- Joined
- Jun 2, 2019
- Messages
- 1
- Reaction score
- 4
- Location
- Western Pennsylvania, USA
- VCDS Serial number
- C?ID=371131
2019 Tiguan SE 4Motion Factory Settings
Auto-Scan
01 Map
02 MAP
2B Map
03 Map
3C Map
05 MAP
5F Map
6C Map
08 Map
09 Map
13 Map
15 Map
17 Map
19 Map
22 Map
42 Map
44 Map
52 Map
CA Map
Auto-Scan
Saturday,01,June,2019,13:01:09:47965
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
VIN: 3VV2B7AX8KM027763 License Plate:
Mileage: 1087km-675mi Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 2B 3C 42 44 52 5F 6C CA
VIN: 3VV2B7AX8KM027763 Mileage: 1087km-675miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA) Labels:. 06L-907-115-V1.clb
Part No SW: 83A 907 115 HW: 06L 907 309 B
Component: R4 2.0l TFSI H31 0003
Revision: 1DH31000
Coding: 012A00122426012F34000000000000000000000000000000
Shop #: WSC 00066 790 00450
ASAM Dataset: EV_ECM20TFS01183A907115 001005
ROD: EV_ECM20TFS01183A907115.rod
VCID: 6393AE6E9BDE0DCFB73-8036
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DT HW: 09G 927 158
Component: AISIN AQ8 206 3549
Coding: 0002000100000000000000000000000000000000
Shop #: WSC 00066 790 00405
ROD: EV_TCMAQ450031_VW37.rod
VCID: 084999C242B88E97821-805C
Part No SW: 5Q0 614 517 DD HW: 5Q0 614 517 AC
Component: ESC H25 0424
Revision: 00000000 Serial number: 52178000001762
Coding: 0BFA6BA454221B73C57E0306A2C649D0D62AD8A3C045927C10415058C28A420B002864121A1C230935351919323200
Shop #: WSC 01383 790 50316
VCID: 76B5E73A384C8867E0D-8022
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0490822431
Coding: 132C0C0723
VCID: 43D34EEE3B1E6DCF973-8016
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NN 907 044 F HW: 5NN 907 044 F
Component: AC Automat H35 4401
Revision: 20K03000 Serial number: 00000D00236867
Coding: 0002002420011800100500001211140E
ASAM Dataset: EV_ACClimaPrehVW37X 002025
ROD: EV_ACClimaPrehVW37X.rod
VCID: 4FFB72DEE75699AF03B-801A
Part No SW: 5Q0 937 087 BB HW: 5Q0 937 087 BB
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C864150918034K
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CA1F5120660D237969-8028
Subsystem 1 - Part No SW: 5NN 955 119 HW: 5NN 955 119 Labels: 1KX-955-119.CLB
Component: 326 LL 180905 034 0373
Serial number: 18090521000830
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Labels: 8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 72254557
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300091020180C202331
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H02 0233
Coding: 3200008110FF8728749C8145004097
Shop #: WSC 00066 790 00273
VCID: 3E253F1A50FC0027F8D-806A
Part No SW: 5Q0 959 655 AG HW: 5Q0 959 655 AG
Component: AirbagVW21 005 0338
Serial number: 003NUM0BMWP$
Coding: 8CCCFC00000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 055790F675AA93FFF97-8050
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000AB9ARR
Coding: 303351
Subsystem 2 - Part No SW: ----------- HW: 480 002 707 18
Serial number: 357000000009C45DC23W
Subsystem 3 - Part No SW: ----------- HW: 480 002 807 18
Serial number: 35800000000ADB78233U
Subsystem 4 - Part No SW: ----------- HW: 480 400 907 18
Component: SideSensor_Dr 004 6149
Serial number: 35100012E2AEB0C2C36C
Subsystem 5 - Part No SW: ----------- HW: 480 401 007 18
Component: SideSensor_Pr 003 6149
Serial number: 35200019F2A0CC7185CI
Subsystem 6 - Part No SW: ----------- HW: 480 402 708 18
Component: FrontSensor_D 004 6149
Serial number: 3550001042B7DB96D34B
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 708 18
Component: FrontSensor_P 004 6149
Serial number: 3560001142B7DB935353
Part No SW: 5NA 920 850 C HW: 5NA 920 850 C
Component: KOMBI 351 2500
Coding: 0BA40C1AA388CF0502882B0954000000A0000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009065
VCID: 3FDB421E57F6092FF3B-806A
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 518 5344
Serial number: 05101800840277
Coding: 030500347F085900FB0322481E0F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 3D2738165DFA1B3FE17-8068
Component: 1-00-0d-00-04
Subsystem 2 - Part No SW: 5NA 959 442 A HW: 5NA 959 442 A
Component: E221__MFL-TAT H06 0025
Serial number: 2551818550702148FE2B
Coding: 280000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 0404246100
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00002.07.18
Coding: 0101
VCID: 4CC165D21640A2B7669-8018
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000282802007
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 33331E2E6BBEDD4F073-8066
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0490464291
Coding: 01011103
ROD: EV_HREntryHella_VW37.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0490944198
Coding: 010111
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 5Q4 959 393 M HW: 5Q4 959 393 F
Component: TSG FS 006 0247
Serial number: 50038827901558
Coding: 003013200000048000000000
VCID: 4DC768D6ED5AABBF717-8018
