Results 1 to 7 of 7
Thread: DQ200 BASIC SETTING OF TRASMISSION ISSUE
    Jun 2019
    Italy
    Hello everyone. I am an owner of GOLF TGI DSG 7, which start has trasmission problem very early 10000 km.
    I feel the trasmission change very soon, the engine always labouring at low rpm, a very bad response of the engine when pushing accelerator pedal.
    These problems start very likely, after a bodyshop mechanich reparation, where the battery was probabily disconnected.
    I lost hope in VW service, so I decided try to do adaptation by my self with a rosstech HEX V2 bought recently.
    TBA was perform succesfully and now I can feel the car better.
    Then an IDE 02903 [basic setting of trasmission] was selected from the scroll menu; initially the screen, shown "RUNNING" but after some minutes and some normal noise of trasmission, the "UNKNOW" message appear (with ignition ON, engine OFF), made me very concerned.
    This procedure appear different from what I aspected, expecially comparing with the one on the following link: wiki-ross tech at this link http://wiki.ross-tech.com/wiki/index...rbox_(DSG/0AM),
    So here I don't need to set any group, eg.60 etc...
    No fault codes are stored and the car seems work quite well, but always with not the best response of the engne when pressing accelerator pedal.
    I found somebody who post the following procedure:
    "Engine idle speed, do not press accelerator pedal
    Parking brake and foot brake applied during the entire procedure. This can be confirmed using Advanced Measuring Values:
    * IDE02713 Brake Light Switch
    * IDE02714 Brake test switch
    0D9 - DQ250 MQB - Basic Settings Procedure:
    [Select]
    [02- Auto Trans]
    [Basic Settings-04]
    Select [Basic settings of transmission]
    [Show Measuring Data] and select:
    * IDE00021 Engine speed
    * IDE00322 Status of basic setting
    * IDE00024 Transmission fluid temperature
    [Go!]
    - During the basic setting procedure, there may be some loud gear shifting noises from the transmission, this is normal."
    In my situation , with idle engine the "UNKNOW" message is shown again and adaptation does not start: I don't know if procedure was succesfully or not, is there a more update guide please??
    Many tanks!
    Hi and welcome.
    Jun 2019
    Italy
    I hope this is the scan required
    Tuesday,04,June,2019,22:20:41:51758
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZJP121418   Mileage: 28884km-17947miles
    Address 01: Engine (J623-CPWA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 ER    HW: 04E 907 309 E
       Component: R4 1.4l CSI   H16 5823
       Revision: WIH16---
       Coding: 01250032236405082000
       Shop #: WSC 30054 264 00000
       ASAM Dataset: EV_ECM14CSI01104E906016ER 002003
       ROD: EV_ECM14CSI01104E906016EH.rod
       VCID: 76B5E77AC84B9F57E0D-8022
       CAN Converter 01:
       Part No SW: 0CW 300 041 N    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1605
       Revision: 00005008    Serial number: CU501802195161
       Shop #: WSC 00028 028 00066
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 40D941A2DA0F61E78A1-8014
       Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
       Component: ESC           H25 0523
       Revision: 00000000    Serial number: 60668000003493
       Coding: 01FA6AA12422216D477B060160CB2580562484E26006A4733822F078C202430B00000012121212B835351919323200
       VCID: 03538EAE8B99BAFFD73-8056
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 00020004200110011005000000101022
       VCID: 6D87C816BD1D5C8F117-8038
       Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H36 0253
       Serial number: 01001806503990
       ROD: EV_BCMBOSCH_018.rod
       VCID: 08499982B2BF99A7821-805C
       Component: WWS    180210  043 0551
       Serial number:         180218230320
       Component: RLHS  047 0105
       Serial number: S8Y18M03D08H09M42S06
       Coding: 00A8DD
       Serial number: 000308418018053
       Coding: 0471051811
       VCID: 4BC3668EE349B2BF6F3-801E
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 3300670111FFC728949C810580400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E253F5AA0FB1717F8D-806A
       Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
       Serial number: 003VVR3YZFV
       Coding: 98CCC000000000005C0000CF000800000065
       Shop #: WSC 00028 028 00063
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 074B9ABEBFA196DF8BB-8052
       Subsystem 1 - Part No SW: -----------    HW: 480 000 103 18
       Serial number: 35700000000755C81C2O
       Subsystem 2 - Part No SW: -----------    HW: 480 000 103 18
       Serial number: 35800000000E0C393C2S
       Subsystem 3 - Part No SW: -----------    HW: 480 400 903 18
       Serial number: 3510001AD298CB0286EJ
       Subsystem 4 - Part No SW: -----------    HW: 480 400 903 18
       Serial number: 3520001C1294E953E7FK
       Subsystem 5 - Part No SW: -----------    HW: 480 400 303 18
       Serial number: 3550001C32929722E460
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 08031820240175
       Coding: 0410
       VCID: 025D8BAA9483B3F7DC5-8056
       Part No SW: 5G1 920 752 C    HW: 5G1 920 752 C
       Component: KOMBI         302 0310
       Coding: 07A42A082780000801882A011401000080000000
       Shop #: WSC 00028 028 00070
       VCID: 290FFC06497580AFBDF-807C
       Component: GW MQB High   518 5323
       Serial number: 24021810803755
       Coding: 030100047F085708FA0002481C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 3829294282DF2927321-806C
       Serial number: 29180000271310098061
       Coding: 2CFFFF
       Serial number: 0494257004
       Serial number: 0000306993038
       Coding: 003A03208000020000001000
       Shop #: WSC 00028 028 00231
       VCID: 47CB5ABEFF2156DF4BB-8012
       Serial number: 00000000000008307055
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  131 1081
       Coding: 011F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73B3DE6EDB398A7FC73-8026
       Serial number: 0000306159747
       Coding: 003A01208E00020000801000
       VCID: 46D557BAF82B4FD7B0D-8012
       Serial number: 00000000000008298091
       Coding: 090000
       Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
       Component: MU-S--ER      722 0867
       Coding: 02731000FF0000005111000100080A001F0500C40120050003
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2D0708167D9D9C8F517-8078
       Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
       Component: ABT_Std-2  H50 8130
       Serial number: VWZ6ZJV0636662
    End----------(Elapsed Time: 01:18, VBatt start/end: 12.4V/12.3V)-----------
    many thanks
  4. Likes Uwe liked this post
    Jun 2019
    Italy
    Solved the problem of basic setting of trasmission.
    adv. measuring block select:
    -basic setting sequence index (this is essential)
    -status of basic setting
    -satus of basic setting data
    [GO] basic setting of transmission
    wait until in the basic setting sequence index appear number 4, and then turn the engine ON
    after a couple of minutes and some noise, the live data should diplay now:
    -basic setting sequence index: [254]
    -status of basic setting: [16]
    -satus of basic setting data: [VALID]
    ...and info: [FINISHED CORRECTLY] finally is dislayed.
    This procedure work fine with me, and gears switch are much smoother but the pedal accelerator still has a bad response (only in Drive mode).
    Maybe a software problem? I have found this link very interesting seem matching with my issue:http://www.tvsengineering.nl/en/gearbox/dsg/dq200.html
  6. Likes Uwe, downtime liked this post
    New User
    Jul 2019
    Kosovo
    Hey when a want to do the basic setting it gives me the message to enter three numbers.does anybody known which numbers
    Quote Originally Posted by Nitnesvakes View Post
    It would be a lot easier to answer your question when you post a full unedited VCDS Auto-Scan so we know what car you have, what TCU is fitted, etc.
    New User
    Nov 2018
    Been waiting over a year for this guide lol. Knew it would come eventually. I had the dreaded unknown too and eventually gave up. Only issue was sometimes I lost drive and if I didn’t know about the holding gas pedal to the floor trick the car would have been off to dealers. I’m still reluctant to try this. Has anyone done a video or maybe plan to ?
