Results 1 to 8 of 8
Thread: DPF
    Mar 2019
    Lightbulb DPF
    Hi
    Could any one help me to understand what is maximum oil ash volume? The reason I'm asking is that mine is 49 g and I don't know if is bad or not. My car is driving fine at the moment.
    Address 01: Engine  (03L 906 023 GL)
    06:35:44
      IDE00427-ENG101722   Particle filter: difference pressure-DIP_PF 0.00 hPa
      IDE00428-ENG100917   Particle filter: offset for differential press.-DIP_PF_AD[0] 1.33 hPa
      IDE00430-ENG102682   Particle filter: field regeneration request status-STATE_RGN_PF 0
      IDE00431-ENG102952   Particle filter: field regeneration lock status-LV_STATE_TEST_RGN_PF_INH_HLD 00000000
      IDE00432-ENG103847   Particle filter: time since last regeneration-T_WOUT_RGN 16254.80 s
      IDE00433-ENG103279   Particle filter: oil ash volume-MASS_ASH_PF 49.1503297 g
      IDE00434-ENG102050   Particle filter: soot mass calculated-MASS_SOOT_SIM_PF 8.88 g
      IDE00435-ENG101197   Particle filter: soot mass measured-MASS_SOOT_PHY_PF 1.40 g
      IDE00436-ENG102397   Particle filter: kilometers since last regeneration-DIST_RGN 201.1 km
      IDE01407-ENG100958   Particle filter: fuel consumption since last regeneration-FCO_SUM_RGN 10.67 l
    Auto Scan
    Wednesday,05,June,2019,06:39:43:36622
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
    VIN: WVWZZZ3CZAE075321   License Plate: 1111
    Mileage: 168850km-104918mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61
    VIN: WVWZZZ3CZAE075321   Mileage: 168850km-104918miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 GL    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 5810
       Revision: --------    Serial number: 00000000000000
       Coding: 00114014032501080000
       ASAM Dataset: EV_ECM16TDI02103L906023GL 001006
       ROD: EV_ECM16TDI_001_VW46.rod
       VCID: 76B410CDD84FCD57B41-8022
       Part No SW: 3C0 614 109 AK    HW: 3C0 614 109 AK
       Component: J104    C4 440 V2   0027
       Revision: --025---    Serial number: 00000795856674
       Coding: 0034287
       Shop #: WSC 05311 000 00000
       VCID: 678A4D89836524DF3F7-8032
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000003
       Shop #: WSC 05311 115 00000
       ROD: EV_ClimaBasis_VW46.rod
       VCID: 6D863FA1AD190E8F45B-8038
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
       Part No SW: 3C8 937 049 AA    HW: 3C8 937 049 AA
       Component: Bordnetz-SG     H57 3204
       Revision: 00H57000    Serial number: 00000003339756
       Coding: A0900F0700041A00470A00000F000000000159435C000100000308000000
       Shop #: WSC 05124 123 12345
       VCID: 70B826D5B6ABE3676ED-8024
       Subsystem 1 - Part No: 3C2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 191009 022  0612
       Coding: 00046997
       Shop #: WSC 05124
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__00J VW10 HI   1916
       Revision: 20013000    Serial number: 003E2PP3YD2Z
       Coding: 0012362
       VCID: 44D0BA05D2932FC7FA5-8010
       Subsystem 1 - Serial number: 6332MTS633892949
       Subsystem 2 - Serial number: 6342MTS658412949
       Subsystem 3 - Serial number: 6351HTS6SKE829KR
       Subsystem 4 - Serial number: 6361HTS6G4C729KR
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C5 953 501 BP    HW: 5K0 953 569 AA
       Component: LENKS.MODUL   009 0122
       Revision: FF010E35    Serial number: 20091105200027
       Coding: 4180270002
       ASAM Dataset: EV_VW360SteerWheelUDS A03002
       VCID: 74B02AC5CE33DF478A5-8020
       Part No SW: 3C0 920 972 J    HW: 3C0 920 972 J
       Component: KOMBI         H03 0305
       Coding: 160F00
       Shop #: WSC 05314 115 12345
       VCID: 2D06FFA16D99CE8F05B-8078
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 N    HW: 3C0 907 951
       Component: J533  Gateway   H14 0170
       Revision:   H14       Serial number: 0821G09B10013C
       Coding: F9801F06000203041003
       Shop #: WSC 05314 000 00000
       VCID: 2C00F2A55A03C787125-8078
       Part No SW: 3C0 959 433 AQ    HW: 3C0 959 433 AQ
       Component:    IMMO         044 0383
       Revision: 00044000    Serial number: VWZCZ000000000
       VCID: 79AE1BF1E5D1A22FD93-802C
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
       Part No SW: 1K0 959 701 AR    HW: 1K0 959 793 N
       Component: J386  TUER-SG FT    1502
       Revision: 72009005    Serial number: 00000538599023
       Coding: 0000565
       VCID: 7EA408EDFCFF8517EC1-802A
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 194    3001
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 313EE3D17D21AA6F213-8064
       Component:    KSG PQ46 ELV 044 0612
       Coding: 00910A0801860E7630049C1D7008DBCE103C01
       Subsystem 1 - Part No: 1K8 951 605
       Component: LIN BACKUP HORN H10 9003
       Part No SW: 1K0 907 532     HW: 3C0 907 951
       Component: EZE_2         H14 0170
       Revision: --------    Serial number: 0821G09B10013C
       Coding: 00000000
       VCID: 6694408D886F3DD7041-8032
       Part No SW: 1K0 959 702 AR    HW: 1K0 959 792 N
       Component: J387  TUER-SG BT    1502
       Revision: 72009005    Serial number: 00000883899026
       Coding: 0000564
       VCID: 7F5AF5E9FBF58C1FE77-802A
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000072339
       Coding: 0000056
    Address 56: Radio
       Part No SW: 1K0 907 534     HW: 3C0 907 951
       Component: Batt.regelung H14 0170
       Coding: 030B085A
       VCID: 68884EB5827B2BA736D-803C
       Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790772682
    End----------(Elapsed Time: 01:18, VBatt start/end: 12.0V/12.0V)-----------
    49 grams doesn't seem excessive for 100,000 miles:
    http://forums.tdiclub.com/showthread.php?t=324067
    Now those are all 2-liter engines and will probably produce a bit more, but still..
    Also:
    https://www.dieselnet.com/tech/dpf_ash.php
    VCDS Distributor NEtech's Avatar
    Quote Originally Posted by alexliebt View Post
    It should be about 60 gram
    Sorry should be 70 gram.
  5. Likes Jacek liked this post
    Mar 2019
    Thank you for info. I'll have it clean soon. I rang my local garage.
    Mar 2019
    For my situation, is it safe to do force re-gen?
    If yes, where can I find more info how to do it?
    Someone can correct me if I'm wrong, but I don't think oil ash can be reduced by regeneration. Regeneration is for carbon soot, which can be burned off. Ash is almost by definition, a non-combustible residue.
  9. Likes Jacek, PetrolDave liked this post
  10. #8
    Mar 2019
    It is like Uwe writes.
  11. Likes Uwe liked this post
