Asam update problem VCDS-Mobile
JPL66
C?ID=354196
I have tried to get VCDS-mobile to work with my Hex-Net Pro.
I have a problem, described below, with ASAM data download failing.
1. At home network via USB-cable at windows 10 laptop, updating, after clearing RODs with VCDS-Mobile:
VCDS Interface Config V2.248
Downloading DS Update
Getting 530k
Download Finished
Unpacking DS Update
Update completed Successfully
Recheck for updates -> You are up to date.
So, this step seems to go smoothly.
2. At car, Golf R Variant DSG 2019 (post-wltp model):
- Hex-net in Infrastructure mode (Green light), connected to the car.
Starting Autoscan is followed with a warning message about missing ASAM data, and that it can be downloaded after the scan.
After the scan completes, I press Download update. (The saved autoscan log is below).
Wed,Jun,05,2019,02:02:59
VCDS Mobile 0.4505.0.4
VIN: WVWZZZAUZKP549473
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 36 39 3C 42 44
	 47 4B 52 5F 75 A5 A9 D6 D7
29-Left Light -- Status: Malfunction 0010
75-Telematics -- Status: Not registered 0001
Address 01: Engine  (DNUE  J623)	Labels: 8V-01.lbl
	Part No SW: 8V0 906 259 R	HW: 06K 907 425 J
	Component: 2.0l R4 TFSI  H13 0002
	Revision: --H13---
	Coding: 092540122466050B3000
	Shop #: WSC 00028 028 00071
	ASAM Dataset: EV_ECM20TFS0208V0906259R 001002
	ROD: N/A
	VCID: 4FE1E03FCA09A4B28808F1-801A
	No ASAM data for: "EV_ECM20TFS0208V0906259R"
No fault codes found.
Address 02: Auto Trans  (J743)	Labels: 0G-02.clb
	Part No SW: 0GC 300 014 B	HW: 0GC 927 711 H
	Component: GSG DQ381     H06 2403
	Revision: 00H06V08
	ROD: N/A
	VCID: 240B7F93F30F77EA057A16-8071
	No ASAM data for: "EV_TCMDQ381061"
Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
	Part No SW: 5Q0 614 517 EF	HW: 5Q0 614 517 BP
	Component: ESC           H35 0107
	Revision: 00000000
	Coding: 04FA6BA150242175477B070760C66920D60A84E2E0069677384250F8D2A84B0B0000000012121212B835351919323200
	Shop #: WSC 00028 028 00069
	ROD: N/A
	VCID: 79B57EE7240DDA0206ACAF-802C
	No ASAM data for: "EV_Brake1UDSContiMK100IPB"
Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
	Part No SW: 3Q0 959 435 L	HW: 3Q0 959 435 L
	Component: VWKESSYMQB    037 1204
	Revision: 00037000
	Coding: 132C0C0723
	ROD: N/A
	VCID: 43C9DC0F164150D21CB07D-8016
	No ASAM data for: "EV_KessyHellaMQBAB"
Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
	Part No SW: 5G0 907 044 CF	HW: 5G0 907 044 CF
	Revision: 00001K08
	Coding: 0202002420041001110500420010102A
	ROD: N/A
	VCID: 6D9D5AB7604576A29A542B-8038
	No ASAM data for: "EV_ACClimaBHBVW37X"
	Subsystem 1 -
	Subsystem 2 -
	Subsystem 3 -
Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
	Part No SW: 5Q0 937 086 BQ	HW: 5Q0 937 086 BQ
	Revision: --------
	ROD: N/A
	VCID: 8A57B12BF1EB419A9F7668-80DF
	No ASAM data for: "EV_BodyContrModul1UDSBosc"
	Subsystem 1 - 	Part No SW: 5G1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component: WWS    181130043 0551
	Serial Number:         181213162931
	Coding: 0E4DFD
	Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb
	Component: RLHS         052 0107
	Serial Number: SAY19M01D17H01M07S34
	Coding: 00A8EE
	Subsystem 3 - 	Part No SW: 5Q0-951-172
	Serial Number: 000000000ZY183300JM1
