DPF
alexliebt
C?ID=362745
Hi
Could any one help me to understand what is maximum oil ash volume? The reason I'm asking is that mine is 49 g and I don't know if is bad or not. My car is driving fine at the moment.
Address 01: Engine  (03L 906 023 GL)
06:35:44
  IDE00427-ENG101722   Particle filter: difference pressure-DIP_PF 0.00 hPa
  IDE00428-ENG100917   Particle filter: offset for differential press.-DIP_PF_AD[0] 1.33 hPa
  IDE00430-ENG102682   Particle filter: field regeneration request status-STATE_RGN_PF 0
  IDE00431-ENG102952   Particle filter: field regeneration lock status-LV_STATE_TEST_RGN_PF_INH_HLD 00000000
  IDE00432-ENG103847   Particle filter: time since last regeneration-T_WOUT_RGN 16254.80 s
  IDE00433-ENG103279   Particle filter: oil ash volume-MASS_ASH_PF 49.1503297 g
  IDE00434-ENG102050   Particle filter: soot mass calculated-MASS_SOOT_SIM_PF 8.88 g
  IDE00435-ENG101197   Particle filter: soot mass measured-MASS_SOOT_PHY_PF 1.40 g
  IDE00436-ENG102397   Particle filter: kilometers since last regeneration-DIST_RGN 201.1 km
  IDE01407-ENG100958   Particle filter: fuel consumption since last regeneration-FCO_SUM_RGN 10.67 l
Auto Scan
Wednesday,05,June,2019,06:39:43:36622
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
VIN: WVWZZZ3CZAE075321   License Plate: 1111
Mileage: 168850km-104918mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61
VIN: WVWZZZ3CZAE075321   Mileage: 168850km-104918miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 GL    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 5810
   Coding: 00114014032501080000
   ASAM Dataset: EV_ECM16TDI02103L906023GL 001006
   ROD: EV_ECM16TDI_001_VW46.rod
   VCID: 76B410CDD84FCD57B41-8022
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AK    HW: 3C0 614 109 AK
   Component: J104    C4 440 V2   0027
   Revision: --025---    Serial number: 00000795856674
   Coding: 0034287
   Shop #: WSC 05311 000 00000
   VCID: 678A4D89836524DF3F7-8032
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000000003
   Shop #: WSC 05311 115 00000
   ROD: EV_ClimaBasis_VW46.rod
   VCID: 6D863FA1AD190E8F45B-8038
   Part No SW: 3C8 937 049 AA    HW: 3C8 937 049 AA
   Component: Bordnetz-SG     H57 3204
   Revision: 00H57000    Serial number: 00000003339756
   Coding: A0900F0700041A00470A00000F000000000159435C000100000308000000
   Shop #: WSC 05124 123 12345
   VCID: 70B826D5B6ABE3676ED-8024
   Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 191009 022  0612
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__00J VW10 HI   1916
   Revision: 20013000    Serial number: 003E2PP3YD2Z
   Coding: 0012362
   VCID: 44D0BA05D2932FC7FA5-8010
   Subsystem 1 - Serial number: 6332MTS633892949
   Subsystem 2 - Serial number: 6342MTS658412949
   Subsystem 3 - Serial number: 6351HTS6SKE829KR
   Subsystem 4 - Serial number: 6361HTS6G4C729KR
   Part No SW: 3C5 953 501 BP    HW: 5K0 953 569 AA
   Component: LENKS.MODUL   009 0122
   Revision: FF010E35    Serial number: 20091105200027
   Coding: 4180270002
   ASAM Dataset: EV_VW360SteerWheelUDS A03002
   VCID: 74B02AC5CE33DF478A5-8020
   Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
   Component: KOMBI         H03 0305
   Coding: 160F00
   Shop #: WSC 05314 115 12345
   VCID: 2D06FFA16D99CE8F05B-8078
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0170
   Revision:   H14       Serial number: 0821G09B10013C
   Coding: F9801F06000203041003
   Shop #: WSC 05314 000 00000
   VCID: 2C00F2A55A03C787125-8078
   Part No SW: 3C0 959 433 AQ    HW: 3C0 959 433 AQ
   Component:    IMMO         044 0383
   Revision: 00044000    Serial number: VWZCZ000000000
   VCID: 79AE1BF1E5D1A22FD93-802C
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Part No SW: 1K0 959 701 AR    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1502
   Revision: 72009005    Serial number: 00000538599023
   Coding: 0000565
   VCID: 7EA408EDFCFF8517EC1-802A
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 194    3001
   Revision: 00H17000
   VCID: 313EE3D17D21AA6F213-8064
   Component:    KSG PQ46 ELV 044 0612
   Coding: 00910A0801860E7630049C1D7008DBCE103C01
   Subsystem 1 - Part No: 1K8 951 605
   Component: LIN BACKUP HORN H10 9003
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Component: EZE_2         H14 0170
   Revision: --------    Serial number: 0821G09B10013C
   Coding: 00000000
   VCID: 6694408D886F3DD7041-8032
   Part No SW: 1K0 959 702 AR    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1502
   Revision: 72009005    Serial number: 00000883899026
   Coding: 0000564
   VCID: 7F5AF5E9FBF58C1FE77-802A
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000072339
   Coding: 0000056
Address 56: Radio
   Part No SW: 1K0 907 534     HW: 3C0 907 951
   Component: Batt.regelung H14 0170
   Coding: 030B085A
   VCID: 68884EB5827B2BA736D-803C
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790772682
End----------(Elapsed Time: 01:18, VBatt start/end: 12.0V/12.0V)-----------
