Results 1 to 8 of 8
Thread: Asam update problem VCDS-Mobile
    Feb 2019
    Question Asam update problem VCDS-Mobile
    I have tried to get VCDS-mobile to work with my Hex-Net Pro.
    I have a problem, described below, with ASAM data download failing.
    1. At home network via USB-cable at windows 10 laptop, updating, after clearing RODs with VCDS-Mobile:
    VCDS Interface Config V2.248
    Downloading DS Update
    Getting 530k
    Download Finished
    Unpacking DS Update
    Update completed Successfully
    Recheck for updates -> You are up to date.
    So, this step seems to go smoothly.
    2. At car, Golf R Variant DSG 2019 (post-wltp model):
    - Hex-net in Infrastructure mode (Green light), connected to the car.
    Starting Autoscan is followed with a warning message about missing ASAM data, and that it can be downloaded after the scan.
    After the scan completes, I press Download update. (The saved autoscan log is below).
    Wed,Jun,05,2019,02:02:59
    VCDS Mobile 0.4505.0.4
    VIN: WVWZZZAUZKP549473
    Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 36 39 3C 42 44
    	 47 4B 52 5F 75 A5 A9 D6 D7
    29-Left Light -- Status: Malfunction 0010
    75-Telematics -- Status: Not registered 0001
    Address 01: Engine  (DNUE  J623)	Labels: 8V-01.lbl
    	Part No SW: 8V0 906 259 R	HW: 06K 907 425 J
    	Revision: --H13---
    	Coding: 092540122466050B3000
    	Shop #: WSC 00028 028 00071
    	ASAM Dataset: EV_ECM20TFS0208V0906259R 001002
    	ROD: N/A
    	VCID: 4FE1E03FCA09A4B28808F1-801A
    	No ASAM data for: "EV_ECM20TFS0208V0906259R"
    No fault codes found.
    Address 02: Auto Trans  (J743)	Labels: 0G-02.clb
    	Part No SW: 0GC 300 014 B	HW: 0GC 927 711 H
    	Component: GSG DQ381     H06 2403
    	Revision: 00H06V08
    	ASAM Dataset: EV_TCMDQ381061 001
    	ROD: N/A
    	VCID: 240B7F93F30F77EA057A16-8071
    	No ASAM data for: "EV_TCMDQ381061"
    Address 03: ABS Brakes  (J104)	Labels: 5Q-03.clb
    	Part No SW: 5Q0 614 517 EF	HW: 5Q0 614 517 BP
    	Component: ESC           H35 0107
    	Revision: 00000000
    	Coding: 04FA6BA150242175477B070760C66920D60A84E2E0069677384250F8D2A84B0B0000000012121212B835351919323200
    	Shop #: WSC 00028 028 00069
    	ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
    	ROD: N/A
    	VCID: 79B57EE7240DDA0206ACAF-802C
    	No ASAM data for: "EV_Brake1UDSContiMK100IPB"
    Address 05: Acc/Start Auth.  (J518)	Labels: 5Q0-959-435.clb
    	Part No SW: 3Q0 959 435 L	HW: 3Q0 959 435 L
    	Component: VWKESSYMQB    037 1204
    	Revision: 00037000
    	Coding: 132C0C0723
    	ROD: N/A
    	VCID: 43C9DC0F164150D21CB07D-8016
    	No ASAM data for: "EV_KessyHellaMQBAB"
    Address 08: Auto HVAC  (J255)	Labels: 5G0-907-044.clb
    	Part No SW: 5G0 907 044 CF	HW: 5G0 907 044 CF
    	Revision: 00001K08
    	Coding: 0202002420041001110500420010102A
    	ROD: N/A
    	VCID: 6D9D5AB7604576A29A542B-8038
    	No ASAM data for: "EV_ACClimaBHBVW37X"