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000926548
Coding: 011000
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 173 1081
Coding: 811F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 50F971A2FA6886571A1-8004
Part No SW: 5Q4 959 392 M HW: 5Q4 959 392 F
Component: TSG BFS 006 0247
Serial number: 54038827803313
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000946254
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 724 0890
Coding: 02730600BE00000051220001001808001F0500C40120050002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2E050F5A809CF0A768D-807A
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 252 8130
Serial number: VWZ6ZMV2765492
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0123060120002017300040
VCID: 392F2C0649D2271FCDF-806C
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00804073260C
End----------(Elapsed Time: 01:28, VBatt start/end: 12.8V/12.8V)-----------
01 Map
;SW:83A-907-115 HW:06L-907-309-B --- Engine
;Component:R4 2.0l TFSI H31 0003, Coding:012A00122426012F34000000000000000000000000000000
;EV_ECM20TFS01183A907115,001005,EV_ECM20TFS01183A907115.rod
;Saturday,01,June,2019,12:53:23:47965
;VCDS Version: Release 19.6.0 (x64) Data version: 20190529 DS308.0
;VCID: 6393AE6E9BDE0DCFB73-8036
IDE01945-Engine run-in oil pressure,not active ,1
IDE02332-Deactivate production mode,00 00 00 ,3
IDE04158-Activation of start-stop function,active ,1
IDE04617-Protective function,OFF ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,0.50 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,2.31 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,0.00 °,2
IDE06736-Timing deviation: current value exhaust bank 1,0.00 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,1 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,2 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,not active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,not active ,1
02 MAP
;SW:09G-927-158-DT HW:09G-927-158 --- Auto Trans
;Component:AISIN AQ8 206 3549, Coding:0002000100000000000000000000000000000000
;EV_TCMAQ450031,001001,EV_TCMAQ450031_VW37.rod
;Saturday,01,June,2019,12:53:28:47965
;VCID: 084999C242B88E97821-805C
IDE00001-Production mode,not activated ,3
IDE04159-Deactivation of start-stop function,not activated ,1
IDE07160-Control module switch-off: switch-off time,20 minute,1
IDE80050-Analysis 50,254 ,1
IDE80051-Analysis 51,65535 ,2
IDE80052-Analysis 52,65535 ,2
IDE80053-Analysis 53,255 ,1
IDE80054-Analysis 54,255 km/h,1
Elapsed Time: 00:02
2B Map
;SW:3Q0-905-861-B HW:3Q0-905-861-B --- Steer. Col. Lock
;Component:ELV-MQBB H05 0020, Coding:0800000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW37.rod
;Saturday,01,June,2019,12:57:14:47965
;VCID: 33331E2E6BBEDD4F073-8066
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,tested ,1
Elapsed Time: 00:01
03 Map
Elapsed Time: 00:01
3C Map
;SW:5Q0-907-686-C HW:5Q0-907-686-C --- Lane Change
;Component:HRE_Master H12 0081, Coding:01011103
;EV_HREntryHella,001028,EV_HREntryHella_VW37.rod
;Saturday,01,June,2019,12:57:17:47965
;VCID: 3D2738165DFA1B3FE17-8068
IDE02332-Deactivate production mode,Deactivating ,3
IDE05397-Calibration mode,not activated ,1
IDE80001-Analysis 1,not activated ,1
IDE80004-Analysis 4,not activated ,1
Elapsed Time: 00:01
05 MAP
;SW:3Q0-959-435-L HW:3Q0-959-435-L --- Acc/Start Auth.
;Component:VWKESSYMQB 037 1204, Coding:132C0C0723
;EV_KessyHellaMQBAB,004046,EV_KessyHellaMQBAB_004_VW37.rod
;Saturday,01,June,2019,12:53:51:47965
;VCID: 43D34EEE3B1E6DCF973-8016
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,FE ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,not activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,10 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,7.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,20 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,50 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,400 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,04 ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,02 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,220 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,40 mV/m,5
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,14 B,1
ENG107595-MCTX settling phase,10 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG244880-Minimum_holdtime_ak,500 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,not activated ,1
ENG244883-Speed_ threshold_for_start_request_plausibilisation,10 km/h,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126938-Terminal_15_adaption_body_control_module,Default ,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG244884-Toggle_offtime_other_doorhandle,2.00 s,1
ENG244885-Toggle_offtime_same_doorhandle,2.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
Elapsed Time: 00:51
5F Map
;SW:3Q0-035-844-B HW:3Q0-035-844-B --- Information Electr.
