Results 1 to 8 of 8
Thread: Misfire Counter Reset
    Jun 2014
    Newcastle, England
    My car spluttered again in the very same place on the very same road on my drive home from work. A smooth 30mph road; but uphill on a gradient of at least 12% (1 in 8). Last time was a month ago. I'm going to have to knuckle down this extremely intermittent fault, probably start around the coilpacks, as at my last Dealer service in March they changed my sparkplugs. (Not casting any aspersions though... )
    The only misfire counters I see are shown below; however I can't clear them. I've tried Clear Faults, then found a Basic Setting to 'Reset all Adapted Values' - but heeded the warning of possibly clearing all parameterization, so backed away very quickly.
    So how do you clear these misfire counters?
    IDE01975,Numb.of misfir.: cylinder 1,2280,
    IDE01976,Numb.of misfir.: cylinder 2,3255,
    IDE01977,Numb.of misfir.: cylinder 3,1236,
    IDE01978,Numb.of misfir.: cylinder 4,3449,
    Monday,03,June,2019,21:59:18:19335
    VCDS Version: 19.6.0.2 (x64)  HEX-NET CB: 0.4505.4
    VIN: WAUZZZ8K69A093649   License Plate: CJW
    Mileage: 92270km-57333mi   Repair Order: AfterMisfires
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 03 05 07 08 09 0E 0F 10 13 15 16 17 19 1E 36 37 42 46 47
              52 53 55 56 57 62 69 6C 72 77
    VIN: WAUZZZ8K69A093649   Mileage: 92270km-57333miles
    Address 01: Engine (-----CDNC)       Labels:* User\TEST-01.lbl
       Part No SW: 8K2 907 115 A    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H12 0002
       Revision: E1H12---
       Coding: 0104000C180F0A60
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM20TFS8K2907115A A01003
       ROD: EV_ECM20TFS8K2907115A.rod
       VCID: 2D12C9137C5AB9270A-8078
    4057 - Cylinder 2
              P0302 00 [101] - Misfire Detected
                        Mileage: 92272 km
                        Date: 2019.06.03
                        Time: 16:33:08
                        Engine speed: 2140.00 /min
                        Normed load value: 70.2 %
                        Vehicle speed: 33 km/h
                        Coolant temperature: 97 °C
                        Intake air temperature: 20 °C
                        Voltage terminal 30: 13.099 V
                        Unlearning counter according OBD: 80
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [101] - -
       Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
       Component: ESP8 quattro  H04 0060
       Coding: 07CD00
       VCID: 7BB6374BFAAEE797C4-802E
       Part No SW: 8K0 907 064 AE    HW: 8K0 907 064 AE
       Component: BCM2 1.1      H71 0134
       Coding: 071100
       VCID: 73A61F6BD2FEAFD79C-8026
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Serial number: 0208000037716016
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 154
                        Mileage: 90800 km
                        Date: 2019.03.29
                        Time: 20:10:44
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 730     HW: 4E0 035 729 A
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 331GW087527386
       VCID: 6E900E1F79DC823F73-803A
       Subsystem 1 - Part No: 8T0 919 609 C
       Subsystem 2 - Serial number: 00000000122047
       Subsystem 3 - Serial number: 0125.07.080000000100010252˙
       Subsystem 4 - Serial number: 010252˙
       Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
       Component: KLIMA 3 ZONEN H06 0140
       Revision: D1000000    Serial number: 0112.07.080038
       Coding: 64040000
       VCID: 43C68FABC2DE5F57CC-8016
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Revision: 05022001    Serial number: 00000000197362
       Coding: 260050914034AF010001000300001D0D4F1D230800010141000000
       Shop #: WSC 00724 210 01500
       VCID: 302CD0676368D4CF21-8064
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 150708  H05 0070
       Serial number: SWFBIE 0000715
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 20021153
       Coding: 022228
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000003107081163
       Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
       Component: MP3-Changer     H44 0390
       Revision: 00044003    Serial number: AUZ5ZBH8521457
       VCID: 2B16C70B8A4EB71714-807E
    Address 0F: Digital Radio        Labels: None
       Part No SW: 4E0 910 563 C    HW: 4E0 035 563
       Component: DAB-Tuner       H41 0830
       Revision: 00000001    Serial number: KE1276W7300525
       Coding: 0000001
       VCID: 24042C37E790786FD5-8070
    Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
       Part No SW: 8K0 919 475 E    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0020
       Revision: 11001001    Serial number: 52830821004243
       Coding: 310003
       VCID: 3B36F74BBA2E279784-806E
       Part No SW: 8K0 907 561     HW: 8K0 907 561
       Component: ACC2          H07 0080
       Coding: 00C7CF
       VCID: 6FAE131BBED68B3778-803A
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD182SKG
       Coding: 30363434363030303030554A3052384B3053
       VCID: 3C34F457B72020AF8D-8068
       Serial number: 6334MSME3E12552BG
