Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: 2015 A3 8v - Coolant system
    Jun 2019
    New to this forum and I love it! New user with vcds and what a great tool. Anyway, 3 weeks ago had fault before i got this Hex-v2 for Coolant flow low / temp.
    I cleared thinking hoping just a fluke. 1 week later came back and like a knucklehead i cleared agin and brought to Audi since I still have about 1 month left on warranty. I have 34k miles. I just plugged in my vcds and did a scan, Oh well, code found again but did not trip the check engine light. Please see my scan and
    point me in right direction?... I have read about leaking thermostat water pump housings but see no visible leaks anywhere. I am familiar with the plastic that VW uses because I had a jetta that leaked twice from the coolant manifold. Thanks for any advice. LOVE this forum and everything about Ross - Tech!
    Monday,03,June,2019,18:56:33:07665
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WAUBFGFF9F1139426   License Plate:
    Mileage: 55519km-34497mi   Repair Order:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 3C 42 44 52 55 5F 6C BB BC
    VIN: WAUBFGFF9F1139426   Mileage: 55519km-34497miles
    Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0006
       Revision: --H13---
       Coding: 0A1D00324426000F2000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
       ROD: EV_ECM20TFS0205G0906259A.rod
       VCID: 2C01055BE68AE877469-8078
    16987 - Insufficient Engine Cooling / Coolant Flow
              P00B7 00 [096] - -
                        Mileage: 55260 km
                        Date: 2019.05.30
                        Time: 17:51:31
                        Vehicle speed: 255 km/h
                        Coolant temperature: 108 °C
                        Intake air temperature: 47 °C
                        Voltage terminal 30: 12.519 V
                        Unlearning counter according OBD: 34
                        Engine: operating status: ES
                        Engine temp. management actuator: raw value: 3715
                        Engine temperature management actuator: stop open: 133
                        Engine temperature management actuator: after-run stop: 3969
                        RVC_SP: 234.69 °
                        RVC_AV: 238.14 °
                        RVCPWM: 33.081 %
       Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4515
       Revision: 05853104    Serial number: TFK01504020715
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1E65DF93A0360AE7D8D-804A
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 61105000002093
       Coding: 13FF6A9234230A75017B030281C929C8562C5080C08194B4024100588208
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 48C959CB52322457421-801C
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 186
                        Mileage: 27774 km
                        Date: 2017.09.29
                        Time: 15:48:57
       Component: AC Automat    H13 0060
       Revision: 20027000    Serial number: 00000000628663
       Coding: 03000014010000000000000000001400
       VCID: 33331E273BB4B78F073-8066
       Serial number: D12804A7000000000001
       Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
       Component: BCM MQBAB MNA H18 0137
       Serial number: 01011510000419
       Coding: 04141A46C04122F541C04004511007000000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 79AFEC0F59588DDF8DF-802C
       Component: WWS371 150415  042 0585
       Serial number:         150422013203
       Coding: 0A47F7
       Serial number: 23908855
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 12 02 2015  00001544
       Serial number: 00000000000032291052
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST00090EM900000
       Coding: 101F00
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39391510500909
       Coding: 0030150011
       VCID: 42DD4BE3740E0E079C5-8016
       Serial number: 003GCR01V1FK
       Coding: 9DCCFCC0000000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB5AF75F2C2B2F4BB-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34178311B21041540228
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34178312B21041540464
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 6940000Y150001BBWY0J
       Coding: 303139
       Subsystem 4 - Part No SW: -----------    HW: 480 001 604 15
       Serial number: 357000000003F314E31G
       Subsystem 5 - Part No SW: -----------    HW: 480 001 604 15
       Serial number: 358000000001F314E31F