;Component:MU-S-S-US 724 0890, Coding:02730600BE00000051220001001808001F0500C40120050002
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
;Saturday,01,June,2019,12:57:43:47965
;VCID: 2E050F5A809CF0A768D-807A
IDE00346-Summertime-automatic,manual ,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
IDE02502-Confirmation of installation change,36 2D ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_NAR ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10604-Menu entries for mobile online services,not activated ,1
IDE11122-Country identification: country of sale HMI,US ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,blocked ,21
IDE11503-Satellite radio tuner: pre-activated subscription,05 ,1
IDE11524-ENG249835-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57,not activated ,192
IDE11524-ENG249836-Vehicle function list BAP 2nd generation: expansion-chassis_control_0x57_msg_bus,not activated ,192
IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
IDE11524-ENG249837-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C,not activated ,192
IDE11524-ENG249838-Vehicle function list BAP 2nd generation: expansion-convertibleTop_0x6C_msg_bus,not activated ,192
IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192
IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
IDE11524-ENG248719-Vehicle function list BAP 2nd generation: expansion-ITM_0x65,not activated ,192
IDE11524-ENG248720-Vehicle function list BAP 2nd generation: expansion-ITM_0x65_msg_bus,not activated ,192
IDE11524-ENG249902-Vehicle function list BAP 2nd generation: expansion-lift_0x64,not activated ,192
IDE11524-ENG249903-Vehicle function list BAP 2nd generation: expansion-lift_0x64_msg_bus,not activated ,192
IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192
IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
Elapsed Time: 00:36
6C Map
;SW:5Q0-980-556-B HW:5Q0-980-556-B --- Back-up Cam.
;Component:RVC Compact H12 0231, Coding:0123060120002017300040
;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
;Saturday,01,June,2019,12:58:21:47965
;VCDS Version: Release 19.6.0 (x64) Data version: 20190529 DS308.0
;VCID: 392F2C0649D2271FCDF-806C
IDE02709-Actuator: PWM signal,100 %,1
IDE03531-Wheel/tire description,1950 mm,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
MAS02209-Image contrast,50 %,1
MAS02851-Brightness,50 %,1
ENG119212-camera_off,35.00 km/h,2
ENG119211-camera_on,30.00 km/h,2
ENG119200-color,50 %,1
ENG119218-debounce_time_for_reverse_gear,0 ms,2
ENG119215-display_position,0 px,1
ENG119216-engine_restart_timer,0 ms,2
ENG119209-Frequency_Swinging_Logo,100 Hz,2
ENG119221-FSG_control_state,On ,1
ENG119220-ENG119101-grafic_element_setting-setting_1_color_value,FF FF ,128
ENG119220-ENG119099-grafic_element_setting-setting_1_HMI_mode,FF ,128
ENG119220-ENG119100-grafic_element_setting-setting_1_pallet_ID,255 ,128
ENG119220-ENG119128-grafic_element_setting-setting_10_color_value,FF FF ,128
ENG119220-ENG119126-grafic_element_setting-setting_10_HMI_mode,FF ,128
ENG119220-ENG119127-grafic_element_setting-setting_10_pallet_ID,255 ,128
ENG119220-ENG119131-grafic_element_setting-setting_11_color_value,FF FF ,128
ENG119220-ENG119129-grafic_element_setting-setting_11_HMI_mode,FF ,128
ENG119220-ENG119130-grafic_element_setting-setting_11_pallet_ID,255 ,128
ENG119220-ENG119134-grafic_element_setting-setting_12_color_value,FF FF ,128
ENG119220-ENG119132-grafic_element_setting-setting_12_HMI_mode,FF ,128
ENG119220-ENG119133-grafic_element_setting-setting_12_pallet_ID,255 ,128
ENG119220-ENG119137-grafic_element_setting-setting_13_color_value,FF FF ,128
ENG119220-ENG119135-grafic_element_setting-setting_13_HMI_mode,FF ,128
ENG119220-ENG119136-grafic_element_setting-setting_13_pallet_ID,255 ,128
ENG119220-ENG119140-grafic_element_setting-setting_14_color_value,FF FF ,128
ENG119220-ENG119138-grafic_element_setting-setting_14_HMI_mode,FF ,128
ENG119220-ENG119139-grafic_element_setting-setting_14_pallet_ID,255 ,128
ENG119220-ENG119143-grafic_element_setting-setting_15_color_value,FF FF ,128