    	Subsystem 1 -
    	Subsystem 2 -
    	Subsystem 3 -
    Address 09: Cent. Elect.  (J519)	Labels: 5Q-09.clb
    	Part No SW: 5Q0 937 086 BQ	HW: 5Q0 937 086 BQ
    	Component: BCM PQ37BOSCH 036 0265
    	Revision: --------
    	ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
    	ROD: N/A
    	VCID: 8A57B12BF1EB419A9F7668-80DF
    	No ASAM data for: "EV_BodyContrModul1UDSBosc"
    	Subsystem 1 - 	Part No SW: 5G1-955-119-A	Labels: 5Qx-955-119-V1.clb
    	Component: WWS    181130043 0551
    	Serial Number:         181213162931
    	Coding: 0E4DFD
    	Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb
    	Component: RLHS         052 0107
    	Serial Number: SAY19M01D17H01M07S34
    	Coding: 00A8EE
    	Subsystem 3 - 	Part No SW: 5Q0-951-172
    	Serial Number: 000000000ZY183300JM1
    	Subsystem 4 - 	Part No SW: 5Q0-951-605-A
    	Serial Number: 00000000000046218922
    	Subsystem 5 - 	Part No SW: 5G0-959-591-A
    	Component: J245 PS22.409H04 0005
    	Serial Number: 0000FST0028MNFY00000
    	Coding: 191900
    	Subsystem 6 - 	Part No SW: 5G0-959-591-A
    	Component: J394 PS22.409H04 0005
    	Serial Number: 0000FST0028MNDW00000
    	Coding: 191900
    	Subsystem 7 -
    	Subsystem 8 - 	Part No SW: 5Q1-953-521-M
    	Component: Lenks.Modul  H03 0170
    	Serial Number: 0100110120190C202314
    Address 10: Park/Steer Assist  (J446)	Labels: 5Q-10.lbl
    	Part No SW: 5QA 919 294 C	HW: 5QA 919 294
    	Component: PDC 8 Kanal
    	Coding: 0471155811
    	ROD: N/A
    	VCID: 4CDBF7333B1F9FAAEDEADE-8019
    	No ASAM data for: "EV_EPHVA18AU3700000"
    Address 13: Auto Dist. Reg  (J428)	Labels: 5Q0-907-572.clb
    	Part No SW: 5Q0 907 572 P	HW: 3QF 907 572 A
    	Component: ACC BOSCH MQB H11 0682
    	Coding: 330067C15DFFC728949C810580400600000000000000000004
    	ASAM Dataset: EV_ACCBOSCHVW416 002008
    	ROD: N/A
    	VCID: 44CBDF13134F57EA25BA76-8011
    	No ASAM data for: "EV_ACCBOSCHVW416"
    Address 14: Susp. Elect.  (J250)	Labels: 5Q0-907-376.clb
    	Part No SW: 5Q0 907 376 B	HW: 5Q0 907 376 A
    	Shop #: WSC 00000 000
    	ROD: N/A
    	VCID: 3833BBE35F87030AB922F2-806D
    	No ASAM data for: "EV_DRCONTITEMIC"
    Address 15: Airbags  (J234)	Labels: 5Q0-959-655.clb
    	Part No SW: 5Q0 959 655 BT	HW: 5Q0 959 655 BT
    	Component: AirbagVW21    007 0403
    	Shop #: WSC 00028 028 00057
    	ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
    	ROD: N/A
    	VCID: 9369AC4FA6A180526CD0CD-80C6
    	No ASAM data for: "EV_AirbaVW20SMEVW37X"
    	Subsystem 1 - 	Part No SW: 5G0-980-945-B
    	Component: BeltPretRevFLH37 0350
    	Serial Number: 34169667E17011940669
    	Coding: 333135
    	Subsystem 2 - 	Part No SW: 5G0-980-946-B
    	Component: BeltPretRevFRH37 0350
    	Serial Number: 34169668E17011920719
    	Coding: 333135
    	Subsystem 3 - 	Part No SW: --------------
    	Component: SideSensor_Df001 0887
    	Serial Number: 357000000003D314D73J
