Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: New Member Barbalatte
    New User
    May 2019
    Sydney, Australia
    Thanks for the Help Don.
    I understand “Select Control Module” bit but I’m a bit wet behind the ears after that.
    After selecting it there is a list of modules.
    After selecting one of them like “5F-Info Electric” it scans but after that I don’t know what to do.
    After Security access I get stuck. I thing from memory it’s 31347?
    Dan
  2. #12
    May 2014
    ^^^ sure - that's a good tweak for starters. The most important thing when facing difficulties with VCDS is to remember why the book "Hitch Hiker's Guide to the Galaxy" sold so well. As Douglas Adams wrote with such simplistic eloquence - because it had the words "Don't Panic" in big bold letters on the front page. The only time that I do this is when Uwe tells me to panic!!!
    Here's a very, very, very unofficial suggestion as to how to proceed!
    After you have fired-up the VCDS software, press select on the "Select Control Module" part of "VCDS:Main screen" -see the top line RHS of the screen for these words. I like to think of this screen as being the front gate to the housing estate that is the CAN network for my car.
    After you do this, the RT software loads the control modules in your car that have successfully reported as being installed.
    Then select 09-Cent. Elect. module - This is one of the modules and it's sometimes called the BCM (hover your cursor over the word to see what it means) on this forum. The "09" means that the BCM lives @ address hex09 on the CAN bus - which is a geeky way of numbering modules (Mr. Google will tell you more about hexadecimal numbering if you have an interest).
    After you do this, you will be presented with the "Open Controller" screen for the BCM. To continue my analogy, I like to think of this screen as being one of the homes in the housing estate - in this case, the particular house has the street address "hex09". Again, in my imagination I liken each of the boxes in the Open Controller screen akin to rooms in my BCM house.
    An important room is the one that has the label "Security Access - 16" on the door (I don't know what "16" means, but I suspect that it's part of the standards nomenclature for OBD - in which case it's way too arcane for my feeble brain and I just don't care).
    In their infinite wisdom, the sage boffins at the Audi factory have "locked-out" the ability for making some changes to these modules by requiring a security access code (called SA in this forum - hover your cursor over the word). Lots of adaptation channels are locked-out in this fashion
    So, to unlock the module for the particular changes that are needed for this tweak, you will need to select "Security Access - 16".
    After you do this, you will be presented with a screen that invites you to enter a SA. Now, SA s for new modules are as scarce as rocking-horse shit because they tend to be closely kept secrets by Audi. However, by various means known only to the wizened troglodytes that work tirelessly for us VCDS users in the bowels of RT's HQ, some SA s have been found. I have no idea (and I don't want to know) what nefarious means are employed by RT staff in this endeavor - but SAs are sometimes embedded into the VCDS software and a suggested SA often appears magically in a balloon when you click in the box on this screen.
    In any event, the SA for the BCM on your car is now well known - enter the magic number 31347 and then hit the doit!! button. You should be aware that these modules can get very cranky if you enter the wrong SA. You do get a couple of tries, but the module will lock-out for a period of time (measured with the car's ignition turned-on) if you are a recidivist. So, enter the SA carefully!
    After you do this, you will return to the Open controller screen, but this time the doors to all of the rooms in the BCM house will be unlocked.
    Select "Adaptation - 10" to enter the room that contains the adaptation channels in the BCM house. Now, for your particular BCM, this is a very full room - your BCM contains a large number of adaptation channels (the count can be in excess of 2,000 channels) and the trick to proceeding is to select the correct one. Fortunately those crazy, zany software folk at RT HQ have added a search box on this screen to help us mere mortals navigate the avalanche of adaptation channels that live in this room.