	Subsystem 4 - 	Part No SW: 5Q0-951-605-A
	Serial Number: 00000000000046218922
	Subsystem 5 - 	Part No SW: 5G0-959-591-A
	Component: J245 PS22.409H04 0005
	Serial Number: 0000FST0028MNFY00000
	Coding: 191900
	Subsystem 6 - 	Part No SW: 5G0-959-591-A
	Component: J394 PS22.409H04 0005
	Serial Number: 0000FST0028MNDW00000
	Coding: 191900
	Subsystem 7 -
	Subsystem 8 - 	Part No SW: 5Q1-953-521-M
	Component: Lenks.Modul  H03 0170
	Serial Number: 0100110120190C202314
Address 10: Park/Steer Assist  (J446)	Labels: 5Q-10.lbl
	Part No SW: 5QA 919 294 C	HW: 5QA 919 294
	Component: PDC 8 Kanal
	Coding: 0471155811
	ASAM Dataset: EV_EPHVA18AU3700000 009039
	ROD: N/A
	VCID: 4CDBF7333B1F9FAAEDEADE-8019
	No ASAM data for: "EV_EPHVA18AU3700000"
Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
	Part No SW: 5Q0 907 572 P	HW: 3QF 907 572 A
	Coding: 330067C15DFFC728949C810580400600000000000000000004
	ROD: N/A
	VCID: 44CBDF13134F57EA25BA76-8011
	No ASAM data for: "EV_ACCBOSCHVW416"
Address 14: Susp. Elect.  (J250)	Labels: 5Q0-907-376.clb
	Part No SW: 5Q0 907 376 B	HW: 5Q0 907 376 A
	Shop #: WSC 00000 000
	ROD: N/A
	VCID: 3833BBE35F87030AB922F2-806D
	No ASAM data for: "EV_DRCONTITEMIC"
Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
	Part No SW: 5Q0 959 655 BT	HW: 5Q0 959 655 BT
	Component: AirbagVW21    007 0403
	Shop #: WSC 00028 028 00057
	ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
	ROD: N/A
	VCID: 9369AC4FA6A180526CD0CD-80C6
	No ASAM data for: "EV_AirbaVW20SMEVW37X"
	Subsystem 1 - 	Part No SW: 5G0-980-945-B
	Component: BeltPretRevFLH37 0350
	Serial Number: 34169667E17011940669
	Coding: 333135
	Subsystem 2 - 	Part No SW: 5G0-980-946-B
	Component: BeltPretRevFRH37 0350
	Serial Number: 34169668E17011920719
	Coding: 333135
	Subsystem 3 - 	Part No SW: --------------
	Component: SideSensor_Df001 0887
	Serial Number: 357000000003D314D73J
	Subsystem 4 - 	Part No SW: --------------
	Component: SideSensor_Pf001 0887
	Serial Number: 35800000000EC885D63
	Subsystem 5 - 	Part No SW: --------------
	Component: SideSensor_Dr004 6149
	Serial Number: 3510001262B805C3D2A+
	Subsystem 6 - 	Part No SW: --------------
	Component: SideSensor_Pr004 6149
	Serial Number: 35200012E2B7227334B-
Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
	Part No SW: 5G1 920 791 B	HW: 5G1 920 791 B
	Component: KOMBI         403 4191
	Coding: 07AD601B7F8C000801887B0B5401000880000000
	ROD: N/A
	VCID: 2B1994AF9ED1B892C4A045-807E
	No ASAM data for: "EV_DashBoardVDDMQBAB"
Address 19: CAN Gateway  (J533)	Labels: 3Q0-907-530-V1.clb
	Part No SW: 3Q0 907 530 AA	HW: 3Q0 907 530 C
	Component: GW MQB High   521 5366
	Coding: 030100047F085900FB00827E9C0F00010001070000000000000000000000
	ROD: N/A
	VCID: 6E9F5DBB6D438DBAA35E24-803B
	No ASAM data for: "EV_GatewNF"
	Subsystem 1 - 	Component: 1-01-09-01-04
	Subsystem 2 - 	Part No SW: 5G0-959-442-AE	Labels: 3C8-959-537.clb
	Component: E221__MFL-DC1H11 0052
	Serial Number: 29180003056140019017
	Coding: 2DFFFF
	Subsystem 3 - 	Part No SW: 5Q0-915-181-K
	Component: J367-BDMHellaH10 9070
	Serial Number: 1073529304
Address 22: AWD  (J492)	Labels: 0CQ-907-554.clb
	Part No SW: 0CQ 907 554 J	HW: 0CQ 525 130
	Component: Haldex4Motion H55 7084
	Coding: 0001
	ROD: N/A