       Subsystem 6 - Part No SW: -----------    HW: 480 401 304 15
       Serial number: 3510002A519EFF5383BO
       Subsystem 7 - Part No SW: -----------    HW: 480 401 604 15
       Serial number: 3520002991A87864226+
       Subsystem 8 - Part No SW: -----------    HW: 480 400 902 15
       Serial number: 35500029D196FF52F2CX
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 400 902 15
       Serial number: 35600029F196FF54330F
       Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 22041508490633
       Coding: A018
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 7CA1F51B566AB8F7969-8028
       Part No SW: 8V0 920 971 D    HW: 8V0 920 971 D
       Component: KOMBI         H02 4292
       Coding: 0BF418092B88D7050200E8001800000000000000
       VCID: 3E253F1300F66AE7F8D-806A
       Revision: --------    Serial number: 18041510801065
       Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72BDDB23042EFE87CC5-8026
       Serial number: 14 04 2015  C0040578
       Serial number: HA1-00010.03.15
       Coding: 0001
       VCID: 46D557F358263227B0D-8012
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0363732741
       Coding: 030211
       ROD: EV_LaneChangAssis_VW51.rod
       VCID: 3829290B22D254D7321-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0080
       Serial number: 0365753967
       Coding: 030211
       Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
       Serial number: 030415BD311549
       Coding: 00100F204000048000000002
       VCID: 40D941EB7A021C178A1-8014
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: 43D34EE76B14070F973-8016
       Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
       Serial number: 250315BCP07028
       Coding: 001007204000048000000002
       VCID: 3FDB421707FC63EFF3B-806A
       Coding: 012A000101000000
       VCID: 75B7E03F7540E9BFE97-8020
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
       Part No SW: 8V0 035 047 B    HW: 8V0 035 047 B
       Component: MU-H-NS-US    H43 0394
       Serial number: A052D0FB006165
       Coding: 01730102FF0A000021220001041A00002F000105010001047E
       ROD: EV_MUHig6C3HBAS_AU37.rod
       Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
       Component: NAR 2015  --- 0035
       Component: DU High  H49 0014
       Serial number: AUZ8Z9FY202YX9
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 K    HW: 8V0 919 614 K
       Component: ControlUnit_H  H81 0816
       Serial number: C1000030011500030427
       Component: Gracenote  --- 3006
    0009 - Antenna for Satellite Radio
              B10F4 13 [008] - Open Circuit
                        Reset counter: 56
                        Mileage: 32924 km
                        Date: 2018.05.03
                        Time: 15:53:21
                        Voltage terminal 30: 14.0 V
                        Satellite radio tuner status-Reception quality: No_signal
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_2CamSysRearPASE.rod
       VCID: 3039112BCAA28C977A1-8064
       Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0028
       Serial number: 310315BCT12779
       Coding: 000007204000048000000002
       Component: TSG HBFS      020 0028
       Serial number: 310315CCU0499A
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.3V/12.3V)-----------
    Emission standard 0GT Emission standard SULEV
    Welcome to the VCDS forum OP!
    JPPSG!
    Under useful life warranty!
    Vehicle Identification No. WAUBFGFF9F1139426
    Model Audi A3 saloon
    Quattro 2.0
    A3
    Date of production 05.05.2015
    Model year 2015
    Sales type 8VS58L
    Engine Code CNTC
    Transmission Code QSN
    Has coolant pump been revised yet?
    The warranty on an SULEV is 15/150K you been misinformed!
    https://forums.ross-tech.com/showthr...l=1#post156577
    OP: Please post the OBD2 data in VCDS MODES 1,3,7 & 9.........
    Jun 2019
    My gut tells me no on the coolant pump being revised but I don't know. I purchased the car 5 1/2 months ago from dealer and "car fax" was clean. How do I verify if it is new or not?.....PS..OP?
    Have you contacted NHTSA and Audi customer care?
    OP = Original Poster
    Please post the OBD2 data as aforementioned.
    RTFB the TSB or TPI....
    https://erwin.audiusa.com/erwin/showHome.do
    Did you JPPSG yet?
    Run along now, go verify and come back with hard data!
  5. Likes Zenerdiode liked this post
    Jun 2019
    PSS....What you're saying is that my coolant pump falls under the CAA emissions?