    So, your first task is to find the channel called IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln. Note: the name that I'm using here is a little different to the channel name in the instructions that you found from Uwe's reference because the newer RT software now reports adaptation channels with what RT calls "Tags" - which is a string of leading numbers followed by the "old" channel name. Compare my channel name with the name in your instruction to see the newer convention for RT's current naming protocol (this has only happened for adaptation channel names)
    Tags are good because all you need do to find the correct channel is to enter the Tag number - just the last part of the Tag number is necessary, so type in "ENG116666" into the search box (hmm.... just ignore the number-of-the-beast in this Tag - I'm sure that it's not a portent for the success of your first tweak)
    After you have done this, click on the down-arrow immediately above the search box and you should see the correct adaptation channel displayed - select this channel
    You should now be presented with a screen for this particular channel showing the "stored value" and another box called "new value". Click on this second box to see the permissible values for this channel and select the setting in your instructions. Then hit the "doit!! button. The VCDS software then does some secret stuff and eventually the setting that you selected magically appears in the "stored value" box to confirm the change that you made. I normally just stare in sheer wonderment at this part of the process and I contemplate what other secret information of mine is being uploaded onto RT's servers - unbeknown to me (but my therapist keeps cautioning that my conspiracy theories are likely to be unfounded- and I'm sufficiently comforted by this advice to keep using VCDS)
    After you do this, you will be returned to the adaptation screen - repeat the process for the second adaptation channel called IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln (remember to search for "ENG116667" - and again, ignore any hidden meaning in the number-of-the-beast!)
    That's it - pending the good auspices of the omnipotent deity that oversees ALL VCDS practices and assuming that the force is with you, the tweak will be completed and your Audi should slavishly bleat every time that you turn-ON/OFF the alarm.
  3. Likes NZDubNurd, Uwe, Bruce, MartinsX liked this post
  4. #13
    New User
    May 2019
    Sydney, Australia
    Don you are truely a magnificent man! I appreciate very much you going through that step by step.
    I wi try this very soon and let you know how I go.
    God speed.
  5. #14
    You, sir, have the patience of a saint.
  6. Likes NZDubNurd, DV52, MartinsX liked this post
  7. #15
    New User
    May 2019
    Sydney, Australia
    Hi Don,
    I finally got around to doing this and set both to “Active” but still no beep on lock on the key fob.
    I have reset the MMI as well but. I go.
    UPDATE: It actually worked. The “Chirp” is very faint.
  8. Likes DV52 liked this post
  9. #16
    May 2014
    Quote Originally Posted by barbalatte View Post
    Hi Don,
    Congratulations. Your first tweak and successfully completed! You can now be considered to be a blooded VCDS user (an honorarium sought by many, but attained by just a few who have the wisdom to buy a RT cable/dongle) !!
    "very faint"? Not sure why this is - on my A3 8V (the R3 is too sporty for my pedestrian personality), the acknowledgement sound frequently wakes-up the dead - according to my neighbors.
    I'm not sure and I'm guessing really, but there is another software switch in the Acknowledgement signals suite of adaptation channels that is used to shorten/lengthen the tone. It may just be that this switch is set to "short" on your car - again, I'm guessing?
    So- given your recent elevation from newbie status, I won't re-describe all the steps in this tweak, but navigate to the adaptation channel below (remember- search for "ENG122187"):
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn.
    This channel can have 2 x settings: kurtz (meaning "short" in English) and normal. If the setting on your car is the former value, back-out of the screen and enter the magic SA - then change setting to normal
  10. #17
    New User
    May 2019
    Sydney, Australia
    Don,
    Thanks again. Yes I remember that one. I changed it to Short from Normal. I will change back when I get the laptop back.
    On another note, I went through the list of available changes and there are so many! Ones that I can understand I will attempt to change them but how do I find the meaning to the list? Is there a link I can source to read?
    One I was particularly interested in was the Ride Height. It was set at 368mm.
    I will get a link for a photo up soon.
    Am I correct in assuming you can drop the ride height?
    After adjusting the "New Value" here:
    https://www.dropbox.com/s/jdeiuwwuna...01.16.jpg?dl=0
    I got this screen next...
    What does this mean?
    https://www.dropbox.com/s/kwabwtkydi...02.00.jpg?dl=0
    SORRY IN ADVANCE, I’m not sure how to make it smaller.
    If Moderators could help out.....
