Results 1 to 7 of 7
Thread: 2016 A6 Enable Automatic front Parking Distance Sensors (PDC)?
    Feb 2016
    I have been searching for a tweak to enable automatic activation of the front parking sensors on my 2016 A6. I found some tips online already but none seem to work with my car. (the one involving bit 1 of byte 37 of controller 9 doesn't seem to work). I have posted an autoscan to show what version of the various modules my car has. Any help would be appreciated.
    Sunday,02,June,2019,10:39:52:28013
    VCDS Version: 19.6.0.2
    VIN: WAUFMAFC2GN006348   License Plate:
    Mileage: 16424km-10205mi   Repair Order:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3B 3C 42 44 46 52 53
              55 5F 62 6C 72 85 8B 8E 8F 90 AC
    VIN: WAUFMAFC2GN006348   Mileage: 16424km-10205miles
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 AA    HW: 4G0 907 401 E
       Component: 3.0TDI FSA    H14 0010
       Revision: 58H14---
       Coding: 0A2A4012056601050000
       Shop #: WSC 23321 002 1048576
       ASAM Dataset: EV_ECM30TDI0114G0907401AA 002009
       ROD: EV_ECM30TDI0114G0907401AA_002.rod
       VCID: 62CB88777522DC5FE7-8036
    10577 - MIL Request Signal Active (Check TCM for errors too!)
              P1624 00 [032] - -
                        Mileage: 16327 km
                        Date: 2019.05.31
                        Time: 14:31:29
                        Coolant temperature: 62 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 14.320 V
                        Unlearning counter according OBD: 38
                        Engine status: COENG_READY
       Part No SW: 4G0 927 158 AQ    HW: 0BK 927 156 AM
       Component: 0BK 30TDIUSA  H19 1006
       Revision: --H19---
       Coding: 000001
       VCID: 7DF1DB0BEC9C03A7FA-8028
       Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
       Component: ESP9 Premium  H01 0420
       Coding: 47A79649E2E569921B00
       ASAM Dataset: EV_ESP9BOSCHAU57X 003019
       ROD: EV_ESP9BOSCHAU57X_003.rod
       VCID: 3F8D6103A610D1B7A8-806A
       Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
       Component: BCM2 2.0      H36 0560
       Coding: 0DA86F4E000000000000
       VCID: 7EF3DC07E99A18BFE3-802A
       Serial number: 3215000012586005
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: 4G0 820 043 CG    HW: 4G0 820 043 CG
       Component: KLIMA 2 ZONEN H14 0112
       Serial number: 02021500110437
       Coding: 368131184D0000
       ASAM Dataset: EV_AirCondiBasisUDS 003009
       ROD: EV_AirCondiBasisUDS_003.rod
       VCID: 66C39467990AA07F0B-8032
       Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
       Revision: 21020001    Serial number: 00000992625402
       Coding: 01050011043C9FE2C100488780003800CF9CD208AE08022180000494F10015020060002D0B0000
       VCID: 76E3C427C1AA50FFBB-8022
       Component: WWS57X 150114  H37 0080
       Serial number:         150120075429
       Coding: 0045F7
       Serial number: 23685819
       Coding: 02006D
       Component: E1 - LDS  H07 0044
       Serial number: 28 01 2015  00000177
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z01DC6AC9
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA120043000011412668
       Coding: 020300
       Subsystem 6 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Serial number: 2278CD87000000000001
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0053
       Coding: 7E01010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002014
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 2959DF5B48944F07E6-807C
    95232 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 189
                        Mileage: 16327 km
                        Date: 2019.05.31
                        Time: 14:31:30
                        Control Module temperature: 37 °C
                        Voltage terminal 15: 14.350 V
                        Velocity_vehicle_reference: -0.01 m/s
    95488 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 189
                        Mileage: 16327 km
                        Date: 2019.05.31
                        Time: 14:31:30
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0086
       Revision: --------    Serial number: 003G0001UX63
       Coding: 303331343135303334354A55304C34473053
       VCID: 34673E2F9F5602EF45-8060
       Component: BF-Gewichtss.  H11 0046
       Serial number: 6940000Y140001A62W0N
       Serial number: 3575HRB40672UMTMEOJ$
       Serial number: 3585HRB400K52SLE8OC%
       Serial number: 3515JRB4010533VUQPO8
       Serial number: 3525JRB405N350J8OH6E
       Serial number: 3554VRB4065358DCC9H8
       Serial number: 3564VRB4065358DCE9A4
       Revision: --------    Serial number: 90372OAS00039
       Coding: 0004FC
       VCID: 387F0A1F8B3EE68F69-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 15 12 2014  E0052147
       Part No SW: 4G8 920 986 C    HW: 4G8 920 986 C
       Component: TDieUsaAccNv  H07 0043
       Revision: 03001036    Serial number: 658290115596013
       Coding: 0FCE0A040F51D705020000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 387F0A1F833EE68F69-806C
       Part No SW: 4G8 907 468     HW: 4G8 907 468
       Component: J533--Gateway H13 0075
       Revision: --------    Serial number: 00000001712949
       Coding: C0CD078110
       ASAM Dataset: EV_GatewPkoUDS 001024
       VCID: 75E1C32BD4AC5BE7B2-8020
       Serial number: 5444165603
       Voltage stabilizer:
       Serial number: 1411160000000000015F
       Revision: AA001002
       VCID: 7CF7D60FFF860AAFCD-8028
       Revision: AA000000    Serial number: 00000134147856
       VCID: 77FDC923C6A029F7A0-8022
       Component: SARA 6D       H04 0056
       Revision: --------    Serial number: EJ1BPA8208XFBS
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 36630427892A10FF7B-8062
