Results 1 to 3 of 3
Thread: Error in module 10 after BSD retrofit
    Apr 2018
    ITALY
    hello all, I finally completed the retrofit of the Blind Spot Detection on my Golf. I cannot clear the error in module 10, I think there is a wrong coding somewhere. I looked around even with experimental coding but I cannot find anything obvious.
    does anybody have a clue?
    Tuesday,04,June,2019,17:30:58:06888
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    Dealer/Shop Name: dB
    Workshop Code: 031 33097 006209
    VIN: WVWZZZAUZHW0xxxxx   License Plate:
    Mileage: 29131km-18101mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 18 19 3C 42 44 52 5F 65
    VIN: WVWZZZAUZHW0xxxxx   Mileage: 29131km-18101miles
    Address 01: Engine (J623-CZCA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HB    HW: 04E 907 309 BH
       Component: R4 1.4l TFS   H25 2833
       Revision: R7H25---
       Coding: 0119003A23441D082000
       Shop #: WSC 33097 031 06209
       ASAM Dataset: EV_ECM14TFS01104E906027HB 001005
       ROD: EV_ECM14TFS01104E906027HB.rod
       VCID: 6B833BBF03045EDF0F3-803E
       CAN Converter 01:
    Readiness: 1110 0001
       Part No SW: 5Q0 614 517 CC    HW: 5Q0 614 517 AG
       Component: ESC           H62 0637
       Revision: 00000000    Serial number: 91596000011507
       Coding: 01FA6AA1242219704779060841C62980562498E26082947314205008408903
       VCID: 74B120C35E3A8127DE9-8020
       Part No SW: 5G0 907 044 BM    HW: 5G0 907 044 BM
       Revision: 00001K08
       Coding: 00020004104111011005004000101022
       VCID: 73B323DF5B34861FC73-8026
       Serial number: 01061633700891
       Coding: 00000846C20102FB0B244080B11407281400000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 045170030E9AB1A7EE9-8050
       Component: WWS    160522  043 0551
       Serial number:         160601172917
       Coding: 0E4DFD
       Component: RLFS  024 0042
       Serial number: Y13M05D10H00M20S03S4
       Coding: 06A8DD
       Serial number: 000000000ZY15028208R
       Serial number: 00000000000030139763
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617145
       Coding: 0271165041
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 50F98C538A629D071A1-8004
    13688835 - Databus
              [Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                        Reset counter: 241
                        Mileage: 29131 km
                        Date: 2019.06.04
                        Time: 17:11:39
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
       Component: ACC3          H08 0390
       Serial number: 19021303030627
       Coding: 00000300FE030B
       ASAM Dataset: EV_ACCBoschMQB 001021
       ROD: EV_ACCBoschMQB_VW37.rod
       VCID: 3FDBBFEF27FC127FF3B-806A
       Serial number: 003F6R1V1W4Y
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 41DFB9175108648F85F-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 35767000000432B44C1Q
       Subsystem 2 - Part No SW: -----------    HW: 480 001 506 16
       Serial number: 358670000008B4C4DB17
       Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
       Serial number: 3516502BB205729313D3
       Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
       Serial number: 3526502AF2076340F201
       Subsystem 5 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 35565029B21160C1025X
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 13061608490829
       Coding: 0400
       VCID: 0D4755275DD0F0EFB17-8058
       Part No SW: 5G1 920 750 B    HW: 5G1 920 750 B
       Component: KOMBI         303 8311
       Coding: 03A501802688000D02882B0D1401000000000000
       VCID: 26150A8BD866A3B790D-8072
       Part No SW: 5Q0 963 272 B    HW: 5Q0 963 272 B
       Component: STH-MQB       006 0069
       Coding: 1309
       VCID: 3537DDC715C0D82F297-8060
       Component: R64 D208L  004 0401
       Serial number: 00000000000000180382
       Revision: --------    Serial number: 0004271482
       Coding: 030100043F085700FB000258080F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA108E3766AC967969-8028
       Component: E221__MFL-DC1  H10 0038
       Serial number: 29140002632800044485
       Coding: 2C0000
       Serial number: 8442320304
       Component: HRE_Master    H11 0071
       Serial number: 0392234969
       Coding: 02031103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3C21C8E336EA0967D69-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H11 0071
       Serial number: 0381249049
       Coding: 020311
       Serial number: 300516EEU02971
       Coding: 003B0220D000040100001000
       VCID: 43D3B31F4B14769F973-8016
       Coding: 8307
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2DCEFB3CDE3757C45-806E
       Serial number: 280516EER24731
       Coding: 003B0020DE00040100801000
       VCID: 42DDB61B540E7F979C5-8016
       Part No SW: 3Q0 035 824 B    HW: 3Q0 035 824 B
       Component: MU-S--ER      710 0744
       Coding: 02730000AA0000005111000100080A001F0206D40120010003
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2C01F8A3C68A99E7469-8078
       Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
       Component: ABT_Std-2  H50 8120
       Serial number: VWZ6ZHT1541317
    6720 - Rear View Camera
              B1102 31 [008] - No Signal
                        Reset counter: 241
                        Mileage: 29131 km
                        Date: 2019.06.04
                        Time: 14:01:50
                        Voltage terminal 30: 13.0 V
       Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0009
       Serial number: 40000000018766
       ROD: EV_RDKBERU30_006_VW37.rod
       VCID: 3431E0C31EBAC1271E9-8060
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.4V/12.3V)-----------
    Jul 2014
    Tallinn, Estonia
    There should be "a few" B8 autoscans in the reference autoscan section with PLA 3.0 and BSD to get sample module 10 codings from.
  3. Likes darkchina811 liked this post
    Apr 2018
    ITALY
    well tonight I went for a movie and when I came back home I was able to clear the error, so maybe the car needed to drive a bit after the installation.
    however, after checking reference scans I decided to adjust the coding as follows, all good and still no errors. I'll drive more tomorrow.
    it is worth mentioning that I did not replace the exterior mirror glasses, so the BSD indicator is a commercial LED. seems to work flawlessly.
    here is the final autoscan:
    Wednesday,05,June,2019,01:52:11:06888
    Mileage: 29199km-18143mi   Repair Order:
    VIN: WVWZZZAUZHW0xxxxx   Mileage: 29199km-18143miles
       Revision: R7H25---
       CAN Converter 01:
       Revision: 00001K08
       Coding: 0E4DFD
       Coding: 06A8DD
       Coding: 0271165041
       Coding: 0400
       Coding: 1309
       Coding: 2C0000
       Coding: 02011103
       Coding: 020111
       Coding: 8307
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.3V)-----------
  5. Likes jyoung8607 liked this post