       Serial number: 6344MSME3F43723AL
       Serial number: 6352QSME7C522E43Q
       Serial number: 6362QSME7F3A3927Y
       Serial number: 63732SME2D024606W
       Serial number: 63832SME45002800J
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H12 0013
       Revision: --------    Serial number: 90304HG3000BA
       Coding: 00001E
       VCID: 3E30FE5FA93C32BFA3-806A
       Part No SW: 8K0 920 980 E    HW: 8K0 920 980 E
       Component: KOMBIINSTR.   H12 0216
       Revision: 00400000    Serial number: 6Y912F1A7
       Coding: 2F0D09000F002600010400
       Shop #: WSC 00783 210 90835
       VCID: 3424DC779770E8EF45-8060
       Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0092
       Revision: FB402044    Serial number: 4400F087218051
       Coding: 000303
       VCID: 4AD8A28FE5F48E1F0F-801E
       Component: J367-BDM  H04 0150
       Serial number: 18032EA6150708
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0850
       Revision: 00000000
       VCID: 2B16C70B4A4EB71714-807E
       Part No SW: 8K0 959 760     HW: 8K0 959 760
       Component: MEM-FS        H05 0043
       Revision: AA000000    Serial number: 00001001111410
       Coding: 00783B00000000000000
       VCID: 77BE2B7BC686C3F7A0-8022
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H51 1060
       Revision: 00000000    Serial number: 333G%087599178
       Shop #: WSC 00762 210 97024
       VCID: 3B36F74B7A2E279784-806E
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007541200
       Coding: 011C12205E01410001
       VCID: 3FCE835BAE363BB7A8-806A
       Revision: 00002001    Serial number: 0113463471
       Coding: 011B0E22003905C5003001
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS034  H06 0037
    01503 - Bulb for 3rd Brake Light (M25)
                        Fault Status: 00101100
                        Fault Frequency: 33
                        Reset counter: 33
                        Mileage: 90130 km
                        Date: 2019.03.05
                        Time: 16:10:52
       Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
       Component: DSP Prem      H14 0400
       Revision: 00H14003    Serial number: 34814002277201
       Coding: 020101
       Shop #: WSC 12336 024 394758
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Date: 2064.00.00
                        Time: 00:00:10
                        Voltage: 11.30 V
                        Temperature: 251.0°C
                        Temperature: 253.0°C
                        Bin. Bits: 00000100
                        Bin. Bits: 00000100
                        Bin. Bits: 00000000
    Address 52: Door Elect, Pass. (J533)       Labels:. 8T0-907-468.clb
       Coding: 000303
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 10000000072910
       VCID: 312AD5636862DDC72E-8064
    Address 55: Headlight Range        Labels: 8T0-907-357.clb
       Part No SW: 8H0 907 357 A    HW: 8H0 907 357
       Coding: 0000019
       Shop #: WSC 06324 000 00000
       VCID: 302CD067A368D4CF21-8064
       Subsystem 1 - Part No: 8K0 941 329
       Component: AFS-Modul links H01 S001
       Subsystem 2 - Part No: 8K0 941 329
       Component: AFS-Modul rechtsH01 S001
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 336H+087584845
       Coding: 0000001
       VCID: 312AD563A862DDC72E-8064
                        Reset counter: 33
                        Mileage: 85228 km
                        Date: 2018.08.11
                        Time: 14:45:31
    Address 57: TV Tuner        Labels: None
       Part No SW: 4E0 910 148 E    HW: 4E0 919 148
       Component: R78 TVHybridDVB     0470
       Revision: R0H06000    Serial number: 76300801710102
       Coding: 0000103
       VCID: 25023133ECAA8167C2-8070
       Part No SW: 8K0 959 795     HW: 8K0 959 795
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000007490460
       Coding: 010C12204001210001
       VCID: 7F4EC35BEEB6FBB7E8-802A
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00008200250331
       Coding: 0100000000000000
       VCID: 3620E67F810CFAFF7B-8062
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J87910O
       Coding: 1032006
       VCID: 373EEB7B460603F760-8062
       Part No SW: 8K0 959 794     HW: 8K0 959 795
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000007559497
       VCID: 7EB03E5FE9BCF2BFE3-802A
    Address 77: Telephone        Labels: 4F1-910-336.lbl
       Part No SW: 4F1 910 336 D    HW: 4F1 862 335
       Component: BTA             H11 1120
       Revision: 00H11000    Serial number: 00000007586811
       Coding: 1010021
       Shop #: WSC 00783 210 84012
    End----(Elapsed Time: 02:03, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    Mode 07: Pending emission related fault codes
    Address 7E8: 1 Fault Found:
    P0302 - Cylinder 2: Misfire Detected
    Type 02 - VIN : WAUZZZ8K69A093649 (Address E8)
    Type 04 - Calibration ID : 8K2907115A Q0002 (Address E8)
    Type 06 - Calibration Verification Number : EC342100 (Address E8)
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Component: 2.0l R4/4V TF H12 0002 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed MED17.1 UDS is a bitch!