    	Subsystem 4 - 	Part No SW: --------------
    	Component: SideSensor_Pf001 0887
    	Serial Number: 35800000000EC885D63
    	Subsystem 5 - 	Part No SW: --------------
    	Component: SideSensor_Dr004 6149
    	Serial Number: 3510001262B805C3D2A+
    	Subsystem 6 - 	Part No SW: --------------
    	Component: SideSensor_Pr004 6149
    	Serial Number: 35200012E2B7227334B-
    Address 17: Instruments  (J285)	Labels: 5G0-920-XXX-17.clb
    	Part No SW: 5G1 920 791 B	HW: 5G1 920 791 B
    	Component: KOMBI         403 4191
    	Coding: 07AD601B7F8C000801887B0B5401000880000000
    	ROD: N/A
    	VCID: 2B1994AF9ED1B892C4A045-807E
    	No ASAM data for: "EV_DashBoardVDDMQBAB"
    Address 19: CAN Gateway  (J533)	Labels: 3Q0-907-530-V1.clb
    	Part No SW: 3Q0 907 530 AA	HW: 3Q0 907 530 C
    	Component: GW MQB High   521 5366
    	Coding: 030100047F085900FB00827E9C0F00010001070000000000000000000000
    	ROD: N/A
    	VCID: 6E9F5DBB6D438DBAA35E24-803B
    	No ASAM data for: "EV_GatewNF"
    	Subsystem 1 - 	Component: 1-01-09-01-04
    	Subsystem 2 - 	Part No SW: 5G0-959-442-AE	Labels: 3C8-959-537.clb
    	Component: E221__MFL-DC1H11 0052
    	Serial Number: 29180003056140019017
    	Coding: 2DFFFF
    	Subsystem 3 - 	Part No SW: 5Q0-915-181-K
    	Component: J367-BDMHellaH10 9070
    	Serial Number: 1073529304
    Address 22: AWD  (J492)	Labels: 0CQ-907-554.clb
    	Part No SW: 0CQ 907 554 J	HW: 0CQ 525 130
    	Component: Haldex4Motion H55 7084
    	Coding: 0001
    	ROD: N/A
    	No ASAM data for: "EV_AllWheelContrHA1VW37X"
    Address 29: Left Light  (J1018)	Labels: 8V0-907-399.clb
    	Part No SW: 8V0 907 399 D	HW: 8V0 907 399 D
    	Component: LCM_MLBevo
    	ROD: N/A
    	VCID: 47D1C81F22797CF2C0D889-8012
    	No ASAM data for: "EV_LCMLeftHELLAAU736"
    000033 - ROD - Unknown faultcode
    Address 2B: Steer. Col. Lock  (J764)	Labels: None
    	Part No SW: 2Q0 905 861 A	HW: 2Q0 905 861 A
    	Component: ELV-MQBB      H08 0021
    	Coding: 0800000000000000
    	ROD: N/A
    	VCID: 312586C7BCFDD242FEFC87-8064
    	No ASAM data for: "EV_ELVMarqMQBA0"
    Address 36: Seat Mem. Drvr  (J810)	Labels: None
    	Part No SW: 5Q0 959 760 C	HW: 5Q0 959 760 C
    	Component: Sitzmemory    H09 0024
    	Coding: 0010000000000500018280808080000000008181000000F400
    	ASAM Dataset: EV_SeatMemorDriveSide 002022
    	ROD: N/A
    	VCID: 3D3DAAF770A526226A743B-8068
    	No ASAM data for: "EV_SeatMemorDriveSide"
    Address 39: Right Light  (J1023)	Labels: 8V0-907-399.clb
    	ROD: N/A
    	No ASAM data for: "EV_LCMRightHELLAAU736"
    Address 3C: Lane Change  (J1086)	Labels: 5Q0-907-686.clb
    	Part No SW: 5Q0 907 686 C	HW: 5Q0 907 686 C
    	Component: HRE_Master    H12 0081
    	Coding: 02011103
    	ROD: N/A
    	No ASAM data for: "EV_HREntryHella"
    Address 42: Door Elect, Driver  (J386)	Labels: 5Q-42.clb
    	Part No SW: 5Q4 959 593 F	HW: 5Q4 959 593 F
    	Component: TSG FS        006 0246