    Monday,02,December,2019,16:49:52:63594
    VCDS Version: 19.6.0.6 (x64) HEX-V2 CB: 0.4505.4
    VIN: WUAZZZ8V8GA901285 License Plate:
    Mileage: 34249km-21281mi Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 52 55 5F
    6C BB BC
    VIN: WUAZZZ8V8GA901285 Mileage: 34249km-21281miles
    Address 01: Engine (------CZGB) Labels:. 07K-907-309-V1.clb
    Part No SW: 8V0 907 404 HW: 07K 907 309 C
    Component: 2.5l R5/4V TF H52 0005
    Revision: NKH52---
    Coding: 12250032252601033620
    Shop #: WSC 29779 002 1048576
    ASAM Dataset: EV_ECM25TFS0118V0907404 001006
    ROD: EV_ECM25TFS0118V0907404.rod
    VCID: 76B51A0DF848BB17E09-8022
    Part No SW: 0DL 300 011 D HW: 0BH 927 711 F
    Component: GSG DQ500 H10 5210
    Revision: 00H10V01
    VCID: 290F01717976A4EFBDB-807C
    Part No SW: 8V0 907 379 HW: 8V0 907 379
    Component: ESC H42 0020
    Revision: 00000000 Serial number: 61345000000176
    Coding: 999CF08DBA9915AA4093086C4396920644990F5DA80210C249 6022
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 061003
    ROD: EV_Brake1UDSContiMK100IPB_061.rod
    VCID: 015F79D1A1868CAFC5B-8054
    Revision: 00021000 Serial number: 0370138548
    Coding: 030C0C
    VCID: 3A2DCE3D8CD01F77C41-806E
    Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
    Component: AC Automat H13 0060
    Revision: 20027000 Serial number: 00000000674672
    Coding: 03100015110000001000000000001400
    VCID: 3333E319ABBAEE3F077-8066
    Serial number: 276884B7000000000001
    Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
    Component: BCM MQBAB H H24 0173
    Serial number: 01061516700117
    Coding: 07151C46C24106FD03844004B31C07A8080000000000000000 0000000000
    ROD: EV_BCMBOSCH_015.rod
    VCID: 094F61F199B6C4EF9DB-805C
    Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS370 150522 042 0580
    Serial number: 150616233857
    Coding: 0A47F7
    Component: G397_RLFS H06 0002
    Serial number: 24038408
    Coding: 00006C
    Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
    Serial number: 30 03 2015 00000515
    Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
    Serial number: 000000000ZY151461H0K
    Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Serial number: 00000000000032761267
    Sun Roof:
    Subsystem 6 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
    Component: J245 PS73.404 H03 0004
    Serial number: 0000FST000D2SKR00000
    Coding: 901E00
    263442 - Siren / Alarm Horn for Anti-Theft Alarm System
    B131D F7 [008] - No Release by Immobilizer
    Fault Frequency: 64
    Reset counter: 254
    Mileage: 31418 km
    Date: 2019.06.22
    Time: 10:50:40
    Revision: -------- Serial number: 39391517006018
    Coding: 0030150011
    VCID: 43D3B3D9FB1A5EBF977-8016
    Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
    Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
    Component: DAEMPFUNGS-SG H09 0072
    Serial number: 110615001
    ROD: EV_AudiMagneRide.rod
    Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
    Component: AirbagVW20 012 0361
    Serial number: 003M2R0VZTS5
    Coding: 98CCC000008000005C54000000C800000065
    ROD: EV_AirbaVW20SMEVW37X.rod
    VCID: 4BC39BF9D34A96FF6F7-801E
    Subsystem 1 - Part No SW: ----------- HW: 480 002 306 15
    Serial number: 35767000000B6C21351Q
    Subsystem 2 - Part No SW: ----------- HW: 480 002 306 15
    Serial number: 3586700000077CD0351Y
    Subsystem 3 - Part No SW: ----------- HW: 480 401 606 15
    Serial number: 35165029F1B5A871C13J
    Subsystem 4 - Part No SW: ----------- HW: 480 401 606 15
    Serial number: 3526502C31B5A870B218
    Subsystem 5 - Part No SW: ----------- HW: 480 402 705 15
    Serial number: 3556502C51A14CC3E29P
    Part No SW: 8V0 953 521 FB HW: 5Q0 953 549 E
    Component: Lenks. Modul 003 0110
