- Joined
- Mar 30, 2014
- Messages
- 43
- Reaction score
- 6
- Location
- Philippines
- VCDS Serial number
- C?ID=187082
Dear VCDS Experts,
We have the attached car in the shop, replaced 2 front suspension shocks, but somehow all settings are lost.
codes: 403200 function shut off active
and 367877 ride height not learned
Can you please advice,
Best Regards,
Chris
Best Regards,
Chris
Monday,03,June,2019,00:24:33:59804
VCDS Version: 19.6.0.2
VIN: WAUZZZ4H9CN012329 License Plate: RK0110
Mileage: 50038km-31092mi Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 20 28 34 36 3B 42 46
47 48 52 53 56 57 5B 5F 62 6C 6D 6F 72 81 88 89 8A 8D 8F 90
VIN: WAUZZZ4H9CN012329 Mileage: 50038km-31092miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CDTA) Labels: Redir Fail!
Part No SW: 4H0 907 401 A HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0002
Revision: 53H37---
Coding: 4A2A0012052600010000
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_ECM30TDI0114H0907401A 001002
ROD: EV_ECM30TDI0114H0907401A.rod
VCID: 224B0B9C35266D5FA7-8076
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4H1 927 158 AA HW: 0BK 927 156 L
Component: 0BK 30 TDIRdW H08 0002
Revision: --H08---
Coding: 001111
ASAM Dataset: EV_TCMALX51011 001013
ROD: EV_TCMALX51011_001.rod
VCID: 6FED32A8B674903778-803A
12446 - Valve for Transmission Fluid Cooler
P2753 00 [175] - Open Circuit
Mileage: 50038 km
Date: 2019.05.31
Time: 18:44:04
Voltage terminal 30: 12.470 V
Voltage supply of regulator valves: 12.427 V
Current N215 Pressure control valve 1: 850.0 mA
Current N218 pressure reg.valve 4: 50.0 mA
Current N216 pressure reg.valve 2: 350.7 mA
Current N233 pressure reg.valve 5: 50.0 mA
Current N217 pressure reg.valve 3: 850.0 mA
Current N371 pressure reg. valve 6 lock-up clutch: 50.0 mA
Current N443 pressure reg.valve 7 main pressure: 653.2 mA
Current solenoid: 1000.0 mA
Engine speed: 846 /min
Transmission fluid temperature: 34 °C
Control Module temperature: 32 °C
selected gear: without traction
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
M015_Time Normal Mode: 5 s
M019_Time Since Reset: 7650 ms
12448 - Valve for Transmission Fluid Cooler
P2753 00 [237] - Open Circuit
Mileage: 50038 km
Date: 2019.05.31
Time: 02:30:58
Voltage terminal 30: 12.174 V
Voltage supply of regulator valves: 12.160 V
Current N215 Pressure control valve 1: 0.0 mA
Current N218 pressure reg.valve 4: 0.0 mA
Current N216 pressure reg.valve 2: 0.0 mA
Current N233 pressure reg.valve 5: 0.0 mA
Current N217 pressure reg.valve 3: 0.0 mA
Current N371 pressure reg. valve 6 lock-up clutch: 0.0 mA
Current N443 pressure reg.valve 7 main pressure: 0.0 mA
Current solenoid: 0.0 mA
Engine speed: 0 /min
Transmission fluid temperature: 68 °C
Control Module temperature: 65 °C
M015_Time Normal Mode: 135 s
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 B HW: 4H0 907 379 B
Component: ESP PREMIUM H10 0273
Coding: 60E5E20006A74700E300
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_005_AU64.rod
VCID: 3169F4D060C0C6C72E-8064
0694 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 5
Mileage: 50038 km
Date: 2019.05.31
Time: 02:31:04
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 00
F-Path: 47
F-Type: 0D
Uz: 99
0717 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 5
Mileage: 50038 km
Date: 2019.05.31
Time: 02:31:04
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 00
F-Path: 47
F-Type: 04
Uz: 99
Part No SW: 4H0 907 064 DF HW: 4H0 907 064 BF
Component: BCM2 2.0 H31 0510
Coding: 05872F00000000000000
Shop #: WSC 21810 001 1048576
VCID: 70EF31D4A34A8FCF61-8024
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000013954814
Coding: C018B60085043201010001010101112131313333283333
VCID: 3561C0C09CA8EAE772-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 H HW: 4H0 820 043 H
Component: Klima 4 Zonen H20 0072
Coding: 360162FE08
VCID: 2541108024089A67C2-8070
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BG HW: 4H0 907 063
Component: BCM1 2.0 H12 0100
Revision: 11012002 Serial number: 00000001044802
Coding: 0907E01009749FE18B810004A0001800009CC3080A000101800108542F01
VCID: 6ED32FACB97E993F73-803A
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 110724 H35 0040
Serial number: 110831185749
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10136951
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 12 09 2011 00000344
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000011081100010731
Coding: 100000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000018081100010812
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA102069000000410490
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 150849C5000000000001
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 E HW: 4H0 035 108
Component: DVDCAlpine H42 0190
Revision: AA001001
VCID: 224B0B9C3D266D5FA7-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901125600801
Coding: 280102
ROD: EV_EPHVA18AU57X0000_002_AU64.rod
VCID: 3B75D6F8B28C3C9784-806E
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG0041X1Y
Coding: 30314246323430303032554A304C34483053
Shop #: WSC 02311 785 00200
VCID: 3663C7CC89AEE1FF7B-8062
Serial number: 3575HRB405P0OPI2A0DT
Serial number: 3585HRB405F0NI36A1SH
Serial number: 3515JRB405N0M5SQO11
Serial number: 3525JRB405N0M5SQBOMR
Serial number: 3554VRB405R0NI3I51L$
Serial number: 3564VRB405R0NI3I61FZ
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815KI90003W
Coding: 000034
VCID: 377DCAC886A418F760-8062
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Component: E221 - MFL H06 0009