    Revision: E1H12---
    Dr. Z try clearing DTC's in OBD2 mode & re-coding the module, in addition check ground strap under load offset!
    Vehicle Identification No. WAUZZZ8K69A093649
    Model audi a4 qu. 2,0
    A4
    Date of production 12.08.2008
    Model year 2009
    Sales type 8K2069
    Engine Code CDNC
    Transmission Code KCA
    Emission standard 7MB Emission standard EU 4 plus
    ECU supersedes!
    PART NUMBER DESCRIPTION REMARK MODEL
    8K2 907 115 P Control unit for petrol engine 37F1
    37F1A001
    PR-7MA,7MB,
    7MG+CDNC
  3. Likes Zenerdiode liked this post
    Jul 2014
    Hi Zenerdiode,
    What do the fuel trims look like? Perhaps log them, the MAF and fuel pressures on the particular hill.
    Regards HMC
  5. Likes Uwe liked this post
    Jun 2014
    Newcastle, England
    Thank you HMC, but (as is usually the case) a bit of water has gone under the bridge. Intermittent faults really are the hardest ones to track down, but I think I've made progress:
    So this misfire has manefested itself five times over two months, three times on that exact same hill, but a couple of times on the flat too. Latest one was just Friday gone; on the hill, but I managed to limp it another mile home to grab the VCDS lead, all the time leaving the engine jumping around and sputtering, clouds of white smoke from the exhaust. Here's the codes pulled:
    Address 01: Engine (-----CDNC)       Labels:| 06H-907-115-CAB.clb
       Revision: E1H12---
       VCID: 2D5B729C7C79B82702-8078
    2838 - Fuel Rail/System Pressure
              P0087 00 [100] - Too Low
                        Mileage: 93779 km
                        Date: 2019.07.05
                        Time: 19:05:50
                        Engine speed: 1987.00 /min
                        Normed load value: 43.9 %
                        Vehicle speed: 32 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 13.546 V
    4010 - Idle Control System
              P0506 00 [096] - RPM Lower than Expected
                        Mileage: 93550 km
                        Date: 2019.06.22
                        Time: 10:05:28
                        Engine speed: 814.50 /min
                        Normed load value: 14.9 %
                        Coolant temperature: 94 °C
                        Intake air temperature: 37 °C
                        Voltage terminal 30: 13.570 V
                        Unlearning counter according OBD: 15
    4060 - Cylinder 3
              P0303 00 [101] - Misfire Detected
                        Mileage: 93779 km
                        Date: 2019.07.05
                        Time: 19:12:09
                        Engine speed: 774.00 /min
                        Normed load value: 9.4 %
                        Coolant temperature: 92 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 13.782 V
    4057 - Cylinder 2
                        Mileage: 93777 km
                        Date: 2019.07.05
                        Time: 19:01:59
                        Engine speed: 760.00 /min
                        Normed load value: 12.9 %
                        Coolant temperature: 96 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 13.405 V
    7960 - Cylinder Disabling
              P130A 00 [036] - -
                        Mileage: 93777 km
                        Date: 2019.07.05
                        Time: 19:02:06
                        Engine speed: 4108.00 /min
                        Vehicle speed: 36 km/h
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 13.735 V
              P0300 00 [101] - -
                        Mileage: 93777 km
                        Date: 2019.07.05
                        Time: 19:01:59
    Whilst running, I checked IDE00589,Fuel pressure,xxxx, kPa rel - and it was bouncing around all over the place. Stopped the engine, then KOEO (to activate the LP fuel lift pump) IDE00589,Fuel pressure, increased and then rapidly dropped to zero, I mean, like a stone. It's supposed to increase slightly with heat soak. This is suggesting an injector stuck open. Unfortunately didn't have any tools to pull stuff apart at that time.