ENG119220-ENG119141-grafic_element_setting-setting_15_HMI_mode,FF ,128
ENG119220-ENG119142-grafic_element_setting-setting_15_pallet_ID,255 ,128
ENG119220-ENG119146-grafic_element_setting-setting_16_color_value,FF FF ,128
ENG119220-ENG119144-grafic_element_setting-setting_16_HMI_mode,FF ,128
ENG119220-ENG119145-grafic_element_setting-setting_16_pallet_ID,255 ,128
ENG119220-ENG119149-grafic_element_setting-setting_17_color_value,FF FF ,128
ENG119220-ENG119147-grafic_element_setting-setting_17_HMI_mode,FF ,128
ENG119220-ENG119148-grafic_element_setting-setting_17_pallet_ID,255 ,128
ENG119220-ENG119152-grafic_element_setting-setting_18_color_value,FF FF ,128
ENG119220-ENG119150-grafic_element_setting-setting_18_HMI_mode,FF ,128
ENG119220-ENG119151-grafic_element_setting-setting_18_pallet_ID,255 ,128
ENG119220-ENG119155-grafic_element_setting-setting_19_color_value,FF FF ,128
ENG119220-ENG119153-grafic_element_setting-setting_19_HMI_mode,FF ,128
ENG119220-ENG119154-grafic_element_setting-setting_19_pallet_ID,255 ,128
ENG119220-ENG119104-grafic_element_setting-setting_2_color_value,FF FF ,128
ENG119220-ENG119102-grafic_element_setting-setting_2_HMI_mode,FF ,128
ENG119220-ENG119103-grafic_element_setting-setting_2_pallet_ID,255 ,128
ENG119220-ENG119158-grafic_element_setting-setting_20_color_value,FF FF ,128
ENG119220-ENG119156-grafic_element_setting-setting_20_HMI_mode,FF ,128
ENG119220-ENG119157-grafic_element_setting-setting_20_pallet_ID,255 ,128
ENG119220-ENG119161-grafic_element_setting-setting_21_color_value,FF FF ,128
ENG119220-ENG119159-grafic_element_setting-setting_21_HMI_mode,FF ,128
ENG119220-ENG119160-grafic_element_setting-setting_21_pallet_ID,255 ,128
ENG119220-ENG119164-grafic_element_setting-setting_22_color_value,FF FF ,128
ENG119220-ENG119162-grafic_element_setting-setting_22_HMI_mode,FF ,128
ENG119220-ENG119163-grafic_element_setting-setting_22_pallet_ID,255 ,128
ENG119220-ENG119167-grafic_element_setting-setting_23_color_value,FF FF ,128
ENG119220-ENG119165-grafic_element_setting-setting_23_HMI_mode,FF ,128
ENG119220-ENG119166-grafic_element_setting-setting_23_pallet_ID,255 ,128
ENG119220-ENG119170-grafic_element_setting-setting_24_color_value,FF FF ,128
ENG119220-ENG119168-grafic_element_setting-setting_24_HMI_mode,FF ,128
ENG119220-ENG119169-grafic_element_setting-setting_24_pallet_ID,255 ,128
ENG119220-ENG119173-grafic_element_setting-setting_25_color_value,FF FF ,128
ENG119220-ENG119171-grafic_element_setting-setting_25_HMI_mode,FF ,128
ENG119220-ENG119172-grafic_element_setting-setting_25_pallet_ID,255 ,128
ENG119220-ENG119176-grafic_element_setting-setting_26_color_value,FF FF ,128
ENG119220-ENG119174-grafic_element_setting-setting_26_HMI_mode,FF ,128
ENG119220-ENG119175-grafic_element_setting-setting_26_pallet_ID,255 ,128
ENG119220-ENG119179-grafic_element_setting-setting_27_color_value,FF FF ,128
ENG119220-ENG119177-grafic_element_setting-setting_27_HMI_mode,FF ,128
ENG119220-ENG119178-grafic_element_setting-setting_27_pallet_ID,255 ,128
ENG119220-ENG119182-grafic_element_setting-setting_28_color_value,FF FF ,128
ENG119220-ENG119180-grafic_element_setting-setting_28_HMI_mode,FF ,128
ENG119220-ENG119181-grafic_element_setting-setting_28_pallet_ID,255 ,128
ENG119220-ENG119185-grafic_element_setting-setting_29_color_value,FF FF ,128
ENG119220-ENG119183-grafic_element_setting-setting_29_HMI_mode,FF ,128
ENG119220-ENG119184-grafic_element_setting-setting_29_pallet_ID,255 ,128
ENG119220-ENG119107-grafic_element_setting-setting_3_color_value,FF FF ,128
ENG119220-ENG119105-grafic_element_setting-setting_3_HMI_mode,FF ,128
ENG119220-ENG119106-grafic_element_setting-setting_3_pallet_ID,255 ,128
ENG119220-ENG119188-grafic_element_setting-setting_30_color_value,FF FF ,128
ENG119220-ENG119186-grafic_element_setting-setting_30_HMI_mode,FF ,128
ENG119220-ENG119187-grafic_element_setting-setting_30_pallet_ID,255 ,128
ENG119220-ENG119191-grafic_element_setting-setting_31_color_value,FF FF ,128
ENG119220-ENG119189-grafic_element_setting-setting_31_HMI_mode,FF ,128