Serial number: 09 04 2011 B0010442
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 900 H HW: 4H0 920 900 H
Component: TDieRDW------ H38 0373
Revision: 32480030 Serial number: 658040911593018
Coding: 13A6080013000008010000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K_AU64.rod
VCID: 285F19B4531A870FF9-807C
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H05 0224
Serial number: 1110817003925
Part No SW: 4H0 907 468 F HW: 4H0 907 468 C
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000240163
Coding: 00C1037D00
ROD: EV_GatewUDS_AU57.rod
VCID: 3467FDC49FD2F3EF45-8060
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650306867
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04018B6B74745D545420363E
VCID: 3365FED892DCF4D75C-8066
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 E HW: 4H0 919 158 E
Component: Klima Fond H15 0062
Coding: 0600000000
ROD: EV_AirCondiHeck_AU64.rod
VCID: 326BFBDC65C6FDDF57-8066
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008000
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_VW51.rod
VCID: 2C57E5A447E2AB2F1D-8078
C10C8 00 [008] - -
Reset counter: 6
Mileage: 50038 km
Date: 2019.05.31
Time: 19:55:45
367877 - Ride Height Not Learned
C1044 00 [009] - -
Reset counter: 221
Mileage: 50038 km
Date: 2019.05.31
Time: 02:31:03
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000014107037
Coding: C018BF8085853201030001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0015
Revision: -------- Serial number: EJ1BPA3100WALI0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6CD725A487626B2F5D-8038
Part No SW: 4H0 959 793 M HW: 4H0 959 793 E
Component: TSG FA H02 0166
Revision: -------- Serial number: 0000119788531
Coding: 011F1E205E0062C202080006
VCID: 4385AE18C27C4457CC-8016
Revision: 00002001 Serial number: 0157215156
Coding: 011A0E2000B93585B320C7C00A0100000000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H07 0006
Serial number: WOO13228561
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G
Component: Dachelektroni H13 0080
Serial number: A2015000000000838580
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS010 H05 0005
Serial number: WOO1000IT2O
Address 47: Sound System
Address 48: Seat, Rear, DS (J876) Labels: None
Part No SW: 4H0 959 860 A HW: 4H0 959 860 A
Component: MEM-FS-Fond H06 0153
Revision: AA000000 Serial number: 00000014428562
Coding: C01892808500300D0B00392038193A2039203B3B202020
VCID: 326BFBDC6DC6FDDF57-8066
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0166
Revision: -------- Serial number: 0000119787105
VCID: 3A7BD3FCB5B6059F9F-806E
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000136065
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5BE3BC4D16B51FEF-807E
Part No SW: 4H0 035 053 C HW: 4H0 035 053
Component: Radio U Basic H52 0079
Revision: AB001007 Serial number: 438I20B7522649
Coding: 070003010000000001
VCID: 1F4D02680E5440B788-804A
Address 57: TV Tuner (R78) Labels: None
Part No SW: 4F0 919 129 F HW: 4F0 919 129
Component: HybridTV-DVB H07 0530
Revision: R0070000 Serial number: 76301302206401
Coding: 16010000
VCID: 2F6DF2A87EF4D03738-807A
Address 5B: Seat,Rear,PS (J877) Labels: None
Component: MEM-BFS-Fond H06 0153
Revision: AA000000 Serial number: 00000014428410
Coding: C01896808500300D0B00392038193A2039203B3B382020
Part No SW: 4H0 035 642 K HW: 4H0 035 642 C
Component: H-BN-ER H42 0410
Revision: -------- Serial number: 056I/0B7506573
Coding: 020000000001F1EF45108B0E00000003FE0001020000000000
VCID: 2B55E6B84AECAC1714-807E
Subsystem 1 - Part No SW: 4H0 919 604 D HW: 4H0 919 604 D
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDB69008RG-
Subsystem 2 - Part No SW: 4H1 919 600 F HW: 4H1 919 600
Component: E380 BDT D4 H09 0064
Serial number: 00000000050962
Subsystem 3 - Part No: 8R0 060 961 B
Component: CD-Database 3371
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 A HW: 4H0 959 795 A
Component: TSG HL H04 0162
Revision: -------- Serial number: 0000118411035
Coding: 010F1E20420062C202080006
VCID: 3979CCF0B0B00E8796-806C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J17D3K4
Coding: 1080003
VCID: 2643178C910E917FCB-8072
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 P HW: 4H0 959 107 M
Component: HDSG-Modul H11 0036
Revision: 10011001 Serial number: 251100188
Coding: 0210044000
ROD: EV_DeckLidContrUnit.rod
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000039462
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63C54E986ABC2457EC-8036
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H04 0162
Revision: -------- Serial number: 0000119687547
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H07 0083
Revision: 0L0D5012 Serial number: SN110718 0126
ROD: EV_GSM2x3Mono.rod
VCID: 2B55E6B842ECAC1714-807E
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00002225158902
Coding: 764FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F6DF2A876F4D03738-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00002225154602
Coding: 364FF2
Address 8A: Multicont. Seat Rear,DS (J875) Labels:* None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00000841123601
Coding: 304F00
ASAM Dataset: EV_IVBDriveSideRear 001003
VCID: 2E53EFAC71FED93F33-807A
Address 8D: Multicont. Seat Rear,PS (J874) Labels:* None
Serial number: 00001867020401
Coding: 304F00
ASAM Dataset: EV_IVBPasseSideRear 001003
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70EF31D4AB4A8FCF61-8024
End-------------------------(Elapsed Time: 07:59)-------------------------