    	Coding: 001F1220D200048000001000
    	ROD: N/A
    	VCID: 48D3CB232F67738AC9C282-801D
    	No ASAM data for: "EV_DCU2DriveSideMAXHCONT"
    Address 44: Steering Assist  (J500)	Labels: 5Q0-909-144.clb
    	Part No SW: 3Q0 909 144 M	HW: 3Q0 909 144 L
    	Component: EPS_MQB_ZFLS  507 5082
    	Coding: 911F0000
    	ROD: N/A
    	VCID: 3C3BA7F36BBF2F2A5D4A0E-8069
    	No ASAM data for: "EV_SteerAssisMQB"
    Address 47: Sound System  (J525)	Labels: 5Q0-035-456.clb
    	Part No SW: 5Q0 035 456 A	HW: 5Q0 035 456 A
    	Component: MIB2_lite_amp H40 0200
    	Revision: 00000001
    	Coding: 12000000008AAA8A000000000000
    	ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
    	ROD: N/A
    	VCID: 2E1F9DBBADC3CDBAE3DE64-807B
    	No ASAM data for: "EV_AMPMst11CGen2ALPI"
    Address 4B: Multifunc. Module  (J745)	Labels: None
    	Part No SW: 3Q0 907 338 C	HW: 3Q0 907 338 C
    	Component: FCM MQB Low   002 0345
    	Coding: 00000005090019D206204F01020000000000000000000000000000000000
    	ASAM Dataset: EV_MultiModulContiVW48X 002006
    	ROD: N/A
    	VCID: 352DB2D74895FE62A204D3-8060
    	No ASAM data for: "EV_MultiModulContiVW48X"
    Address 52: Door Elect, Pass.  (J387)	Labels: 5Q-52.clb
    	Part No SW: 5Q4 959 592 F	HW: 5Q4 959 592 F
    	Component: TSG BFS       006 0246
    	Coding: 001F1020DE00048000001000
    	ROD: N/A
    	No ASAM data for: "EV_DCU2PasseSideMAXHCONT"
    Address 5F: Information Electr.  (J794)	Labels: 5N-5f.clb
    	Part No SW: 5NA 035 043 D	HW: 5NA 035 043
    	Component: MU-H-N-EU     H55 1367
    	Coding: 02731201000000004111000200080A231F0107F4012004009E
    	ROD: N/A
    	VCID: 3731B8DF52990C72B038F9-8062
    	No ASAM data for: "EV_MUHig4CGen2HBAS"
    	Subsystem 1 - 	Part No SW: 5G6-919-606
    	Component: ABT_High-2   H52 9130
    	Serial Number: VWZ6ZJW0211258
    	Subsystem 2 - 	Part No SW: V03-959-806-FL
    	Component: ECE 2019     --- 0175
    	Serial Number: --------------------
    	Subsystem 3 - 	Part No SW: V03-959-800-EG
    	Component: Gracenote2   --- 1017
    Address 75: Telematics  (J949)	Labels: 5QE-035-285.clb
    	Part No SW: 5NA 035 284 C	HW: 5NA 035 284 C
    	Component: OCULowMQBLGE  H19 0825
    	Revision: --------
    	Coding: 02730201EA42380D3F1CBE020045400382E608
    	ASAM Dataset: EV_OCULowMQBLGE 004049
    	ROD: N/A
    	No ASAM data for: "EV_OCULowMQBLGE"
    Address A5: Frt Sens. Drv. Assist  (R242)	Labels: 3Q0-980-65X-A5.clb
    	Part No SW: 3Q0 980 654 H	HW: 3Q0 980 654 A
    	Component: MQB_B_MFK     H09 0272
    	Coding: 0003070200000401002623548150A90098000E300040
    	ROD: N/A
    	No ASAM data for: "EV_MFKBoschMQBB"
    Address A9: Struct. Borne Sound  (J869)	Labels: 5G-a9.lbl
    	Part No SW: 5G0 907 159 D	HW: 4H0 907 159 A
    	ROD: N/A
    	VCID: 2F2180BFAAC9C4B2E8C891-807A
    	No ASAM data for: "EV_SoundActuaGen2AU64X"
    Address D6: Light Ctrl Left 2  (A31)	Labels: None
    	Part No SW: 7P5 941 572 AG	HW: 7P5 941 572 A
