Results 1 to 10 of 19
Thread: New Member Barbalatte
    New User
    May 2019
    Sydney, Australia
    Hay guys, I just picked up a VCDS. I’m gona download Hex-V2 shortly.
    I currently own an Audi RS3, SQ5 and my brother in law has a Q3 and VW Caddy. So plenty to muck around on!
    I would like to change some basic stuff 1st. What’s the best way to start fiddling with this thing?
  2. Likes jyoung8607 liked this post
  3. #2
    ALWAYS take and save an Auto-Scan before you change anything - VCDS automatically saves scans and logs.
    If you're not 100% confident what coding(s) and/or adaptation(s) to change then post a full unedited Auto-Scan and ask away
  4. Likes Uwe, Dana liked this post
  5. #3
    New User
    May 2019
    Sydney, Australia
    Thanks Dave. Will do.
  6. Likes Dana liked this post
  7. #4
    New User
    May 2019
    Sydney, Australia
    Guys just plugged the VCDS HEX-V2 in for the 1st time.. I’ve run the test and connection seems to be good.
    PORT STATUS: OK
    INTERFACE: Found
    Type Hex-V2
    CAN: OK K1: OK K2: OK
    After this it jumps to another screen asking for Firmware update.
    “Network Error
    Unable to contact server. Check your internet access.
    Couldn’t connect to server
    Outgoing TCP 11000
    Test result Fail”
    What’s the problem???
    Also I have the SQ5 but it’s not listed under the “Auto-Scan” section. If I use Auto detect I get another error
    “Failure to communicate (0)
    Please use (Options) > (Test) for further details.
  8. #5
    New User
    May 2019
    Sydney, Australia
    Guys i plugged in my RS3 and it worked.
    Please see below.
    Any help appreciated. I would like to learn how to reprogram a few things like alarm beep. Strobbing(?) lights etc
    Saturday,15,June,2019,20:14:44:63594
    VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WUAZZZ8V8GA901285   License Plate: Nxxxx
    Mileage: 31281km-19437mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 52 55 5F
              6C BB BC
    VIN: WUAZZZ8V8GA901285   Mileage: 31281km-19437miles
    Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
       Part No SW: 8V0 907 404     HW: 07K 907 309 C
       Component: 2.5l R5/4V TF H52 0005
       Revision: NKH52---
       Coding: 12250032252601033620
       Shop #: WSC 29779 002 1048576
       ASAM Dataset: EV_ECM25TFS0118V0907404 001006
       ROD: EV_ECM25TFS0118V0907404.rod
       VCID: 76B51A0DF848BB17E09-8022
       Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
       Component: GSG DQ500     H10 5210
       Revision: 00H10V01
       VCID: 290F01717976A4EFBDB-807C
       Part No SW: 8V0 907 379     HW: 8V0 907 379
       Component: ESC           H42 0020
       Revision: 00000000    Serial number: 61345000000176
       Coding: 999CF08DBA9915AA4093086C4396920644990F5DA80210C2496022
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 061003
       ROD: EV_Brake1UDSContiMK100IPB_061.rod
       VCID: 015F79D1A1868CAFC5B-8054
       Revision: 00021000    Serial number: 0370138548
       Coding: 030C0C
       VCID: 3A2DCE3D8CD01F77C41-806E
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000674672
       Coding: 03100015110000001000000000001400
       VCID: 3333E319ABBAEE3F077-8066
       Serial number: 276884B7000000000001
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Component: BCM MQBAB H   H24 0173
       Serial number: 01061516700117
       Coding: 07151C46C24106FD03844004B31C07A80800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 094F61F199B6C4EF9DB-805C
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 150522  042 0580
       Serial number:         150616233857
       Coding: 0A47F7
       Serial number: 24038408
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 30 03 2015  00000515
       Serial number: 000000000ZY151461H0K
       Serial number: 00000000000032761267
       Sun Roof:
       Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST000D2SKR00000
       Coding: 901E00
    263442 - Siren / Alarm Horn for Anti-Theft Alarm System
              B131D F7 [008] - No Release by Immobilizer
                        Fault Frequency: 45
                        Reset counter: 248
                        Mileage: 29348 km
                        Date: 2019.03.21
                        Time: 15:32:12
       Revision: --------    Serial number: 39391517006018
       Coding: 0030150011
       VCID: 43D3B3D9FB1A5EBF977-8016
       Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
       Component: DAEMPFUNGS-SG H09 0072
       Serial number:       110615001
       ASAM Dataset: EV_AudiMagneRide 002003
       ROD: EV_AudiMagneRide.rod
       Component: AirbagVW20    012 0361
       Serial number: 003M2R0VZTS5
       Coding: 98CCC000008000005C54000000C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4BC39BF9D34A96FF6F7-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 002 306 15
       Serial number: 35767000000B6C21351Q
       Subsystem 2 - Part No SW: -----------    HW: 480 002 306 15
       Serial number: 3586700000077CD0351Y
       Subsystem 3 - Part No SW: -----------    HW: 480 401 606 15
       Serial number: 35165029F1B5A871C13J
       Subsystem 4 - Part No SW: -----------    HW: 480 401 606 15
