Results 1 to 7 of 7
Thread: 2008 VW Jetta 1.4 TSI engine start idle RPM variations
    Mar 2019
    Romania
    Question 2008 VW Jetta 1.4 TSI engine start idle RPM variations
    My 2008 2008 VW Jetta 1.4 TSI 122HP has some issues when started after a couple of days not used.
    Upon ignition it goes to 1400 RPM and then starts its very unstable descent towards 700 RPM where it becomes stable. The 10-15 seconds in-between are hectic, the revs go up and down and the car shakes. Even after stabilizing, sometimes it feels like the engine doesn't run very "round" (if you carefully listen to it, it feels somewhat like a missfire).
    This doesn't happen every time. From what I could observe it almost doesn't happen during cold weather. when it is hot outside, it happens more when the tank is less tan half full.
    The spark plugs have been changed and the throttle body cleaned (not very dirty anyway).
    On the tester there are some errors, but nothing related to engine management (see report below).
    Does anyone have an idea what is causing this?
    Thank you in advance!
    Wednesday,05,June,2019,20:37:17:50604
    VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
    VIN: WVWZZZ1KZ8M174332   License Plate:
    Mileage: 125990km-78286mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ8M174332   Mileage: 125990km-78286miles
    Address 01: Engine (CAX)       Labels: 03C-906-022-CAX.clb
       Part No SW: 03C 906 022 J    HW: 03C 906 022 J
       Component: MED17.5.20      G   8644
       Revision: D5H03---    Serial number: VWX7Z0H4243045
       Coding: 0000072
       Shop #: WSC 10102 599 84138
       VCID: A3066DE76210D4572C-80F6
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 P
       Component: ASR FRONT MK70      0105
       Coding: 0017025
       VCID: BFCEC197EEB890B728-80EA
       Part No SW: 1K0 907 044 DA    HW: 1K0 907 044 DA
       Component: ClimatronicPQ35 130 1213
       Revision: 00130023    Serial number: 00000000000000
       VCID: E99A3FCFC0BCCE07A6-80BC
       Revision: 00H54000    Serial number: 00000000952804
       Coding: 81078E0700041500470A00000F00000000095D035C00010C000000000000
       Shop #: WSC 00066 123 12345
       VCID: F1AA57AFE86C36C7EE-80A4
       Component: Wischer 300408 021  0501
       Coding: 00038805
       Shop #: WSC 00066
       Component: 2J AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1W1GN-
       Coding: 0012874
       VCID: BD32BB9FE4B482A73A-80E8
       Subsystem 1 - Serial number: 6332MSME3672732DE
       Subsystem 2 - Serial number: 6342MSME32521415
       Subsystem 3 - Serial number: 6351HSME141C4D47D
       Subsystem 4 - Serial number: 6361HSME141C24620
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Component: J0527           051 0100
       Coding: 0002021
       VCID: F8BC6A8B8B16678F29-80AC
    00576 - Terminal 15
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 1K0 920 874 A    HW: 1K0 920 874 A
       Component: KOMBIINSTRUMENT 3HL 2216
       Revision: V0002000    Serial number: VWX7Z0H4243045
       Coding: 0023103
       Shop #: WSC 10102 599 176587
       VCID: AB1685C70AC01C1794-80FE
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 260308F2013695
       Coding: E9807F060002021002
       VCID: B02C92AB23E67FCFA1-80E4
       Component: IMMO            3HL 2216
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000260088418
       Coding: 0000180
       VCID: BB36B587FAA08C9704-80EE
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.069 H08 1901
       VCID: B522A3BFDC845AE7F2-80E0
       Coding: 98900A0001060C7F2D048C0D70084FC6F0FC00
       VCID: 83460D67C2D034570C-80D6
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000078588412
       Coding: 0000180
       VCID: BC34B69BFFAE8BAF0D-80E8
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
                        Reset counter: 223
                        Mileage: 125980 km
       Part No: 1K0 035 186 AD
       Component: Radio GR0       034 0033
       Revision: 0003404S    Serial number: VWZ2Z2H6540654
       Coding: 0040400
       VCID: E89C3ACBDBB6F70FB9-80BC
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1120
       Revision: 11006001    Serial number: 00000003011286
       Coding: 0000144
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1120
       Revision: 11006001    Serial number: 00000003006863
       Coding: 0000144
       VCID: BE30BC93E9B299BF23-80EA
    End----(Elapsed Time: 01:26, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    No DTC's though huh?