ENG119220-ENG119190-grafic_element_setting-setting_31_pallet_ID,255 ,128
ENG119220-ENG119194-grafic_element_setting-setting_32_color_value,FF FF ,128
ENG119220-ENG119192-grafic_element_setting-setting_32_HMI_mode,FF ,128
ENG119220-ENG119193-grafic_element_setting-setting_32_pallet_ID,255 ,128
ENG119220-ENG119110-grafic_element_setting-setting_4_color_value,FF FF ,128
ENG119220-ENG119108-grafic_element_setting-setting_4_HMI_mode,FF ,128
ENG119220-ENG119109-grafic_element_setting-setting_4_pallet_ID,255 ,128
ENG119220-ENG119113-grafic_element_setting-setting_5_color_value,FF FF ,128
ENG119220-ENG119111-grafic_element_setting-setting_5_HMI_mode,FF ,128
ENG119220-ENG119112-grafic_element_setting-setting_5_pallet_ID,255 ,128
ENG119220-ENG119116-grafic_element_setting-setting_6_color_value,FF FF ,128
ENG119220-ENG119114-grafic_element_setting-setting_6_HMI_mode,FF ,128
ENG119220-ENG119115-grafic_element_setting-setting_6_pallet_ID,255 ,128
ENG119220-ENG119119-grafic_element_setting-setting_7_color_value,FF FF ,128
ENG119220-ENG119117-grafic_element_setting-setting_7_HMI_mode,FF ,128
ENG119220-ENG119118-grafic_element_setting-setting_7_pallet_ID,255 ,128
ENG119220-ENG119122-grafic_element_setting-setting_8_color_value,FF FF ,128
ENG119220-ENG119120-grafic_element_setting-setting_8_HMI_mode,FF ,128
ENG119220-ENG119121-grafic_element_setting-setting_8_pallet_ID,255 ,128
ENG119220-ENG119125-grafic_element_setting-setting_9_color_value,FF FF ,128
ENG119220-ENG119123-grafic_element_setting-setting_9_HMI_mode,FF ,128
ENG119220-ENG119124-grafic_element_setting-setting_9_pallet_ID,255 ,128
ENG119201-image_delay_timer,0.0 s,1
ENG119219-Minimal_time_to_stay_in_bus_sleep_before_ECU_off,20000 ms,2
ENG119214-rv_dark_off,10.00 km/h,2
ENG119213-rv_dark_on,15.00 km/h,2
ENG119203-RV_Last_Mode,90° parking spot ,1
ENG102898-RV_Start_Mode,90° parking spot ,1
ENG119205-Time_to_open_Swinging_Logo,750 ms,2
Elapsed Time: 00:07
08 Map
;SW:5NN-907-044-F HW:5NN-907-044-F --- Auto HVAC
;Component:AC Automat H35 4401, Coding:0002002420011800100500001211140E
;EV_ACClimaPrehVW37X,002025,EV_ACClimaPrehVW37X.rod
;Saturday,01,June,2019,12:54:44:47965
;VCID: 4FFB72DEE75699AF03B-801A
IDE00001-Production mode,Deactivating ,3
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1
IDE01483-Blower voltage for voice operation,not activated ,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01493-Air quality sensor sensitivity,Maximum ,1
IDE01503-Runtime for compressor run-in basic setting,60 s,1
IDE01536-Post-heating of parking heater,0 min,1
IDE02155-Reset all counters,not activated ,1
IDE03176-Duration of compressor run in,0 s,1
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE07108-Climate modes,Matching coding ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,15 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20 °C,1
IDE07307-Remote start function: activation stage of seat heating,level 2 ,1
IDE07308-Remote start function: activation stage of seat ventilation,level 2 ,1
IDE07398-Blower logic for manual adjustment,Matching coding ,1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,not active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE13676-Remote start function: rear window defogger,not activated ,1
IDE13677-Remote start function: seat climate control takeover,not activated ,1
MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
MAS17226-Remote start function: windshield defogger can be activated,activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
ENG122846-ENG99777-dimming_characteristic_3-Y1,2 %,12
ENG122846-ENG100480-dimming_characteristic_3-Y2,2 %,12
ENG122846-ENG100773-dimming_characteristic_3-Y3,5 %,12
ENG122846-ENG100631-dimming_characteristic_3-Y4,10 %,12
ENG122846-ENG102174-dimming_characteristic_3-Y5,85 %,12
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %,12
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
ENG153708-Remotestart_window_heating_temperature,4 ,1
Elapsed Time: 00:13
09 Map
;SW:5Q0-937-087-BB HW:5Q0-937-087-BB --- Cent. Elect.