    	Component: LED1L         H07 0008
    	ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
    	ROD: N/A
    	VCID: 80439303C7D70BCAC1121A-80D5
    	No ASAM data for: "EV_LEDMinMaxL_KEBODAVW481"
    Address D7: Light Ctrl Right 2  (A27)	Labels: None
    	Component: LED1R         H07 0008
    	ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
    	ROD: N/A
    	No ASAM data for: "EV_LEDMinMaxR_KEBODAVW481"
    End--(Elapsed Time: 03:09, VBatt start/end: 12.4/12.3 Vign: 0.0)-
    VCDS-Mobile ASAM Update -> Updating ASAM dataset: 0% Step 1/3 Downloading update 6/1001 KB, Status: Downloaded: 6KB
    The only way forward is to press “Cancel the update”.
    It always gets stuck at downloading 6KB of ASAM Data, whatever I do. The total amount to be downloaded has changed, however (e.g. to 264KB when starting the “Check for updates” again after cancelling), but it again stops the download immediately at 6KB. I have waited for over 30 minutes, and it does not progress. The Internet connection works fine, and is not slow otherwise.
    I have tried “Clear RODs” in VCDS Mobile several times and “Clear Dataset cache” but it has no effect on the end result, always stuck on 6KB’s downloaded (the total amount to be downloaded varies, as said before).
    CB: 0.4505
    FW:0.256
    CFB: 0.10
    BL: 0.28
    DS: 60000057
    How to proceed?
    Best regards,
    Jukka-Pekka L.
    Last edited by Boki Ar; 06-05-2019 at 07:20 AM. Reason: [/Code] tags fix; / instead \
    Enjoyng a Golf Variant R 2019 post-WLTP with GPF
  2. Likes Dana, Uwe, Andy liked this post
  3. #2
    Administrator Andy's Avatar
    Sector 7G
    After you ran the VCDS-Mobile AutoScan in step 2 you may need to go back to step 1 to check for updates using the Config utility connected to the Windows PC via USB. I ran a scan today on my 2018 A3 e-tron and similarly had lots of missing ROD files which VCDS-Mobile tried but failed to fetch during updates. I updated using the VCDS Interface Config V2.248 and it found ROD data. After ensuring it could find no more updates, I went back out to the car and ran an AutoScan using VCDS-Mobile successfully including all the RODs. Please give it a try.
  4. Likes Uwe, Dana liked this post
  5. #3
    Feb 2019
    Ok, thanks,
    I will try this now and report back after finished. I think I have tried this already, but will try again. I may have cleared the RODs before the previous try, however, now I will try immediately via USB/PC after the VCDS-Mobile autoscan as you suggested.
    Best regards,
    Jukka-Pekka L.
  6. #4
    Feb 2019
    For some reason, it seems to have worked this time following your suggestion. VCDS-Mobile cannot do the update (a bug somewhere?), but immediately after the autoscan, the VCDS Interface Config V2.248 did fetch the ROD files via USB-cable/laptop.
    Autoscan (VCDS-Mobile) result below, now it finished successfully, without prompting to download ASAM data.