    Revision: -------- Serial number: 19061504220345
    Coding: A418
    VCID: 7F5BFF29D772FA5FB3F-802A
    Part No SW: 8V0 920 871 L HW: 8V0 920 871 L
    Component: KOMBI H02 6420
    Coding: 27AD081A3B8800080104EA001000000000000000
    Shop #: WSC 12345 123 61029
    VCID: 45D7ADC1F52E608FB93-8010
    Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
    Component: GW MQB High 128 1223
    Revision: -------- Serial number: 0003635673
    Coding: 030100043F0860005B000268B80B0000000101000000000000 0000000000
    ROD: EV_GatewLear_013.rod
    VCID: 75B71D01E54EB00FE93-8020
    Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
    Serial number: 04 04 2015 E0012621
    Subsystem 3 - Part No SW: 8S0 915 181 HW: 8S0 915 181
    Component: J367-BDMHella H10 9041
    Serial number: 3513796803
    Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
    Component: Haldex4Motion H52 7754
    Serial number: HA1-00026.03.15
    Coding: 0601
    Component: ELV-MQBA H01 0120
    Revision: 00000000 Serial number: 15000164676005
    Coding: 5D00000000000000
    ROD: EV_ELVMarquMQB.rod
    VCID: 3431E005AEB4E9071ED-8060
    Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
    Component: SWA Master H05 0080
    Serial number: 0369838358
    Coding: 030312
    VCID: 3829D435B2DC0D67325-806C
    Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
    Component: SWA Slave H05 0080
    Serial number: 0370215124
    Coding: 030312
    Component: TSG FS 020 0041
    Serial number: 090615BF805645
    Coding: 005D1A205C01040000001002
    Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
    Component: EPS_MQB_ZFLS 505 5061
    Coding: 8103
    VCID: 372BD709BFC2021F3BF-8062
    Component: TSG BFS 020 0041
    Serial number: 270515BEQ18337
    Coding: 005D12205E01040000001002
    VCID: 42DDB6DDE40057B79C1-8016
    Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
    Component: AFS-ECU H01 0110
    Coding: 01A600002B200200
    VCID: 3FDBBF2997F23A5FF3F-806A
    Coding: E00100
    Coding: E00100
    Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
    Component: LeiMo links H01 7050
    Coding: E00100
    Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H01 7050
    Coding: E00100
    Part No SW: 8V0 035 022 HW: 8V0 035 022
    Component: MU-H-ND-RW H45 0398
    Serial number: A628F0F7500714
    Coding: 017303080000000021511102000A00002F000326010001005E
    ROD: EV_MUHig6C3HBAS_AU37.rod
    VCID: 6A8D3E7DBCF06FF7741-803E
    Subsystem 1 - Part No SW: V03 959 801 PQ HW: -----------
    Component: ROW 2018 --- 0068
    Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
    Component: DU High H49 0014
    Serial number: AUZ8Z9FY203E2Q
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
    Component: ControlUnit_H H81 0816
    Serial number: C1000030041500020193
    Component: Gracenote --- 4006
    6697 - Databus
    [Airbag: no communication]
    Reset counter: 254
    Mileage: 27388 km
    Date: 2018.12.14
    Time: 10:27:55
    Voltage terminal 30: 13.0 V
    Network diagnosis-Status: Enabled
    Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
    Component: MQB RVC Mid H07 0140
    Coding: 027300010201000300
    ROD: EV_2CamSysRearPASE.rod
    VCID: 3039EC155AACD5277A5-8064
    Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
    Component: TSG HFS 020 0041
    Serial number: 170515BEG18131
    Coding: 004D12204001040000001002
    Component: TSG HBFS 020 0041
    Serial number: 170515BEG18134
    End----------(Elapsed Time: 01:44, VBatt start/end: 12.0V/12.0V)-----------
  11. #18
    New User
    May 2019
    Sydney, Australia
    Guys I’m not sure if need to start a new thread or stay here but any help would be appreciated.
    Thanks Dan
  12. #19
    If it's about the same problems on the same car, stay with this thread.
  13. Likes Uwe liked this post