	No ASAM data for: "EV_AllWheelContrHA1VW37X"
Address 29: Left Light  (J1018)	Labels: 8V0-907-399.clb
	Part No SW: 8V0 907 399 D	HW: 8V0 907 399 D
	Component: LCM_MLBevo
	ROD: N/A
	VCID: 47D1C81F22797CF2C0D889-8012
	No ASAM data for: "EV_LCMLeftHELLAAU736"
000033 - ROD - Unknown faultcode
Address 2B: Steer. Col. Lock  (J764)	Labels: None
	Part No SW: 2Q0 905 861 A	HW: 2Q0 905 861 A
	Component: ELV-MQBB      H08 0021
	Coding: 0800000000000000
	ROD: N/A
	VCID: 312586C7BCFDD242FEFC87-8064
	No ASAM data for: "EV_ELVMarqMQBA0"
Address 36: Seat Mem. Drvr  (J810)	Labels: None
	Part No SW: 5Q0 959 760 C	HW: 5Q0 959 760 C
	Component: Sitzmemory    H09 0024
	Coding: 0010000000000500018280808080000000008181000000F400
	ASAM Dataset: EV_SeatMemorDriveSide 002022
	ROD: N/A
	VCID: 3D3DAAF770A526226A743B-8068
	No ASAM data for: "EV_SeatMemorDriveSide"
Address 39: Right Light  (J1023)	Labels: 8V0-907-399.clb
	ROD: N/A
	No ASAM data for: "EV_LCMRightHELLAAU736"
Address 3C: Lane Change  (J1086)	Labels: 5Q0-907-686.clb
	Part No SW: 5Q0 907 686 C	HW: 5Q0 907 686 C
	Component: HRE_Master    H12 0081
	Coding: 02011103
	ROD: N/A
	No ASAM data for: "EV_HREntryHella"
Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
	Part No SW: 5Q4 959 593 F	HW: 5Q4 959 593 F
	Component: TSG FS        006 0246
	Coding: 001F1220D200048000001000
	ROD: N/A
	VCID: 48D3CB232F67738AC9C282-801D
	No ASAM data for: "EV_DCU2DriveSideMAXHCONT"
Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
	Part No SW: 3Q0 909 144 M	HW: 3Q0 909 144 L
	Component: EPS_MQB_ZFLS  507 5082
	Coding: 911F0000
	ROD: N/A
	VCID: 3C3BA7F36BBF2F2A5D4A0E-8069
	No ASAM data for: "EV_SteerAssisMQB"
Address 47: Sound System  (J525)	Labels: 5Q0-035-456.clb
	Part No SW: 5Q0 035 456 A	HW: 5Q0 035 456 A
	Component: MIB2_lite_amp H40 0200
	Revision: 00000001
	Coding: 12000000008AAA8A000000000000
	ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
	ROD: N/A
	VCID: 2E1F9DBBADC3CDBAE3DE64-807B
	No ASAM data for: "EV_AMPMst11CGen2ALPI"
Address 4B: Multifunc. Module  (J745)	Labels: None
	Part No SW: 3Q0 907 338 C	HW: 3Q0 907 338 C
	Component: FCM MQB Low   002 0345
	Coding: 00000005090019D206204F01020000000000000000000000000000000000
	ASAM Dataset: EV_MultiModulContiVW48X 002006
	ROD: N/A
	VCID: 352DB2D74895FE62A204D3-8060
	No ASAM data for: "EV_MultiModulContiVW48X"
Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
	Part No SW: 5Q4 959 592 F	HW: 5Q4 959 592 F
	Component: TSG BFS       006 0246
	Coding: 001F1020DE00048000001000
	ROD: N/A
	No ASAM data for: "EV_DCU2PasseSideMAXHCONT"
Address 5F: Information Electr.  (J794)	Labels: 5N-5f.clb
	Part No SW: 5NA 035 043 D	HW: 5NA 035 043
	Component: MU-H-N-EU     H55 1367
	Coding: 02731201000000004111000200080A231F0107F4012004009E
	ROD: N/A
	VCID: 3731B8DF52990C72B038F9-8062
	No ASAM data for: "EV_MUHig4CGen2HBAS"
	Subsystem 1 - 	Part No SW: 5G6-919-606
	Component: ABT_High-2   H52 9130
	Serial Number: VWZ6ZJW0211258
	Subsystem 2 - 	Part No SW: V03-959-806-FL
	Component: ECE 2019     --- 0175
	Serial Number: --------------------
	Subsystem 3 - 	Part No SW: V03-959-800-EG
	Component: Gracenote2   --- 1017
Address 75: Telematics  (J949)	Labels: 5QE-035-285.clb
	Part No SW: 5NA 035 284 C	HW: 5NA 035 284 C