;Component:BCM PQ37BOSCH 036 0265, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,019001,EV_BCMBOSCH_019_VW37.rod
;Saturday,01,June,2019,12:54:59:47965
;VCID: 7CA1F5120660D237969-8028
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
IDE01550-Service position,178.999822 °,2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Horn_verbaut ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1A 12 06 9A 00 00 00 04 4C 00 4C 14 00 64 08 0A 1A 13 07 9A 00 00 00 01 3A 00 49 14 00 7F 06 00 80 08 09 7F 00 00 00 01 44 00 4B 14 00 7F 07 00 80 08 0A 7F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,21.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,21.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,20.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,49.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,48.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,40.999959 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,DISKRET ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,50 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,19.999980 °,2
IDE10299-Alternating park position 2,34.999965 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.40 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000 ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000 ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000 ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000 ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000 ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000 ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,70 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,70 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,70 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,70 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,70 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,70 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,70 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,70 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,70 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,70 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,70 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,70 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,70 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,70 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber,not active ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
MAS05055-lower turn position,42.999957 °,2
MAS05056-upper turn position,178.999822 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2512 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 50 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,4500 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,6000 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,2000 mV,24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,Panoramic roof ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,Yes ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,true ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,No ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,6 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,Basis ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Not deactivated ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,64.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,64.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,64.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,64.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,57.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,42.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,27.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,22.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,15.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,00 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,not active ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,not active ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,00 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,not active ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,not active ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,48 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,47 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,13 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,13 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,54 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,minimize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,26 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Nebellicht links ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,Blinken links aktiv (beide Phasen) ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,minimize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,26 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Nebellicht rechts ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,Blinken rechts aktiv (beide Phasen) ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,minimize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Blinken links aktiv (beide Phasen) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,minimize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Blinken rechts aktiv (beide Phasen) ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,Parking light right ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,100 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,11 - Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,not active ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,100 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,11 - Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,not active ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,1C ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,37 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Left high beam ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Lichthupe generell ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,1D ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,41 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Right high beam ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Lichthupe generell ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 08 00 0D 00 00 00 23 23 00 3E 18 04 64 05 00 80 08 00 0D 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,25 00 00 48 08 00 7F 00 00 00 00 00 00 00 00 00 25 00 00 47 08 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-101.5 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,1.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,10.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,1.00 s,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001 ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG122979-ENG141969-Networking-UGDO,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,not active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
ENG124714-OCU-,not installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,not_active ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,800 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,not active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,not active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys,not active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
Elapsed Time: 01:55
13 Map
;SW:2Q0-907-572-M HW:2Q0-907-572-B --- Auto Dist. Reg
;Component:ACCCONTIMQB H02 0233, Coding:3200008110FF8728749C8145004097
;EV_ACCMRRCONTIVW376,002012,EV_ACCMRRCONTIVW376_002.rod
;Saturday,01,June,2019,12:56:56:47965
;VCDS Version: Release 19.6.0 (x64) Data version: 20190529 DS308.0
;VCID: 3E253F1A50FC0027F8D-806A
IDE00001-Production mode,Deactivating ,3
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01795-Heated lens,OFF ,1
IDE01949-Distance basic setting option,OFF ,1
IDE03642-Presentation mode,not active ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,OFF ,1
IDE09564-Distance change via speed adjustment,OFF ,1
IDE09565-Prioritized target object display,OFF ,1
IDE10280-Constant delay after transfer request,No ,1
IDE13334-Reduced radar performance,38 ,1
Elapsed Time: 00:05
15 Map
;SW:5Q0-959-655-AG HW:5Q0-959-655-AG --- Airbags
;Component:AirbagVW21 005 0338, Coding:8CCCFC00000000005000001AC20800000065
;EV_AirbaVW20SMEVW37X,002160,EV_AirbaVW20SMEVW37X.rod
;Saturday,01,June,2019,12:57:03:47965
;VCID: 055790F675AA93FFF97-8050
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined ,8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined ,8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined ,8
Elapsed Time: 00:03
17 Map
;SW:5NA-920-850-C HW:5NA-920-850-C --- Instruments
;Component:KOMBI 351 2500, Coding:0BA40C1AA388CF0502882B0954000000A0000000
