Results 1 to 5 of 5
Thread: 2012 Audi Q7 Issues with Bose following MMI update
    Aug 2014
    Sad days but this is seemingly a common problem with some cars. Update was completed with genuine original discs and followed instructions to the letter but now have bose fader problems and the fault codes as per the scan below. Before I have to take the car to a dealer please can anyone offer any direction?
    Originally it was HNAv_EU_K0031_3_D1, Nav Database was 8R0060884R ECE 5.11.7
    First Software update was
    8R0 906 961 AS - SVM Code 3GHEU206
    Then 8R0 906 961 DF - SVM Code 3GHEU257
    Map database 8R0 051 884 GA/ ECE 2019
    Tuesday,04,June,2019,01:04:12:38198
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4438.4
    VIN: WAUZZZ4L3BD005627   License Plate: ALFQ7
    Mileage: 77680km-48268mi   Repair Order:
    Chassis Type: 4L-AU56 (4F0)
    Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3D 42 46 47 4F 52 55 56
              5F 62 6C 6D 6F 72 76
    VIN: WAUZZZ4L3BD005627   Mileage: 77680km-48268miles
    3D-Special Function -- Status: OK 0000
    Address 01: Engine (J623-CJGA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4L1 910 401 H    HW: 4L0 907 401 C
       Component: 3.0TDI EDC17  H35 0003
       Revision: 53H35---    Serial number:
       Coding: 2A2A4012A52701020000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114L1910401H 001008
       ROD: EV_ECM30TDI0114L1910401H.rod
       VCID: 2809FBBC027A4827F6D-807C
       Part No SW: 0C8 927 750 AE    HW: 0C8 927 750 AE
       Component: AL1000 AISIN  001 1783
       Coding: 001578
       Shop #: WSC 48400 000 1048576
       ASAM Dataset: EV_TCMAL991031 001001
       ROD: EV_TCMAL991031_001_AU56.rod
       VCID: 6FBBD0A0E7145F1F777-803A
       Revision: 00H02001
       Coding: 2200689
       VCID: 34311FCCC2323CC74A5-8060
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
       Component: FBSAUDIC6 ELV   H05 0130
       Revision: 00H05000    Serial number: 10602901615404
       Coding: 0000211
       VCID: 2517F28879E8554FCDB-8070
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 IDG   H01 0054
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AE
       Component: KLIMA 4 ZONEN H13 0050
       Revision: 00---021    Serial number: 00000030158112
       Coding: 01009416
       VCID: 2517F28875E8554FCDB-8070
                014 - Defective
                        Fault Status: 01101110
                        Fault Frequency: 21
                        Reset counter: 161
                        Mileage: 77495 km
                        Date: 2019.05.28
                        Time: 20:29:48
                        Temperature: 24.0°C
       Part No SW: 4F0 910 279 AD    HW: 4F0 907 279 D
       Component: ILM Fahrer      H28 0360
       Coding: 0033121
       VCID: 6B83C4B0DF8CA33F5BF-803E
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H12 0100
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 71 AIRBAG AUDI8RH43 0230
       Revision: 04H43000    Serial number: 00399D06YTT3
       Coding: 0014129
       VCID: 2E050DA42C1E16173C1-807A
       Subsystem 1 - Serial number: 6332QSME526A4A22G
       Subsystem 2 - Serial number: 6342QSME68695432J
       Subsystem 3 - Serial number: 6352QSME4F6A0D1E/
       Subsystem 4 - Serial number: 6362QSME30651F22C
       Subsystem 5 - Serial number: 63734SME56624734
       Subsystem 6 - Serial number: 63834SME5061242E-
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90026101900222
       Coding: 0102142
       VCID: 270BF88003E4475FFF7-8072
       Component: E0221           H02 0100
       Part No SW: 4L0 920 983 T    HW: 4L0 920 983 T
       Component: KOMBIINSTR.   H10 0214
       Revision: 00000000    Serial number: FDD21F97A
       Coding: 2F56630400012600010400
       Shop #: WSC 00428 210 184921
       VCID: 43D34C109B9C8B7FC3F-8016
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4L0 910 105     HW: 4L0 815 071 G
       Component: Heizgeraet      H09 0140
       Revision: 0000000C    Serial number: 00000009021078
       Coding: 0000101
       VCID: 6099A39C264AF067FED-8034
       Part No SW: 4F0 907 468 P    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0047
       Revision: LB200032    Serial number: 3200L107060039
       Coding: 00CF07
       VCID: 3C2137ECE662F487825-8068
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790309805
       Component: J532_DCDCStab  H16 0038
       Serial number: 10194000398011200180
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 H    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7870
       Revision: --H03001    Serial number: 15.1528-0123.2
       Coding: 0015510
       Shop #: WSC 00428 210 15987
       VCID: 2F3B10A02B141F1F377-807A
    Address 3D: Special Function        Labels: 8K0-907-440.clb
       Part No SW: 8K0 907 440     HW: 8K0 907 440
       Component: STS             H04 0040
       Revision: S0H04000    Serial number: 00000000022132
       Coding: 01010101000000000000000202