    This afternoon, did the IDE00589,Fuel pressure, test - this time holding pressure so the fault intermittent again. Without starting the engine I pulled all plugs; zyl1: slightly dirty, zyl2: normal, zyl3: filthy sooty black (there's my problem..!), zyl4: normal. I think injector for zyl3 has been sticking full open, dumping fuel like crazy.
    Because the fault wasn't on with everything cold, I put everything back together and it started and ran well, but *CLOUDS* of smoke from the tail. My hypothesis for that is when zyl3 injector stuck open, it's washing piston carbon and then this sits in the manifold, turbo and cat. Initially I thought I had hydro-locked and burst something, but it cleared after about 4 miles of 3000rpm running.
    Got back home and pulled the plugs again, this time all lovely and clean. All injectors read 1.6Ω. Thank you if you've got this far down; questions:
    1. How likely is an intermittent mechanically sticking (open) injector?
    2. Does the ECU switch the ground side of the injector, if so I could have an intermittent short to ground, however GDi injectors employ that inductive pulse from the back EMF, stored in a capacitor to 'generate' a 60-80V injector pulse in the ECU output stages.
    3. Considering 2. above, is the ECU going bad? I thought if it would fail with a constant output to the injector - it wouldn't recover.
    4. Should I load the parts cannon with four injectors?
  7. Likes Uwe, jyoung8607, Eric liked this post
  8. #5
    Injectors are phucked!
    Ethanol anyone?
    Add Marvel Mystery oil and MOS2 to fuel and maybe you get lucky with fuel cleaner agent.
    I'd change them......
    Could swap locations for isolated test!
    Get that oil changed!
  9. Likes Zenerdiode, Uwe liked this post
  10. #6
    Jun 2014
    Newcastle, England
    Thanks mate
    I don't deliberately run E85 or anything like that, just what the UK gov decide what they deem acceptable in the British Standard.
    I know, I know. I may have seen a slight increase on the dipstick...
  11. Likes Uwe liked this post
  12. #7
    Windsor UK
    Zenor
    Do you have, or can you get your hands on an oscilloscope. IF so the looking at Rail, pressure, Injector Command & Current alongside the CKP will give you a 3 dimensional view of what is happening.
    Another channel on O2 will tell you if it is going rich or lean causing the misfire.
  13. Likes Zenerdiode liked this post
  14. #8
    Jun 2014
    Newcastle, England
    Yes, I've got a couple of 2-channel DSOs; in fact, I've just taken delivery of a 4-channel Pico for work. I understand the charging curve, pintle 'bump' and all of that, but it's just so darn intermittent. I'd even thought of connecting the Pico and having it and the laptop permanently connected so I may capture when it happens - but of course the practicalities of that are somewhat different.
    To give an idea just how intermittent it is, here's a rough history:
    1. 3rd May, on the hill coming home from work, 5 seconds of misfire CEL set, CEL clears by the top of the hill.
    2. 3rd June, on the same hill, again coming home from work, 7 seconds of misfire, CEL set, CEL clears by the top of the hill. (About 70 miles have passed)
    3. 12th June, on my way down to Felixstowe, failed at Grantham, didn't clear when I was recovered, local garage thought it was the PCV valve (because of all the smoke) but by the time I collected the car, running normally. (250 miles have passed)
    4. 22nd June, on my weekly shopping trip, misfired until I got off the road, I had a look under the bonnet, but ran perfectly when re-started. (400 miles have passed)
    5. 5th July, back on the hill from work, this time misfired for the remainder of journey home, allowing me to do the diagnostic in my post 4 above. (220 miles have passed).
    So it's definitley zyl3 injector stuck fully open that's causing the mis - but so intermittent.
  15. Likes Eric, Uwe liked this post