;EV_DashBoardVDDMQBAB,009065,EV_DashBoardVDDMQBAB_009_VW37.rod
;Saturday,01,June,2019,12:52:21:47965
;VCID: 3FDB421E57F6092FF3B-806A
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,1087 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,US English ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,12 H,1
IDE00501-Minute,51 min,1
IDE00502-Year,2019 yr,2
IDE00503-Month,6 mon,1
IDE00504-Day,1 d,1
IDE00510-ESI: distance driven from inspection,1030 km,3
IDE00511-ESI: time from inspection,30 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,1400 km,2
IDE00819-Day counter,228 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,16000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,7.9 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Fahrenheit ,3
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,32100 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,1000 km,2
IDE03352-FIX: Time since last time-dependent inspection,30 d,2
IDE03372-Source for synchronization of time,GPS ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,No ,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,32100 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,730 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Display ,1
IDE11086-Service notification,30 d,1
IDE11932-MAS01877-Display of colour adjustment-Red,0 ,3
IDE11932-MAS01878-Display of colour adjustment-Green,0 ,3
IDE11932-MAS01879-Display of colour adjustment-Blue,0 ,3
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
IDE14220-Vehicle speed warning for India-,No ,1
IDE14220-Vehicle speed warning for India-,0 s,1
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,10 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0E ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG119874-Gas_functionality,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:29
19 Map
;SW:3Q0-907-530-Q HW:3Q0-907-530-C --- CAN Gateway
;Component:GW MQB High 518 5344, Coding:030500347F085900FB0322481E0F00010001070000000000000000000000
;EV_GatewNF,013023,EV_GatewNF.rod
;Saturday,01,June,2019,12:52:53:47965
;VCID: 3D2738165DFA1B3FE17-8068
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
IDE00002-Transport mode,not active ,1
IDE01211-Static current measuring mode,not activated ,1
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01459-Energy management heat output control status,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
IDE01860-Generator specified voltage value variable,10.6 V,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,69 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE04186-Battery terminal recognition,connected ,1
IDE04330-Transfer of release code for a SWaP function,00 ,1
IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
IDE06541-Distance left for deactivation of transport mode,50 ,1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE07838-Counter for inconsistent states,7 ,2
IDE08348-Start/stop start voltage limit,7.8 V,1
IDE08624-MKE Check box,activated ,1
IDE10735-Number requests autonomous recharging,3 ,1
IDE10736-Cyclization limitation request battery service,0 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
IDE11689-48V-System: locking,regular operation ,1
MAS16372-Security version number,3 ,2
SFT271921-IDE02583-Multi Function Steering Wheel Control Module-Steering wheel Tiptronic switch,not installed ,3
SFT271921-MAS04733-Multi Function Steering Wheel Control Module-Two-stage,not active ,3
SFT271921-MAS06614-Multi Function Steering Wheel Control Module-Version,CCS ,3
SFT271921-MAS09758-Multi Function Steering Wheel Control Module-Temperature sensor,not installed ,3
SFT271921-MAS19102-Multi Function Steering Wheel Control Module-Dimming after-run,active ,3
SFT271921-MAS19103-Multi Function Steering Wheel Control Module-Local data bus: wake-up function,not active ,3
SFT271921-MAS19104-Multi Function Steering Wheel Control Module-Alarm horn wake-up function,not active ,3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1
ENG137850-MVK_Warning,regular operation ,1
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
Elapsed Time: 00:26
22 Map
;SW:0CQ-907-554-J HW:0CQ-525-130 --- AWD
;Component:Haldex4Motion H52 7084, Coding:0101
;EV_AllWheelContrHA1VW37X,004013,EV_AllWheelContrHA1VW37X_004.rod
;Saturday,01,June,2019,12:57:10:47965
;VCDS Version: Release 19.6.0 (x64) Data version: 20190529 DS308.0
;VCID: 4CC165D21640A2B7669-8018
IDE07843-ENG142105-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_4,2000 ,8
IDE07843-ENG142107-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_5,2000 ,8
IDE07843-ENG142109-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_6,2000 ,8
IDE07843-ENG142111-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_7_plus,2000 ,8
IDE07843-ENG142104-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_4,1150 ,8
IDE07843-ENG142106-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_5,1150 ,8
IDE07843-ENG142108-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_6,1150 ,8
IDE07843-ENG142110-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_7_plus,1150 ,8
IDE07844-ENG142113-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_4,2200 ,8
IDE07844-ENG142115-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_5,2200 ,8
IDE07844-ENG142117-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_6,2200 ,8
IDE07844-ENG142119-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_7_plus,2200 ,8
IDE07844-ENG142112-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_4,1300 ,8
IDE07844-ENG142114-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_5,1300 ,8
IDE07844-ENG142116-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_6,1300 ,8
IDE07844-ENG142118-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_7_plus,1300 ,8
MAS06098-Acoustic measure: wiring logic,Standard ,1
Elapsed Time: 00:02
42 Map
;SW:5Q4-959-393-M HW:5Q4-959-393-F --- Door Elect, Driver
;Component:TSG FS 006 0247, Coding:003013200000048000000000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW37.rod
;Saturday,01,June,2019,12:57:21:47965
;VCID: 4DC768D6ED5AABBF717-8018
IDE00001-MAS10864-Production mode-Reduce reverse threshold,Deactivating ,3
IDE00001-MAS10865-Production mode-Power windows operable with terminal 15 off,Deactivating ,3
IDE00001-MAS10866-Production mode-Reduce switch-on time of lighting,Deactivating ,3
IDE00001-MAS10867-Production mode-Deactivate speed control for power windows,Deactivating ,3
IDE00001-MAS10868-Production mode-Deactivate closing aid,Deactivating ,3
IDE00001-MAS10869-Production mode-Activate test mode for the fold-in mirror,Deactivating ,3
IDE00001-MAS10870-Production mode-Activate test mode for power windows,Deactivating ,3
IDE00001-MAS17286-Production mode-Deactivation of actuation of opening assistance motor: e-lock,Deactivating ,3
IDE00001-MAS17291-Production mode-Deactivation of CarWakeUp due to activation of seatbelt feeder,Deactivating ,3
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 97 01 04 4F 0C 08 03 4D 15 20 3D 04 64 00 00 00 00 00 00 00 00 00 C2 32 04 ,128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,33 48 ,128
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %,1
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,66 4E 03 02 00 00 18 24 7F 7C 02 9A 15 0D 2A 7A 04 0F 1E 18 07 00 05 3E 23 03 00 14 28 AA 00 00 1E 5A AA 08 0A 05 05 00 00 00 23 64 1E 1E 0A 68 04 00 09 00 73 00 04 35 4C C0 05 0E 16 4C 54 64 96 14 96 8C 7D 7D 7D 7D A0 80 98 94 90 90 90 90 9A 32 02 06 08 0A 00 00 00 32 04 A4 0F F5 F5 1E 23 0C 1E 69 46 0A 50 96 00 00 96 96 05 00 00 00 01 01 4C 00 00 02 03 05 14 75 33 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,E6 58 ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,14 04 60 03 48 1F 13 00 14 14 00 28 00 26 02 58 01 90 02 58 0A 7D 0C 1E 28 00 32 32 00 F0 00 00 00 00 00 00 00 E4 00 00 3F 05 9C 4E 20 4D 58 1D 0C 0C 4E 44 A7 4D 9F 32 0A 9C 1F 9C 00 00 00 00 00 00 00 00 00 FA 00 00 33 4B 30 31 03 00 00 00 00 00 00 00 00 00 6C 45 ,88
Elapsed Time: 00:07
44 Map
;SW:5QM-909-144-B HW:5QM-909-144-B --- Steering Assist
;Component:EPS_MQB_ZFLS 173 1081, Coding:811F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Saturday,01,June,2019,12:57:30:47965
;VCID: 50F971A2FA6886571A1-8004
IDE03724-Straight line running,active ,1
IDE03734-Support power,100% ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE04555-Activation of pwr steering asst without engine running,not active ,1
IDE05162-Software end stop,active ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE07540-Download without rest bus,not active ,1
IDE09571-RPM monitoring,active ,1
MAS02080-XCP calibration protocol,not active ,1
Elapsed Time: 00:02
52 Map
;SW:5Q4-959-392-M HW:5Q4-959-392-F --- Door Elect, Pass.
