Results 1 to 6 of 6
Thread: 3.0 TDI P0172, bank 1 too Rich.
    Feb 2019
    Canada
    Hi everyone, I'm trying to diagnose the P0172 code on a 2009 Touareg 3.0 TDI with 130k miles. I've Smoke tested the vacuum lines, quite a bit of smoke coming out of the crankcase when smoking the Intake, it seems excessive. Could I have an PCV issue? Fuel pump pressures seem fine.
    Air filter is new.
    Just the single code, nothing else.
    How should I proceed?
    Thank you all.
    Thursday,06,June,2019,09:22:35:28500
    VCDS Version: Release 18.9.1 Running on Windows 7 x64
                    Address 01: Engine       Labels:
    Control Module Part Number:
      Component and/or Version:
               Software Coding:
                Work Shop Code:
                          VCID: 55E903051C07A3EF9DB-5184
    000370 - Fuel Trim; Bank 1
                   P0172 - 000 - System Too Rich - Intermittent - MIL ON
                        Fault Status: 10100000
                        Mileage: 205283 km
                        Date: 2019.05.27
                        Time: 09:10:42
                        RPM: 1848 /min
                        Speed: 93.0 km/h
                        Voltage: 14.52 V
                        Load: 31.0 %
                        Bin. Bits: 00000000
                        Voltage: 1.560 V
                        Voltage: 0.760 V
    Readiness: N/A
    Thursday,06,June,2019,09:29:49:28500
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4437.4
    VIN: WVGFM67L29D035657   License Plate:
    Chassis Type: 7L (6N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 2E 36 37 46 47 55 56 68 69
              6C 6D 6E 76
    VIN: WVGFM67L29D035657   Mileage: 206040km-128027miles
    68-Wiper Electr. -- Status: OK 0000
    6E-Ctrl Head Roof -- Status: OK 0000
    Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
       Part No SW: 7L0 907 401 T    HW: 7L0 907 401 K
       Component: 3.0TDI FSA  G004AG  0140
       Revision: 33H01---    Serial number: VWX3Z0H2826271
       Coding: 0421002A590F0968
       Shop #: WSC 63425 002 1048576
       VCID: 3C3436797E04F3AAC1-5184
                        Mileage: 205283 km
                        Date: 2019.05.27
                        Time: 09:10:42
                        RPM: 1848 /min
                        Speed: 93.0 km/h
                        Voltage: 14.52 V
                        Load: 31.0 %
                        Bin. Bits: 00000000
                        Voltage: 1.560 V
                        Voltage: 0.760 V
    Readiness: N/A
       Part No SW: 09D 927 750 HN    HW: 09D 927 750 HN
       Component: AL 750 6A           3403
       Revision: 00H75000    Serial number:
       Coding: 0004984
       VCID: 014A878D59665E42D2-5160
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
       Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
       Component: ESP ALLRAD MK25E1   0304
       Revision: 00H53001
       Coding: 0004354
       Shop #: WSC 31414 790 00001
       VCID: 46C0549135C8B97AA7-8012
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
       Component:    Kessy            6850
       Revision: 00H22071    Serial number: VWX3Z0H2826271
       Coding: 0000232
       VCID: 312A174DAC460EC262-8064
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 AL
       Component: CLIMAtronic R/L     4537
       Coding: 0003030
       VCID: 7AB8F06131B00D9A93-802E
    00353 - Function Return Message from Fresh Air Blower Regulator
                        Voltage: 14.60 V
                        Voltage: 4.91 V
                        Voltage: 0.00 V
                        Voltage: 14.00 V
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
       Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
       Component: J519                2004
       Revision: -0004---    Serial number: --------------
       Coding: 230008002F00BC000000000000000000
       VCID: 004C8289576C574ADD-8054
    Address 15: Airbags        Labels: 7L0-959-655.lbl
       Part No SW: 7L0 959 655     HW: 7L0 959 655
       Component: J234__3V VW8T       0250
       Revision: 92012025    Serial number: 0039P0073MG%
       Coding: 0013142
       Part No: 7L6 953 549 G
       Component: J527                3601
       Coding: 0010211
       VCID: 43C64D8506FA8C5280-8016
    Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
       Part No SW: 7L6 920 890 P    HW: 7L6 920 890 P
       Component: J285 KOMBI-INST.    9733
       Revision: KHH06V42
       Coding: 0007301
       Shop #: WSC 31414 067 57207
       VCID: 45C2539D0CCEB262AE-8010
                        Fault Frequency: 22
                        Reset counter: 207
                        Mileage: 205106 km
                        Date: 2019.05.16
                        Time: 00:00:03
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 7L6 920 890 P