    Autoscan
    Finished
    Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 36 39 3C 42 44 	 47 4B 52 5F 75 A5 A9 D6 D7
    01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000
    Labels: 8V-01.lbl
    HW: 06K 907 425 J
    Revision: --H13---
    ROD: EV_ECM20TFS0208V0906259R.rod
    Labels: 0G-02.clb
    HW: 0GC 927 711 H
    Revision: 00H06V08 	Coding: 0014
    ROD: EV_TCMDQ381061.rod
    Labels: 5Q-03.clb
    HW: 5Q0 614 517 BP
    Revision: 00000000
    ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
    HW: 3Q0 959 435 L
    Revision: 00037000
    Coding: 132C0C0723
    HW: 5G0 907 044 CF
    Revision: 00001K08
    Subsystem 1 -
    Subsystem 2 -
    Subsystem 3 -
    Labels: 5Q-09.clb
    HW: 5Q0 937 086 BQ
    Revision: --------
    ROD: EV_BodyContrModul1UDSBosc_019_VW37.rod
    Subsystem 1 - 	Part No SW: 5G1-955-119-A	Labels: 5Qx-955-119-V1.clb 	Component: WWS 181130043 0551 	Serial Number: 181213162931 	Coding: 0E4DFD
    Subsystem 2 - 	Part No SW: 5Q0-955-547-B	Labels: 5Q0-955-547.clb 	Component: RLHS 052 0107 	Serial Number: SAY19M01D17H01M07S34 	Coding: 00A8EE
    Subsystem 3 - 	Part No SW: 5Q0-951-172 	Component: Sensor, DWA 005 0316 	Serial Number: 000000000ZY183300JM1
    Subsystem 4 - 	Part No SW: 5Q0-951-605-A 	Component: Sirene, DWA 005 0314 	Serial Number: 00000000000046218922
    Subsystem 5 - 	Part No SW: 5G0-959-591-A 	Component: J245 PS22.409H04 0005 	Serial Number: 0000FST0028MNFY00000 	Coding: 191900
    Subsystem 6 - 	Part No SW: 5G0-959-591-A 	Component: J394 PS22.409H04 0005 	Serial Number: 0000FST0028MNDW00000 	Coding: 191900
    Subsystem 7 -
    Subsystem 8 - 	Part No SW: 5Q1-953-521-M 	Component: Lenks.Modul H03 0170 	Serial Number: 0100110120190C202314
    Labels: 5Q-10.lbl 	Part No SW: 5QA 919 294 C
    HW: 5QA 919 294
    Coding: 0471155811
    HW: 3QF 907 572 A
    HW: 5Q0 907 376 A
    ROD: EV_DRCONTITEMIC_VW37.rod
    HW: 5Q0 959 655 BT
    ROD: EV_AirbaVW20SMEVW37X.rod
    Subsystem 1 - 	Part No SW: 5G0-980-945-B 	Component: BeltPretRevFLH37 0350 	Serial Number: 34169667E17011940669 	Coding: 333135
    Subsystem 2 - 	Part No SW: 5G0-980-946-B 	Component: BeltPretRevFRH37 0350 	Serial Number: 34169668E17011920719 	Coding: 333135
    Subsystem 3 - 	Part No SW: -------------- 	Component: SideSensor_Df001 0887 	Serial Number: 357000000003D314D73J 	Coding: 2D2D2D
    Subsystem 4 - 	Part No SW: -------------- 	Component: SideSensor_Pf001 0887 	Serial Number: 35800000000EC885D63 	Coding: 2D2D2D
    Subsystem 5 - 	Part No SW: -------------- 	Component: SideSensor_Dr004 6149 	Serial Number: 3510001262B805C3D2A+ 	Coding: 2D2D2D
    Subsystem 6 - 	Part No SW: -------------- 	Component: SideSensor_Pr004 6149 	Serial Number: 35200012E2B7227334B- 	Coding: 2D2D2D
    HW: 5G1 920 791 B
    HW: 3Q0 907 530 C
    ROD: EV_GatewNF_VW37.rod
    Subsystem 2 - 	Part No SW: 5G0-959-442-AE	Labels: 3C8-959-537.clb 	Component: E221__MFL-DC1H11 0052 	Serial Number: 29180003056140019017 	Coding: 2DFFFF
    Subsystem 3 - 	Part No SW: 5Q0-915-181-K 	Component: J367-BDMHellaH10 9070 	Serial Number: 1073529304
    HW: 0CQ 525 130
    Coding: 0001