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0004000109340
       Coding: 011F06205061440004
       VCID: 48C95B3CA2BAA82716D-801C
       Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
       Component: Komfortgeraet   H10 0110
       Revision: 0110 ---    Serial number: 01325865710000
       Coding: 3809531
       VCID: 353722C8C94825CF7DB-8060
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H03 0160
       Revision: CH003000    Serial number: 00000000000139
       Coding: 030000
       VCID: 290FFEB819F0712FE93-807C
    03389 - Data Set Implausible
                        Reset counter: 161
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H14 0100
       Revision:             Serial number: 00000000175633
       Coding: 0011101
       VCID: 5EE59D641C3EC697CC1-800A
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0004000110220
       VCID: 47CB5800AFA4A75F1F7-8012
       Part No: 8P0 907 357 H
       Coding: 0000008
       VCID: 3FDB40E0FB74EF9FA77-806A
       Part No SW: 4G0 035 053 H    HW: 4G0 035 053
       Component: Radio U Basic H51 0134
       Revision: AB001007    Serial number: 496G00A7527470
       Coding: 010003010000000000
       VCID: 2313EC907BDCAB7FA3F-8076
       Part No SW: 4L0 035 670 H    HW: 4L0 035 670 A
       Component: H-BNT-EU      H49 0187
       Revision: --------    Serial number: 474G00A7535286
       Coding: 010101060004D3EF01000315EF6300030000
       Shop #: WSC 00428 210 83177
       VCID: 2D070AA82D186D0F05B-8078
       Subsystem 1 - Part No: 8R0 060 884 GA
       Component: EUR 2019  2802
       Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
       Component: DU7 High  H43 0098
       Serial number: 9466HV0A0068044
       Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 B
       Component: E0380 Bedient  H05 0060
       Serial number: 00000001635313
       Component: CD-Database  1886
                        Reset counter: 161
                        Mileage: 77687 km
                        Date: 2019.06.04
                        Time: 01:02:40
                        Voltage: 11.80 V
    03175 - Invalid Data Set
                        Reset counter: 161
                        Mileage: 77687 km
                        Date: 2019.06.04
                        Time: 00:40:38
                        Voltage: 12.00 V
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0004000108301
       Coding: 010E06204061230004
       VCID: 46D55504A8AEBE57E41-8012
       Revision: --H04---    Serial number: 525PA8-J0642V5
       Coding: 1021001
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H55 0500
       Revision: --H55001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C81C7ACDA82A407525-8038
       Subsystem 3 - Serial number: RD16.07.10--H55001001A0272˙
       Subsystem 4 - Serial number: 1A0272˙
       Part No SW: 4L0 910 290     HW: 4L0 907 290
       Component: ILM HINTEN 2    H05 0070
       Revision: AAH05061    Serial number: 106479852-----
       VCID: 6597B2883968954F0DB-8030
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0004000108315
       Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
       Component: Parkhilfe 8-Kan H02 0100
       Revision: 00H02000    Serial number: 85131018707781
       Coding: 0221066
       VCID: 2C0107AC1A026407125-8078
    End----(Elapsed Time: 01:57, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
    16.4905° S, 151.7375° W
    ... Before I have to take the car to a dealer please can anyone offer any direction?
    Did you follow the following:"Technical product information - Transaction No.: 2019922"
    "MMI3G/MMI3G+: software updating instructions
    Specifically in this step...
    Step 23.
    After a successful update the feedback/to the software version management (SVM) must be carried out. Connect a diagnostic tester and enter the SVM code (see attachment).
    Note:
    If the feedback is broken off, do it later. The message "Check software version management“ (DTC 03276 (0x0ccc) is automatically deleted, as soon as a feedback takes place.
    At this time I do believe the SVM test plans (at the dealer) will need to be completed as mentioned in Step 24.
    Note:
    - We do have Ross-Tech wiki pages for these fault codes...
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
    Aug 2014
    HI Many thanks for your reply and appreciate the direction. Yes I did follow instructions and have done this update on a few occasions using genuine software etc. I will look further into this and if needs be will simply take to a dealer.
  5. Likes DrPeter liked this post
  6. #4
    Quote Originally Posted by paul View Post
    Thanks, let us know if the SVM test plan fixes it or if there was another fix, this way others in the future may find this thread even more helpful
    drp
  7. Likes Uwe liked this post
  8. #5
    Aug 2014
    Rest assured once up and running will update. May be a while as moving house at present. Thanks again.
  9. Likes DrPeter liked this post