	Component: OCULowMQBLGE  H19 0825
	Revision: --------
	Coding: 02730201EA42380D3F1CBE020045400382E608
	ASAM Dataset: EV_OCULowMQBLGE 004049
	ROD: N/A
	No ASAM data for: "EV_OCULowMQBLGE"
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q0-980-65X-A5.clb
	Part No SW: 3Q0 980 654 H	HW: 3Q0 980 654 A
	Component: MQB_B_MFK     H09 0272
	Coding: 0003070200000401002623548150A90098000E300040
	ROD: N/A
	No ASAM data for: "EV_MFKBoschMQBB"
Address A9: Struct. Borne Sound  (J869)	Labels: 5G-a9.lbl
	Part No SW: 5G0 907 159 D	HW: 4H0 907 159 A
	Component: SAS-GEN 2     H07 0001
	ROD: N/A
	VCID: 2F2180BFAAC9C4B2E8C891-807A
	No ASAM data for: "EV_SoundActuaGen2AU64X"
Address D6: Light Ctrl Left 2  (A31)	Labels: None
	Part No SW: 7P5 941 572 AG	HW: 7P5 941 572 A
	Component: LED1L         H07 0008
	ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
	ROD: N/A
	VCID: 80439303C7D70BCAC1121A-80D5
	No ASAM data for: "EV_LEDMinMaxL_KEBODAVW481"
Address D7: Light Ctrl Right 2  (A27)	Labels: None
	Component: LED1R         H07 0008
	ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
	ROD: N/A
	No ASAM data for: "EV_LEDMinMaxR_KEBODAVW481"
End--(Elapsed Time: 03:09, VBatt start/end: 12.4/12.3 Vign: 0.0)-
VCDS-Mobile ASAM Update -> Updating ASAM dataset: 0% Step 1/3 Downloading update 6/1001 KB, Status: Downloaded: 6KB
The only way forward is to press “Cancel the update”.
It always gets stuck at downloading 6KB of ASAM Data, whatever I do. The total amount to be downloaded has changed, however (e.g. to 264KB when starting the “Check for updates” again after cancelling), but it again stops the download immediately at 6KB. I have waited for over 30 minutes, and it does not progress. The Internet connection works fine, and is not slow otherwise.
I have tried “Clear RODs” in VCDS Mobile several times and “Clear Dataset cache” but it has no effect on the end result, always stuck on 6KB’s downloaded (the total amount to be downloaded varies, as said before).
CB: 0.4505
FW:0.256
CFB: 0.10
BL: 0.28
DS: 60000057
How to proceed?
Best regards,
Jukka-Pekka L.
Andy
Sector 7G
HC424490
After you ran the VCDS-Mobile AutoScan in step 2 you may need to go back to step 1 to check for updates using the Config utility connected to the Windows PC via USB. I ran a scan today on my 2018 A3 e-tron and similarly had lots of missing ROD files which VCDS-Mobile tried but failed to fetch during updates. I updated using the VCDS Interface Config V2.248 and it found ROD data. After ensuring it could find no more updates, I went back out to the car and ran an AutoScan using VCDS-Mobile successfully including all the RODs. Please give it a try.
JPL66
C?ID=354196
Ok, thanks,
I will try this now and report back after finished. I think I have tried this already, but will try again. I may have cleared the RODs before the previous try, however, now I will try immediately via USB/PC after the VCDS-Mobile autoscan as you suggested.
Best regards,
Jukka-Pekka L.
JPL66
C?ID=354196
For some reason, it seems to have worked this time following your suggestion. VCDS-Mobile cannot do the update (a bug somewhere?), but immediately after the autoscan, the VCDS Interface Config V2.248 did fetch the ROD files via USB-cable/laptop.