;Component:TSG BFS 006 0247, Coding:003013200000048000000000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW37.rod
;Saturday,01,June,2019,12:57:34:47965
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F 97 01 04 4F 0C 08 03 4D 15 20 3D 04 64 00 00 00 00 00 00 00 00 00 C2 32 04 ,128
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,33 48 ,128
ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %,1
ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %,1
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,6C 4E 03 02 00 00 18 24 7F 7C 02 9A 15 0D 2A 7A 04 0F 1E 18 07 00 05 3E 23 03 00 14 28 AA 00 00 1E 5A AA 08 0A 05 05 00 00 00 23 64 1E 1E 0A 68 04 00 09 00 73 00 04 35 4C C0 05 0E 16 4C 54 64 96 14 96 8C 7D 7D 7D 7D A0 80 98 94 90 90 90 90 9A 32 02 06 08 0A 00 00 00 32 04 A4 0F F5 F5 1E 23 0C 1E 69 46 0A 50 96 00 00 96 96 05 00 00 00 02 01 4C 00 00 02 03 05 14 75 33 00 00 00 ,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,C8 B5 ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,14 04 60 03 48 1F 13 00 14 14 00 28 00 26 02 58 01 90 02 58 0A 7D 0C 1E 28 00 32 32 00 F0 00 00 00 00 00 00 00 E4 00 00 3F 05 9C 4E 20 4D 58 1D 00 00 4E 44 A7 4D 9F 32 0A 9C 1F 9C 00 00 00 00 00 00 00 00 00 FA 00 00 33 4B 30 31 03 00 00 00 00 00 00 00 00 00 A9 85 ,88
Elapsed Time: 00:07
CA Map
;SW:4M0-907-594-J HW:4M0-907-594 --- Sunroof
;Component:SAD_STG_1 014 0005, Coding:00804073260C
;EV_SunRoofCONTIAU736,006008,EV_SunRoofCONTIAU736_006.rod
;Saturday,01,June,2019,12:58:30:47965
;VCID: 3D2738165DFA1B3FE17-8068
IDE00001-Production mode,not active ,3
IDE02104-IDE03633-Temperature dependent activation-Close sunroof,not active ,1
IDE02104-MAS09030-Temperature dependent activation-Open sun roof,active ,1
IDE02104-MAS09031-Temperature dependent activation-Open roof blind,active ,1
IDE02104-MAS09032-Temperature dependent activation-Close roof blind,active ,1
IDE09435-IDE03633-Speed dependent activation-Close sunroof,not active ,1
IDE09435-MAS09030-Speed dependent activation-Open sun roof,active ,1
IDE09435-MAS09031-Speed dependent activation-Open roof blind,not active ,1
IDE09435-MAS09032-Speed dependent activation-Close roof blind,not active ,1
IDE09439-MAS08884-Logic switch-over: controls-Sunroof button,not active ,1
IDE09439-MAS08932-Logic switch-over: controls-Sunroof shade button,not active ,1
IDE09439-MAS08992-Logic switch-over: controls-Button for sliding roof,not active ,1
IDE09439-MAS10443-Logic switch-over: controls-Button for sunroof/tilt roof: rear,not active ,1
IDE09439-MAS10444-Logic switch-over: controls-Sunroof shade button: rear,not active ,1
IDE09451-MAS08936-Travel path-Tilted position: max. opening width,not active ,1
IDE09451-MAS08937-Travel path-Sliding position: intermed. pos.,active ,1
IDE09451-MAS08991-Travel path-Sliding position: reduc. opening width,not active ,1
IDE09451-MAS10725-Travel path-Sunroof shade: interm. position open,not active ,1
IDE09451-MAS10726-Travel path-Sunroof shade: interm. position close,not active ,1
IDE11842-IDE09434-Comfort functions-Target position for comfort opening,Tilt out posi. ,1
IDE11842-MAS13329-Comfort functions-Comfort opening of roof shade,active ,1
IDE11842-MAS13330-Comfort functions-Comfort closing of roof shade,active ,1
IDE11842-MAS14142-Comfort functions-Private sphere mode,not active ,1
ENG146366-Applikationmode deactivate,Deactivating ,1
Elapsed Time: 00:02