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H06 0060
       Serial number: 0359056246
       Coding: 040211
       VCID: 39790F1BB834FF8796-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H06 0060
       Serial number: 0359088761
       Coding: 040211
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F17015E00628002000013
       VCID: 458173EBCCCC8B67E2-8010
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0003377794
       Coding: 101001010001
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 33653D339A5805D75C-8066
       Revision: 00002001    Serial number: 0358681020
       Coding: 0106063A00FA408580A0080402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000269788
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST00043AQ700000
       Coding: 101F02
       Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93423586
       Coding: 011F17015E00628002000002
       VCID: 468374E7F1CA807FEB-8012
       Revision: --------    Serial number: 00000001347417
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D512B4B7C7C53270A-8078
       Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0081
       Coding: 04FA021122600400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
       Coding: E01E00
       Coding: E01E00
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 025 E    HW: 4G1 035 025
       Component: MU-H-LNS-US   040 1062
       Serial number: A278B0FB005061
       Coding: 01750102FF0A000013220001041A00102F0006E5F17001047E
       Shop #: WSC 50909 003 1048576
       VCID: 204FC27F3BAE8E4FB1-8074
       Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
       Component: NAR 2017/2018  --- 0060
       Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
       Serial number: AUZ8Z9EY800GBH
       Multimedia Operating Unit:
       Serial number: 90349OAR0003Y
       Component: Gracenote2  --- 3006
              B11CF 53 [009] - Deactivated
                        Reset counter: 149
                        Mileage: 16327 km
                        Date: 2019.05.31
                        Time: 14:43:20
                        Voltage terminal 30: 14.8 V
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
       VCID: 49997FDBE0D46F0706-801C
       Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
       Component: TopView       H07 0330
       Revision: 11001001    Serial number: 82330JF0199421
       Coding: 0211000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
       ROD: EV_CamerSysteTopViewAUDI.rod
       VCID: 2E532C47717A283F33-807A
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: 6A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C57264F47665A2F1D-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E01010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 275DD9635E807977F0-8072
              U1113 00 [008] - -
                        Reset counter: 189
                        Mileage: 16327 km
                        Date: 2019.05.31
                        Time: 14:31:30
                        Control Module temperature: 34 °C
                        Voltage terminal 15: 14.364 V
                        Velocity_vehicle_reference: -0.00 m/s
              U1113 00 [008] - -
                        Reset counter: 189
                        Mileage: 16327 km
                        Date: 2019.05.31
                        Time: 14:31:30
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H33 0090
       Serial number: 005000622601157
       Coding: 04C1B8180111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 3169373B604437C72E-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 326B383765420CDF57-8066
       Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0012
       Revision: 00000000    Serial number: 143280778
       ROD: EV_RDCMA00100_008.rod
    End-------------------------(Elapsed Time: 06:45)--------------------------
    Jul 2014
    Tallinn, Estonia
    On the A6 C7.5 the factory PDC is its own seperate module, not integrated into the BCM1 (module 09). But where is your PDC (module 10) ?
    Feb 2016
    I show no module 10 installed on my car, as you can see. The only thing I can think of is the North American version may be a different configuration from the ROW.
    I have full parking sensors as well as front, back and top cameras and everything works as designed...just wanted the sensors to come on automatically like they do in my other cars and in the post 2016 Audis.
    Nov 2018
    In 2016 the PDC is integrated in 09 unless you have parallel park then it’s in 10. I have the same vehicle and would love to get this activated also.
    2016 Audi A6 TDI
    So Cal, USA
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by wuplur View Post
    Thanks for the clarification. Didn't see that nuance in Elsa.
    PQ platform VW-s got the PDC automatic activation in 2015 but these are always seperate module 10. One could simply retrofit the newer module but this doesn't seem the case with the C7.5.
    Jun 2017
    Not possible.
  7. #7
    Feb 2016
    From what I have been able to find online Audi enabled automatic front PDC in MY 2017 in some models (the Q saw it roll into mid year production) and the A4 sometime after that but on both of those models the earlier versions could be tweaked to work using this:
    Enable Automatic PDC Front
    [09 – Central Elect.] [Coding - 07]
    Select Long Coding Helper
    Select Byte 37
    Check Bit 1
    Exit Long Coding Helper
    Click Do It
    I tried using VCDS to change bit 1 of byte 37 to 1 from 0 but it didn't seem to change anything on my car. The one thing I didn't try was rebooting the MMI after I made the change so I might try that and see if it works. My guess is the answer is somewhere in controller 9. It is just a matter of finding which bit it is.