    Boy this sounds familiar like a bad fuel lift prime or other fuel related condition for pre regulation to HPP.
    Read TSB's on this engine and consider installing fuel psi gauge on lift and post HPP to observe after a few days to see if prime is lost or an injector sticking open maybe.
    Mar 2019
    Romania
    Thank you for the answer, Jack!
    I did not install the gauge yet (I need to find one first). What I managed to do, in exchange is to use the tester to monitor the HPP's parameters before the ignition and afterwards, during the functioning of the engine. As you can see in the attached images, the pressure just before ignition is 6.76 bar (after turning the key off and then to the first position for three times it rose to 7.26 bar).
    During the actual ignition the pressure goes up to 75.57 bar and then it settles to 50 bar (which I understand is the normal operating pressure of the HPP).
    I also did a test with the engine warmed up to 80 degrees C (temperature of the cooling liquid). Once it reached this temperature I stopped the engine and the pressure was still rising (I understand this is a pressure test for the HPP, and if there was a leakage the pressure should have dropped).
    I don't know if what I wrote helps in identifying the cause of this issue, I am trying to "isolate" it. Does this help you more in figuring it out or should I stick to your first advice of installing a gauge to measure the pressure?
    https://scontent.fotp3-3.fna.fbcdn.n...55&oe=5D564EC9
    OBD is a guide, not an absolute and I trust mechanical's or DVOM & so I can cross check & to it; often it helps me find issues when the controller is lying to me & over the last 20 years from FOD tuners or the OEM!
    Mar 2019
    Romania
    Ok, so from the last update i managed to measure the pressure of the fuel coming from the fuel lift prime (the first video attached). Since the pressure varying a lot I bought a new one. It is not OEM, but Starline PC 1219 fuel pump.
    The second movie link is with the current situation. The pressure seems to be more stable, but the engine still starts awkward. It seems to struggle a little bit less than before, but the problem is still not solved. The only benefit I can observe is that when stabilized and running idle the engine doesn't have that irregular "misfire" feeling I described in my initial posting. Another observation would be that for the same trip done before on the highway at 120km/h on cruise control now, at 130km/h I get better fuel consumption (I know there are many variables involved, and I my observation could be misleading).
    Honestly if after the first movie I was sure, after the second I am not so sure I did a good thing with replacing the fuel pump in the tank.
    https://www.facebook.com/alex.boanca...7377374673415/
    https://www.facebook.com/alex.boanca...gaUbBXpQXbz-GE
    Any advice?
    Thanks a lot!
    Jul 2017
    Kenya
    Quote Originally Posted by asabiutza View Post
       Coding: 0000072
       Coding: 0017025
       Coding: 00038805
       Shop #: WSC 00066
       Coding: 0012874
       Coding: 0002021
    00576 - Terminal 15
       Coding: 0023103
       Coding: 0000180
       Coding: 0000180
                        Reset counter: 223
                        Mileage: 125980 km
       Coding: 0040400
       Coding: 0000144
       Coding: 0000144
    Consider carbon cleaning if not done so....and bear in mind that precatalyst warm up period exhibits such symptoms....I think you got misfires but below MIL detection threshold....log misfire counters on VCDS and watch in real time during the engine stuttering episode....as Jack has said,worth checking TSB for this engine,I recall struggling with faulty injector valves on a Golf 6 with similar engine,only to later realise VW updated them to a newer revision
  7. Likes Jack@European_Parts, Uwe liked this post
    May 2016
    asabiutza, FP look good enough for ignition.
    Assume last shot is KOEO, (key on engine off.) DON'T know if there is anything to be gleaned from boost specified and actual not congruent, but maybe a software VAG thing as said thought it not running as no RPM pid.
    Did have a Jetta that exhibited same problem, was over pressure oil pump holding open hydraulic lifter for first minute or so of start up. Was not consistent, but a real problem, would produce over 100psi when cold.
    Would be interested to graph manifold pressure (I,E, ) boost in case of turbo and see if manifold pressure is fluctuating during this. Would think at idle would only produce 1 psi at most, but curious if it is going into negative, I.E less than atmosphere 1000 bar at sea level, don't know your elevation.
    Understand with rough idle some of this is going to happen but maybe learn something.
    Don't know of VAG allows view of oil pressure, might watch it and see if yours is high, once warm thins and lifter problem will go away, just a thought.
    LARIMORE
  9. Likes Jack@European_Parts, Uwe liked this post
