: WSC 01324 785 00200
       VCID: 397925A87034958796-806C
       Part No SW: 6R0 907 379 BQ    HW: 6R0 907 379 AS
       Component: ESP9.0i front H03 0002
       Serial number: --------------
       Coding: 13DD287D412800C5C8191471825900880909
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
       VCID: 0E13A674D13A623F13-805A
    0018 - Suspension Sensors
              C104B 29 [008] - Signal Implausible
                        Reset counter: 121
                        Mileage: 381 km
                        Date: 2019.06.03
                        Time: 01:02:44
    0625 - Display for Tire Pressure Monitoring
                        Reset counter: 0
                        Mileage: 380 km
                        Date: 2019.06.03
                        Time: 01:00:57
    0944 - Databus
              U1122 00 [137] - Implausible Message
                        Reset counter: 81
                        Mileage: 383 km
                        Date: 2019.06.03
                        Time: 00:01:20
       Component: LENKW.SENSOR  H07 0070
       Serial number: 02051504651961
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF3F6B4E19A72BFE3-802A
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6J0 820 043 E    HW: 6J0 820 043 E
       Component: Climatronic   H03 0809
       Revision: S0000000
       VCID: 2643FED4518A0A7FCB-8072
       Part No SW: 7H0 937 090 D    HW: 7H0 937 090
       Component: BCM PQ25 Max4 H78 0725
       Revision: B9078001    Serial number: 0671 119150936
       Coding: 24882BE88861250093380EF06FCB9EC80FC063A9608C2049200000020000
       VCID: 2F6D1BF07E704B3738-807A
       Component: RLS 160415 05  54  0403
       Coding: 02242D
       Subsystem 2 - Part No SW: 6R0 959 802 AP    HW: 6R0 959 802 AP  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  007 5110
       Serial number: 13202558140623154835
       Coding: 030000
       Subsystem 3 - Part No SW: 6R0 959 801 AM    HW: 6R0 959 801 AM  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  007 5110
       Serial number: 13202563150303030918
       Coding: 030000
       Subsystem 4 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
       Subsystem 5 - Part No: 1K0 951 605 C
       Subsystem 6 - Part No: 1K8 951 171 A
       Subsystem 7 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B
       Component: E221__MFL-TAS  H30 0036
       Serial number: 0211742
       Subsystem 8 - Part No SW: 6R0 959 811 K    HW: 6R0 959 811 K
       Component: J388__TSG_HL  006 5110
       Serial number: 13202567150504135456
       Subsystem 9 - Part No SW: 6R0 959 812 K    HW: 6R0 959 812 K
       Component: J389__TSG_HR  006 5110
       Serial number: 13102566150505065459
    03591 - Control Circuit for Horn
                        Fault Frequency: 19
                        Reset counter: 82
                        Mileage: 357 km
                        Date: 2019.06.03
                        Time: 02:58:33
    Address 10: Park/Steer Assist (J446)       Labels:| 6J0-919-475.clb
       Part No SW: 6J0 919 475 E    HW: 7N0 919 475
       Component: PARKHILFE 8K  H01 0018
       Revision: --------    Serial number: 28291510300888
       Coding: 100102
       ASAM Dataset: EV_SE250ParkiAssis8K S01002
       ROD: EV_SE250ParkiAssis8K.rod
       VCID: 387F20AC833E8C8F69-806C
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagA0D H10 0020
       Revision: --------    Serial number: 003GX02AKSUD
       Coding: 003044
       Shop #: WSC 00049 770 00114
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4A9B6A64EDD20E1F0F-801E
       Serial number: 3495RRB405D36OUMDH3B
       Serial number: 3505RRB405P36OUMFGT%
    9447251 - Seat Occupied Sensor; Passenger's Side
              B1027 53 [009] - Deactivated
                        Mileage: 357 km
                        Date: 2019.06.03
                        Time: 02:57:52
       Part No SW: 6J0 920 907 P    HW: 6J0 920 907 P
       Component: KOMBI         H02 0805
       Coding: 110A01
       VCID: 3B753FA0B208A79784-806E
       Part No SW: 6N0 909 901     HW: 7H0 937 090
       Component: GW-K-CAN TP20 H78 0725
       Revision: B9078001
       Coding: 022200
       VCID: 70EFD88CA3CE14CF61-8024
       Component: IMMO          H02 0805
       VCID: 6ADBCAE48D12EE1F2F-803E
       Part No: 6R0 423 156 C
       Component: LenkhilfeTRW        V278
       Coding: 11221
       Shop #: WSC 00788
       VCID: 306F188CF74E54CF21-8064
    Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
       Part No: 6J0 959 441 A
       Component: MF-Modul       0007 0001
       Shop #: WSC 77005 000 00000
       VCID: 31691D88A8445DC72E-8064
       Part No SW: 6J0 035 156 A    HW: 6J0 035 156 A
       Component: Radio         H04 0013
       Revision: R0000000    Serial number: SEZAZ1R6894021
       Coding: 010004080203
       VCID: 2541F9D82C8C0167C2-8070
    End-------------------------(Elapsed Time: 03:24)--------------------------
    I try change coding in abs
    RHD 13DD287D412800C5C8191471825900880909
    LHD 13DD287D412800C5C8191471825900480909
    but can't , maybe other unit need change coding ? Try in 19 but the same resault