    Jun 2019
    Run along now?, Im not a child....Really, just trying to learn......Guess Ill try to look elsewhere.
    If a P-code will light up the MIL & the MIL is responsible for informing of CAA failures than isn't it under useful life warranty?
    If the engine ran too hot or too cold would it effect SMOG, indeed it would?
    Effectively you are new & like a child in a manner of speaking and part of the learning process is following directions and doing home work when asked.
    I should of warned you while my methods of being the local yokel asshole are in fact self evident, you should realize that I am trying to help you help yourself.
    Did I not answer your questions or point you to where you could scholastically achieve them?
  9. #8
    Jun 2019
    Your name handle fits you like a glove!....While i was a child I was told no question is a dumb question. That was 45 yrs ago.
    With that being said I understand about the warranty now. I assumed that is what you meant. I will contact customer care. Again, I can take the beatings if in the long run I learn as much as I can.......
  11. #9
    Indeed you will, smart answer & I like it!
    Welcome
    Seriously JPPSG!
    Verify latest part number for coolant pump, it's not like they catch on fire, right?
    Einst there was a boo boo.....
    https://static.nhtsa.gov/odi/rcl/201...8V229-5195.pdf
    This notice applies to your vehicle: NHTSA: 18V229IMPORTANT!Information about Safety Recall 19N4 – After Run Coolant PumpTHIS RECALL REPAIR IS NOT YET AVAILABLE. We will send another letter as soon as therecall work can be completed on your vehicle.As an interim measure, please contact your Audi dealer immediately to have SafetyRecall 19M1 performed.This notice is sent to you in accordance with the National Traffic and Motor Vehicle Safety Act.Audi has decided that a defect, which relates to motor vehicle safety, exists in certain 2013-2017model year Audi vehicles equipped with a 2.0L TFSI gasoline engine. Our records show that youare the owner of a vehicle affected by this action. At this time, the recall repair is not yetavailable; however we anticipate being able to begin recall repairs in late 2018.Recall Description: In certain vehicles equipped with a 2.0L TFSI gasoline engine, the electriccoolant pump may experience a short circuit and/or overheat. A short circuit or overheating withinthe electric coolant pump may lead to a fire resulting in vehicle or other property damage.What You Need to Do: Have Safety Recall 19M1 performed on your vehicle immediately.The software installed for FREE under Safety Recall 19M1 will turn off the electriccoolant pump if the pump becomes blocked with debris, and will alert you if this happensby turning on the Electronic Power Control lamp (EPC). This can help reduce the risk ofthe pump overheating and possibly causing a fire. Please schedule this important, FREErecall with your authorized Audi dealer without delay. Contact your Audi dealer without delay if the EPC light comes on.After Safety Recall 19M1 is completed, an illuminated EPC light can mean that thecoolant pump in your vehicle is blocked. For FREE, your dealer will diagnose the reasonfor the EPC light and also replace the coolant pump for FREE if necessary. Until Safety Recall 19N4 has been completed on your vehicle, Audi recommendsparking your vehicle outdoors as a precaution. Contact your dealer or Audi if you have any concerns about your vehicle.Your authorized Audi dealer knows your vehicle best, and has the tools and informationnecessary to address your vehicle concerns. If you should have any questions about thiscommunication, please contact Audi Customer Experience at 1-800-253-2834 or via our“Contact Us” page at www.audiusa.com.
  12. #10
    Revision: --H13---
    P00B7 00 [096] - -
    Mileage: 55260 km
    Date: 2019.05.30
    Time: 17:51:31
    RVC_SP: 234.69 °
    RVC_AV: 238.14 °
    RVCPWM: 33.081 %
    OP: Isn't the ability to see DTC's with VCDS & as proof of a fault, with date and time stamp, oh such a glorious means of documentation for court or to inform an agency when needed?
    CAA is fun stuff huh?
    FOR EACH PENNY DENIED OR INCURRED, LET ME CAST & THERE BE INVERSE A BILLION PENNIES FOLD
  13. Likes tclark18 liked this post