       Component: J533  GW-K-CAN TP20 9733
       Coding: 77E2EFDB4B846002
       VCID: 70ACD24963CC47CA2D-8024
                        Fault Frequency: 22
                        Reset counter: 207
                        Mileage: 205106 km
                        Date: 2019.05.16
                        Time: 00:00:03
       Part No: 0AD 927 755 BG
       Component: TRANSFERCASE        0126
       VCID: 014A878D59665E42D2-5184
    Address 2E: Media Player 3
       Part No: 7L0 959 760
       Component: Sitzverstellung     0702
       VCID: 77BEE95502A210F2EC-8022
       Part No SW: 7L6 035 684 C    HW: 7L6 035 684 C
       Component: RNS-MID       H02 0382
       Revision: AB001001    Serial number: VWZ6Z7K9083182
       Coding: 200500000100002600
       Shop #: WSC 93008 999 67494
       VCID: 36202451812829FA37-8062
                        Reset counter: 207
                        Mileage: 199392 km
                        Date: 2019.01.03
                        Time: 09:22:05
    00862 - Antenna for GPS Navigation (R50/R52)
                        Reset counter: 247
                        Mileage: 203242 km
                        Date: 2019.04.09
                        Time: 11:10:49
       Part No: 7L6 959 933 A
       Component: 4M HSG              0601
       Coding: 0000085
       VCID: 40CC428912EC974A9D-4B1E
       Subsystem 1 - Part No: 7L0 959 701 N
       Component: Tuersteuergeraet FS 6304
       Subsystem 2 - Part No: 7L0 959 702 N
       Component: Tuersteuergeraet BF 6304
       Subsystem 3 - Part No: 7L0 959 703 C
       Subsystem 4 - Part No: 7L0 959 704 C
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No SW: 7L6 035 466 C    HW: 7L6 035 466 C
       Component: DSP 10 Kanal        0020
       Revision: 00H05001    Serial number: 75835000591304
       VCID: 34241E5957543BEA09-8060
    Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
       Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
       Component: AFS-Steuergeraet    0136
       Coding: 1290371
       VCID: 3B3635657E0AF492C8-806E
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000019
       Coding: 00000019
                        Reset counter: 207
                        Mileage: 199392 km
                        Date: 2019.01.03
                        Time: 09:22:05
                        Reset counter: 247
                        Mileage: 203242 km
                        Date: 2019.04.09
                        Time: 11:10:49
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L6 955 119 B
       Component: J400__ Front Wiper  5301
       Coding: 0001397
       VCID: 393A2F6D7036C682DA-806C
       Component: RLS     180209 054  0402
       Coding: 00208941
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
       Component: J345  Anhaenger     0080
       Revision: 4A008002    Serial number: 00000117139279
       Coding: 0016386
       VCID: 3FCE41756A12E8B2E4-806A
       Part No SW: 7L6 907 441 B    HW: 7L6 907 441 B
       Component: J772__Rearview      0033
       Revision: 00H13000    Serial number:    PA8 J910223
       Coding: 0110001
    Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
       Part No SW: 7L6 959 107 B    HW: 7L6 959 107 B
       Component: J605  HECKKLAPPE    1310
       Revision: --H05---    Serial number: --------043825
       Coding: 0122110
       VCID: 3A3830617130CD9AD3-806E
    Address 6E: Ctrl Head Roof        Labels: None
       Part No SW: 7L6 919 044 AD    HW: 7L6 919 044 AD
       Component: J702  Dachdisplay   0401
       Revision: 1030006S    Serial number: 00000000110570
       VCID: 79BAEF6D30B606829A-802C
       Part No: 7L0 919 283 F
       Component: 0L Einparkhilfe     1108
       VCID: 393A2F6D7436C682DA-806C
    End----------(Elapsed Time: 02:25, VBatt start/end: 11.6V/14.2V)-----------
    HQ
    With engine at temp (+80C coolant) and at idle, go to 01-08-001 and field 3 should show fuel rail pressure, make a note of it. Exit out of the ECM, shut engine off. Now back into 01-08-001 and see what the fuel rail pressure does.
    Check compression.
    Jef
  3. Likes Uwe liked this post
    Tartu, Estonia
    Too rich on a TDI --- Clogged O2 sensor.
    The world is my oyster...
  6. #4
    Feb 2019
    Canada
    Thanks Jeff,
    The pressure at idle when warm is 223.6 bar.
    Engine off its 0.0.
    HQ
    223.6 BAR of fuel rail pressure at idle seem a bit... excessive. And I would expect rail pressure to be maintained when the engine is off, so 0 BAR doesn't seem good as well.... at face value, leaking injector(s).
    Jef
  8. Likes Uwe liked this post
  9. #6
    I agree with Golfi_vend on the OXS being contaminated & this is pretty common, additionally the ECU is FOD tuned and manifold missing stack data with deletes.
    There is a firmware update.
    Don't trust PSI displayed in controller or vicariously VCDS, verify with mechanical gauge.