Autoscan (VCDS-Mobile) result below, now it finished successfully, without prompting to download ASAM data.
Autoscan
Finished
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 36 39 3C 42 44 	 47 4B 52 5F 75 A5 A9 D6 D7
01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000
Labels: 8V-01.lbl
HW: 06K 907 425 J
Revision: --H13---
ROD: EV_ECM20TFS0208V0906259R.rod
Labels: 0G-02.clb
HW: 0GC 927 711 H
Revision: 00H06V08 	Coding: 0014
ROD: EV_TCMDQ381061.rod
Labels: 5Q-03.clb
HW: 5Q0 614 517 BP
Revision: 00000000
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
HW: 3Q0 959 435 L
Revision: 00037000
Coding: 132C0C0723
HW: 5G0 907 044 CF
Revision: 00001K08
Subsystem 1 -
Subsystem 2 -
Subsystem 3 -
Labels: 5Q-09.clb
HW: 5Q0 937 086 BQ
Revision: --------
ROD: EV_BodyContrModul1UDSBosc_019_VW37.rod
Subsystem 1 - 	Part No SW: 5G1-955-119-A	Labels: 5Qx-955-119-V1.clb 	Component: WWS 181130043 0551 	Serial Number: 181213162931 	Coding: 0E4DFD
Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb 	Component: RLHS 052 0107 	Serial Number: SAY19M01D17H01M07S34 	Coding: 00A8EE
Subsystem 3 - 	Part No SW: 5Q0-951-172 	Component: Sensor, DWA 005 0316 	Serial Number: 000000000ZY183300JM1
Subsystem 4 - 	Part No SW: 5Q0-951-605-A 	Component: Sirene, DWA 005 0314 	Serial Number: 00000000000046218922
Subsystem 5 - 	Part No SW: 5G0-959-591-A 	Component: J245 PS22.409H04 0005 	Serial Number: 0000FST0028MNFY00000 	Coding: 191900
Subsystem 6 - 	Part No SW: 5G0-959-591-A 	Component: J394 PS22.409H04 0005 	Serial Number: 0000FST0028MNDW00000 	Coding: 191900
Subsystem 7 -
Subsystem 8 - 	Part No SW: 5Q1-953-521-M 	Component: Lenks.Modul H03 0170 	Serial Number: 0100110120190C202314
Labels: 5Q-10.lbl 	Part No SW: 5QA 919 294 C
HW: 5QA 919 294
Coding: 0471155811
HW: 3QF 907 572 A
HW: 5Q0 907 376 A
ROD: EV_DRCONTITEMIC_VW37.rod
HW: 5Q0 959 655 BT
ROD: EV_AirbaVW20SMEVW37X.rod
Subsystem 1 - 	Part No SW: 5G0-980-945-B 	Component: BeltPretRevFLH37 0350 	Serial Number: 34169667E17011940669 	Coding: 333135
Subsystem 2 - 	Part No SW: 5G0-980-946-B 	Component: BeltPretRevFRH37 0350 	Serial Number: 34169668E17011920719 	Coding: 333135
Subsystem 3 - 	Part No SW: -------------- 	Component: SideSensor_Df001 0887 	Serial Number: 357000000003D314D73J 	Coding: 2D2D2D
Subsystem 4 - 	Part No SW: -------------- 	Component: SideSensor_Pf001 0887 	Serial Number: 35800000000EC885D63 	Coding: 2D2D2D
Subsystem 5 - 	Part No SW: -------------- 	Component: SideSensor_Dr004 6149 	Serial Number: 3510001262B805C3D2A+ 	Coding: 2D2D2D
Subsystem 6 - 	Part No SW: -------------- 	Component: SideSensor_Pr004 6149 	Serial Number: 35200012E2B7227334B- 	Coding: 2D2D2D
HW: 5G1 920 791 B
HW: 3Q0 907 530 C
ROD: EV_GatewNF_VW37.rod
Subsystem 2 - 	Part No SW: 5G0-959-442-AE	Labels: 3C8-959-537.clb 	Component: E221__MFL-DC1H11 0052 	Serial Number: 29180003056140019017 	Coding: 2DFFFF
Subsystem 3 - 	Part No SW: 5Q0-915-181-K 	Component: J367-BDMHellaH10 9070 	Serial Number: 1073529304
HW: 0CQ 525 130
Coding: 0001
HW: 8V0 907 399 D
1 Fault Found: 0033 - Supply voltage 	U1011 00 [008] - Voltage too Low 	Intermittent - Confirmed - Tested Since Memory Clear
Labels: None
HW: 2Q0 905 861 A
ROD: EV_ELVMarqMQBA0_VW37.rod
Labels: None
HW: 5Q0 959 760 C
ROD: EV_SeatMemorDriveSide_002.rod
HW: 8V0 907 399 D
ROD: EV_LCMRightHELLAAU736_VW37.rod