    HW: 8V0 907 399 D
    1 Fault Found: 0033 - Supply voltage 	U1011 00 [008] - Voltage too Low 	Intermittent - Confirmed - Tested Since Memory Clear
    Labels: None
    HW: 2Q0 905 861 A
    ROD: EV_ELVMarqMQBA0_VW37.rod
    Labels: None
    HW: 5Q0 959 760 C
    ROD: EV_SeatMemorDriveSide_002.rod
    HW: 8V0 907 399 D
    ROD: EV_LCMRightHELLAAU736_VW37.rod
    HW: 5Q0 907 686 C
    Coding: 02011103
    ROD: EV_HREntryHella.rod
    Labels: 5Q-42.clb
    HW: 5Q4 959 593 F
    HW: 3Q0 909 144 L
    Coding: 911F0000
    ROD: EV_SteerAssisMQB_015.rod
    HW: 5Q0 035 456 A
    Revision: 00000001
    ROD: EV_AMPMst11CGen2ALPI.rod
    Labels: None
    HW: 3Q0 907 338 C
    ROD: EV_MultiModulContiVW48X_002_VW37.rod
    Labels: 5Q-52.clb
    HW: 5Q4 959 592 F
    Labels: 5N-5f.clb 	Part No SW: 5NA 035 043 D
    HW: 5NA 035 043
    ROD: EV_MUHig4CGen2HBAS.rod
    Subsystem 1 - 	Part No SW: 5G6-919-606 	Component: ABT_High-2 H52 9130 	Serial Number: VWZ6ZJW0211258
    Subsystem 2 - 	Part No SW: V03-959-806-FL 	Component: ECE 2019 --- 0175 	Serial Number: --------------------
    Subsystem 3 - 	Part No SW: V03-959-800-EG 	Component: Gracenote2 --- 1017 	Serial Number: --------------------
    HW: 5NA 035 284 C
    Revision: --------
    ROD: EV_OCULowMQBLGE_004_VW37.rod
    HW: 3Q0 980 654 A
    ROD: EV_MFKBoschMQBB_001_VW37.rod
    Address A9:
    Labels: 5G-a9.lbl 	Part No SW: 5G0 907 159 D
    HW: 4H0 907 159 A
    Labels: None
    HW: 7P5 941 572 A
    ROD: EV_LEDMinMaxL_KEBODAVW481.rod
    End--(Elapsed Time: 03:06, VBatt start/end: 12.1/12.1 Vign: 0.0)-
    Maybe VCDS-Mobile can be fixed to do the update independently, for those situations when there is no access to a computer?
    Now also VCDS-Mobile update tells me I am actually up to date.
    Best regards, and thanks!
    Jukka-Pekka L.
    Last edited by JPL66; 06-05-2019 at 06:06 PM. Reason: Trying to get the Autoscan log to show.
  7. Likes Uwe, Dana liked this post
  8. #5
    How does it fail, does it give an error? Does it just not start?
  9. Likes Uwe liked this post
  10. #6
    Feb 2019
    Quote Originally Posted by Shaun View Post
    It was just stuck at download (6KB) stage, after "preparing to download". No matter how long I waited.
    No error message at all, even after 45min of waiting.
    Only way forward was "cancel update" as described in first post.
    No matter how many times I tried, the download stuck at the same 6KB. The total amount to be downloaded was different each time I tried to do the update in VCDS-Mobile.
    Best regards,
    Jukka-Pekka L.
  11. Likes Uwe, Dana, Andy liked this post
  12. #7
    Sector 7G
    I'm glad the workaround worked. I experienced a similar "hang" when I tried to update using mobile:
    That was using HN0-000159.
  13. Likes Uwe liked this post
  14. #8
    Feb 2019
    Ran into the same problem again after an autoscan with VCDS mobile. It does not update the ASAM files, but hangs immediately when the download starts. Could you, please, try to fix this problem? The car is the same and the VCDS Hex-net is also the same as before - so no change there.