       Serial number: 3526502C31B5A870B218
       Subsystem 5 - Part No SW: -----------    HW: 480 402 705 15
       Serial number: 3556502C51A14CC3E29P
       Part No SW: 8V0 953 521 FB    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 19061504220345
       Coding: A418
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 7F5BFF29D772FA5FB3F-802A
       Part No SW: 8V0 920 871 L    HW: 8V0 920 871 L
       Component: KOMBI         H02 6420
       Coding: 27AD081A3B8800080104EA001000000000000000
       Shop #: WSC 12345 123 61029
       VCID: 45D7ADC1F52E608FB93-8010
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1223
       Revision: --------    Serial number: 0003635673
       Coding: 030100043F0860005B000268B80B00000001010000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 75B71D01E54EB00FE93-8020
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 04 04 2015  E0012621
       Subsystem 3 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9041
       Serial number: 3513796803
       Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7754
       Serial number: HA1-00026.03.15
       Coding: 0601
       Revision: 00000000    Serial number: 15000164676005
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E005AEB4E9071ED-8060
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Component: SWA Master    H05 0080
       Serial number: 0369838358
       Coding: 030312
       ROD: EV_LaneChangAssis_VW51.rod
       VCID: 3829D435B2DC0D67325-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0080
       Serial number: 0370215124
       Coding: 030312
       Serial number: 090615BF805645
       Coding: 005D1A205C01040000001002
       Coding: 8103
       VCID: 372BD709BFC2021F3BF-8062
       Serial number: 270515BEQ18337
       Coding: 005D12205E01040000001002
       VCID: 42DDB6DDE40057B79C1-8016
       Coding: 01A600002B200200
       ROD: EV_HeadlRegulAFSMQBMLB.rod
       VCID: 3FDBBF2997F23A5FF3F-806A
       Coding: E00100
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 7050
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 7050
       Coding: E00100
       Part No SW: 8V0 035 022     HW: 8V0 035 022
       Component: MU-H-ND-RW    H45 0398
       Serial number: A628F0F7500714
       Coding: 017303080000000021511102000A00002F000326010001005E
       ROD: EV_MUHig6C3HBAS_AU37.rod
       VCID: 6A8D3E7DBCF06FF7741-803E
       Subsystem 1 - Part No SW: V03 959 801 PQ    HW: -----------
       Component: ROW 2018  --- 0068
       Component: DU High  H49 0014
       Serial number: AUZ8Z9FY203E2Q
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
       Component: ControlUnit_H  H81 0816
       Serial number: C1000030041500020193
       Component: Gracenote  --- 4006
    6697 - Databus
              [Airbag: no communication]
                        Reset counter: 248
                        Mileage: 27388 km
                        Date: 2018.12.14
                        Time: 10:27:55
                        Voltage terminal 30: 13.0 V
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_2CamSysRearPASE.rod
       VCID: 3039EC155AACD5277A5-8064
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 170515BEG18131
       Coding: 004D12204001040000001002
       Serial number: 170515BEG18134
    End----------(Elapsed Time: 01:41, VBatt start/end: 12.0V/11.9V)-----------
  9. #6
    Quote Originally Posted by barbalatte View Post
    https://duckduckgo.com/?q=8V+A3+VCDS+mods
  10. #7
    New User
    May 2019
    Sydney, Australia
    I can’t see an RS3 but I’m suspecting that the A3/S3/RS3 would be all the same. Correct?
    Thanks Uwe
  11. #8
    Yes, an except for the engine (and possibly the trans), the A3, S3, and RS3 are all essentially the same. The most important thing is that you find stuff for the correct generation of car; yours is the current 8V chassis. Prior to that, there was the 8P chassis, and before that, the 8L chassis. In some cases, the model year also makes a difference; BCMs tend to change mid-way through the production life of a chassis.
  12. #9
    Thanks Uwe
    G'day cobber!!! sounds like you are where I was after my first purchase of a VCDS cable -lots of stuff to learn and lots of discoveries. I'm sure that you will have a heap of fun, but try to make a few errors on the way - it's by far the best learning environment!!
    Uwe's link is a great reference facility and sites like these (including the brilliant on-line VCDS manual HERE) are real useful. But if you need some specific questions answered - there is an absolutely awesome experience base waiting behind the responses on this forum.
    And, my experience has been that even (my) not-so-intelligent questions are answered with due-consideration and sage empathy.
    PS: RS3 ? Very nice!! I don't believe that RS3s travel south of Sydney into the bad-lands of Victoria!!
  13. Likes Uwe, Bruce liked this post
  14. #10
    New User
    May 2019
    Sydney, Australia
    I’ve just tested the line and run a scan as you saw above. What would be your next step?
    How about I try something like activating the beep on the remote when you turn the alarm on. Hopefully not too difficult.