HW: 5Q0 907 686 C
Coding: 02011103
ROD: EV_HREntryHella.rod
Labels: 5Q-42.clb
HW: 5Q4 959 593 F
HW: 3Q0 909 144 L
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
HW: 5Q0 035 456 A
Revision: 00000001
ROD: EV_AMPMst11CGen2ALPI.rod
Labels: None
HW: 3Q0 907 338 C
ROD: EV_MultiModulContiVW48X_002_VW37.rod
Labels: 5Q-52.clb
HW: 5Q4 959 592 F
Labels: 5N-5f.clb 	Part No SW: 5NA 035 043 D
HW: 5NA 035 043
ROD: EV_MUHig4CGen2HBAS.rod
Subsystem 1 - 	Part No SW: 5G6-919-606 	Component: ABT_High-2 H52 9130 	Serial Number: VWZ6ZJW0211258
Subsystem 2 - 	Part No SW: V03-959-806-FL 	Component: ECE 2019 --- 0175 	Serial Number: --------------------
Subsystem 3 - 	Part No SW: V03-959-800-EG 	Component: Gracenote2 --- 1017 	Serial Number: --------------------
HW: 5NA 035 284 C
Revision: --------
ROD: EV_OCULowMQBLGE_004_VW37.rod
HW: 3Q0 980 654 A
ROD: EV_MFKBoschMQBB_001_VW37.rod
Address A9:
Labels: 5G-a9.lbl 	Part No SW: 5G0 907 159 D
HW: 4H0 907 159 A
Labels: None
HW: 7P5 941 572 A
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
End--(Elapsed Time: 03:06, VBatt start/end: 12.1/12.1 Vign: 0.0)-
Maybe VCDS-Mobile can be fixed to do the update independently, for those situations when there is no access to a computer?
Now also VCDS-Mobile update tells me I am actually up to date.
Best regards, and thanks!
Jukka-Pekka L.
Shaun
How does it fail, does it give an error? Does it just not start?
JPL66
C?ID=354196
It was just stuck at download (6KB) stage, after "preparing to download". No matter how long I waited.
No error message at all, even after 45min of waiting.
Only way forward was "cancel update" as described in first post.
No matter how many times I tried, the download stuck at the same 6KB. The total amount to be downloaded was different each time I tried to do the update in VCDS-Mobile.
Best regards,
Jukka-Pekka L.
Andy
Sector 7G
HC424490
I'm glad the workaround worked. I experienced a similar "hang" when I tried to update using mobile:
That was using HN0-000159.
JPL66
C?ID=354196
Ran into the same problem again after an autoscan with VCDS mobile. It does not update the ASAM files, but hangs immediately when the download starts. Could you, please, try to fix this problem? The car is the same and the VCDS Hex-net is also the same as before - so no change there.
botttos
Minneapolis.MN USA
C?ID=266667
I’ve had the same problem for 2 or 3 years. Still not fixed. Is there anyone that has actually had the ASAM update work for them via VCDS-Mobile? Or is this just a bug that will never be fixed? Just tried it tonight again. It just hangs forever. Lucky I have a windows pc.
I also have excellent WiFi at my car
Shaun
If you can reproduce this, are you willing to make a debug log? Go to [Options] -> enter debug level = 0827 -> [Submit]
Then trigger an asam update, so the log can be made.
Otto
C?ID=178462
Has the ASAM update issue ever been resolved? I have seen no reply to that effect. I also encountered the ASAM update starting today and then it stalled and just sat there.
ASAM update
Shaun
That looks like a network issue, since I believe the window is 6k and therefore you didn't receive anything after the first window. Describe your internet connection here. Can you post a network test? Have you tried with a different connection? You could also try downloading the rods via VCI-Config on a PC.
